26.08.2011 11:14:51
deus ex: human revolution update released (steam)
tsitaat: |
This latest patch addresses:
- A frequent issue for AMD/ATI hardware users that can cause the game to crash on startup.
- Improvements to loading speed. The speed increase depends on machine spec and settings, but loading time improvements of over 50% have been measured on some machines.
- Some control fixes:
- Diagonal movement is no longer faster as intended.
- Adjustments have been made to mouse sensitivity in response to user feedback.
- Mouse sensitivity for X and Y axis can still be configured separately, but is now consistent when set to default settings.
- The range of settings for mouse sensitivity has been adjusted to provide for more accurate adjusting.
- The default mouse sensitivity has been altered to be somewhat less sensitive. |
_________________ - londiste
Kommentaarid: 241 loe/lisa |
215 |
AIQ88
26.08.2011 12:12:11
Mis on parim koht mängu ostmiseks netist? Steami hind pole parim ja kohalikus GAMEis polnud olemas...
26.08.2011 12:40:49
g2play
edit:
hmm, neil on hind üle 30€ tõusnud.
215 |
delef
26.08.2011 12:49:15
Kas see on hea mõte, kui võtta sõbraga või mõnega siin foorumist 2 peale üks pela?
Kommentaarid: 140 loe/lisa |
123 |
26.08.2011 12:59:00
delef, mäng seotakse steami accountiga.
215 |
Voyage
26.08.2011 13:00:28
küsin uuesti, kas keegi on ostnud sellelt vene sitelt mis eelmisel lehel mainiti?
Kommentaarid: 756 loe/lisa |
604 |
eShelobik
26.08.2011 13:29:15
Voyage kirjutas: |
küsin uuesti, kas keegi on ostnud sellelt vene sitelt mis eelmisel lehel mainiti? |
vaevalt, vene key'dega on steamis erinevatel mängudel piisavalt suured ikaldused, et ei hakka isegi riskima mitte.
Kommentaarid: 293 loe/lisa |
260 |
madfury
26.08.2011 13:36:16
Olen kah enda augmented editioni lahti pakkinud, soundtrack on ikka kõva .
_________________ Avatar by Flacko |
Kommentaarid: 26 loe/lisa |
26 |
XeStAiSy
Aeg maha 60
26.08.2011 13:41:05
Siin on savegame nagu vanasti ja algad esimesel missioonil kus on kõik lahti ja kasutatud full augs. Ehk algad super võimuga. Hiljem pole vaja Praxist kasutada kuna kõik juba kasutadud full.
Mina ei vastuta kui te tööle ei saa. Vanasti saadi ja ka nüüd tomorrow postitust ühte lugege. Kasutatud sama trikki.
Ma ei tea kas kõike faile läheb vaja.
Kommentaarid: 12 loe/lisa |
sukelduja
26.08.2011 13:58:30
Margus kirjutas: |
Ma ei tea kas kõike faile läheb vaja. |
See ju rikub kogu lõbu ära.
Kommentaarid: 25 loe/lisa |
25 |
heretic666
26.08.2011 14:46:26
Ise olen hiilija, kes vastaseid uimaseks maha koksab, meeldib just nõndaviisi kõige enam. Päris 100% nähtamatuks vastastele jääda ilma sõrmeotsaga puudutamata ka ei meeldi, selja tagant teadvusekaotusse viia on parem variant.
Kommentaarid: 72 loe/lisa |
XeStAiSy
Aeg maha 60
26.08.2011 15:19:03
sukelduja kirjutas: |
Margus kirjutas: |
See ju rikub kogu lõbu ära. |
Mulle küll meeldib. Kohe powaga õppima urkaid.
Slazenger
26.08.2011 16:55:14
Kuidas ka C2D peal see jookseb, nöuab palju resursse ?
Kommentaarid: 74 loe/lisa |
69 |
XeStAiSy
Aeg maha 60
26.08.2011 18:51:34
Slazenger kirjutas: |
Kuidas ka C2D peal see jookseb, nöuab palju resursse ?  |
Minu profiili künaga alla 60fps ei kukku. Mul vsyn peal unustasin launcheris 75 panna.
1280x1024 RESO SIIS. Muutsin siis refresrate 75 peale, siis ka seal istub 75fps ees ja ka kordagi pole näinud ,et alla viskaks.
madfury
26.08.2011 19:20:03
Kui Q6600 on küna, siis mina olen Elvis Imelikul kombel jookseb dx11 peal tunduvalt paremini, kui dx9 peal. Minu profiili kast jooksutab kellade-viledega 25x14 ära küll. C2D peaks maa ja ilm olema kui korralik GPU kõrval. 4850 on küll iseenesest päris hää kaart, aga ma arvan, et pigem jääb see takistuseks, kui C2D.
26 |
heretic666
26.08.2011 19:50:59
Varjatuks jäämine on ikka nii aeganõudev et kole sidemissioonid võtavad meeletult palju aega (mis on ka positiivne). Ainult et vahepeal sai uinutamismeetod otsa ja no mis parata, pidi lahingumoonaga natuke nottima.
Mafia
26.08.2011 20:39:22
Supper mäng
_________________ Bawse |
Kommentaarid: 19 loe/lisa |
17 |
HDTanel
Overclocker
26.08.2011 23:15:42
Eitea kas just super Graafika suht kesine ikka, õnneks objekte on kõvasti, mis teevad maailmad veidi elavamaks. Pelan veidi edasi ehk siis ka muutub arvamus tiba paremuse poole
edit: ei krt mängitavuse poolelt küll ikka vägahea stealth on väga hea, igaljuhul praegu veel
_________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel |
Kommentaarid: 635 loe/lisa |
496 |
Cromaclear
23 |
Mafia
27.08.2011 00:27:03
Ega seda tulebki stealth-iga mängida. Run n Gun jaoks on teised mängud ning enamus mängu võlust läheb kaduma. Poel juba ammu nii head stealh mängu mänginud
17 |
omgitspins
27.08.2011 04:15:38
miskipärast ei lase ta mul dx versiooni valida, kaart on 5830
27.08.2011 06:14:49
Eile sain mängu kätte.Täna hakkan pelama.Olen terve nädalavahetuse selleks eraldanud.Tõotab vägev tulla
Kommentaarid: 92 loe/lisa |
madfury
27.08.2011 10:04:13
Kõrgtehnoloogiline kaamera neutraliseerimine:
26 |
zpsy
27.08.2011 10:14:03
vene võtmega laseb ingliskeeles mängida.
saan õhtul lõpuks kah aega ning proovin mängu ära
Kommentaarid: 825 loe/lisa |
587 |
scarface
27.08.2011 11:30:00
madfury kirjutas: |
Ega jah kaamerat ennast ei julgeks katsud anii teravad nurgad
Kommentaarid: 43 loe/lisa |
41 |
