veltsz
24.09.2011 17:08:32
Vajan abi:oma kokkupandud arvuti freezib. |
Tere ! Probleem siis järgmine ,et lihtsalt lambist jookseb arvuti kokku ,kas siis mängides või netis surfates. Kokkujooksmisi esineb üsna tihti ja muu ei aita kui RESET nupp. Guugeldades annab igasuguseid variante ning leidsin ka enda omale sarnase probleemi , pakkus mingeid update faile :Windows6.1-KB979444-x64 ja Windows6.1-KB983615-x64 ei tea kas on ikka õige asi. Peale installides ütleb ,et Täiendust ei saa teie arvutile installida. Tegin ka format:c , probleem sama.
Arvuti parameetrid on siis järgmised :
Mobo: Asus P5Q PRO
Prose : Intel Pentuim Dual Core E6800 @3,33Ghz
Ram :2x2GB Corsair DDR2 1066Mhz PC8500
Toide :Sapphire FirePSU 625-watt PC Power Supply
Ketas_1 :WD CAVIAR BLUE 320GB SATA2
Ketas_2 :WD CAVIAR GREEN 750GB 3.5" SATA2 IP 64MB
Video : SAPPHIRE VGA 1GB GDDR5 PCIE16 HD679011194-00-20G SML SAPPHIRE
OP System : Windows 7 x64bit koos sp1-ga
Jahutus :CNPS9900 MAX BLUE ZALMAN CNPS9900 M
Peale selle veel 3 jahutus venti
Mobol on uusim bios ,mida koduleht pakub ja enamus driverid ning kellanud midagi ei ole.
Ette T.nades !
Panen siia ka Event vieweri log-i
Log Name: System
Source: Microsoft-Windows-Kernel-Power
Date: 24.09.2011 12:22:35
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (2)
User: SYSTEM
Computer: Lauaraal_1-PC
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
<EventID>41</EventID>
<Version>2</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000002</Keywords>
<TimeCreated SystemTime="2011-09-24T09:22:35.891216500Z" />
<EventRecordID>4340</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>Lauaraal_1-PC</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="BugcheckCode">0</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">false</Data>
<Data Name="PowerButtonTimestamp">0</Data>
</EventData>
</Event>
| Kommentaarid: 13 loe/lisa |
Jann1
24.09.2011 21:28:10
| Vigane windows. kindlasti on see ka piraat ja kräkitud? siis ei tasu viga mujalt otsida.
128 |
veltsz
25.09.2011 00:02:00
Hästi arvatud ! OK minu viga , kui ei toonud kohe windows-i täpseid andmeid välja .
Vigane Windows ei saa kohe kindlasti olla , kuna ostetud ametlike teid pidi ja regab ennast ilusti ära. Format C: tehtud samalaadse windowsiga ja kasutatud oma võtit ,samuti pole regamisega probleeme olnud. Microsoft kodulehel kontrollitud Genuinet - kõik OK .(Microsoft Windows 7 Ultimate US Retail DVD ).
Kui midagi tarka ei ole välja pakkuda, pole mõtet loba ajada. Loodan probleemile lahendust saada , mitte mingit jura lugada.
heikis
25.09.2011 00:05:43
esimese asjana kindlasti memtest lasta joosta. mida kauem seda kindlam- 24h peaks olema juba piisav. sealt saab juba edasi arutada.
võid ka uurida kõvaketta smart raportit.
| Kommentaarid: 338 loe/lisa |
290 |
veltsz
26.09.2011 14:59:48
| Kuna viibin paar nädalat eestimaa teises otsas ,siis ei ole praegu võimalik memtesti teha aga annan teada ,kui probleemse arvuti juures tagasi olen.
yerba
01.10.2011 02:55:15
Millised videokaardi driverid peal on? Mul sama kaardiga plaadi pealt peale driverite peale panekut hakkas ka masin rõõmsalt hanguma. Peale seda, kui netist uusimad driverid peale panin, kadus probleem kenasti ära.
_________________ www.lapik.ee - parima hinnaga patareid!
ja lisaks ERYONE filamendid ( küsige HVs ): www.eryone.ee |
| Kommentaarid: 1224 loe/lisa |
901 |
veltsz
02.10.2011 10:29:36
| Ati kodulehelt kõige uuemad .
