| Kas kavatsed osta D3: Reaper of Souls expansioni? |
| Jah |
52% |
[ 171 ] |
| Ei |
47% |
[ 154 ] |
| hääli kokku : 325 |
23.09.2011 10:47:30
You can’t pause. In fact, in most ways, the game acts like an MMO. For instance, quit it, and you’re given the optional cooldown to have your player clear the server properly. But it’s not an MMO. It’s not even close to an MMO. So when I’m playing the single-player game, and I’m in the middle of a frenzied mob, and there’s a knock at the front door, there’s nothing I can do. As happened to me yesterday. Twice. On another occasion I was surprised by a phone call that led to my having to do some other things. I’d safely left my character in a cleared area, but long between checkpoints. When I came back to the PC, I’d been idle for too long and the game had logged me out.
I’d been logged out of a single-player game because I was away for an hour. And thus lost all my progress (although not my items and stats) since the last checkpoint, a long, long way back. |
_________________ - londiste
viimati muutis londiste 23.09.2011 10:48:21, muudetud 1 kord |
217 |
Kristoferr
23.09.2011 10:48:20
| sukelduja kirjutas: |
Nojah, kui isegi pausi võimalust pole, siis jääb mäng minu poolt ostmata. Ehk siis mäng tõelistele noliferitele. |
Need väikesed vead saavad beetas parandatud. Ei ole wowis kunagi olnud ületamatuid probleeme seoses internetivajadusega ja ei saa ka diablos olema. Progress salvestatakse blizzi serveritesse.
Suurem osa rahvast on siiski kahe käega praeguse lahenduse poolt. See mõni mäng, mis nüüd müümata jääb (püsivat internetiühendust mitteomavatele huvilistele) ei kaalu üle selle süsteemi plusse.
Mäng tuleb kahtlemata mega hitt.
_________________ Liitu Opencode Go soodsa coding plaaniga ja saa 5€ soodust!
Liitu Wise'ga! |
| Kommentaarid: 267 loe/lisa |
218 |
23.09.2011 10:48:53
Kristoferr, erinevalt wowist ei müüda diablot kui mmorpgd.
217 |
Scart
23.09.2011 10:50:35
| Kristoferr kirjutas: |
| Progress salvestatakse blizzi serveritesse. |
Sa ikka saad aru, kui idiootne on checkpoint süsteem sellises online-only mängus?
101 |
Kristoferr
23.09.2011 10:52:28
| londiste kirjutas: |
| Kristoferr, erinevalt wowist ei müüda diablot kui mmorpgd. |
Mis selle lause point on?
| Scart kirjutas: |
Sa ikka saad aru, kui idiootne on checkpoint süsteem sellises online-only mängus? |
Ma näen ainult 2 inimest kurtmas. Minumeelest on see süsteem täiesti OK.
Liitu Wise'ga! |
218 |
Archangel
23.09.2011 10:54:00
Mis selle lause point on?  |
Point selles, et Diablo peaks olema Single Player mäng koos tugeva Multiplayer toetusega. Ja nii seda ka reklaamitakse. Selle asemel on see täis featureid, mis sobiks pigem MMO-desse.
Ehk sama hästi võiks reklaamida Wow'i kui MMO-d aga eemaldada võimalus teistega mängida.
| Kommentaarid: 25 loe/lisa |
25 |
23.09.2011 10:58:27
Kristoferr, loos toodi välja vähemalt 2 head pointi mis on (vähemalt) singleplayer mängus valesti. sinu vastus sellele on, et kõik on vägev, kõigile meeldib ja sellest tuleb hitt? nagu, really?
217 |
Kristoferr
23.09.2011 11:02:13
"Täis featureid?"
Ei oskagi kommenteerida sellist lollust. Leitakse paar sarnasust WoWiga, või MMOga ja kohe on KÕIK paha.
Saad ikka aru, milleks need muudatused head on?
