borderlands wannabe pela....
anyways misasi see gpu transcode on ja miks graafika ni jube on, ainult selle teeb teravamaks ka kuhu vaatad, mis veidike häirib tegelt.
ehk päts toob parandused sisse + saab siis ka graafika valikuid muuta. Osad kohad näevad jubedamad välja kui Doom 3'es
... pilved on kah taevasse maalitud. Kenad on jah kohati aga mis sest pildist ikka vaadata. Reaal ajas liikuvaid pilvi + udu - suitsu efekt õhus on kõvasti lahedam. Näiteks need .-> http://www.upload.ee/image/1716357/ManiaPlanet.jpg (reaal ajas muutuvad, liikuvad pilved) _________________ |--{o,o}-----(\__/)-----------------|
edit: Ja läbi mäng mul saigi.. 12h kokku gameplayd, kõiksugu sidequestid tegin ka ära omastarust... meh. Lugu oleks võinud ikka kordades parem olla ning suurem avatud maailm.. Borderlands on mäekõrguselt üle sellest. _________________ Minu Youtube - HDTanel
RAGE defaults to lower video settings to allow the game to work on a
wide variety of hardware and software configurations.
Unfortunately, it is not possible to anticipate all possible graphics
driver issues in combination with unique end user hardware and software
configurations. For this reason RAGE does not automatically increase
video/graphics settings as this could result in negative side effects
on specific hardware and software configurations. The original release
of RAGE does not expose many video/graphics options for people to tweak
because some of these settings, although desirable from a quality
perspective, simply will not work on specific configurations either due
to hardware limitations and/or driver bugs. Due to popular demand for
more video and graphics options, this patch updates the video settings
menu and exposes several quality and performance settings. However, not
everyone may be able to increase the settings due to hardware limitations
and/or driver bugs.
VSync
The new "VSync" option in the video settings menu allows you to remove
screen tearing. There are three options: ON, OFF and SMART.
When VSync is turned OFF you may experience screen tearing.
When VSync is turned ON you should not see screen tearing. However,
any time your frame rate drops below 60 frames per second you will
get a sudden more severe drop to 30 frames per second. This is how VSync
inherently works. If your computer cannot maintain 60 frames per
second and you miss the synchronization to the vertical retrace of
your monitor then you will miss a whole frame and synchronize to
the next frame instead.
Some graphics drivers now support a so called "swap-tear" extension.
You can try using this extension by setting VSync to SMART.
If your graphics driver supports this extension and you set VSync
to SMART then RAGE will synchronize to the vertical retrace of
your monitor when your computer is able to maintain 60 frames per
second and the screen may tear if your frame rate drops below 60 frames
per second. In other words the SMART VSync option trades a sudden drop
to 30 frames per second with occasional screen tearing. Occasional
screen tearing is usually considered less distracting than a more
severe drop in frame rate.
If your graphics driver does not support SMART VSync and you set VSync
to SMART in the video settings then RAGE will automatically fall back to
turning VSync OFF and you may experience screen tearing. The "swap-tear"
extension is brand new and may still present some issues on certain
graphics hardware. If you experience any problems using SMART Vsync
then set VSync to either ON or OFF. We are actively working with the
graphics hardware vendors to improve the "swap-tear" extension.
If changing VSync in the RAGE video settings menu does not appear to
make any difference then make sure you are not overriding the VSync
setting in the graphics vendor control panel. You can find the
graphics vendor control panel by right-clicking on the Windows desktop
and selecting the " control panel" option from the pop-up menu.
If you force VSync to the 'on' setting in the graphics vendor control
panel then you should not see any screen tearing in RAGE but you may
get a more severe drop in frame rate if your computer cannot maintain
60 frames per second.
If you force VSync to the 'off' setting in the graphics vendor control
panel then you may experience screen tearing no matter what setting you
use for the VSync option in the RAGE video settings menu.
Texture Cache
The new "Texture Cache" option in the video settings menu allows you
to increase the texture cache size to keep more texture data in
video memory.
If the Texture Cache is set to LARGE then RAGE will keep more texture
data in video memory. This may not only significantly reduce blurry
textures and texture popping, it will also allow complex scenes to be
rendered with more texture detail.
However, this may not work on computers that do not have enough system
or video memory, or you may experience a significant drop in performance.
If you experience issues due to hardware limitations you will have to set
the Texture Cache back to SMALL.
If after changing the Texture Cache to LARGE you experience a crash or
texture corruption (like a partially or completely blue world) then
the graphics driver may have run out of memory.
We are actively working with the graphics card vendors to resolve
any crashes.
If you do not experience a crash but you see texture corruption then you
may be able to get the large Texture Cache to work by accepting the change
and restarting the game. If you still experience texture corruption after
restarting the game you will have to set the Texture Cache back to SMALL.
