Mind häirib wasd süsteemi juures liiga lähestikku asetsevad klahvid. Pealegi sünnist saati nooltega pelatud (alates half-life' action mod'ist ). FPS mängimiseks on noolte ümber klahve küllalt, delete, insert punt, keypad loomulikult ja enter klahvi ümbrus, mis annab ~31 erinevat klahvi + G500 hiire 5 nuppu. Ainuke koht kus see valik kitsaks jääb on olnud Operation Flashpoint või Arma, aga seal peaks vist peavõru kasutama enivei ...
(Not a complete list – for up to date news, visit the News section in Battlelog)
* Fixed occasional client crash when reviving.
* Fixed killcam showing glitched area under map if your killer is dead.
* Issue with spawning on dead squad mates fixed.
* Fixed a bug where shooting at a moving enemy could cause more than the intended amount of damage.
* Crosshairs for shotguns have been replaced with a new, thinner, art.
* A subtle low health screen effect has been added.
* Tweaked scores of Medals and Service Stars.
* Tweaked the Rank progression.
* Pushing prone on console will not play the animation twice.
* Fixed loss of Squad Leader after EOR at some times.
* Framerate stability fixes.
* The 3D spotting icons has been tweaked to better match the target’s visibility. Icons will show frequently less on mostly obscured targets.
* Fixed issue with crosshair disappearing after round transition.
* Fixed issue with crosshair disappearing after trying to deploy while the countdown timer still active.
* Squad list now shows specializations chosen, VOIP activity and dead squad mates.
* Non working options in squad menu fixed: "Private" flag and "Switch Teams".
Iga roundi järel pakib mäng end ilusti kokku. Mõttetu on aega viita selle iba peale
Endal töötab ilusasti, aga sõbral ei lähe mäng enam üldse tööle. Ühel hetkel töötas ilusasti, järgmine kord, kui mängu tahtis minna ei juhtunud enam midagi. bf3.exe viskab mõneks ajaks Task Magagerisse ja kõik.
Assault klass päris huvitav, see on hea et meedikuga kokku pandud, mitte nagu bf2-es oli. Relvad on tal täitsa head ja päris fun on elustada vendi ja neid medpakke loopida. Punkte tuleb päris kiiresti nii.
Assault on jah Metros parim klass imo Saad pihta viskad pikali ja medpaki ette, elud täis lased edasi, medpakk on ees saad pihta kohe elud taastuvad Loobid oma teammatidele med pakke koguaeg, punkte tuleb _________________ Bawse
Kuradi camperid seal Metroos koguaeg. Triple kill tuli ära SMAWiga, paras!
Eks neid on aga ei häri. Defenderi pool on campimine loomulik, ülesanne on ikka punkti kaitsta mitte kuskile vastase spawni ligidale joosta et seal surma saada. Kui assult campib, see on teine asi, õnneks siiani pole kaotanud assaulti poolel selle tõttu ,et tiim campib _________________ Bawse
olen tähele pannud, et kuskil 20 playeriga servus on über mängida... ei rubberbandi ei lagi, hitreg on hea ja kõik korras, üle selle on suht koomas... rahvas tekib lampi ekraanile ja mingid nähtamatud mikid jooksevad ringi
Ma tahan oma nooli tagasi!
Mulle ka need wasd klahvid ei meeldi,mängus olles vajutasin esc ja muutsin liikumisnupud ära noolte peale nii et täitsa mugav on nüüd Kahju et hiirel ei saa neid nuppe muuta,mul parempoolne hiireklahv ei tööta korralikullt enam viimasel ajal. kui sihikut tahan hoida siis nagu ei jää nagu hoidma seda :Ssuht väsind see kova juba vist
Saab küll!!! BF3 kasuab sellist saiti nagu Gavatar teed sinna enale konto ja voila olemas.
P.S. Battlelog-i ja Gavatari E-maili aadress peab sama olema.
Kuidas nende hävitajate relvadega on? Kas ainult kuulipildur ongi või saab levelitega lahti ka rakette? Siiamaani pole üheski videos rakette laskvaid hävitajaid näinud
Kas kuidagi soldieri nime saab ka muuta, mul muidu täna oli mingi exe kala, öösel tiris ära ja installis, aga täna kordagi mängima ei saanud. Koguaeg kisas mingit exe errorit. panin uuesti tõmbama.
