Villemk2
01.10.2011 15:22:02
Pea asi, et AMD Intelist liiga kaugele maha ei jää icon_neutral.gif icon_rolleyes.gif
midagi hullu vist ei juhtuks kui hinna madala hoiavad
| Kommentaarid: 127 loe/lisa |
119 |
Ho Ho
02.10.2011 14:42:36
(klokatud?) i2500k vs FX.
Passmark'i benchid on ikka multithreaded?
86 |
1dumbpcuser
02.10.2011 15:22:43
(klokatud?) i2500k
Vaata paremat akent, seal näha, et CPU max on 3600
_________________ M: |
97 |
Ho Ho
02.10.2011 15:47:30
Pole enam pikka aega konkreetsete prosede detailidega nii kursis kui mõned aastad tagasi, ei teadnud kas tegu turbo või muu imevidinaga
aga endiselt, kui paljud noist bencidest kasutavad kõiki tuumi?
86 |
1dumbpcuser
02.10.2011 16:04:13
http://www.passmark.com/forum/showthread.php?t=1237
A lot has changed since 2003.
All the CPU tests are multi-threaded (multi-process to be precise). So they can take advantage of dual core, quad core and multiple CPU scenarios.
The other tests (like the disk test and 2D test) are single threaded.
But regardless of being multi-threaded or not, CPU performance is determined by more than just the clock speed. For example all the new Intel Core 2 CPU's are faster than the old Pentiums, but the Pentiums had a higher clock speed. |
All the CPU tests are multi-threaded. All the other tests are single threaded. At least from the applications point of view, we can't vouch for what happens in the O/S and device drivers.
Differences in the 2D video results is more likely to be the result of 1) your video cards 2) video card device drivers and 3) system configuration. |
EDIT:
http://forums.anandtech.com/showthread.php?p=32352534
viimati muutis 1dumbpcuser 02.10.2011 16:06:16, muudetud 1 kord |
97 |
pohmakas,
käed värisevad
02.10.2011 16:05:54
Tegu on ikka turboga.
Passmark peaks olema ikka multithreaded.
Edit: 1dumbpcuser oli kiirem..
| Kommentaarid: 165 loe/lisa |
137 |
erick
02.10.2011 21:59:59
Bulldozer FX-8150 PassMarkis sees: LINK
2600K-le jääb arvestatavalt alla, 2500Kst jälle arvestatavalt kiirem. i7 975 4C8T on veel rohkem maas.
Samas kui asi läheb õhuga 5GHz - 5,5GHz ... kellatuna peaks vast keskmisele 4,6GHz 2600K-le ära sõitma.
96 |
Ho Ho
02.10.2011 22:05:00
| erick kirjutas: |
| Samas kui asi läheb õhuga 5GHz - 5,5GHz |
Kui mitu noist sadadest kividest mida nad seal rekordüritusel kellasid sellise takti peale läksid?
Muidu suht üllatav oli näha BD'd tegemas nii suuri tegusid x87 koodiga.
86 |
Kristoferr
03.10.2011 00:55:57
See Passmark on idiootsuse tipp. 2600 ja 2600K saavad CPU testis 1000p vahe. Mismoodi .
Lisaks on Intel Mobile seeria prosed täiesti ebanormaalselt kõrgel.
+veel mitmeid imelikke ebatäpsusi.
_________________ Liitu Z.ai soodsa coding plaaniga
Liitu Wise'ga! |
216 |
Ho Ho
03.10.2011 08:19:18
Mobilest veel kuidagi aru saab kui nad kogu benchi jooksul turboga jooksid.
86 |
erick
03.10.2011 10:03:53
| Ho Ho kirjutas: |
| erick kirjutas: |
Kui mitu noist sadadest kividest mida nad seal rekordüritusel kellasid sellise takti peale läksid? |
Macci ütles ühes hilisemas intervjuus, et kuigi AMD andis tray täie prosesid neile, võtsid nad neid sealt suht suvaliselt. Samamoodi ütles ta, et kõik isendid mida nad proovisid, läksid õhuga vähemalt 5GHz, parim aga 5,5GHz.
EDIT:
NordicHardware: "It says you reached frequencies "well above 5 GHz" with only air and sub-$100 water cooling solutions. Mind going more into detail about your ventures on air and water?"
Sami Mäkinen: "In terms of CPUZ MHz I’ve seen virtually every CPU reach over 5GHz when using a good air/watercooler. I believe the highest result I saw with aircooling was around 5.5GHz CPUZ. This CPU hit around 7.8GHz on LN2." |
LINK
| Kristoferr kirjutas: |
+veel mitmeid imelikke ebatäpsusi. |
2600K on kellamiseks mõeldud, ilmselt võetakse madalama TDPga isendid selle jaoks, mis omakorda tähendab, et CPU saab veeta rohkem aega Turbo Mode'is enne kui temperatuurilagi ette tuleb?