Sarnast halamist tuleb muidugi erinevates D3 foorumites ette. Enamus nendest halajatest on vaesed pirajad, kes loodavad, et online only süsteem ära muudetakse ja saaks torrentist tõmmatud mängu probleemivabalt offline mängida.
| Kristoferr, loos toodi välja vähemalt 2 head pointi mis on (vähemalt) singleplayer mängus valesti. sinu vastus sellele on, et kõik on vägev, kõigile meeldib ja sellest tuleb hitt? nagu, really? |
Nagu ma ütlesin, siis need pugid saavad beetas parandatud. Juhul, kui välja on vaja logida, siis checkpointid on piisavalt tihedalt, et ei peaks tagasi mängu tulles kaugelt alustama. Interneti ühenduse stabiilsus pole minul mitte kunagi WoWi mängides probleeme põhjustanud.
Kahtlemata on igale muudatusele nii poolt, kui vastuhääli. Ma pole veel ühtki muudatust näinud, mis poleks aksepteeritav, või milles plussid miinuseid üle ei kaaluks. Jälgin aktiivselt ka erinevaid D3 foorumeid. Täpselt samamoodi arvatakse seal. Ei ole näinud ühtki teemat, kus massiliselt millegi vastu ollakse ja põhjused konstruktiivselt välja toodaks. Kõik vingumise teemad/postitused on siiani olnud mingi vello isiklik frustratsioon, mis erilist poolehoidu ei saavuta.
Liitu Wise'ga!
viimati muutis Kristoferr 23.09.2011 11:11:20, muudetud 1 kord |
218 |
Ho Ho
23.09.2011 11:07:26
Pausi puudumine on ainus nurin minu poolt. Arvestades et netivaba olukorda praktiliselt pole siis muud probleemid on d2's täpselt samad.
| Scart kirjutas: |
Erinevus D2'ga?
87 |
Scart
23.09.2011 11:13:45
| Ho Ho kirjutas: |
| Erinevus D2'ga? |
10 aastat arengut.
101 |
Kristoferr
218 |
Scart
23.09.2011 11:22:48
Ära lahmi lolluseid vaid too siis välja omapoolne lahendus, mis oleks teostatav ja meeldiks rohkematele, kui praegune variant. |
A) Sa ei saa timeouti single-player mängust, issand jumal. Kui ma tahan, siis pausin või idlen kasvõi ööpäev, see on minu mäng. See on SP mäng. Oma achievementid ja lipud võib Blizz endale perse pista.
B) Kui nett käib maha, ei saa sa mitte automaatselt DC, vaid mäng pausib määramata ajaks kuni saad neti uuesti tagasi.
C) Sul on iga hetk võimalik mängu pausida. RL, you know.
101 |
sukelduja
23.09.2011 11:23:04
Mine õige kuupeale on vaese piramise jutuga. Mul on esimene Diablo ( ja kõik järgmised ja lisapakid ka) ostetud ja praktiliselt kohe peale väljatulekut. Sellel ajal oli 99% eestis liikuvates arvutimängudest puhta piraat ja nii mõnigi siinsetest kasutajates ei osanud veel lugedagi. Aga mida mul pole on see aeg, et ma ma tundide kaupa ainult mängin ja midagi muud ei tee. Selleks et pidevalt niimoodi istuda peab olema tõeline nolifer - pole tööd, pole kooli, pole peret, pole RL sõpru.
25 |
Ho Ho
23.09.2011 11:25:46
| Scart kirjutas: |
| Ho Ho kirjutas: |
| Erinevus D2'ga? |
10 aastat arengut. |
Pigem oli mu point selles, et ka D2 sp's pidid taas läbi mobi hordide murdma kui suvatsesid mängu sulgeda.
87 |
Archangel
23.09.2011 11:26:53
Nii on. Ma teen arvuti taga tööd ja tavaliselt mingi mäng on taustal lahti pausi peal. Kui tekib vaba aega siis klõbistan rahulikult windowed modes. Hui mul on vaja sellist jama, et ta disconnectib mind lampi kuna pole mingi tund aega midagi näppinud seal. Või, et üldse pausigi peale panna ei saa... WTF?
Nett kõigub mul ka paar korda päevas. Et siis pean leppima sellega, et paar korda päevas kaotan oma progressi mängus? Sounds like fun.
Ja ärge tulge väitma, et osta parem nett. Kõigil nett vahest kõigub ning see ei sõltu sinu "riistvarast" vaid pigem ISP-st, ning seda juhtub. Miks ma peaksin oma ostetud mängust sellepärast ilma jääma? Ei mõista...
