uus teema   vasta Tarkvara »  Arvutimängude foorum »  Red Orchestra 2: Heroes of Stalingrad märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3, 4, 5 ... 14, 15, 16  järgmine
Avot
sõnum 15.07.2011 00:23:33 vasta tsitaadiga
uus intervjuu :
http://www.youtube.com/watch?v=mDwPNdQYP5U&feature=youtu.be
Kommentaarid: 3 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 1
KrisVr
sõnum 21.07.2011 20:20:00 vasta tsitaadiga
Box art
http://media.pcgamer.com/files/2011/07/RO2_DisplayBox_West_PR.jpg
System specs
Kommentaarid: 30 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 27
invension
invension
sõnum 24.07.2011 09:22:20 vasta tsitaadiga
Taustapilte!
http://www.heroesofstalingrad.com/ro2media/
Liitu vabalt siit: Coinbase / Binance
Kommentaarid: 10 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 9
Avot
sõnum 25.07.2011 09:41:45 vasta tsitaadiga
Siin päris huvitav vöimalus testida kas arvutil on kiirust piisavalt eri mängude puhul:
http://www.systemrequirementslab.com/cyri/
LightsabeR
LightsabeR
sõnum 27.07.2011 05:47:17 vasta tsitaadiga
Natuke infot RO2 squad süsteemi kohta (dev vastas foorumis küsimustele):
Q: What sort of size squads are we likely to see? I know we've seen on various media sources that there are 'fire teams' which seem to consist of about 4 people, however I don't know if that's a reliable source due to unknown casualties etc.
A: Squads in game reflect real-world organisation - so usually 8-10 people, broken up into "fireteams". Depending on mission, can be rifle team, assault team, MG team. You may see a separate sniper team, to reflect that snipers were not usually part of the squad makeup.
Q: Will the number of squads simply increase as you increase the size of the server?
A: As the number of players increases, so new squads will open up.
Q: Will the Class Limits be based off squads or the team as a whole? For example, could one squad have 3 MG42s and a Kar98k Scoped Sniper Rifle? (Not complaining if that is the case!)
A: The squads are set up by map, so the level designer can mess around with the composition of the force, to suit the map. So, one squad can be rifle-heavy, one can be assault-heavy.
Q: Will you be able to place yourself in a specific squad like the way Battlefield does it.
A: If you don't care about which squad you are in, you can just select by role and let the game stick you in a squad, or you can look at the open squads and choose a role within one you want to join.
villu70
villu70
sõnum 27.07.2011 05:53:39 vasta tsitaadiga
Kommentaarid: 142 loe/lisa Kasutajad arvavad:  :: 3 :: 0 :: 122
Lovvi
Lovvi
sõnum 27.07.2011 16:15:26 vasta tsitaadiga
Millal see lubatud beta tuleb või juba käib closed beta (mida fännid saavad mängida)?
Kommentaarid: 61 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 58
LightsabeR
LightsabeR
sõnum 29.07.2011 17:27:33 vasta tsitaadiga
Friends & Family beta käib juba paar kuud. Nädal tagasi algas clan beta. Tehti foorumisse post, et clan'id võivad application'eid saata. Mingi 3-4 tunni pärast pandi kinni ja dev ütles, et sai üle saja application'i. Seda ma ei tea, palju neist siis beta'sse said.
Eks see "trial" beta tuleb ikka ka, pakuks, et augusti keskel äkki. Sinna peaks kõik kes väga tahavad ikka suutma sisse saada. Samas päris open beta't minu teada ei tehta.
EDIT:
Poolakatel siis selline collectors edition:
- game 2xDVD
- T-Shirt
- mousepad
- leash
- movie "Enemy at gates"
- T-34/85 model
- PK or MAXIM ammo box
Eks näeb, kas mujal tuleb sama või on mingid erinevused ka.
invension
invension
sõnum 03.08.2011 14:40:26 vasta tsitaadiga
Nüüd saab Pre-Orderit teha!
http://store.steampowered.com/app/35450/
villu70
villu70
sõnum 03.08.2011 15:00:37 vasta tsitaadiga
naiss..... aga tahaks ennem käpad külge panna kui päris ostuks läheb!
Lovvi
Lovvi
sõnum 03.08.2011 20:44:02 vasta tsitaadiga
-Kaivo-
sõnum 03.08.2011 21:08:18 vasta tsitaadiga
Lovvi kirjutas:
Mõtlemis ?
Lovvi
Lovvi
sõnum 04.08.2011 00:32:31 vasta tsitaadiga
-Kaivo- kirjutas:
Lovvi kirjutas:
Mõtlemis ?