96 |
Sponge
03.10.2011 10:45:26
krt, ei jõua seda buldozerit ära oodata.
| Kommentaarid: 398 loe/lisa |
323 |
Optimist
03.10.2011 13:47:49
Kas kedagi veel häirib et ühegi Passmarki AMD CPU juures pole takti märgitud aga kõik Inteli CPU'd on @ xGHz ?
CPU tests Mathematical operations, compression, encryption, SSE, 3DNow! instructions and more = liiga ümmargune jutt. Raske aru saada mida nad seal täpselt arvutavad ja mis optmisatsioonide järgi. AES-NI supporti ei tundu Passmargis olevat, SSE versiooni ka ei mainita. Bench vähemalt paar-kolm aastat ajale jalgu jäänud aga eks vanakooli asjade mõõtmise bence ole ka vaja. Mõõdetud FX-8150 kohta oleks ka huvitav teada, mis emaplaadi AGESA/CPU steppingu jms versioonid olid.
Usun kui AES, AVX, XOP, CVT16, FMA4 optimisatsioonid mängu panna, võib osade benchide numbrid BD'ga ikka päris kõrgeks ajada. Aga mnjah, kui isegi benchide koodijad ei suuda alati viimase sõnaga kaasas käia, siis tavaliste rakenduste rekompileerimisest ei maksa Windoze keskkonnas väga unistadagi.
| Kommentaarid: 10 loe/lisa |
Ho Ho
03.10.2011 13:54:47
| Optimist kirjutas: |
| Aga mnjah, kui isegi benchide koodijad ei suuda alati viimase sõnaga kaasas käia, siis tavaliste rakenduste rekompileerimisest ei maksa Windoze keskkonnas väga unistadagi |
Ajaga kaasas käia on küll tore aga samas tähendaks see ka seda, et iga koodiuuenduse peale muutuvad võrdlused vanemate tulemustega mõttetuks. Muidugi superpi laadset jura on ka mõttetu teha kus kood on enam-vähem muutumata kujul sama püsinud umbes 20a
Mis aga puutub lihtsalt ümber kompileerimisse siis sellest küll midagi eriti loota mõtet pole. Kui koodi pole kirjutatud otseselt ära kasutama noid featureid siis kompilaator suudab väga vähe aidata.
86 |
erick
03.10.2011 14:11:57
| Kas kedagi veel häirib et ühegi Passmarki AMD CPU juures pole takti märgitud aga kõik Inteli CPU'd on @ xGHz ? |
See tuleneb sellest et Intel kirjutab default sageduse oma CPU IDsse. AMD seda ei tee ja PassMark sagedust iseseisvalt ei tuvasta.
96 |
03.10.2011 14:36:22
Kuna see AMd juba välja tuleb?
ja uued prosed töötavad igal juhul ka DDR2 AMD plaadil, millel töötab AM3 Sempron?
200 |
Sven
03.10.2011 14:43:34
| Magic kirjutas: |
ja uued prosed töötavad igal juhul ka DDR2 AMD plaadil, millel töötab AM3 Sempron? |
BD-l ei ole DDRII supportti.
| Kommentaarid: 35 loe/lisa |
marxveix
03.10.2011 14:44:09
| Magic kirjutas: |
Looda sa, osadel am3-l hakkab toimima.
| Kommentaarid: 310 loe/lisa |
270 |
1dumbpcuser
03.10.2011 17:42:45
Usun kui AES, AVX, XOP, CVT16, FMA4 optimisatsioonid mängu panna, võib osade benchide numbrid BD'ga ikka päris kõrgeks ajada. Aga mnjah, kui isegi benchide koodijad ei suuda alati viimase sõnaga kaasas käia, siis tavaliste rakenduste rekompileerimisest ei maksa Windoze keskkonnas väga unistadagi. |
OT, aga nt MPC-HC-st on olemas AVX toega (test)versioonid: http://www.mediafire.com/?r367kbp7p9but
Iseasi, palju sest seal kasu on...
Tahaks juba ühe 8-tuumase doozri arvutisse susata
97 |
Hazar
04.10.2011 02:00:17
| nuh nüüd lubati 12 okt, eks nädala pärast näeb
| Kommentaarid: 29 loe/lisa |
28 |
neoman
04.10.2011 20:21:43
| Mis kanti hinnad jäävad ? odavam / kallim kui i2500K ?
| Kommentaarid: 79 loe/lisa |
71 |
1dumbpcuser
97 |
Ho Ho
05.10.2011 08:15:22
Samas pidavat Intel ka hinnakorrektuure tegema. 2500k vist kukkus paar-kolmkümmend euri kui mälu ei peta. Või nood hinnad ongi sul juba peale hinnalangust?
86 |
WäntWõll
make.believe
05.10.2011 08:54:35
| i7-2700k ka juba uksetaga ja liigutab tiba neid hindu vast veel allapoole, kuigi algselt pakuti et 2700 on ainult 20€ ca. kallim kui 2600.
300 |
One
728 |