25 |
Miki-Hiir
23.09.2011 11:27:50
| Pausi puudumine on tõepoolest nõme. Online multiplayer mängu puhul on see sama nõme aga arusaadav, single player mängu puhul ma pausi puudumisest aru ei saa.
| Kommentaarid: 46 loe/lisa |
43 |
Kristoferr
23.09.2011 11:30:23
Checkpointist checkpointi minemine ei võta tunde. Halvimal juhul on see maksimum 5 minutit. NPCdest võimalik hoiduda ka keset kaarti. Selleks ei pea tingimata mängu pausile panema.
Kui sa seda 5 minutit leida ei suuda, siis tõesti, see mäng pole sinu jaoks.
Liitu Wise'ga!
viimati muutis Kristoferr 23.09.2011 11:32:45, muudetud 1 kord |
218 |
Zust
23.09.2011 11:31:40
| Küll sellele mängule mingi offline crack tehakse... (see ei tähenda kohe piraatlust). Nagu on ka alterIW poolt tehtud modern warfare 2'le dedicated serverid, et inimesed saaks normaalselt mängida.
Scart
23.09.2011 11:56:58
Kui sa seda 5 minutit leida ei suuda, siis tõesti, see mäng pole sinu jaoks. |
Aitäh, et sina oled see, kes teab mis mulle on parem.
101 |
Killer85
23.09.2011 12:06:01
Kulla rahajõmm kristoferr, kui sa juba statistikat teed, siis pane mind ka kirja - pole "vaene piraja", ent mullegi ei meeldi always-online nõue.
| Kommentaarid: 69 loe/lisa |
67 |
Kristoferr
23.09.2011 12:10:39
Pole mõtet lahmida. Sinu nime pole kuskil mainitud. "Enamus" ei tähenda "kõik".
PS. "Vaene" ei tähendanud siinkohal rikka vastandit. Kõik ei ole alati mustvalge.
Scart, ära võta isiklikult. See ei olnud sinule mõeldud tekst. Mind ausalt ei huvita, kas sa jätad nende "vigade" pärast nüüd mängu ostmata või mitte.
Liitu Wise'ga!
viimati muutis Kristoferr 23.09.2011 12:15:14, muudetud 1 kord |
218 |
Villemk2
23.09.2011 12:10:50
keegi küsitlust ei viitsi teha?
121 |
karmo29
23.09.2011 12:31:42
olgu offline või online, paus või pausita
mängu ostan ikkagi.
_________________ Rincewindil käis elu nii tihti silme eest läbi, et ta võis juba igavamate kohtade peal tukastada
Rincewindi maahirm, mis tabab teda kõrgustes - maa on see, mis sind lõpuks tapab
Dropbox |
| Kommentaarid: 29 loe/lisa |
25 |
Redikate
23.09.2011 14:10:36
Nii see on....
_________________ http://nodejs.org/
"I'm also a person. Programming is just one thing I do." |
| Kommentaarid: 34 loe/lisa |
33 |
HDTanel
Overclocker
23.09.2011 15:15:05
See DRM asi on ikka lauslolluse tipp... Üks asi on osta mänge downloaditavana, kui programm pankrotti läheb või ajamöödudes lihtsalt välja sureb siis jääd oma kõikidest mängudest ilma. Diablo III puhul kui serverid lõpuks töötamast lakkavad (eluaeg nad ju ei käi) siis oled mängust ilma.
Siin aga tulebki loota kõige parematele inimestele maailmas! CRACKERITELE!
Suht idiootseks on kõik tehtud ma ütlen, nii või naa crackitakse mäng ära, mispärast peab inimene, kes ostab ausalt mängu nüüd kannatama sellepärast??
Miks ei või olla nii nagu vanasti? Tavaline CD key ja plaadi olemasolek.
Minuarust kõige ideaalsem oleks lihtsalt CDkey teha ja kui mäng installitud siis pole disci ka vaja.
Muidugi veel idiootsem on see, et ostad mängu ja saad 5x installida ainult või noh sama windowsi peale vähemalt.
