uus teema   vasta Hinnavaatlus »  Microsoft »  Windows 7 (arutelu ja probleemid) märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 287, 288, 289 ... 372, 373, 374  järgmine
ewur
ewur
sõnum 26.09.2011 19:49:25 vasta tsitaadiga
Kuna läpakas on SSD, siis lülitasin Prefetch`i (registrist) kui ka Superfetch`i (registrist ja service.msc-st) välja. Mõne aja pärast on Superfetch aga registris ("value" on "3") ja service.msc-s jälle "enabletud". Ja kuigi Prefetch´i "value" on registris "0", aga raibe ikka kirjutab oma andmeid Windows/Prefetch kataloogi. Milles asi?
friik1
friik1
sõnum 26.09.2011 20:41:23 vasta tsitaadiga
Miks seda prefetchi ja superfetchi kinni üritatakse panna... RAM on ju veel paar suurusjärku kiirem kui SSD...?
LiivaneLord
Sõpradele "Olavi"
sõnum 26.09.2011 21:22:52 vasta tsitaadiga
Kas superfetch ei salvesta mitte andmed kettale, et neid sealt kiiresti rammi laadida?
Loogiliselt on superfetch mittevajalik, kuna rakendused laevad ennast piisavalt kiiresti. Jääb lihtsalt nende failide kirjutamine ära.
sõnum 26.09.2011 21:26:28 vasta tsitaadiga
Will Superfetch be disabled on SSDs?
Yes, for most systems with SSDs.
If the system disk is an SSD, and the SSD performs adequately on random reads and doesn’t have glaring performance issues with random writes or flushes, then Superfetch, boot prefetching, application launch prefetching, ReadyBoost and ReadDrive will all be disabled.
Initially, we had configured all of these features to be off on all SSDs, but we encountered sizable performance regressions on some systems. In root causing those regressions, we found that some first generation SSDs had severe enough random write and flush problems that ultimately lead to disk reads being blocked for long periods of time. With Superfetch and other prefetching re-enabled, performance on key scenarios was markedly improved.
Ja pange omale ükskord järjehoidjaks: http://blogs.msdn.com/b/e7/archive/2009/05/05/support-and-q-a-for-solid-state-drives-and.aspx
LiivaneLord
Sõpradele "Olavi"
sõnum 26.09.2011 21:47:26 vasta tsitaadiga
tomorrow, ei ole põhjust, kuna Superfetch millegipärast minu SSD-ga süsteemil töötab. icon_sad.gif
Kuidas kogu see jada ühekorraga ära keelata?
sõnum 26.09.2011 21:53:38 vasta tsitaadiga
LiivaneLord kirjutas:
Batch failiga.Osad asjadel peab teenused peatama ja osadel registrit muutma.
LiivaneLord
Sõpradele "Olavi"
sõnum 26.09.2011 21:58:29 vasta tsitaadiga
sõnum 26.09.2011 22:03:21 vasta tsitaadiga
Parem jah guugeldada.Kindlasti on mingi programm millega saab kenasti need kinni keerata.
ewur
ewur
sõnum 26.09.2011 22:21:26 vasta tsitaadiga
tomorrow kirjutas:
Sa vist ei viitsinud profiilist vaadata, aga tegemist on M4-ga, mis saab WEI 7,9...
Ja nagu sa lugesid, siis - "Osad asjadel peab teenused peatama ja osadel registrit muutma" ei aidanud.
mazdagti
mazdagti
sõnum 27.09.2011 05:55:04 vasta tsitaadiga
tahanteada kirjutas:
mazdagti: Nii, kui kivi on kuum, loll - või ei anna enam emaplaadile õiget informatsiooni, siis peabki ju emaplaat Sulle teada andma, et videoga on mingid jamad majas.
Ja kui maha jahtub või kui temperatuur on teatud piires, siis asi töötab, kui temperatuur kõrgemaks läheb, siis on veateade ekraanil.
Võid ju teha lihtsa katse, lase originaaldraiverid maha ja jäta ainult Windowsi Plug-and-play draiver, pilt on küll kehvake, aga võrdluse saad, et kas siis ka pilt kinni lendab või mitte.
Kas ka siis on põhjuseks kivi kui esimese 5 mintsa jooksul lööb 4x driver error ja siis ei juhtu pea 2 tunni jooksul miskit? Naise arvutil on ajaga see probleem näiteks kadunud, minu omal win aga 4 kuud vähem peal olnud!
No ikka täitsa kagu nukas!