You may also be able to improve the memory situation on your computer by
changing the Windows paging file management. Note that making changes to
the Windows paging file management may change the performance characteristics
of your computer. Any changes you make to your system configuration are
at your own risk. Always make backups of your system and revert these
changes if you notice undesirable side effects.
To change the paging file management on Windows Vista and Windows 7, first
press the "Start" button, then right-click on "Computer" and then select
"Properties" from the popup menu. Then select "Advanced system settings"
on the window that appears. Select the "Advanced" tab on the
"System Properties" window that is displayed and press the "Settings"
button under "Performance". Select the "Advanced" tab on the
"Performance Options" window that shows up next and press the
"Change..." button under "Virtual memory". Now uncheck the option
"Automatically manage paging file size for all drives" and make
sure that the option "System managed size" is selected on the
"Virtual Memory" window. Confirm the change by pressing the "OK" button
on each window. After making this change you will have to restart your
computer for the change to take effect.
To change the paging file management on Windows XP, first press the
"Start" button, then right-click on "My Computer" and then select
"Properties" from the popup menu. Select the "Advanced" tab on the
"Performance Options" window that shows up next and press the "Change"
button under "Virtual memory". Make sure that the option
"System managed size" is selected on the "Virtual Memory" window.
Confirm the change by pressing the "OK" button on each window.
After making this change you will have to restart your computer for
Anisotropic Filter
The new "Anisotropic Filter" option in the video settings menu allows
you to increase the anisotropic texture filtering.
Anisotropic filtering is a method to enhance the image quality of
textures on surfaces that are at oblique viewing angles.
The anisotropic texture filtering in RAGE defaults to a low value to
accommodate for low-end graphics hardware. However, the anisotropic
filtering can be increased for high-end graphics hardware by setting
the Anistropic Filter option to HIGH in the video settings menu.
Do not force anisotropic filtering to the �on� setting in the graphics
vendor control panel because this may cause rendering artifacts in
the game.
Note that increasing the anisotropic filtering may improve the
texture quality while it may also decrease the frame rate.
Patch Changes / Fixes
- Implemented workaround for AMD driver crash right after intro cinematic
on Win 7 32-bit systems.
- Disabled UBOs because they are causing animation issues with AMD drivers.
- Don't allow swap-tear to be enabled on AMD while the extension is not
exposed because it may crash.
- Support for new video settings: "texture cache", "vsync" and
"anisotropic filter"
- Automatically adjust vt_maxPPF based on the number of available cores.
- Improved performance for SLI cards when GPU transcode is enabled.
- Fix for GPU Transcoding option being disabled after exiting gameplay.
- Added safe mode to restore video settings to default values.
- Allow g_fov to be changed from the RAGE launch options in Steam.
- Server now forwards text chat from clients to all other clients while
in-game.
Known Graphical Issues
The following issues were found using NVIDIA graphics hardware with
the GeForce R285 Driver or AMD graphics hardware with the AMD Catalyst
11.10 Version 2 Preview Driver.
- If you turn up both the screen resolution and anti-aliasing settings
to high values in the video settings menu and/or you enable
"GPU Transcode" then the screen may no longer update on some hardware
configurations. This means your system does not have the necessary
video memory to run with these high settings. You can re-enter the video
settings menu and lower your settings to restart screen updates.
to high values in the video settings menu you may experience a crash
if your system does not have the necessary memory to run with these
high settings. To avoid this problem you will have to re-enter the
video settings menu to lower the settings. If you can no longer launch
the game after changing the video settings to high values you can add
the following to your RAGE launch options in Steam:
+com_safemode 1
The launch options can be found by right-clicking on RAGE in Steam
and selecting "Properties". Then click on "Set Launch Options" in
the dialog that pops up. Adding this option will reset your video
settings to the default values the next time the game is launched.
When the game is launched in safe mode the game will show "safe mode"
in the corners of the screen. Do not forget to remove the safe mode
launch option after launching the game once to make sure you do not
lose your video settings each time you launch the game.
- Using a NVIDIA graphics card on Windows XP 32-bit or XP 64-bit, you
may experience a crash or hang when changing the screen resolution in
full screen mode or switching from windowed mode to full screen mode.
This has been identified as a graphics driver problem. We have spent
significant effort trying to work around this problem and were
successful in reducing the frequency of occurrence but a driver update
is necessary to completely fix the problem. We are actively working with
NVIDIA to make a solution to this problem available as soon as possible.
- Using an AMD graphics card, you may experience black flickering
artifacts on flags, banners and zip-lines if you run in full screen
mode. This has been identified as a graphics driver problem. We are
actively working with AMD on a solution to this problem.
