uus teema   vasta Raud »  Protsessorid »  AMD Bulldozer/Piledriver arutelu märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 48, 49, 50 ... 210, 211, 212  järgmine
Villemk2
Villemk2
sõnum 01.10.2011 16:22:02 vasta tsitaadiga
Pea asi, et AMD Intelist liiga kaugele maha ei jää icon_neutral.gif icon_rolleyes.gif
Kommentaarid: 127 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 119
Ho Ho
Ho Ho
sõnum 02.10.2011 15:42:36 vasta tsitaadiga
(klokatud?) i2500k vs FX.
Passmark'i benchid on ikka multithreaded?
1dumbpcuser
sõnum 02.10.2011 16:22:43 vasta tsitaadiga
(klokatud?) i2500k
M:
Kommentaarid: 102 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 97
Ho Ho
Ho Ho
sõnum 02.10.2011 16:47:30 vasta tsitaadiga
Pole enam pikka aega konkreetsete prosede detailidega nii kursis kui mõned aastad tagasi, ei teadnud kas tegu turbo või muu imevidinaga icon_razz.gif
aga endiselt, kui paljud noist bencidest kasutavad kõiki tuumi?
1dumbpcuser
sõnum 02.10.2011 17:04:13 vasta tsitaadiga
http://www.passmark.com/forum/showthread.php?t=1237
A lot has changed since 2003.
All the CPU tests are multi-threaded (multi-process to be precise). So they can take advantage of dual core, quad core and multiple CPU scenarios.
The other tests (like the disk test and 2D test) are single threaded.
But regardless of being multi-threaded or not, CPU performance is determined by more than just the clock speed. For example all the new Intel Core 2 CPU's are faster than the old Pentiums, but the Pentiums had a higher clock speed.
All the CPU tests are multi-threaded. All the other tests are single threaded. At least from the applications point of view, we can't vouch for what happens in the O/S and device drivers.
Differences in the 2D video results is more likely to be the result of 1) your video cards 2) video card device drivers and 3) system configuration.
EDIT:
http://forums.anandtech.com/showthread.php?p=32352534
M:
viimati muutis 1dumbpcuser 02.10.2011 17:06:16, muudetud 1 kord
pohmakas,
käed värisevad
pohmakas,
sõnum 02.10.2011 17:05:54 vasta tsitaadiga
Tegu on ikka turboga.
Passmark peaks olema ikka multithreaded.
Edit: 1dumbpcuser oli kiirem.. icon_smile.gif
Kommentaarid: 166 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 137
erick
erick
sõnum 02.10.2011 22:59:59 vasta tsitaadiga
Bulldozer FX-8150 PassMarkis sees: LINK
2600K-le jääb arvestatavalt alla, 2500Kst jälle arvestatavalt kiirem. i7 975 4C8T on veel rohkem maas.
Samas kui asi läheb õhuga 5GHz - 5,5GHz ... kellatuna peaks vast keskmisele 4,6GHz 2600K-le ära sõitma.
Ho Ho
Ho Ho
sõnum 02.10.2011 23:05:00 vasta tsitaadiga
erick kirjutas:
Kui mitu noist sadadest kividest mida nad seal rekordüritusel kellasid sellise takti peale läksid?
Muidu suht üllatav oli näha BD'd tegemas nii suuri tegusid x87 koodiga.
Kristoferr
Kristoferr
sõnum 03.10.2011 01:55:57 vasta tsitaadiga
See Passmark on idiootsuse tipp. 2600 ja 2600K saavad CPU testis 1000p vahe. Mismoodi icon_rolleyes.gif .
Lisaks on Intel Mobile seeria prosed täiesti ebanormaalselt kõrgel.
+veel mitmeid imelikke ebatäpsusi.
Liitu Z.ai soodsa coding plaaniga
Liitu Wise'ga!
Kommentaarid: 265 loe/lisa Kasutajad arvavad:  :: 4 :: 0 :: 216
Ho Ho
Ho Ho
sõnum 03.10.2011 09:19:18 vasta tsitaadiga
Mobilest veel kuidagi aru saab kui nad kogu benchi jooksul turboga jooksid.
erick
erick
sõnum 03.10.2011 11:03:53 vasta tsitaadiga
Ho Ho kirjutas:
erick kirjutas:
Macci ütles ühes hilisemas intervjuus, et kuigi AMD andis tray täie prosesid neile, võtsid nad neid sealt suht suvaliselt. Samamoodi ütles ta, et kõik isendid mida nad proovisid, läksid õhuga vähemalt 5GHz, parim aga 5,5GHz.
EDIT:
NordicHardware: "It says you reached frequencies "well above 5 GHz" with only air and sub-$100 water cooling solutions. Mind going more into detail about your ventures on air and water?"
Sami Mäkinen: "In terms of CPUZ MHz I’ve seen virtually every CPU reach over 5GHz when using a good air/watercooler. I believe the highest result I saw with aircooling was around 5.5GHz CPUZ. This CPU hit around 7.8GHz on LN2."
LINK
Kristoferr kirjutas:
2600K on kellamiseks mõeldud, ilmselt võetakse madalama TDPga isendid selle jaoks, mis omakorda tähendab, et CPU saab veeta rohkem aega Turbo Mode'is enne kui temperatuurilagi ette tuleb?