Steam annab paljude mängudega TF2 mütsi kaasa
bitCON
sõnum 06.08.2011 14:20:06 vasta tsitaadiga
Red Orchestra 2: Heroes of Stalingrad Steam Key Pre-order - 26.99 EUR
http://www.g2play.net/store/Red-Orchestra-2-Heroes-of-Stalingrad-Steam-Key-Pre-order.html
LightsabeR
LightsabeR
sõnum 08.08.2011 16:00:24 vasta tsitaadiga
2 nädalat lükkub mängu release edasi. Uus release date on september 13.
http://www.heroesofstalingrad.com/faq/2-week-delay-to-13-sep/
Minu meelest igati õige otsus. Mida kauem nad endale aega võtavad, et betas mängu lihvida ja vigu parandada, seda parem saab release olema. Lisaks sellele jäi mulje, et beta tähtajad ei muutu vaid beta lihtsalt pikeneb. Nii et nende jaoks, kellel pre-order tehtud, ei muutu tegelikult midagi.
Crow
Crow
sõnum 08.08.2011 22:32:48 vasta tsitaadiga
võtas-uxu kirjutas:
+1
Scart
Scart
sõnum 11.08.2011 00:30:42 vasta tsitaadiga
http://www.greenmangaming.com/games/action/red-orchestra-2-heroes-of-stalingrad/ + kupong "SUNNY-SAVER-20PEC" ning tulemuseks on 19 eurot.
EDIT: just ostsin, läks 18.4 juurot ja mäng juba mu Stiimi kontol.
Avot
sõnum 11.08.2011 15:28:39 vasta tsitaadiga
Kas keegi viitsiks täpsemalt seletada kuidas saan ostetud selle deluxe versiooni.(mul on ka olemas RO ostfront 41-45). Kahjuks omistan ainult visa electron kaarti (kas sellega yldse saab osta?)
Olen äärmislet suur käpard netist ostmise suhtes :( (inglis keel väga nörk).
Olen ette tänulik köigile kes vaevuvad vastama!
Killzone88
Killzone88
sõnum 11.08.2011 17:25:12 vasta tsitaadiga
Scart kirjutas:
http://www.greenmangaming.com/?gmgr=ropinapo
Red Orchestra 2: Heroes of Stalingrad - Digital Deluxe Edition 23,87.-
edit: Mingi kupong veel "10PEC-VOUCH-SURV1" aga minul see ei tööta ro2 mängu tellides.
Kommentaarid: 20 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 13
Lovvi
Lovvi
sõnum 11.08.2011 18:03:30 vasta tsitaadiga
Kust te neid kuponge leiate?
Avot
sõnum 11.08.2011 19:46:26 vasta tsitaadiga
No nii.Ostisn ikkagi steamist selle deluxe versiooni. Kas olen nüüd öieti aru saanud et millalgi saab ka beta versiooni sellega proovida?
(ärge saatke ingliskeelseid linkke)
Kas steamist tuleb millalgi mingi kood või kuidas see asi öieti käib. Vastake teadjad, vähe ajast maha jäänud mehele :).
LightsabeR
LightsabeR
sõnum 12.08.2011 01:25:20 vasta tsitaadiga
Digital Deluxe versiooni omanikud saavad varsti betasse. Millal täpselt beta algab, pole veel teada (ma julgeks pakkuda, et paari nädala pärast). Mängu väljalaske kuupäev lükkus 30. augusti pealt 13. septembrile.
Lovvi
Lovvi
sõnum 13.08.2011 16:51:34 vasta tsitaadiga
Oleks vaja kedagi, kes aitaks osta greenmangaming.com -ist
Avot
sõnum 13.08.2011 17:26:36 vasta tsitaadiga
Soovitan osta otse steamist!
WäntWõll
make.believe
WäntWõll
sõnum 13.08.2011 17:36:37 vasta tsitaadiga
Lovvi kirjutas:
Mafia
Mafia
sõnum 13.08.2011 18:28:25 vasta tsitaadiga
Võtsin ka greenmangamingust selle -20% vauncheriga digital editioni 23 eurtsi eest icon_cool.gif
Bawse
Kommentaarid: 19 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 17
LightsabeR
LightsabeR
sõnum 15.08.2011 17:05:59 vasta tsitaadiga
Uus trailer:
invension
invension
sõnum 15.08.2011 18:12:24 vasta tsitaadiga
Lovvi
Lovvi
sõnum 15.08.2011 21:22:33 vasta tsitaadiga
Sain ka siis lõpuks soetatud mängu.
Scart
Scart
sõnum 15.08.2011 23:37:36 vasta tsitaadiga
Lovvi kirjutas:
Sven
Sven
sõnum 16.08.2011 08:25:55 vasta tsitaadiga
Kust neid Vouchereid saab muidu? €23 poe iseenesest üldse palju.