- Using an AMD graphics card, you may experience black grid lines on
some graphical user interface (GUI) elements like the in-game mini-map.
This has been identified as a graphics driver problem. We are actively
working with AMD on a solution to this problem. If you find the grid
lines particularly distracting, you can add the following to the RAGE
launch options in Steam as a temporary workaround.
+vt_maxAniso 1
the dialog that pops up. However, note that adding this setting will
lower the general texture quality in the game.
- If you have an AMD graphics card with a dual core CPU system you may
experience severe hitching and low frame rates. This has been
identified as a driver problem. We are actively working with AMD on
a solution to this problem. As a temporary workaround you may add the
following to the RAGE launch options in Steam:
+jobs_numThreads 0
- If you are running RAGE in full-screen mode and you ALT-TAB to a
different application you may lose your VSync setting. When you
switch to a different application VSync stops functioning.
RAGE detects that VSync is no longer working and automatically switches
back to synchronizing to real-time to make sure the game time advances
in a consistent manner. We are actively working with the graphics
vendors on a solution to this problem.
e.
Patch peal ja tekstuuride jama on lahenenud
Vsync peal, Texture Cache "Large" ja AA 8x ning hd4850 fps piirajas koguaeg.
Üks-sama intervjuu, kaks erinevat järeldust. Kõik sõltub sõnumi tõlgendajast _________________ Teach a man to reason and he'll think for a lifetime
ok update1 päris hea..suvalised crashid on kadunud ning texture popingut eriti pole enam. natuke siiski on.
kuid mustad kastid tekivad lambist vahepeal:(
http://dl.dropbox.com/u/28788188/Screenshot-222.png _________________ Linux Gaming Videos: Xpander69
Kust seda patchi saab? Esmase otsinguga ei leidnud.
Steam automaagiliselt ei tirinud ära? _________________ Teach a man to reason and he'll think for a lifetime
peale patchi läksid tekstuurid justkui s1temaks. texture cache jms kõik mis seal on, on põhjas valikutest + rageconfig.cfg on 8k peale sätitud kõik asjad _________________ "Kuidas on see hea?"
-Auto kirurgia kliinik
Seda see patch teeb. Pira ftw, ei mingit automaatselt peale surutud patchi
Need kes 8k tekstuurid panid, oskavad ehk öelda kas 1G mäluga video ka seda välja veab?
Vabalt. Teist nägugi ei tee. FPS raudselt 60 peal lukus. Aga... peale patchi, mul on kuri kahtlus, et cvar'id ei toimi enam päris nii, nagu enne. _________________ "Kuidas on see hea?"
jääb siiski küsimus:
Mida seal on rohkem (18gb+patch) vs just cause 2 (4 gb)
viimases on päris suur kaart ning peaks mainima ,et pilt on just cause 2s ilusam kui need "actual screenshot" pildid siin teemas? _________________ Winter is coming...
njah mina paremaks ei saa
black texture vidinad ajavad suht närvi. texture poping nüüd palju väiksem update1'ga
jookseb ka suht smooth v.a. kui recordin...uut prose vaja vist
soundi unustasin ka recordida korralikult. mikri peal oli ja suht vaikselt on kuulda aint.
saaks nüüd sellest black textureist lahti, olekstäitsa mängitav
NeroEST, Ho Ho seda mitu korda seletand. Rage's on kõik textuurid unikaalsed, iga viimne kui üks, iga pind koosneb ühest suurest textuurist, ehk puudub tiling, eem, tileing, mis iganes, ehk siis selline asi, et ühel pinnal kasutatakse ühte ruudukest mitu korda, sellist asja pole. Välja näebki mäng sellepärast nii jama, et ühte 8k textuuri on venitatud üle suurte pindade, mis tähendab seda, et virtuaalne dpi, ehk nö puntki tihedus on väga väike. Kuna iga objekt omab unikaalset textuuri siis peabki mängu suurus selline ulmeline olema, võrreldes teiste mängudega, millel maailm vb palju suurem, aga kus näiteks 1000 puud on ühe ja sama textuuriga ülelöödud, mis tähendab, et sellel väiksemal mängul on puude jaoks näiteks 1 textuur ja ragel 1000 puu jaoks 1000 textuuri, ehk siis ragel kulub puude jaoks 1000 korda rohkem ruumi, kui tollel väiksemal mängul. _________________ "Kuidas on see hea?"
Saan täna enda ülevaate valmis mängust..