Sponge
Sponge
sõnum 03.10.2011 11:45:26 vasta tsitaadiga
Kommentaarid: 398 loe/lisa Kasutajad arvavad:  :: 4 :: 4 :: 323
Optimist
Optimist
sõnum 03.10.2011 14:47:49 vasta tsitaadiga
Kas kedagi veel häirib et ühegi Passmarki AMD CPU juures pole takti märgitud aga kõik Inteli CPU'd on @ xGHz ?
CPU tests Mathematical operations, compression, encryption, SSE, 3DNow! instructions and more = liiga ümmargune jutt. Raske aru saada mida nad seal täpselt arvutavad ja mis optmisatsioonide järgi. AES-NI supporti ei tundu Passmargis olevat, SSE versiooni ka ei mainita. Bench vähemalt paar-kolm aastat ajale jalgu jäänud aga eks vanakooli asjade mõõtmise bence ole ka vaja. Mõõdetud FX-8150 kohta oleks ka huvitav teada, mis emaplaadi AGESA/CPU steppingu jms versioonid olid.
Usun kui AES, AVX, XOP, CVT16, FMA4 optimisatsioonid mängu panna, võib osade benchide numbrid BD'ga ikka päris kõrgeks ajada. Aga mnjah, kui isegi benchide koodijad ei suuda alati viimase sõnaga kaasas käia, siis tavaliste rakenduste rekompileerimisest ei maksa Windoze keskkonnas väga unistadagi.
Kommentaarid: 10 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 8
Ho Ho
Ho Ho
sõnum 03.10.2011 14:54:47 vasta tsitaadiga
Optimist kirjutas:
Ajaga kaasas käia on küll tore aga samas tähendaks see ka seda, et iga koodiuuenduse peale muutuvad võrdlused vanemate tulemustega mõttetuks. Muidugi superpi laadset jura on ka mõttetu teha kus kood on enam-vähem muutumata kujul sama püsinud umbes 20a icon_biggrin.gif
Mis aga puutub lihtsalt ümber kompileerimisse siis sellest küll midagi eriti loota mõtet pole. Kui koodi pole kirjutatud otseselt ära kasutama noid featureid siis kompilaator suudab väga vähe aidata.
erick
erick
sõnum 03.10.2011 15:11:57 vasta tsitaadiga
Optimist kirjutas:
See tuleneb sellest et Intel kirjutab default sageduse oma CPU IDsse. AMD seda ei tee ja PassMark sagedust iseseisvalt ei tuvasta.
sõnum 03.10.2011 15:36:22 vasta tsitaadiga
Kuna see AMd juba välja tuleb?
ja uued prosed töötavad igal juhul ka DDR2 AMD plaadil, millel töötab AM3 Sempron?
Sven
Sven
sõnum 03.10.2011 15:43:34 vasta tsitaadiga
Magic kirjutas:
BD-l ei ole DDRII supportti.
Kommentaarid: 35 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 32
marxveix
marxveix
sõnum 03.10.2011 15:44:09 vasta tsitaadiga
Magic kirjutas:
Looda sa, osadel am3-l hakkab toimima.
Kommentaarid: 310 loe/lisa Kasutajad arvavad:  :: 1 :: 2 :: 270
1dumbpcuser
sõnum 03.10.2011 18:42:45 vasta tsitaadiga
Optimist kirjutas:
OT, aga nt MPC-HC-st on olemas AVX toega (test)versioonid: http://www.mediafire.com/?r367kbp7p9but
Iseasi, palju sest seal kasu on...
M:
Hazar
Hazar
sõnum 04.10.2011 03:00:17 vasta tsitaadiga
nuh nüüd lubati 12 okt, eks nädala pärast näeb
neoman
sõnum 04.10.2011 21:21:43 vasta tsitaadiga
Mis kanti hinnad jäävad ? odavam / kallim kui i2500K ?
Kommentaarid: 80 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 72
1dumbpcuser
sõnum 05.10.2011 06:33:10 vasta tsitaadiga
EDIT: Arvutusvead icon_redface.gif parandatud
Bulldoozri arvatavad hinnad:
FX-6100 ~160€
FX-8120 ~185€
FX-8150 ~220€
Võrdluseks juurde:
i5-2500K - 190€
i5-2600K - 265€
https://foorum.hinnavaatlus.ee/viewtopic.php?p=6661215#6661215 icon_wink.gif
M:
viimati muutis 1dumbpcuser 08.10.2011 12:03:15, muudetud 1 kord
Ho Ho
Ho Ho
sõnum 05.10.2011 09:15:22 vasta tsitaadiga
Samas pidavat Intel ka hinnakorrektuure tegema. 2500k vist kukkus paar-kolmkümmend euri kui mälu ei peta. Või nood hinnad ongi sul juba peale hinnalangust?
WäntWõll
make.believe
WäntWõll
sõnum 05.10.2011 09:54:35 vasta tsitaadiga
i7-2700k ka juba uksetaga ja liigutab tiba neid hindu vast veel allapoole, kuigi algselt pakuti et 2700 on ainult 20€ ca. kallim kui 2600.
One
sõnum 05.10.2011 12:20:58 vasta tsitaadiga
link :: AMD Readies Opteron 4200 ''Valencia'' Line for 1P/2P Servers
Pole paha, 2.5GHz kaheksatuumaline mille TDP on vaid 32W
uus teema   vasta Raud »  Protsessorid »  AMD Bulldozer/Piledriver arutelu mine lehele eelmine  1, 2, 3 ... 48, 49, 50 ... 210, 211, 212  järgmine
