ewur
26.09.2011 19:49:25
| Kuna läpakas on SSD, siis lülitasin Prefetch`i (registrist) kui ka Superfetch`i (registrist ja service.msc-st) välja. Mõne aja pärast on Superfetch aga registris ("value" on "3") ja service.msc-s jälle "enabletud". Ja kuigi Prefetch´i "value" on registris "0", aga raibe ikka kirjutab oma andmeid Windows/Prefetch kataloogi. Milles asi?
friik1
26.09.2011 20:41:23
| Miks seda prefetchi ja superfetchi kinni üritatakse panna... RAM on ju veel paar suurusjärku kiirem kui SSD...?
LiivaneLord
Sõpradele "Olavi"
26.09.2011 21:22:52
Kas superfetch ei salvesta mitte andmed kettale, et neid sealt kiiresti rammi laadida?
Loogiliselt on superfetch mittevajalik, kuna rakendused laevad ennast piisavalt kiiresti. Jääb lihtsalt nende failide kirjutamine ära.
26.09.2011 21:26:28
Will Superfetch be disabled on SSDs?
Yes, for most systems with SSDs.
If the system disk is an SSD, and the SSD performs adequately on random reads and doesn’t have glaring performance issues with random writes or flushes, then Superfetch, boot prefetching, application launch prefetching, ReadyBoost and ReadDrive will all be disabled.
Initially, we had configured all of these features to be off on all SSDs, but we encountered sizable performance regressions on some systems. In root causing those regressions, we found that some first generation SSDs had severe enough random write and flush problems that ultimately lead to disk reads being blocked for long periods of time. With Superfetch and other prefetching re-enabled, performance on key scenarios was markedly improved. |
Ja pange omale ükskord järjehoidjaks: http://blogs.msdn.com/b/e7/archive/2009/05/05/support-and-q-a-for-solid-state-drives-and.aspx
LiivaneLord
Sõpradele "Olavi"
26.09.2011 21:47:26
tomorrow, ei ole põhjust, kuna Superfetch millegipärast minu SSD-ga süsteemil töötab.
Kuidas kogu see jada ühekorraga ära keelata?
LiivaneLord
Sõpradele "Olavi"
26.09.2011 21:58:29
Ja tead sa mõnda sellist või hakkan guugeldama?
ewur
26.09.2011 22:21:26
| tomorrow kirjutas: |
Sa vist ei viitsinud profiilist vaadata, aga tegemist on M4-ga, mis saab WEI 7,9...
Ja nagu sa lugesid, siis - "Osad asjadel peab teenused peatama ja osadel registrit muutma" ei aidanud.
mazdagti
27.09.2011 05:55:04
| tahanteada kirjutas: |
mazdagti: Nii, kui kivi on kuum, loll - või ei anna enam emaplaadile õiget informatsiooni, siis peabki ju emaplaat Sulle teada andma, et videoga on mingid jamad majas.
Ja kui maha jahtub või kui temperatuur on teatud piires, siis asi töötab, kui temperatuur kõrgemaks läheb, siis on veateade ekraanil.
Võid ju teha lihtsa katse, lase originaaldraiverid maha ja jäta ainult Windowsi Plug-and-play draiver, pilt on küll kehvake, aga võrdluse saad, et kas siis ka pilt kinni lendab või mitte. |
Kas ka siis on põhjuseks kivi kui esimese 5 mintsa jooksul lööb 4x driver error ja siis ei juhtu pea 2 tunni jooksul miskit? Naise arvutil on ajaga see probleem näiteks kadunud, minu omal win aga 4 kuud vähem peal olnud!
_________________ No ikka täitsa kagu nukas!
FB Volvokodu, diagnostikaabi Võrumaal. |
27.09.2011 07:48:17
mazdagti: Nägin, muide, suht-koht hiljuti alles jälle samasugust pilti, kus jaheda videokivi korral oli kõik OK, kuid kuuma videokivi korral hakkas läppar kirju ekraanile loopima, et "videodraiveri" jama. Ja mingi aeg hiljem, oli asi lõplikult pime.
- vist müüdi osadeks maha, ei hakatud "ahjuga jändama".
Nii, et video ülekuumenemisega saab kaasneda mitmeid valesid käitumisi, sai just lauaarvutiks kokku laotud üks taoline Compaqi 6400 seeria läpp, millel enam sees pilti pole, välisega veel on ja siis oli ka hästi näha, kuidas video enam suuremat koormamist välja ei kannatanud - nii, kui kuum, siis "lõi ekraanipildile müralained" sisse.
