Mercury
| Kommentaarid: 61 loe/lisa |
60 |
Redikate
01.10.2011 02:51:05
Vaatan et ufo jms siin müüvad 1GB servereid 16'nele inimesele. Mis see optimaalne RAM useage per person on siis lõpuks?
_________________ http://nodejs.org/
"I'm also a person. Programming is just one thing I do." |
| Kommentaarid: 34 loe/lisa |
33 |
Mercury
01.10.2011 10:17:14
| Redikate kirjutas: |
| Vaatan et ufo jms siin müüvad 1GB servereid 16'nele inimesele. Mis see optimaalne RAM useage per person on siis lõpuks? |
Optimaalne ja teoorias:
Based on the filesize of a chunk and all the data it holds, this is where the approximation exists "have at least 100MB of RAM per player." This is a great rule-of-thumb, but the point of this guide is to know why!
Sometimes you may see servers that support dozens of players--and they advertise how much RAM is used to keep it running. At 100MB per player, sometimes it just doesn't fit! Here's why:
If two players load at the spawn, their 'bubble' surrounding them is entirely overlapping. And as such, the world and its blocks only need to be loaded into RAM once to feed to both players. As the players run away from eachother, the bubbles surrounding them overlap less, and the server has to generate new blocks (or load existing ones) at the edge of the bubble, and drop chunks from memory that are no longer within range of any player.
http://minecraft.codeemo.com/helpdoc_ram.html |
Praktikas aga 20 inimest saab ka 1GB hakkama, kuid on piiri peal.
60 |
ddrikk
01.10.2011 13:15:44
cheti ja ezurek tahaks whitelisti saada minekraft.eu servusse
aitäh !
| Kommentaarid: 78 loe/lisa |
71 |
Mercury
01.10.2011 13:20:23
| hvallimagi kirjutas: |
aitäh !  |
olemas.
60 |
ddrikk
01.10.2011 13:21:25
| Mercury kirjutas: |
aitäh !  |
olemas. |
ezurek saab sisse aga ma mitte:
connection lost - end of stream
71 |
Mercury
01.10.2011 13:32:44
| Mercury kirjutas: |
aitäh !  |
olemas. |
connection lost - end of stream |
See on mc probleem. restart mcle aitab.
http://minekraft.eu:40023/
Hetkel renderdab, õhtuks on valmis.
60 |
Lohepoiss
01.10.2011 14:40:27
kingofmagnet soovib ka whitelisti
Mercury
02.10.2011 19:41:04
| Lohepoiss kirjutas: |
kingofmagnet soovib ka whitelisti  |
Lisatud!
60 |
xpander
| Kommentaarid: 18 loe/lisa |
16 |
03.10.2011 13:21:00
lahe
See vee kohal ehitamine ju päris haige?
200 |
namstoop
03.10.2011 14:20:59
Magic, miks? Kõvasti ohutum kui maa kohal . Kui kükitamist kasutada siis üle serva ju ei kuku ka muidugi.
| Kommentaarid: 72 loe/lisa |
63 |
xpander
03.10.2011 14:23:44
väike sõrm väsis aint ära sedasi ehitades:)
ja aeg ajalt sai ikka vette ka potsatatud lol
_________________ Linux Gaming Videos: Xpander69 |
16 |
03.10.2011 14:29:54
| xpander kirjutas: |
ja aeg ajalt sai ikka vette ka potsatatud lol |
Seda minagi... muidugi maa kohal nüridam jah..
Aga tore, et maailm areneb.
Falsebook peaks ka mitmed asjad huvitavamaks tegema.
200 |
etk
03.10.2011 15:04:27
Ajaga kamp kokku ja ehitage siis juba spawn külake vms ka ära, kui ikkagi 1.9 tulekuga server whitelistist avalikuks muutub.
Ja kui juba raudteede ehitamine käsil, siis võiks nad ära ühendada ja spawni linkida ka, saaks igalepoole mugavalt liikuda.
| Kommentaarid: 44 loe/lisa |
42 |
namstoop
03.10.2011 15:07:12
jeh kui ma oma klaasilda WxMc serveris ehitasin siis tegelikult paar korda kukkusin alla ikkagi, ilmselt sõrm veidi vääratas . Sai aga rõõmsasti käia nodi kokku korjamas.
63 |
ertr2
03.10.2011 15:10:28
| kas map tuleb resetida kui õige kui 1.8 pealt 1.9 peale minna?
| Kommentaarid: 67 loe/lisa |
65 |
Mercury
03.10.2011 15:21:41
| ertr2 kirjutas: |
| kas map tuleb resetida kui õige kui 1.8 pealt 1.9 peale minna? |
no wai
60 |
ertr2
03.10.2011 15:37:36
| Mercury kirjutas: |
| ertr2 kirjutas: |
no wai  |
Ma mõtlen, et kui need uued bioomid tulevad, kas ta olemasolevale mapile neid juurde ei hakka genereerima?
65 |
xpander
03.10.2011 15:42:40
kaart piisavalt väike hetkel.
uued bioomid tulevad hetke alast välja arvatavasti..seega map läheb suuremaks.
16 |
tarts608
03.10.2011 20:02:24
Kellelgi kuskilt 1.7.3 minecraft_server.jar faili on välja võluda? Googlest ainult minecraft_server.exe leidnud aga sinna ei saa mode peale panna.:S
_________________ http://steamcommunity.com/id/Twizek/ |
xpander
16 |
MrAndu
03.10.2011 21:27:23
tuleks uuriks ka ringi
mängus: MrAndu
| Kommentaarid: 63 loe/lisa |
51 |
Mercury
03.10.2011 23:43:01
| vazzar kirjutas: |
mängus: MrAndu |
olemas.
Tänu Twizek'le on meil nüüd TS3 kanal!
http://bit.ly/mkserver
Hetkel ei saa tuld põlema panna mis peagi lahendatakse.
60 |
kriist
03.10.2011 23:43:06
Lisa palun: kri1st
93 |