Suurim pettumus on ilmselt kehv story ja üsna väike avatud maailm ja noh muidugi sadadel inimestel suured probleemid mänguga _________________ Minu Youtube - HDTanel
... ning venitama pidi seetõttu, et XB peale ei lubatud Carmac'il mängu välja anda >3 plaadi peal ning samuti keelati ära releaseda mängu selliselt, et muudel platformidel tekstuurikvaliteet kõrgem oleks. Ainus lootus on, et mingi hetk tuleb PC'le "DLC" kus on normaalse kvaliteediga kama ja mitte see soga mis praegu.
Muidu olge "õnnelikud" et asi niigi hea välja näeb. Originaalis pidi seal tulema 5 kaarti praeguse 2 asemel kuid konsoolide limiteerituse tõttu oldi sunnitud kogu värki kordades väiksema maa-ala peale kokku suruma et tekstuurid päris läbuks kätte ära ei läheks. _________________ Teach a man to reason and he'll think for a lifetime
Päris huvitav lugu see MS'i 3 plaadi piirang, kas sul mingit info allikat kah jagada on?
Sellest on korduvalt siin ja mujal teemades räägitud. Kammi Carmac'i twitterit kui ei usu. _________________ Teach a man to reason and he'll think for a lifetime
Huvitav lahendus developeride poolt.
Ütle, kas sulle meenub üks mäng kus sind on häirinud, et 1000 puud kasutavad ühte textuuri?
Minule ei meenu ühtegi näiteks.
Graafikast teeb ilusa graafika kui tekstuurilt tekstuurile üleminekud on sujuvad ja juures on palju eyecandit, valgusvihud, õhus liuglev tolm, maast ülespaisatud tolm, lendlevad puulehed, vedelev praht, sunflares etc. Tilulilu teeb graafikast hea graafika.
Kui kasutada lihtsalt mingeid megasuperhüper kõrgeid tekstuure, siis on kokkuvõttes pilt palju koledam ju...
Ehk siis tegelikult ju kui 1 teksuuri 1000 korda kasutamine annab parema tulemuse välja, miks raisata aega ja ressurssi 1000 tekstuuri loomisele? _________________ Winter is coming...
NeroEST, mingi ho ho ja carmacki fetish. ja veel seda, et mingisugune tilulilu küll pasku tekstuure ei kompenseeri. see on fakt. _________________ "Kuidas on see hea?"
ot:
f1 2011 tänu tilulilule on 1024x768 low low low minu jaoks väga ilusa graafikaga mäng.
fallout 3 mingi megahüper high res texture packidega 1920x1080 resol nägi ka hullem välja imo.
viimati muutis NeroEST 10.10.2011 15:13:48, muudetud 2 korda
HDD'del on ruumi enam kui piisavalt Rage'i jaoks, lihtsalt mitte konsoolides kasutatavatel variantidel. _________________ Teach a man to reason and he'll think for a lifetime
ei soovi c.a. 10% ketta mahtu ühe mängu alla panna. põmst nad võiks siis ju 3TB mängu ka teha, sest PC HDD'le mahub ju vabalt ära. arvutiga muudki teha, kui rage mängida. _________________ "Kuidas on see hea?"
Scart, ma ei näe probleemi, kui HDD'd oleksid suurusjärk 10TB, mitte 1TB. Ega tõesti pole probleemi, kui ainult rage mängid, siis võib vabalt see 150GB ühe mängu all tiksuda, aga muud ka veel vaja teha, siis see suht katastroof + muud mängud + muusika + video edit. _________________ "Kuidas on see hea?"
Mul mängumasinas peale lastud kogu steami ~200 mängu ja võtab see lõbu suts alla TB. Töömasinas muu kama jaoks veel mõned terad. Olukorras, kus 2T saab kätte ~60€ eest ei ole nagu eriti mõtet vinguda. _________________ Teach a man to reason and he'll think for a lifetime
Lugesin terve selle teema siin uuesti läbi ja ei näe mingit viidet. Samuti lugesin Carmacki twitter feedi uuesti läbi alates juunist ja ei leidnud midagi. Siis surkisin googles ringi, tulemuseta. Äkki aitad mind ikka hädast välja ja jagad oma allikat, kasvõi privaatselt?
kunagi pc mängude puhul oli täiesti norm, et ainult 2 mängu peale mahubki.
tänapäeval kui on developeritel võimalus, et ei peaks optimeerima ei tea mitte millegi pärast siis ulutakse, et uauauauauau liiga palju ruumi võtab
sellesse tellisesse mis kraana pulti haldab muidugi loogiliselt võttes midagi peale ei mahu, kuidas saakski
ärge vinguge ja laske juba lõpuks ometi carmackil mängu arendada mitte mingi saia jaoks söödavaks teha
mina pean teie telliste pärast kannatama, no krt.. ilma teie si....käkita oleks tõenäoliselt praegu ragel korralikud dedicated serverid ja vähemalt võimalik 32 keisi mapp täiesti sodiks lasta.
