19.10.2011 04:16:25
AMD Catalyst™ 11.10 Version 3 Preview Driver
http://support.amd.com/us/kbarticles/Pages/GPU124AMDCat1110PreDriverV3.aspx
*Reduces random crashing and stability encountered when playing Rage on Windows® 7 32-bit edition
*Reduces object / animation flickering and texture corruption encountered when playing Rage
*Reduces stuttering seen on Dual CPU and Tri CPU core systems
*Improves performance in Battlefield 3 Open Beta release for both non-Anti-Aliasing and application enabled Anti-Aliasing cases on single GPU configurations using the AMD Radeon™ HD 6000 and AMD Radeon HD 5000 series of products.
*Improves performance in Battlefield 3 Open Beta release for both non-Anti-Aliasing and application enabled Anti-Aliasing cases on AMD CrossFire™ configurations using the AMD Radeon HD 6000 and AMD Radeon HD 5000 series of products.
*Improves performance in Rage on single GPU configurations using the AMD Radeon HD 6000, AMD Radeon HD 5000 Series and AMD Radeon HD 4000 series of products.
*Reduces intermittent crashing seen loading levels in Rage
*Reduces flickering of NPCs in Rage
*Enables automatic Vsync for Rage
*Enables support for AMD Eyefinity 5x1 display (portrait and landscape) configurations using the AMD Radeon HD 6000 and AMD Radeon HD 5000 series of products.
*AMD Vision Engine Control Center: User Interface enhancements have been implemented for the AMD CrossfireX™, GPU AMD Overdrive™ and Information Center pages. |
Kes ütles, et HD4K on unustatud
| Kommentaarid: 92 loe/lisa |
19.10.2011 09:00:17
| tomorrow kirjutas: |
Kes ütles, et HD4K on unustatud  |
196 |
Mercury
19.10.2011 14:10:08
| Etz kirjutas: |
Tänud!
| Kommentaarid: 61 loe/lisa |
60 |
tont23
22.10.2011 00:46:30
11.10 prwe3 on muidu täitsa ok...RAGE on juba päris hea ...AGA...joutuubis hakab video mängima rohelise ekraanina ja normiks muutub asi alles siis kui videot natuke tagasi kerida.
kellelgi veel midagi sarnast?
112 |
Vants...
25.10.2011 23:48:24
| Kas ma olen ainus kellel HDMI'ga ühendatud telekal/ suurel monitoril pilt hakib nagu oleks v-sync oleks vaja sisse ülitada. Probleem tekkis siis kui uuendasin Catalisti 11.9 peale(kahjuks ei mäleta mis versioonilt). Ühendasin teleri teise arvutiga, millel oli vanem driver ning probleemi ei esinenud. Proovisin ka ühendada HDMI monitori külge mis tavaliselt on DVI'ga ja kõik oli korralik. Kaardiks HD6850 ja teleriks Philips...
painkillah
26.10.2011 06:08:09
Kas keegi teema pealkirja enam ei uuendagi?
| Kommentaarid: 95 loe/lisa |
6 :: |
86 |
rene p
26.10.2011 18:48:31
| 11.10 preview 3 on Battlefield 3-s täiega jura. 4870 kaardiks ja asi täiega tirib pilti kinni, mängida võimatu. Rollback 11.10 preview 2 peale ja asi jookseb hästi.
68 |
trip
26.10.2011 23:04:57
ffs, ati/amd piidrid jälle keerasid midagi sassi, 11.9cap3 application profiles + 11.10 preview 3 drivudega bf3 cf6850-ga üldse ei saa mängiga, laagib metsikult.
ap uninstallida ei saa, kohe bsod ilmub .
303 |
libe
kvaliteetne mees
26.10.2011 23:09:17
| trip kirjutas: |
ap uninstallida ei saa, kohe bsod ilmub . |
tee arvuti korda
_________________ ☠ |
| Kommentaarid: 82 loe/lisa |
26.10.2011 23:28:52
Kusjuures siinpool see 11.10 Pre 3 asi täitsa töötab, sai 11.9 CAP3 profiilid kah peale ja FPS tõusis veel tuntavalt
Tundub, et mu kaart polegi veel päris vanaraud, kannatab BF3`me nende driveritega High peal jooksutada veel küll
196 |
trip
26.10.2011 23:34:17
| libe kirjutas: |
| tee arvuti korda |
f off mby?
http://twitter.com/#!/CatalystCreator
For those of you running in CF with BF3, and suffering stuttering, please remove Catalyst 11.9 CAP3, we're looking into the stuttering issue
25 Oct |
303 |
keegi-Hannes
30.10.2011 01:41:01
| trip kirjutas: |
| libe kirjutas: |
| tee arvuti korda |
f off mby?