Ning asi on isegi nii piiri peal, et kuidagimoodi suudab töötada XP-ga, kuid suurema, näiteks, Windows 7 videokoormuse juures, "lainetab" pilt juba üsna kiiresti.
olavsu1
külaline
28.09.2011 01:56:04
Kust kohast saab igaveseks ära muuta selle, mis infoveergusid failibrauser näitab kindla failitüübi puhul?
ma tahan .mid failde puhul kuvatavaid veergusid ära muuta. hetkel kuvatakse peale faili nime täiesti ebavajalikke veergusid ja vajalikku veergu (faili maht) ei kuvatagi.
ja kust võtab Windows selle tarkuse, et .mid on muusikafail? mid on noodifail, mitte muusika.
28.09.2011 04:12:53
| olavsu1 kirjutas: |
ja kust võtab Windows selle tarkuse, et .mid on muusikafail? mid on noodifail, mitte muusika. |
Win7 ei oska veergusid kohandada vastavalt failitüübile.On üldised kategooriad mille aluses veerud paika pannakse ja see sõltub sellest mis failid antud kaustas enamuses on.
.mid fail loetakse jah muusikafailiks ja minuarust on see ka normaalne.Antud juhul kohandatakse sellele siis vastavalt Music veeru sätted.
Kuigi eks see contenti autodetect on kah vahel kalane ja ei tuvasta korrektselt mida antud kaust kõige rohkem sisaldab
Mind näiteks häirib, et muusikakaustas ei näidata vaikimisi Bit rate veergu.
LiivaneLord
Sõpradele "Olavi"
28.09.2011 08:19:29
tomorrow, bitikiirus ehk bit rate on ju olemas.
LiivaneLord
Sõpradele "Olavi"
28.09.2011 08:34:41
Seda küll. Tavakasutajale pole bitikiirust ju vaja.
olavsu1
külaline
28.09.2011 10:58:42
| siis peaks saama kord paika pandud asetust salvestada.
olavsu1
külaline
28.09.2011 21:14:55
tomorrow, tänud vihje eest aga vihje oli metsa...
õige koht on järgnev
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\FolderTypes
otsisin sealt muusikakausta kohta käiva kirjelduse, mis minul järgnev
| HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\FolderTypes\{94d6ddcc-4a68-4175-a374-bd584a510b78}\TopViews\{00000000-0000-0000-0000-000000000000} |
ja muutsin veeruloendis soovitud veerude nimed aktiivseks, veerunimes "1System.Size;" sai number "1" asendatud numbriga "0". Soovitud veerg ilmuski nähtavale ja on kogu aeg näha.
see oli kirve meetod.
õigem oleks eraldada .mid .midi .kar failitüübid muusikafailidest. luua neile uued failitüübid.
.mid, .midi - SheetMusic
.kar - SheetMusicWithWords // sama mis midi, kuid on lisatud sõnade rada või mõnele rajale on lisatud sõnade kiht.
lõpuks siis neile omaette kaustatüübid....
timpser
28.09.2011 22:25:21
| tere, mul sellline mure, et ostsin flex sulearvuti poest endale sellise arvuti http://flex.ee/3776-Acer-Aspire-5755G aga see oli ilma tarkvarata. Okei m6tleisn et t6mban alla windowsi 7 ja lasen plaadile, tegin k6ik internetis antud juhitelele. Plaat valmis panin arvutisse ja arvuti t66le, aga jamh, tuli mingi jama ette, mingi linux booting. lugesin, nats internetist ja noh, siis 6eldi et peaksid panema biosis endale cd romi esimeseks bootijaks. tegin ka seda, vähemalt arvan et tegin, juhste järgi peaks toimima, aga ikka l66b mingi linuxi ette, ja siis mingid errorid. Ärge pikka viha pidage lihtsalt ei oska midagi teha selles olukorras.
olavsu1
külaline
timpser
28.09.2011 23:46:39
| sai ka proovitud originaal plaat, uurisin veidi rahva käest ja huvitaval kokkusattumuselt, oli minu naabril windows 7 home premium plaat, kuid samuti ka see ei t66danud :S! Ei saa aru . Samui panin ka biosis k6ik sammoodin tagsi, ikka ei t66danud.
olavsu1
külaline
28.09.2011 23:48:37
| ilmselt sa ei salvestanud biosis vajalikke seadeid. et CD pealt boodiks.