FB Volvokodu, diagnostikaabi Võrumaal.
sõnum 27.09.2011 07:48:17 vasta tsitaadiga
mazdagti: Nägin, muide, suht-koht hiljuti alles jälle samasugust pilti, kus jaheda videokivi korral oli kõik OK, kuid kuuma videokivi korral hakkas läppar kirju ekraanile loopima, et "videodraiveri" jama. Ja mingi aeg hiljem, oli asi lõplikult pime.
- vist müüdi osadeks maha, ei hakatud "ahjuga jändama".
Nii, et video ülekuumenemisega saab kaasneda mitmeid valesid käitumisi, sai just lauaarvutiks kokku laotud üks taoline Compaqi 6400 seeria läpp, millel enam sees pilti pole, välisega veel on ja siis oli ka hästi näha, kuidas video enam suuremat koormamist välja ei kannatanud - nii, kui kuum, siis "lõi ekraanipildile müralained" sisse.
Ning asi on isegi nii piiri peal, et kuidagimoodi suudab töötada XP-ga, kuid suurema, näiteks, Windows 7 videokoormuse juures, "lainetab" pilt juba üsna kiiresti.
olavsu1
külaline
sõnum 28.09.2011 01:56:04 vasta tsitaadiga
Kust kohast saab igaveseks ära muuta selle, mis infoveergusid failibrauser näitab kindla failitüübi puhul?
ma tahan .mid failde puhul kuvatavaid veergusid ära muuta. hetkel kuvatakse peale faili nime täiesti ebavajalikke veergusid ja vajalikku veergu (faili maht) ei kuvatagi.
ja kust võtab Windows selle tarkuse, et .mid on muusikafail? mid on noodifail, mitte muusika.
sõnum 28.09.2011 04:12:53 vasta tsitaadiga
olavsu1 kirjutas:
Win7 ei oska veergusid kohandada vastavalt failitüübile.On üldised kategooriad mille aluses veerud paika pannakse ja see sõltub sellest mis failid antud kaustas enamuses on.
.mid fail loetakse jah muusikafailiks ja minuarust on see ka normaalne.Antud juhul kohandatakse sellele siis vastavalt Music veeru sätted.
Kuigi eks see contenti autodetect on kah vahel kalane ja ei tuvasta korrektselt mida antud kaust kõige rohkem sisaldab icon_rolleyes.gif
Mind näiteks häirib, et muusikakaustas ei näidata vaikimisi Bit rate veergu.
LiivaneLord
Sõpradele "Olavi"
sõnum 28.09.2011 08:19:29 vasta tsitaadiga
sõnum 28.09.2011 08:31:15 vasta tsitaadiga
LiivaneLord
Sõpradele "Olavi"
sõnum 28.09.2011 08:34:41 vasta tsitaadiga
sõnum 28.09.2011 08:57:09 vasta tsitaadiga
Jah pole ju vaja masendusse viia neid nende 64kbps muusikakogu pärast icon_lol.gif
olavsu1
külaline
sõnum 28.09.2011 10:58:42 vasta tsitaadiga
siis peaks saama kord paika pandud asetust salvestada.
sõnum 28.09.2011 16:31:22 vasta tsitaadiga
olavsu1 kirjutas:
Selleks, et järgmisel wini installil explorer kasutaks samu sätteid veergude jaoks peab vanalt installilt varundama (eksportima) järgmise registrivõtme ja selle siis uuele süsteemile importima:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer
olavsu1
külaline
sõnum 28.09.2011 21:14:55 vasta tsitaadiga
tomorrow, tänud vihje eest aga vihje oli metsa...
õige koht on järgnev
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\FolderTypes
otsisin sealt muusikakausta kohta käiva kirjelduse, mis minul järgnev
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\FolderTypes\{94d6ddcc-4a68-4175-a374-bd584a510b78}\TopViews\{00000000-0000-0000-0000-000000000000}
ja muutsin veeruloendis soovitud veerude nimed aktiivseks, veerunimes "1System.Size;" sai number "1" asendatud numbriga "0". Soovitud veerg ilmuski nähtavale ja on kogu aeg näha.
see oli kirve meetod.
õigem oleks eraldada .mid .midi .kar failitüübid muusikafailidest. luua neile uued failitüübid.
