26.08.2011 11:14:51
deus ex: human revolution update released (steam)
This latest patch addresses:
- A frequent issue for AMD/ATI hardware users that can cause the game to crash on startup.
- Improvements to loading speed. The speed increase depends on machine spec and settings, but loading time improvements of over 50% have been measured on some machines.
- Some control fixes:
- Diagonal movement is no longer faster as intended.
- Adjustments have been made to mouse sensitivity in response to user feedback.
- Mouse sensitivity for X and Y axis can still be configured separately, but is now consistent when set to default settings.
- The range of settings for mouse sensitivity has been adjusted to provide for more accurate adjusting.
- The default mouse sensitivity has been altered to be somewhat less sensitive. |
_________________ - londiste
217 |
AIQ88
26.08.2011 12:12:11
| Mis on parim koht mängu ostmiseks netist? Steami hind pole parim ja kohalikus GAMEis polnud olemas...
26.08.2011 12:40:49
g2play
edit:
hmm, neil on hind üle 30€ tõusnud.
217 |
delef
26.08.2011 12:49:15
| Kas see on hea mõte, kui võtta sõbraga või mõnega siin foorumist 2 peale üks pela?
125 |
26.08.2011 12:59:00
delef, mäng seotakse steami accountiga.
217 |
Voyage
26.08.2011 13:00:28
| küsin uuesti, kas keegi on ostnud sellelt vene sitelt mis eelmisel lehel mainiti?
| Kommentaarid: 826 loe/lisa |
655 |
eShelobik
26.08.2011 13:29:15
| Voyage kirjutas: |
| küsin uuesti, kas keegi on ostnud sellelt vene sitelt mis eelmisel lehel mainiti? |
vaevalt, vene key'dega on steamis erinevatel mängudel piisavalt suured ikaldused, et ei hakka isegi riskima mitte.
| Kommentaarid: 295 loe/lisa |
262 |
madfury
26.08.2011 13:36:16
Olen kah enda augmented editioni lahti pakkinud, soundtrack on ikka kõva .
_________________ Avatar by Flacko |
| Kommentaarid: 28 loe/lisa |
28 |
XeStAiSy
Aeg Maha 2a
26.08.2011 13:41:05
Siin on savegame nagu vanasti ja algad esimesel missioonil kus on kõik lahti ja kasutatud full augs. Ehk algad super võimuga. Hiljem pole vaja Praxist kasutada kuna kõik juba kasutadud full.
Mina ei vastuta kui te tööle ei saa. Vanasti saadi ja ka nüüd tomorrow postitust ühte lugege. Kasutatud sama trikki.
Ma ei tea kas kõike faile läheb vaja.
| Kommentaarid: 12 loe/lisa |
sukelduja
26.08.2011 13:58:30
| Margus kirjutas: |
Ma ei tea kas kõike faile läheb vaja. |
See ju rikub kogu lõbu ära.
| Kommentaarid: 25 loe/lisa |
25 |
heretic666
26.08.2011 14:46:26
| Ise olen hiilija, kes vastaseid uimaseks maha koksab, meeldib just nõndaviisi kõige enam. Päris 100% nähtamatuks vastastele jääda ilma sõrmeotsaga puudutamata ka ei meeldi, selja tagant teadvusekaotusse viia on parem variant.
| Kommentaarid: 73 loe/lisa |
XeStAiSy
Aeg Maha 2a
26.08.2011 15:19:03
| sukelduja kirjutas: |
| Margus kirjutas: |
See ju rikub kogu lõbu ära. |
Mulle küll meeldib. Kohe powaga õppima urkaid.
Slazenger
26.08.2011 16:55:14
Kuidas ka C2D peal see jookseb, nöuab palju resursse ?
| Kommentaarid: 74 loe/lisa |
69 |
XeStAiSy
Aeg Maha 2a
26.08.2011 18:51:34
| Slazenger kirjutas: |
Kuidas ka C2D peal see jookseb, nöuab palju resursse ?  |
Minu profiili künaga alla 60fps ei kukku. Mul vsyn peal unustasin launcheris 75 panna.
1280x1024 RESO SIIS. Muutsin siis refresrate 75 peale, siis ka seal istub 75fps ees ja ka kordagi pole näinud ,et alla viskaks.
madfury
26.08.2011 19:20:03
Kui Q6600 on küna, siis mina olen Elvis Imelikul kombel jookseb dx11 peal tunduvalt paremini, kui dx9 peal. Minu profiili kast jooksutab kellade-viledega 25x14 ära küll. C2D peaks maa ja ilm olema kui korralik GPU kõrval. 4850 on küll iseenesest päris hää kaart, aga ma arvan, et pigem jääb see takistuseks, kui C2D.
28 |
heretic666
26.08.2011 19:50:59
Varjatuks jäämine on ikka nii aeganõudev et kole sidemissioonid võtavad meeletult palju aega (mis on ka positiivne). Ainult et vahepeal sai uinutamismeetod otsa ja no mis parata, pidi lahingumoonaga natuke nottima.