Kommentaarid: 35 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 32
invension
invension
sõnum 16.08.2011 09:51:44 vasta tsitaadiga
Sai esilehte ka muudetud veits.
LightsabeR
LightsabeR
sõnum 19.08.2011 12:03:51 vasta tsitaadiga
Final Beta algab järgmine nädal:
http://translate.google.com/translate?hl=en&sl=fr&tl=en&u=http%3A%2F%2Fwww.nofrag.com%2F2011%2Faou%2F18%2F38650%2F (prantsuse keelne artikkel, google translate'iga tõlgitud)
I also asked Alan if the semi-private beta will start soon: they are next week, but prefer to announce the date the night before to ensure that players do not spend a sleepless night waiting for anything in the event that a problem of last minute.
villu70
villu70
sõnum 19.08.2011 12:22:17 vasta tsitaadiga
Nice, kui mul pre-orderit tehtud ei ole, ega siis vist beetat proovida ei saa?
Tegelikult kunagi tegin läbi proxy ühest rootsi neti poest preorderi ära, ehk saadavad mingi koodi meilile!
LightsabeR
LightsabeR
sõnum 19.08.2011 12:36:40 vasta tsitaadiga
võtas-uxu kirjutas:
Digital Deluxe Pre-order peab olema, siis saad betasse.
Lovvi
Lovvi
sõnum 19.08.2011 15:06:51 vasta tsitaadiga
Küsin üle, et kas teil näitab ka steamis "Red Orchestra 2" nimena?
WäntWõll
make.believe
WäntWõll
sõnum 19.08.2011 15:33:50 vasta tsitaadiga
Killzone88
Killzone88
sõnum 19.08.2011 17:55:50 vasta tsitaadiga
Lovvi kirjutas:
Jah
LightsabeR kirjutas:
Avot
sõnum 20.08.2011 22:16:36 vasta tsitaadiga
Minul on deluxe ostettu ja steamis näen oma mängude reas Red Orchestra 2, aga seal loeb , et mäng ei ole veel avaldatud.
siin lisa piltte:
http://ve3d.ign.com/articles/news/61801/In-House-Red-Orchestra-2-Heroes-of-Stalingrad-Screenshots
Lovvi
Lovvi
sõnum 22.08.2011 16:32:49 vasta tsitaadiga
LightsabeR
LightsabeR
sõnum 22.08.2011 16:49:58 vasta tsitaadiga
Ikka suht mööda see koomiks minu meelest. Mingit beta kuupäeva pole kunagi kusagil lubatud ja vaid 2 nädalane release date'i delay on ikka väga tühine aeg.
Lovvi
Lovvi
sõnum 22.08.2011 16:51:11 vasta tsitaadiga
Ma ei kurdagi, lihtsalt pidasin seda naljakaks.
Best hat simulator
Killzone88
Killzone88
sõnum 22.08.2011 17:06:23 vasta tsitaadiga
this 23 August was the Battle of Stalingrad
the German troops reach the suburbs of Stalingrad.
maybe the beta release will be this date ?
http://en.wikipedia.org/wiki/Battle_of_Stalingrad
LightsabeR
LightsabeR
sõnum 22.08.2011 23:52:51 vasta tsitaadiga
TotalBiscuit'i video üleval:
Link
invension
invension
sõnum 23.08.2011 00:22:51 vasta tsitaadiga
Ainus asi mis häirib on see et kuidagi jõle tühjad tunduvad mapid...selles mõttes et nagu pole eriti viitsitud random objekte teha...puud,põõsad,kastid,tünnid,autod jne.
bitCON
sõnum 23.08.2011 12:17:16 vasta tsitaadiga
http://www.gametrailers.com/video/exclusive-gameplay-red-orchestra/719542?
LightsabeR
LightsabeR
sõnum 23.08.2011 19:21:52 vasta tsitaadiga
Final beta algab 30. augusti paiku. Võib päeva või kaks edasi lükkuda.
http://forums.tripwireinteractive.com/showthread.php?t=56818
Lovvi
Lovvi
sõnum 23.08.2011 20:01:52 vasta tsitaadiga
Ja ma juba lootsin enne kooli algust nolada seda mängu.
WäntWõll
make.believe
WäntWõll
sõnum 23.08.2011 21:52:07 vasta tsitaadiga
-Kaivo-
sõnum 23.08.2011 21:52:40 vasta tsitaadiga
WäntWõll kirjutas:
uus teema   vasta Tarkvara »  Arvutimängude foorum »  Red Orchestra 2: Heroes of Stalingrad mine lehele eelmine  1, 2, 3, 4, 5 ... 14, 15, 16  järgmine