_________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel |
496 |
Ho Ho
23.09.2011 15:42:34
| PlatoonSgtElias kirjutas: |
| See DRM asi on ikka lauslolluse tipp... Üks asi on osta mänge downloaditavana, kui programm pankrotti läheb või ajamöödudes lihtsalt välja sureb siis jääd oma kõikidest mängudest ilma. Diablo III puhul kui serverid lõpuks töötamast lakkavad (eluaeg nad ju ei käi) siis oled mängust ilma. |
Kas mõni blizzi mäng on lõpetanud töö kuna servereid ei hoita töös? Kas on lootust/kartust näha blizzi pankroti kus nad on mängumaailma vaieldamatud liidrid kokku aetava papi hulga juures?
| Siin aga tulebki loota kõige parematele inimestele maailmas! CRACKERITELE! |
Saame näha, mina isiklikult väga ei usu et suudetakse asjalikku offline-modet pakkuda D3'le kuid eks saame näha.
87 |
lepkai
23.09.2011 15:58:47
kui juba praegu saab niisama demos ringijoosta siis mina usun küll et saame D3 ka ilma DRM mängida
| Kommentaarid: 9 loe/lisa |
9 |
Archangel
23.09.2011 16:00:17
Eks mängu ostan ma ikka ära, liialt kaua oodatud. Aga loodan südamest, et vähemalt selline kaitse on tõesti peal, et kui korraks neti ära lööb siis ei viska kohe mängust välja vaid paneb vähemalt pausi peale või midagi. Hoiab nö. sessiooni elus ja pärast kui ühendus tagasi tuleb siis teeb oma vajalikult kontrollid ära "authenticate" vms ning saab ilusti edasi mängida.
Aga eks näeb. Küll jõuab tulevikus nutta küll ja küll
25 |
Ho Ho
23.09.2011 16:00:39
Ringi saab joosta aga kas mobid ka miskit teevad ning kuidas on lood questidega?
87 |
HDTanel
Overclocker
23.09.2011 16:04:40
Archangel, see on ju idiootne, et internet peab kindlasti taga olema... Umbes nagu käsivad sul maksta kuutasu mängimise eest.
496 |
Cyberlord
23.09.2011 16:09:32
Tuleks juba see mäng ometi välja - siis saaksite kõik oma jonnimise jätta ning suures mängutuhinas oleksid igasugused pseudomured ununenud.
/me ootab kannatlikult ja ei arva midagi ennem kui pole valmis toodet proovida saanud.
| Kommentaarid: 546 loe/lisa |
449 |
Archangel
23.09.2011 16:09:46
| Archangel, see on ju idiootne, et internet peab kindlasti taga olema... Umbes nagu käsivad sul maksta kuutasu mängimise eest. |
Idiootne muidugi. Aga seni kuni mäng on hea siis ma elan kuidagi selle üle - seni kuni vähemalt mingi süsteem on paigas, mis ei sunni mind uuesti mängu käivitama iga kord, kui nett korraks vilgub. Siis on ikka väga jama.
25 |
Player1
23.09.2011 16:25:01
| Oskab keegi sellest DRM-ist lähemalt rääkida: mis juhtub, kui näiteks panen mängu tööle ja mingi moment lülitan lihtsalt ruuteri välja, kas mäng katkeb hetkega või see DRM kontroll käib iga teatud aja tagant? Jutt käib siis üksikmängu kohta.
| Kommentaarid: 40 loe/lisa |
38 |
Kristoferr
218 |
23.09.2011 16:40:06
põhimõtteliselt samamoodi nagu d2 bneti mängus.
sealsamas viimati viidatud loos vist oli see kirjas - alguses hakkad mingeid anomaaliadi nägema a la lased nooli aga need kohale ei jõua jms ning sutsu aja pärast kukub ära.
217 |
sten260
23.09.2011 18:08:04
et siis 2012..
Archangel
23.09.2011 18:55:15
| No sellega seoses loodan ma seda, et Beta-st tuli niivõrd palju asjalikku vastukaja, et mõned suuremad probleemid tehakse ümber. Loodetavasti.