Mafia
26.08.2011 20:39:22
Supper mäng
_________________ Bawse |
| Kommentaarid: 19 loe/lisa |
17 |
HDTanel
Overclocker
26.08.2011 23:15:42
Eitea kas just super Graafika suht kesine ikka, õnneks objekte on kõvasti, mis teevad maailmad veidi elavamaks. Pelan veidi edasi ehk siis ka muutub arvamus tiba paremuse poole
edit: ei krt mängitavuse poolelt küll ikka vägahea stealth on väga hea, igaljuhul praegu veel
_________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel |
496 |
Cromaclear
| Kommentaarid: 26 loe/lisa |
23 |
Mafia
27.08.2011 00:27:03
Ega seda tulebki stealth-iga mängida. Run n Gun jaoks on teised mängud ning enamus mängu võlust läheb kaduma. Poel juba ammu nii head stealh mängu mänginud
17 |
omgitspins
27.08.2011 04:15:38
| miskipärast ei lase ta mul dx versiooni valida, kaart on 5830
| Kommentaarid: 92 loe/lisa |
madfury
27.08.2011 10:04:13
Kõrgtehnoloogiline kaamera neutraliseerimine:
28 |
zpsy
27.08.2011 10:14:03
vene võtmega laseb ingliskeeles mängida.
saan õhtul lõpuks kah aega ning proovin mängu ära
| Kommentaarid: 825 loe/lisa |
587 |
scarface
27.08.2011 11:30:00
| madfury kirjutas: |
Ega jah kaamerat ennast ei julgeks katsud anii teravad nurgad
| Kommentaarid: 44 loe/lisa |
42 |
XeStAiSy
Aeg Maha 2a
27.08.2011 20:01:03
Julm koht see HIINA vägev ehitis kui taevasse vaadata nagu spaceship. Kondamist on ka seal kõvasti. Inimesi peab ise otsima, haigeks võib joosta seal ringi.
caarel123
28.08.2011 08:55:17
huvitav tundub kll kuid xp võik kiiremini tulla kuid sellest järeldub et mängutunde vist küllaga
enda raaliga jookseb vileb põhjas päris hästi. min fps mis näinud 32 kuid enamjaolt 40-60
pildiilu lootsin kll rohkem dx11 poolt nagu mingi 2010 aasta mängu mängigks
| Kommentaarid: 83 loe/lisa |
74 |
softis
28.08.2011 10:02:40
Hea mäng! 5+
Kahju, et DX11 crashib, pean DX9 peal laskma.
Aga graafika polegi kõige olulisem
| Kommentaarid: 21 loe/lisa |
21 |
angel
28.08.2011 13:40:19
... hm kuidas sul dx11 saab olla kui profiilis olev kaart üle dx10 ei toeta
157 |
angel
28.08.2011 14:01:53
doh jah...
kuid asi ei olnud eriti "kena" välimusega seega peakski jooksma hästi. iseasi palju lisa efekte see dx11 annab.
endal asi veel kusagil euroopa parimas postiteenuses nimega eesti post... tea kas järgmine nädal antakse kätte
157 |
marko
28.08.2011 14:30:15
minu maitsele ka selle aasta parim mäng, proovisin vahepeal sõbra juures kes ostis steamist ja no krt. tunnid jooksid nii märkamatult, et ei saanud arugi enne kui pime väljas. Ammu pole sellist kogemust enam olnud.
Minu isiklik on ka veel EP kanaalides kinni kuskil. Loodetavasti järgmise nädala alguses saab kätte.
| Kommentaarid: 178 loe/lisa |
161 |
Helbeke
| Kommentaarid: 16 loe/lisa |
Voyage
28.08.2011 15:34:46
mina kahjuks koperdanud ka ühe bugi otsa juba nimelt Q:Cloak & Daggers on üks mees mapist välja lennanud ja tänu sellele q lõpetada ei saa
655 |
HDTanel
Overclocker
28.08.2011 16:56:38
tomorrow, peale LA Noire pelamist tunduvad selle mängu karakterite animatsioonid ikka KOHUTAVAD. Mõndadel võib isegi vist esimese Deus Exiga seda võrrelda
Muidu endale ei meeldi, et häkkimisel need special proged nii ligidal on teistele, pidevalt vajutan speciali peale ja peab sellepärast uuesti alustama
Quicksave ja Quickloadi puudumine on suht idiootne. Redelitel peab alati ronima kui pole just üht augmentationit. Prügikasti kõrguselt võid surnuks kukkuda ma ei tea.. ja noh, hääled on samad enamustel (keegi kes crysise neegrile häält vist tegi) ning kohati suu ei liigu kui juttu räägitakse
496 |
heretic666
28.08.2011 16:58:24
Kuulge härra, F5 ja F8 pole proovinud ?