Kalle
02.10.2011 12:47:17
| Vaata mis kiirusel mälud töötavad, kui 1066MHz peal, siis lase prooviks BIOS-is mälude kiirus 800MHz peale. Mäludel peaks olema kleepsul kirjas, palju volti tahavad 1066 peal töötamiseks ja enamusel jääb see üle 2,0 voldi. Endal töötab Kingston DDR2 8500 stabiilselt 800MHz peal aga 1066MHz peale pannes hakkab kohati masin hanguma. See jõudluse kasv 1066 v 800 ei ole märkimisväärne võrreldes hea stabiilse systeemiga. Laadi all cpu-z programm, see abix.
| Kommentaarid: 4 loe/lisa |
veltsz
07.10.2011 16:47:55
Nii ,olen siis probleemse arvuti juures tagasi ! Sai siis jooksutatud Memtest 86+ v3.5 , mis peale 6 tundi toimetamist kinni kiilus , aitas Reset nupp. Otsisin siis Memtesti kodukalt uue versiooni ja kribasin plaadile . Panin käima ja peale 17 tundi jooksutamist ei ole ühtegi errorit tuvastanud , mis edasi teha?
Täheldasin ka seda ,et Bios muudab oma sätteid Defauldi peale tagasi.
KALLE - vaatasin järgi : mälud jooksevad jah 1066 MHz ja 2.1 volti aga kui Memtest mingeid erroreid ei tuvastanud ,kas siis on mõtet neid torkida !
07.10.2011 18:22:14
| veltsz kirjutas: |
Täheldasin ka seda ,et Bios muudab oma sätteid Defauldi peale tagasi. |
Arvuti komplekteerimisel BIOS-i patarei alt isoleeriva kileriba tõmbasid ikka välja?
veltsz
07.10.2011 19:20:31
Täpsustan siis natuke asja ,et arvuti on kokku pandud umbes kevadel ja selle aja jooksul on bios 2 korda defaultinud ennast.
Bios-i patarei alt ei paista ühtegi kileriba mida tõmmata saaks.
haldz
07.10.2011 19:32:38
| veltsz kirjutas: |
Bios-i patarei alt ei paista ühtegi kileriba mida tõmmata saaks. |
jep enda prol sellist asja seal ka ei olnud. Säti bios sätteid , jooksuta nt prime siis näha kas prose stabiilne
| Kommentaarid: 153 loe/lisa |
138 |
veltsz
08.10.2011 11:37:49
haldz : kust ma selle proge saaks (Google annab kõike peale selle ).
Kalle : hakkasin vahepeal kahlema ,et kas mälud jooksevad ikka 1066 MHZ peal ?
Panen CPU-Z ülesse.
http://www.upload.ee/image/1715872/Malu.png
08.10.2011 12:46:24
See pilt näitab mälu SPD parameetreid, mitte hetkel kasutusel olevat kiirust.
veltsz
08.10.2011 13:50:22
| Dogbert kirjutas: |
| See pilt näitab mälu SPD parameetreid, mitte hetkel kasutusel olevat kiirust. |
Kust ma selle õige pildi saan?
08.10.2011 13:57:38
Ma pole CPU-Z väga ammu kasutanud, aga memory või mainboard võiks vaadata.
Marie
| Kommentaarid: 83 loe/lisa |
74 |
veltsz
Marie
08.10.2011 21:21:21
Mälu töötab õigel kiirusel, 1066 MHz kuid iseenesest need mälud sellisel kiirusel tööle küll ei lähe, arvatavasti on mälu kiirus käsitsi seadistatud, automaatselt peaks need 800MHz peal töötama, viiteajad on ka sellised piiripeal 5-5-5-18 mis sellisel kiirusel võivad ebastabiilsust põhjustada, ehk lisaksid veel mälule Volti 2,3V või lase mälu kiirus alla 800Mhz peale ja vaata kas siis ka arvuti freezib
74 |
veltsz
15.10.2011 09:10:06
Vot ei oska öelda , kui arvuti komplekteerisin panin mälupulgad sisse ja Bios-is midagi mälude kohapealt näppinud ei ole .
Lugesin siis natuke emaplaadi manuali ja leidsin sellise koha : DRAM Frequency [Auto]. Nagu ma aru sain, siis see AUTO tuleb käsitsi ära muuta ja panna Manual. Tahan mälu 800 MHz jooksutada. Kas tuleb mälu timinguid ja volte ka muuta või võivad nad samaks jääda?
Lugesin veel CPU kohta: kui paigaldad 2 tuumalise prose siis on soovitav ühendada prose jahutus CHA_FAN1-ga ,parema stabiilsuse saavutamiseks ,aga mul on ta CPU_FAN-is . Küsimus siis ,et kummas ta siis olema peab ?