.mid, .midi - SheetMusic
.kar - SheetMusicWithWords // sama mis midi, kuid on lisatud sõnade rada või mõnele rajale on lisatud sõnade kiht.
lõpuks siis neile omaette kaustatüübid....
sõnum 28.09.2011 21:35:26 vasta tsitaadiga
timpser
sõnum 28.09.2011 22:25:21 vasta tsitaadiga
tere, mul sellline mure, et ostsin flex sulearvuti poest endale sellise arvuti http://flex.ee/3776-Acer-Aspire-5755G aga see oli ilma tarkvarata. Okei m6tleisn et t6mban alla windowsi 7 ja lasen plaadile, tegin k6ik internetis antud juhitelele. Plaat valmis panin arvutisse ja arvuti t66le, aga jamh, tuli mingi jama ette, mingi linux booting. lugesin, nats internetist ja noh, siis 6eldi et peaksid panema biosis endale cd romi esimeseks bootijaks. tegin ka seda, vähemalt arvan et tegin, juhste järgi peaks toimima, aga ikka l66b mingi linuxi ette, ja siis mingid errorid. Ärge pikka viha pidage lihtsalt ei oska midagi teha selles olukorras.
olavsu1
külaline
sõnum 28.09.2011 23:08:10 vasta tsitaadiga
pira plaadiga nagu pole mõtet miskit teha.
aga tegelikult Linux ei ole viga, vägagi pädev häkkeri tööjaama ja serveri opsüsteem.
http://distrowatch.com/ sealt saab tasuta opsüsteemi. kui windowsi eest maksta ei soovi.
ise muretsesin selle karbi https://pood.elion.ee/productInfo/44/microsoft-windows-7-ultimate/GLC-00181
timpser
sõnum 28.09.2011 23:46:39 vasta tsitaadiga
sai ka proovitud originaal plaat, uurisin veidi rahva käest ja huvitaval kokkusattumuselt, oli minu naabril windows 7 home premium plaat, kuid samuti ka see ei t66danud :S! Ei saa aru . Samui panin ka biosis k6ik sammoodin tagsi, ikka ei t66danud.
olavsu1
külaline
sõnum 28.09.2011 23:48:37 vasta tsitaadiga
ilmselt sa ei salvestanud biosis vajalikke seadeid. et CD pealt boodiks.
timpser
sõnum 28.09.2011 23:52:58 vasta tsitaadiga
f10 salvestab ju ? väheamlt kusis mult kas tahan salvestada,
vastasin jah
olavsu1
külaline
sõnum 29.09.2011 01:01:18 vasta tsitaadiga
proovi mälupulgalt installi. on endalgi haru harva juhtunud seda, et plaat ei boodi ja kõik
http://landfield.pri.ee/Windows_7/Win7_allalaadimine.html
Märt.
Märt.
sõnum 29.09.2011 11:20:06 vasta tsitaadiga
timpser, kui sul on juba peal legaalne Linux, sellega saab tööd väga hästi teha ning paljude fotokate-telefonide jaoks pole mingeid draivereid või lisaprogesid vaja installida-torkad masina taha ja võtad oma asjad välja, simpel.
timpser
sõnum 29.09.2011 23:30:01 vasta tsitaadiga
udusiil kirjutas:
nii, sain windowsi bootima, aga nuud sellin probleem, et l66b ette installmise ajal sellise errori : Windows cannot be installed to disk 0 partition 1.
sõnum 29.09.2011 23:34:39 vasta tsitaadiga
timpser kirjutas:
Ruumipuudus kettal?
timpser
sõnum 30.09.2011 00:25:06 vasta tsitaadiga
tomorrow kirjutas:
timpser kirjutas:
Ruumipuudus kettal?
Nii, kas keegi oskab 6elda mismoodi ma saaksin teada oma emaplaadi tootja nime ,et selle vastavad RAID driver alla t6mmata. Lugesin et serial nr. kaudu peaks teada saama! Mul on BIOSis Serial nr : LXRQ00C02313313FEC1601. BIOS ise on InsydeH2O. Arvuti on Acer Aspire 5755G. No olen uurinud kuid ei suuda kuidgi välja m6elda millised driverid ja kusy downloadida. Kui keegi teab kust ja kuidas ehk saab aidata icon_smile.gif
TNT
TNT
sõnum 30.09.2011 13:28:32 vasta tsitaadiga
timpser kirjutas:
tomorrow kirjutas:
timpser kirjutas:
Ruumipuudus kettal?
Programmike nimegha CPUID näitab ära tavaliselt emaplaadi tootja ja margi
aga driverid saab ikka kodukalt http://www.acer.co.uk/ac/en/GB/content/drivers
Hell Was Full So I Came Back !
viimati muutis TNT 30.09.2011 13:37:34, muudetud 1 kord
siinus
siinus
sõnum 30.09.2011 13:35:12 vasta tsitaadiga
cpuid töötab windowsil.