28.08.2011 17:02:43
| PlatoonSgtElias kirjutas: |
| Muidu endale ei meeldi, et häkkimisel need special proged nii ligidal on teistele, pidevalt vajutan speciali peale ja peab sellepärast uuesti alustama |
Kusjuures betas oli mul see probleem aga lõppmängus pole kordagi juhtunud
Võibolla patch kah aitas nüüd.Küll aga olen vahel kogemata koodilugejasse vale koodi pannud.
HDTanel
Overclocker
28.08.2011 17:08:04
heretic666, hmm, ei teagi, F6 ja F10 proovisin, F1-F4 vaatasin, et olid augmentide jaoks, ei hakanud F5 peale mõtlemagi..
496 |
Mafia
28.08.2011 17:19:40
Mai tea... see mäng on lihtsalt nii hea ,et ei ole sõnu. F5 oli esimene asi mis ma proovsin ja olin üllatunud kui näitas silti Quick Save sest olgem ausad, savemis võimalust igal võimalikult ajahetkel kohtab tänapäeval harva. Kindlalt Witcher 2 kõrvale GOTY kandidaadiks. Mängus olen kohanud nii mitmeidki asju, mis on mind positiivselt üllatanud aga neid ma ette lugema ei hakka, las igaüks avastab ise Üks asi mis veidike häirib on see, et manti pole kuhugi storeda. Oma ruumis, võiks olla mingi kapp kuhu manti pista ikka
Tore, et Eidos/SE tiim end kokku võtsid ja Deus Ex 1-le väärilise järglase tegid, sest pärast seda Invisible War shooter über feili ei olnud enam usku sinna...
17 |
HDTanel
Overclocker
28.08.2011 17:22:29
Mafia, Hetkel mis mind kõigerohkem vist üldse riivab on, et kas tõesti KAKS imepisikest kaarti terve mängu jooksul? Ei taha uskuda... hetkel mingis kolmandas hiina osas või maiteagi aga osad on nooo kohutavalt väikesed, ülimalt mõttetu missioone teha.
496 |
Kaun
28.08.2011 18:17:59
Ma alles oma esimesel playthroughl, aga juba on paar kana kitkuda
aga see vb sellepärast et ma ära hellitatud bioware kvaliteediga
loodan et tuleb DLCid ka sellele... muidu on replayability väga low
_________________ PC: Planetside 2, Warframe
xbox tag: Plat0nius |
angel
28.08.2011 18:46:15
mis kvaliteet seal bioware'il enam alles on? kunagi oli jah über alles aga nüüd on juba mõnda aega veega alla lastud (EA omand). Graafilise poole pealt oli midagi aga siis tuli selline "asi" nagu dragon age 2 mille üle isegi dev'id häbi tundsid. Graafiline kvaliteet oli sellel sitem kui väga vanadel mängudel...
netis lugedes ja uurides pidi replay value just suur olema... mingit DLC lüpsi festi küll sellele mängule ei sooviks...
157 |
Kaun
28.08.2011 18:57:37
Mass effect 1/2 olen läbi mänginud 6 korda. dragon age 1 olen 2 korda, DA2 2 korda.
DA2 pealt olen ma 100% nõus, see oli masendav mis nad tegid sellega
ütleme nii et Deus exi mybe mängin heal juhul 2 korda läbi.
ja kui algse mängu pikkus on piisav, siis pole DLCd ka mingid lüpsmised.
aga jah, see on minu arvamus asjast.
ainuke mäng peale nende mida ma olen suht palju mänginud uuesti, on GTA4.
omgitspins
28.08.2011 19:04:00
| heretic666 kirjutas: |
Kuulge härra, F5 ja F8 pole proovinud ? |
sama hästi võiks küsida mis nupuga lasta saab
MatchMaker
28.08.2011 19:36:08
| Peaaegu läbi, midagi erilist mille üle vinguda pole, aga midagi erilist millega mäng silma paistaks kah mitte. Main story on üsna viisakas, side questid keskpärased. Hiilimine jms = meh.
marko
28.08.2011 19:43:23
Ma olen siiani ka olnud BioWare fanboy, aga peale seda kui nad alates DA1 -st läksid odavate DLC-de teed, et raha kokku riisuda... ja siis überfeil DA2 sinna otsa... krt ma olen tugevalt kahtlema nendes hakanud.
Samas, Eidos Montrealilt ei osanud sellist kvaliteeti oodata, sest nemad tegelikult ikka esimesest Deus Ex-ist väga kauged tegelased. Sellepärast on positiivne üllatus vast isegi suurem. Mis muidugi on suurim pluss (viimase aja trendidele vastuvoolu) on see, et mäng pole mingi odav konsooli port, vaid PC versiooniga on ikka eraldi vaeva nähtud ja see on väga väga hea.
161 |
denis28
28.08.2011 20:45:23
| omgitspins kirjutas: |
sama hästi võiks küsida mis nupuga lasta saab |
minuarust ka, f5 on nagu by default quicksave
| Kommentaarid: 67 loe/lisa |