Marie
15.10.2011 10:43:32
| veltsz kirjutas: |
Lugesin veel CPU kohta: kui paigaldad 2 tuumalise prose siis on soovitav ühendada prose jahutus CHA_FAN1-ga ,parema stabiilsuse saavutamiseks ,aga mul on ta CPU_FAN-is . Küsimus siis ,et kummas ta siis olema peab ? |
Kust sa sellist jama lugesid, õige on CPU_FAN, mis protsessor varem siis oli, ehk probleem hoopis liialt vanas BIOS_s versioonis mis ei toeta korralikult seda Pentuim Dual Core E6800 protsessorit, selle protsessori toetus algab suhteliselt hilja, eelviimasest BIOS väljaandest alles, mis versiooni numbrit hetke BIOS kannab, AIDA64 abiks kiirelt BIOS versiooni tuvastamiseks http://www.aida64.com/downloads
74 |
veltsz
15.10.2011 22:38:17
| Lugesin seda siis lk. 31 (2-5) ja nagu esimeses postis kirjutasin, BIOS on kõige uuem, mida koduleht pakub ehk siis 2102. OK see selleks, rohkem huvitab mind nende mälude MHz-ide, timingute ja voltide teema, et kust neid sättida, mida sättida ja kui palju sättida? Tahan panna mälud jooksma 800 MHz-i peale.
BTK0
15.10.2011 23:03:37
HDD test ja kontrolli kaablid üle(sata).
Kindlam on, kui testimise ajal oleks neist vaid üks ühendatud.
| Kommentaarid: 20 loe/lisa |
19 |
Kalle
16.10.2011 09:56:41
Võtad lahti BIOS Ai Tweaker menüü ja sealt:
AI Overclock Tuner -Manual-
CPU Ratio Settings -Auto-
FSB Frequency - sinu E6800 puhul on 1066MHz järelikult -266-
PCI Frequency -100-
DRAM Frequency -DDR2-800MHz-
Ülejäänud sätted jäta -Auto- peale
veltsz
19.10.2011 22:38:23
| Panin siis Kalle juhendi järgi mälud 800 MHz-i peale jooksma. Proovib ja vaatab, kas anomaalia kestab edasi või mitte!
Kalle
25.10.2011 01:50:02
| No kas hakkas tööle ok või freezib endiselt ?
veltsz
11.11.2011 13:18:43
Bios-i jama |
| Sai siis nüüd mõnda aega jooksutatud 1066MHz-d mälusid 800MHz-i peal, arvuti freezimist ei esine aga restardid ja Bios-i settingute defauldid tulevad ikka ette. Proovi mõttes sai katsetatud 800MHz-seid mälusid - sama probleem restardid ja nullib Biosi sätteid (muutnud olen: flopy-disable, expsessgate üleslaadimis aegaja, rohkem vist midagi). Aru ma ei saa, mis asi talle seal ei meeldi, et ta Bios-i defauldib ja nagu esimeses postis öeldud , siis bios on kõige uuem - äkki sellega on mingi kala. On keegi sellise jamaga ennem kokku puutunud ja oskab juhendada mida teha?
Nr2
12.11.2011 13:49:22
| Kas sa ainult ühe RAMi pulgaga erinevates pesades oled proovinud jooksutada? Palju volte põhjasild (NB Voltage) saab?
| Kommentaarid: 12 loe/lisa |
12 |
veltsz
12.11.2011 19:46:43
| Nr2 kirjutas: |
| Kas sa ainult ühe RAMi pulgaga erinevates pesades oled proovinud jooksutada? Palju volte põhjasild (NB Voltage) saab? |
Kõik sätted AI TWEAKER-i all on AUTO!
Nr2
12.11.2011 21:12:17
| Millal BIOSi resetid toimuvad, kas peale restarte või kui arvuti on vooluvõrgust väljas? Hangi endale need kaks programmi LinX v0.6.4 ja HWMonitor, lase LinXil suurima "Problem size"-iga ~10-15 tiiru teha, HWMonitoriga jälgi temperatuure. Tee HWMonitorist screenshot ja postita siis siia. GL!
12 |
veltsz
16.11.2011 19:49:15
Arvuti vooluvõrgust väljas ei käi ja resetib bios-i jah peale restarte erinevate toiminkute ajal. . Alguses, kui olid sees 1066 Mhz-i mälud , loopis bluescreen erroreid ja läks restardile, peale mida nullis biosi ära. Nüüd kui on 800 MHz-i mälud ei tahtnud mingit aega arvutit kasutamata SLEEP MODE minna ja arvutit välja lülitada, aitas RESET nupp, peale seda ülesse tulles oli kiri ees: press F1 to enter setup või press F2 to get default setting. Täpselt ei mäleta aga midagi sellist vist oli kirjas. Ja veel muudab ära päeva, kuu ja aasta. Resetib ka DEFAULT sätetega bios-i. Äkki on biosi patarei tühi?
Esimeses postituses ülesse pandud Event Vieweri logis oli selline asi - Description: The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Mida see võiks nagu tähendada?
