uus teema   vasta Tarkvara »  Arvutimängude foorum »  Minecraft märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 121, 122, 123 ... 175, 176, 177  järgmine
Mercury
sõnum 30.09.2011 23:07:22 vasta tsitaadiga
cubedude kirjutas:
Kes pole juba märganud siis on Minecraft 1.9 Pre-release 2 väljas.
1.9 paistab väga huvitav tulema.
http://www.minecraftforum.net/topic/673147-all-about-potions-and-brewing-19-reference-guidepics-and-a-mod-download-to-make-them-usable/
Minekraft.eu:25570 Survival (Eesti/Inglise Server) (Hetkel on server testimisel, sisenemiseks postitage oma nimi siia teemasse icon_exclaim.gif )
Kommentaarid: 61 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 60
Redikate
Redikate
sõnum 01.10.2011 02:51:05 vasta tsitaadiga
Vaatan et ufo jms siin müüvad 1GB servereid 16'nele inimesele. Mis see optimaalne RAM useage per person on siis lõpuks?
http://nodejs.org/
"I'm also a person. Programming is just one thing I do."
Mercury
sõnum 01.10.2011 10:17:14 vasta tsitaadiga
Redikate kirjutas:
Optimaalne ja teoorias:
Based on the filesize of a chunk and all the data it holds, this is where the approximation exists "have at least 100MB of RAM per player." This is a great rule-of-thumb, but the point of this guide is to know why!
Sometimes you may see servers that support dozens of players--and they advertise how much RAM is used to keep it running. At 100MB per player, sometimes it just doesn't fit! Here's why:
If two players load at the spawn, their 'bubble' surrounding them is entirely overlapping. And as such, the world and its blocks only need to be loaded into RAM once to feed to both players. As the players run away from eachother, the bubbles surrounding them overlap less, and the server has to generate new blocks (or load existing ones) at the edge of the bubble, and drop chunks from memory that are no longer within range of any player.
http://minecraft.codeemo.com/helpdoc_ram.html
Praktikas aga 20 inimest saab ka 1GB hakkama, kuid on piiri peal.
ddrikk
sõnum 01.10.2011 13:15:44 vasta tsitaadiga
cheti ja ezurek tahaks whitelisti saada minekraft.eu servusse
Kommentaarid: 78 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 71
Mercury
sõnum 01.10.2011 13:20:23 vasta tsitaadiga
hvallimagi kirjutas:
olemas.
ddrikk
sõnum 01.10.2011 13:21:25 vasta tsitaadiga
Mercury kirjutas:
olemas.
ezurek saab sisse aga ma mitte:
connection lost - end of stream
Mercury
sõnum 01.10.2011 13:32:44 vasta tsitaadiga
Mercury kirjutas:
olemas.
See on mc probleem. restart mcle aitab.
http://minekraft.eu:40023/
Hetkel renderdab, õhtuks on valmis.
Lohepoiss
Lohepoiss
sõnum 01.10.2011 14:40:27 vasta tsitaadiga
Mercury
sõnum 02.10.2011 19:41:04 vasta tsitaadiga
Lohepoiss kirjutas:
Lisatud!
xpander
xpander
sõnum 03.10.2011 11:42:35 vasta tsitaadiga
ehitajad siis: hannz18 ja xpander0
http://dl.dropbox.com/u/28788188/Screenshot-206.png
Linux Gaming Videos: Xpander69
sõnum 03.10.2011 13:21:00 vasta tsitaadiga
See vee kohal ehitamine ju päris haige?
namstoop
namstoop
sõnum 03.10.2011 14:20:59 vasta tsitaadiga
Magic, miks? Kõvasti ohutum kui maa kohal icon_biggrin.gif. Kui kükitamist kasutada siis üle serva ju ei kuku ka muidugi.
verba volant, scripta manent
xpander
xpander
sõnum 03.10.2011 14:23:44 vasta tsitaadiga
väike sõrm väsis aint ära sedasi ehitades:)
ja aeg ajalt sai ikka vette ka potsatatud lol
sõnum 03.10.2011 14:29:54 vasta tsitaadiga
xpander kirjutas:
Seda minagi... muidugi maa kohal nüridam jah..
Aga tore, et maailm areneb.
Falsebook peaks ka mitmed asjad huvitavamaks tegema.
etk
etk
sõnum 03.10.2011 15:04:27 vasta tsitaadiga
Ajaga kamp kokku ja ehitage siis juba spawn külake vms ka ära, kui ikkagi 1.9 tulekuga server whitelistist avalikuks muutub.
Ja kui juba raudteede ehitamine käsil, siis võiks nad ära ühendada ja spawni linkida ka, saaks igalepoole mugavalt liikuda.
Kommentaarid: 44 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 42
namstoop
namstoop
sõnum 03.10.2011 15:07:12 vasta tsitaadiga
jeh kui ma oma klaasilda WxMc serveris ehitasin siis tegelikult paar korda kukkusin alla ikkagi, ilmselt sõrm veidi vääratas icon_smile.gif. Sai aga rõõmsasti käia nodi kokku korjamas. icon_lol.gif
ertr2
ertr2
sõnum 03.10.2011 15:10:28 vasta tsitaadiga
kas map tuleb resetida kui õige kui 1.8 pealt 1.9 peale minna?
Kommentaarid: 67 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 65
Mercury
sõnum 03.10.2011 15:21:41 vasta tsitaadiga
ertr2 kirjutas:
ertr2
ertr2
sõnum 03.10.2011 15:37:36 vasta tsitaadiga
Mercury kirjutas:
ertr2 kirjutas:
Ma mõtlen, et kui need uued bioomid tulevad, kas ta olemasolevale mapile neid juurde ei hakka genereerima?
xpander
xpander
sõnum 03.10.2011 15:42:40 vasta tsitaadiga
kaart piisavalt väike hetkel.
uued bioomid tulevad hetke alast välja arvatavasti..seega map läheb suuremaks.
tarts608
tarts608
sõnum 03.10.2011 20:02:24 vasta tsitaadiga
Kellelgi kuskilt 1.7.3 minecraft_server.jar faili on välja võluda? Googlest ainult minecraft_server.exe leidnud aga sinna ei saa mode peale panna.:S
http://steamcommunity.com/id/Twizek/
xpander
xpander
sõnum 03.10.2011 21:05:39 vasta tsitaadiga
tarts608 kirjutas:
aga palun: http://dl.dropbox.com/u/28788188/minecraft-1.7.3.jar
aa krt server.
pole vist
MrAndu
MrAndu
sõnum 03.10.2011 21:27:23 vasta tsitaadiga
mängus: MrAndu
Kommentaarid: 63 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 51
Mercury
sõnum 03.10.2011 23:43:01 vasta tsitaadiga
vazzar kirjutas:
mängus: MrAndu
olemas.
Tänu Twizek'le on meil nüüd TS3 kanal!
http://bit.ly/mkserver
Hetkel ei saa tuld põlema panna mis peagi lahendatakse.
kriist
kriist
sõnum 03.10.2011 23:43:06 vasta tsitaadiga
Lisa palun: kri1st beer_yum.gif
Kommentaarid: 104 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 93
uus teema   vasta Tarkvara »  Arvutimängude foorum »  Minecraft mine lehele eelmine  1, 2, 3 ... 121, 122, 123 ... 175, 176, 177  järgmine