Nagu mina aru saan, tuleb antud masinale windowsi installimiseks raid draiverid saada.
vist
suck less | no slop grenade
LiivaneLord
Sõpradele "Olavi"
sõnum 30.09.2011 14:19:56 vasta tsitaadiga
djpvx, Miks neid raidi draivereid tarvis on? BIOSis on IDE modeks valitud RAID?
siinus
siinus
sõnum 30.09.2011 14:27:24 vasta tsitaadiga
LiivaneLord, vat ei oska teise inimese masinast midagi kosta.
2 trini
2 trini
sõnum 30.09.2011 14:38:05 vasta tsitaadiga
Seal algselt oli linux ,nagu aru saan. Kas see linuxi partitsioon sai üldse kustutatud ning uus tehtud?
water
sõnum 30.09.2011 16:29:25 vasta tsitaadiga
Kui on ostetud poest w7 plaat koos litsentsiga, kas seda saab siis ainult ühel arvutil kasutada, või saab ka teistele arvutitele installida ?
sukelduja
sukelduja
sõnum 30.09.2011 16:33:27 vasta tsitaadiga
water kirjutas:
Ainult ühel.
LiivaneLord
Sõpradele "Olavi"
sõnum 30.09.2011 17:07:21 vasta tsitaadiga
Ainult ühel korraga*
Märt.
Märt.
sõnum 01.10.2011 11:29:26 vasta tsitaadiga
Sõltub ju ostetud litsentsi tüübist. Aga kodukasutaja tüüpiliselt saab jah ühe masina litsentsi.
Miki-Hiir
sõnum 01.10.2011 11:56:02 vasta tsitaadiga
Kui on ostetud "Family Pack", siis saab kolmele masinale, tavaversiooni saab jah ainult ühele.
Tener
sõnum 02.10.2011 18:22:22 vasta tsitaadiga
Ei teagi nüüd, kas probleem mängu või windowsiga, aga mul on taskbar paremal pool ekraani ja muudetud suurusega (laiem nagu) ja alati esimene kord COD4 mängides alt-tab aknaid vahetan, läheb suurus tagasi kõige väiksemaks peenikeseks ribaks.
Lock peal või mitte, ei aita.
Milles võib probleem olla?
sõnum 02.10.2011 20:42:18 vasta tsitaadiga
udusiil kirjutas:
ot:
Milline see pira linux on?
Märt.
Märt.
sõnum 03.10.2011 07:34:34 vasta tsitaadiga
salatoimik, vastukaaluks täiesti ilmsele katsele peale lasta pira-Windows 7 Linuxi asemele. Naljakas oli see, et väidetavalt ostis ta "softita" ehk tühja arvuti.
siinus
siinus
sõnum 03.10.2011 08:30:31 vasta tsitaadiga
salatoimik, on ju ka litsenseeritavaid linuxi distrosid. rhel näiteks
olavsu1
külaline
sõnum 03.10.2011 19:43:56 vasta tsitaadiga
salatoimik, ilma maksmata Mandriva Powerback'i kasutamine näiteks.
pirnikas
sõnum 03.10.2011 22:58:32 vasta tsitaadiga
Küsimus järgmine : kui kustutan file ära siis prügikasti ei lähe vaid file lihtsalt kadunud.Dont move files to recycle bin sinna pole linnukest ette pandud.
sõnum 03.10.2011 23:20:10 vasta tsitaadiga
pirnikas kirjutas:
SHIFT klahv kinni kiilunud vms.Vb ka prügikast katki läinud, mis juhul tuleks kustutada see ja lasta süsteemil uus teha.
Süsteemikettal %SystemDrive%\$Recycle.Bin ja mujal vastavalt D:\$Recycle.Bin & E:\$Recycle.Bin jne.
Lisaks see varjatud aga võid lubada peidetud failide näitamise, et prügikaste näha.
mhei
mhei
sõnum 04.10.2011 18:41:45 vasta tsitaadiga
mul mingi jama tekkinud, igakord kui läppari sisse lükitan on mingid suvad otseteed töölauale ilmunud... iga päev on need erinevad
LiivaneLord
Sõpradele "Olavi"
sõnum 04.10.2011 19:07:23 vasta tsitaadiga
mhei, viirusetõrjega vaja teha full skann, malwarebytesiga ka. Kui need ei leia midagi, siis superantispyware, asquared vms.
uus teema   vasta Hinnavaatlus »  Microsoft »  Windows 7 (arutelu ja probleemid) mine lehele eelmine  1, 2, 3 ... 287, 288, 289 ... 372, 373, 374  järgmine