Avastasin, et biosis näitab POWER FAN SPEED 490RPM-i ja on punast värvi (Minumeelest tähendab see halba ja tõsta käsitsi ei saa pöördeid). Toiteploki vendi pöördeid reguleeriv kaabel on emaplaadi CHA_FAN1-s.
Panen siis üleesse desktopi pildi tempidest ja jne.
http://www.upload.ee/image/1816390/Temperatuurid.png
Nr2
16.11.2011 22:41:20
| veltsz kirjutas: |
Mida see võiks nagu tähendada? |
Sellega ütleb Windows, et teda ei pandud korralikult kinni (ilma shut down/restart-ita).
| veltsz kirjutas: |
Esimeses postis kirjutasid, et uusim BIOS on peal, panid selle ise või oli juba peal? BIOSi reflashi oled proovinud teha?
Kõik tundub normis olevat peale VIN1 (mis on ilmselt RAMi pinge), mis peaks vähemalt 1.8V olema. Proovi DRAM Voltage käsitsi 1.8-1.9 peale panna.
| nr2 kirjutas: |
| lase LinXil suurima "Problem size"-iga ~10-15 tiiru teha, |
Tegid selle ära muidu, tegi ilma erroriteta läbi?
| veltsz kirjutas: |
| Avastasin, et biosis näitab POWER FAN SPEED 490RPM-i ja on punast värvi (Minumeelest tähendab see halba ja tõsta käsitsi ei saa pöördeid). Toiteploki vendi pöördeid reguleeriv kaabel on emaplaadi CHA_FAN1-s. |
Ma pole 100% kindel, aga arvan, et RPM-id on seetõttu madalad, et BIOSis olles pole toiteplokil koormust peal ja ventilaator ei pea väga kiiresti töötama ja punane on sellepärast, et BIOS arvab, et pöörded on natuke madalad. Sa võid testida, HWmonitoris oli AUXFANIN0 ~500 RPM, see peaks toiteploki ventilaator olema. Tee üks 3DMark-i tiir või paar tiiru sedasama LinX-i ja vaata, kas RPM-i Max arv suureneb. Võid kuulata ka, kui koormuse all toiteploki ventilaatori kiiremini töötama hakkab, peaks seal kõik korras olema. GL!
12 |
veltsz
17.11.2011 19:22:13
Kinni olen arvuti stardi alt kogu aeg pannud. Ma ARVAN, et seda kirja viskab mul sellepärast, et arvuti läheb ööseks SLEEP MODE-sse ja kui ma arvuti sealt äratan, siis mingi aja pärast toimub restart ja EVENT VIEWER näitab sellist kirja: Description: The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Teine arvuti toimib mul täpselt samamoodi ja äratades pole tal küll mingeid jamasid.
Bios on 2102 läbi windowsi installitud ja nüüd tegin reflashi biosile ASUS EZ Flash 2-ga. Eks vaatab kas sellest oli midagi kasu.
Panin 1.8V ja see HWMonitor näitab VIN1 ikka sama volti 1.74V ning siis lisasin veel mälu 2x2GB ja nüüd näitab 1.73V: Mina seda proge küll ei usalda.
Ole hea ja räägi sellest progest 3DMark natsa rohkem, pole ise kokku puutunud: kust saab ja mida seal täpsemalt teha ning kuidas see LinX töötab - pole nagu aru saada, et kuskil seal midagi toimetaks
Nr2
22.11.2011 15:05:10
Vabandust, et nii pikk vahe tuli vastamisega.
| veltsz kirjutas: |
Kas on abi olnud BIOSi reflashist?
| veltsz kirjutas: |
Minu viga, VIN1 näitab arvatavasti aiateibaid, sest uurisin teistest foorumitest screenshotte ja nendes näitas VIN1 samamoodi 1.73, 1.74 olenemata sellest, mis BIOSis pandud. Sul on nüüd kõik neli mälupesa täis?
| veltsz kirjutas: |
LinXi kohta saad lugeda siit. 3DMarki saab siit. Üldiselt 3D benchmark, aga paneb kogu masina koormuse alla.
12 |
LiivaneLord
Sõpradele "Olavi"
23.11.2011 00:08:00
| Võibolla tuleks protsessori clock ratio't või sagedust vähendada.
19 |
veltsz
26.11.2011 21:39:11
Peale biosi reflashi lasin muidugi windowsi ka uuesti peale, nii igaks juhuks.
Arvan, et sellest biosi reflashist oli vist kasu, sest siiamaani ei ole restarte ja biosi defaulti enam esinenud ja EVENT VIEWERi all ei näita selleteemalist errori logi. Eks näis, kuidas arvuti siis edasi toimetab!
PS! Kui peaks edaspidi mingi anomaalia jälle tekkima, eks siis saab teemas teada anda.
Tänud aitajatele ja edu!