25 |
s4nder
23.09.2011 19:11:19
| Nüüd on kodukal saadaval ka itemisüsteemi ülevaade koos näiteks kõigi legendary itemitega. Natuke lahja tundub valik, arvestades, et kogu mäng on sellele üles ehitatud. Parimad legendaryd mängus annavad ikkagi sisuliselt ainult +stats nagu MMO-des. Nime vaatamata neil vahet ei tee.
| Kommentaarid: 8 loe/lisa |
HDTanel
Overclocker
23.09.2011 20:54:36
Archangel, Mõne kuuga ei tehta midagi, väike tweaking elude, dammi suhtes, mõni aken muudetakse võibolla ka ära.
496 |
Kristoferr
218 |
Rasvane
24.09.2011 00:25:07
| Electrocute späm?
| Kommentaarid: 13 loe/lisa |
Killer85
24.09.2011 00:34:51
| Eks see itemite balanseerimine on üks viimaseid arendusetappe. Selle pärast ma küll väga ei muretseks.
67 |
recent
24.09.2011 03:51:52
No ega siin muud, kui tuleb hambaid krigistada ja oodata.
Ise loodan et saan mängu GEFORCE LAN 6'el näppida... nimelt toimub usas, San Francisco külje all, Alamedas USS Hornet, ehk lennukikandjal suur Lan.
Mis õnneks asub minust ~15 km kaugusel, vast pea igapäev möödun sellest
Ostsin just pileti ära ning olen päris elevil. asi toimub 14-16 Okt. hakatakse seal kindlasti uut Call of Dudyt ja Battlefieldi laduma niiet maa on must.
Ja samas loodan ise palju näha, kahjuks ei lähe ise kohale oma arvutiga kuna pole aega olnud harjutada ning ka kõiki uuemaid mänge osta.
Ise loodan, et väike nurgake on tehtud ka Diablo 3'me jaoks, kus saaks järjekorras seista ja Beta't taguda,
kuna tavaliselt sellistel üritustel on ka väiksed Beta nurgad.
muu info @ http://www.geforce.com/landingpage/geforce-lan
| Kommentaarid: 43 loe/lisa |
41 |
noonius
24.09.2011 16:37:16
kas blizzcon pole mitte nädal hiljem? vaevalt, et blizzard suurte jõududega sinna kohale ronib, kui enda oma ukse ees.
Mingi paks pihv paugub siin
recent
24.09.2011 20:25:10
| Taavi© kirjutas: |
Ati kaardiga lähed siis tehtakse kambakas  |
Kohe registreerimisel oli küsimus, et mis ja mitut GPU'd kasutan, ikka GTX'i !
41 |
vutt
25.09.2011 11:20:14
Lugedes neid alalise Interneti ühenduse vajaduse teemalisi poste siin - leidsin ühe disconnecti näite: http://www.youtube.com/watch?v=eapqzT5cNcU&t=13m47s
Loomulikult tegemist on hetkel veel betaga seega võib mängu käitumine lõpp versioonis muutuda.
| Kommentaarid: 7 loe/lisa |
recent
26.09.2011 04:23:19
Eks kindlasti saab olema disconnecte, loodetavasti neid väga tihti ei juhtu.
100% solid mäng pole minuteada ükski.
41 |
Redikate
26.09.2011 07:15:18
Kuidas selle BETA'ga lood on? Keegi siit key saanud? On teada palju keysid jagatakse / jagatud on jne?
33 |
heretic666
| Kommentaarid: 73 loe/lisa |
minake
26.09.2011 18:21:08
kui offline m2ngida ei saa siis j22b see m2ng ka ostmata minupoolt, tahan m2ngu m2ngida offline ja mitte online, kui tekib soovi siis m2ngix online, a mitte nii, et see on kohustus...
v2ga hea kommentaar sealt lingilt mis siin ennem jagati selle online DRM-i kohta:
Now…..not pausing? Really? That’s the worst thing they could have added. It’s like I’m being given the choice, would I like to play Diablo 3, or have a functioning life? That’s really how I see it, Diablo or hemit.
I have to answer my phone some times. I enjoy grabbing gasps of gaming while I cook food. I have my fiancee come speak to me while playing games all the freaking time. I often enjoy going to the bathroom WHEN I WANT TO. Do I want to have to clear this entire freaking mob before I go for a dump? No, I wouldn’t, and yes, I’m above wearing a diaper. |
| Kommentaarid: 164 loe/lisa |
137 |