25 Oct |
Kussjuures ikka ahastama ajavad need AMD driverite vead! Win update automaatset uuendamise seadet ei saa just seetõttu sees hoida, iga kord tuleb mingeid ebameeldivaid üllatusi ja ega siis tuliuute-uuenduse haigustest keegi veel infot ei jaga, rääkimata ravimisest
| Kommentaarid: 42 loe/lisa |
38 |
XeStAiSy
Aeg Maha 2a
30.10.2011 11:38:53
Ei oska ütelda midagi driverite kohta, kõik on töötanud. Unustage see mängimine ükskord. See mis ma vaadanud olen on kõik tip-top töötanud. Ennem läheb winn segi kui mingid vead hakkavad tekkima. Tehke oma arvutid korda kui 150 probleemi on pidevalt.
Need preview DRIVERID on AS IS ehk nii nagu on ja supporti nendele pole. Need on BETAd.
Teil ennem midagi ei juhtu kui arvutid korda teete ja amd supporti FEEDBACK muljuma hakkate. BETAdega seda teha pole mõtet küll aga WHQL omadega.
| Kommentaarid: 12 loe/lisa |
Timo1337
30.10.2011 11:39:43
| Margus kirjutas: |
Teil ennem midagi ei juhtu kui arvutid korda teete ja amd supporti FEEDBACK muljuma hakkate. BETAdega seda teha pole mõtet küll aga WHQL omadega. |
täpselt kuskil 95% driveitest töötavad probleemivabalt siiski.
| Kommentaarid: 49 loe/lisa |
46 |
30.10.2011 14:30:54
| Margus kirjutas: |
| Unustage see mängimine ükskord. |
75% inimesi ostavad kaarte mängimiseks.15% graafikatööks (kallid workstation kaardid) ja ülejäänud 10% kõigeks muuks k.a boinc,f@h jne.
| Margus kirjutas: |
| Need preview DRIVERID on AS IS ehk nii nagu on ja supporti nendele pole. Need on BETAd. |
keegi-Hannes rääkis WU kaudu pakutavatest driveritest ja need on ERANDITULT WHQL variandid, seega probleemide ilmnemisel igati õigustatud kaevelda
XeStAiSy
Aeg Maha 2a
30.10.2011 16:45:34
| Margus kirjutas: |
| Margus kirjutas: |
keegi-Hannes rääkis WU kaudu pakutavatest driveritest ja need on ERANDITULT WHQL variandid, seega probleemide ilmnemisel igati õigustatud kaevelda  |
See mis winows update pakub on M$ poolt testitud. Sealt ei tule openCL ja CAL. Seega pointless, see pole amd enda driver ehk terviklik.
CCC ammugi mitte. Sellekallal küll nüüd vinguda siin ei tasuks, M$ on see asi kuhu kiri saata sel juhul.
Mängides päevast päeva satute hullumajasse. 80% inimestest seal mängu ja töö arvutihullud kes sinna satuvad. Paljud on minust veel nooremad. Küsisn miks sattusite siia arvuti ja mängud mõned neist olid ka ületundie tegijad. Võib vedada ,et midagi suurt ei juhtu ja võib juhtuda, ,et te olete päris sassis hiljem. Mina lõpetasin nonstop mängimise 6-7 aastat tagasi ja nüüd olen ravil.
XeStAiSy
Aeg Maha 2a
30.10.2011 17:16:08
Margus, Jutust arvasin, et sa oled arst  |
Ma pole arst vaid psühhopaat. Ma panin ka arstidele silmad pähe. Mind ei anna lolliks teha kuigi olen kergelt haige. Kuigi ma olen üle keskmise siis jällegi ei suudeta midagi teha.
Leiti ,et midagi pole viga kuigi tegelikult on natuke väike asi. ARVUTIST KÄSTI LOOBUDA, sealhulgas ka mängud kõigerohkem. Piiri peab pidama.
Syncmahv
01.11.2011 17:05:54
OT: Seda lugedes võib siin korraliku arvutuse teha et mitu % HV kasutajatest on sassis inimesed ?
102 |
tont23
02.11.2011 23:14:56
paluks linki? ise küll kuskilt hetkel ei leia...ainult 11.9 ja siis need 11.10 preview versioonid
E:leidsin siiski midagi
112 |
Lord Ami
| Kommentaarid: 57 loe/lisa |
52 |
keegi-Hannes
17.11.2011 00:17:57
Aidake lingiga! Koduleht mainib et on saadaval eraldi:
Notes
· Windows Driver Model (WDM) drivers are no longer bundled in the AMD Catalyst™ software suite. The WDM drivers install bundle can be downloaded independently through the AMD website.
Kuskohast saaks AMD lehelt ja ilma muu jamata?
see esimene pakutav siiski koos CCS-ga http://sites.amd.com/us/game/downloads/Pages/radeon_win7-32.aspx#2
Noh atomaatinstalli peatades ja lahtipakke kataloogi "kaevudes" näen ma W7_INf kahtesid MSI konteinereid kuid kumba ma peaks kasutama kui mul ei ole pealelastud SP1-te
Ja ärge enam jahuge mängimisest või sõltuvustest mul vaja puhast driverit!
viimati muutis keegi-Hannes 17.11.2011 00:40:55, muudetud 1 kord |
38 |
tont23
112 |
