uus teema   vasta Raud »  Mängukonsoolid ja konsoolimängud »  [PS4] SONY PlayStation 4 arutelu märgi kõik teemad loetuks
mine lehele 1, 2, 3 ... 128, 129, 130  järgmine
firemark
firemark
sõnum 27.05.2011 17:24:48 [PS4] SONY PlayStation 4 arutelu vasta tsitaadiga
Natukene riistvara infot:
Console Hardware Specifications
CPU: x86-64 AMD "Jaguar" single-chip custom processor
Number of Cores/Threads: 8/8 [1]
Frequency: speculated to be running a base clock speed of 1.6 GHz on a 2.75 GHz capable chip
Shared L2 Cache: 2 x 2MB [2]
Manufacturing Process: 28nm [3]
GPU: AMD next-generation Radeon based graphics engine
Peak Shader Throughput: 1.84TFLOPS [4]
GPU Cores: 1152 [5]
Memory: 8GB GDDR5
Frequency: 5500MHz [6]
System Memory Bus: 256-bits [7]
System Memory Bandwidth: 176.0GB/s [8]
Storage size: 500GB hard disk drive, user removable*
External dimensions: Approximately 275 x 53 x 305mm
Mass: Approx 2.8kg
BD/DVD drive (read only): BD x 6 CAV, DVD x 8 CAV, Blu-ray and DVD playback, no audio CD support
Input/Output: Super-Speed USBx (USB 3.0) port x2, AUX port x1
Networking: Ethernet x1, IEEE 802.11b/g/n, Bluetooth 2.1 (EDR)
AV output: HDMI out port, digital out optical port. SD output is supported for lower-resolution displays. HD output at 720p, 1080p and 1080i.
Included Peripherals: PlayStation 4 system x1, Wireless controller (DualShock 4) x1, Mono headset x1, AC power cord x1, HDMI cable x1, USB cable x1
Stereoscopic Output: Hardware supported
PS4 PRO:
Main processor: Custom-chip single Processor
CPU: x86-64 AMD "Jaguar," 8 cores
GPU: 4.20 TFLOPS, AMD Radeon™ based graphics engine
Memory: GDDR5 8GB
Storage size: 1TB
External dimensions: Approx. 295×55×327 mm (width × height × length) (excludes largest projection)
Mass: Approx. 3.3 kg
BD/DVD Drive: BD × 6 CAV, DVD × 8 CAV
Input/Output: Super-Speed USB (USB 3.1 Gen.1) port × 3, AUX port × 1
Networking: Ethernet (10BASE-T, 100BASE-TX, 1000BASE-T)×1, IEEE 802.11 a/b/g/n/ac, Bluetooth® 4.0 (LE)
Power: AC 100V, 50/60Hz
Power consumption: Max. 310W
Operating temp: 5ºC – 35ºC
AV Output: HDMI out port (supports 4K/HDR) DIGITAL OUT (OPTICAL) port
viimati muutis firemark 08.09.2016 11:25:33, muudetud 2 korda
Kommentaarid: 102 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 93
iDemon
iDemon
sõnum 27.05.2011 17:33:04 vasta tsitaadiga
Seda kinnitati juba mitu aastat tagasi..
Eelmine aasta oli juba uudis et mängud on arenduses.
Kommentaarid: 122 loe/lisa Kasutajad arvavad:  :: 3 :: 1 :: 104
firemark
firemark
sõnum 27.05.2011 17:35:29 vasta tsitaadiga
Huvitav palju see seade maksma hakkab kui välja tuleb? 500€?
iDemon
iDemon
sõnum 27.05.2011 17:37:52 vasta tsitaadiga
firemark, ei.
PS3 oli hinnalt kallis kuna sellega suruti ka uus meedia turule (BD).
Järgmine konsool kasutab sama Blu-ray tehnoloogiat mis on juba praeguseks küllaltki odav. Dual-layer BD plaadid on ca 47,5GB mis on igati piisav.
aise
aise
sõnum 27.05.2011 18:04:12 vasta tsitaadiga
eks see oli teada jah, et arendavad aga mis karul kõhus saab olema oleks huvitav teada.
Kommentaarid: 189 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 172
pealuu
pealuu
sõnum 27.05.2011 18:32:50 vasta tsitaadiga
olgu mis on kõhus, peaasi et tearing ära likvideeritakse. või siis vähemalt on miski pedaal mille abil saab öelda "vsync ON"
Kommentaarid: 212 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 171
Olaf
Olaf
sõnum 27.05.2011 18:48:33 vasta tsitaadiga
iDemon kirjutas:
firemark, ei.
Panen punkti maha ja ennustan, et tulevane PS4 on sootuks suuremalt jaolt võrgu põhine. Mänge laetakse alla ja plaadid on teisejärgulised.
Ja seda ennutan ka, et maksab ta algselt ümaralt 650€
Aastate pärast saame näha, kas panin ennustusega pihta või mitte. icon_biggrin.gif
Erx15
Erx15
sõnum 27.05.2011 18:54:51 vasta tsitaadiga
Huvitav, ei tea kas kuskil mingeid riistvaralisi spekulatsioone kah on?
Mercury
sõnum 27.05.2011 22:29:23 vasta tsitaadiga
Olaf kirjutas:
iDemon kirjutas:
firemark, ei.
Kommentaarid: 61 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 60
firemark
firemark
sõnum 27.05.2011 22:36:14 vasta tsitaadiga
No ütleme nii,et kui need teenusepakkujad lubavad lähitulevikus ulmelisi kiiruseid nagu 4G võrgud jne ning 100mb/s allalaadimisi, siis pole see 25gb midagi nii suur.
Riddim
Riddim
sõnum 27.05.2011 22:38:31 vasta tsitaadiga
Suuremaid kettaid on ka vaja ju.
LEVEL1.EE - Videomängudest eesti keeles!
firemark
firemark
sõnum 27.05.2011 22:40:56 vasta tsitaadiga
TB suuruseid kettad levivad ju praegugi müügil, seega nende lisamine masinale ei ole küll erilne vaev. Hea oleks kui Sony paigaldaks hoopis suured SSD kettad, siis jookseks kogu süsteem kiiremini
TombcaT
sõnum 28.05.2011 13:28:05 vasta tsitaadiga
firemark kirjutas:
Jeeesh..... muidugi võiks panna "suured" SSD kettad...... siis hakkab maksma tulevane konsool samapalju kui pereauto. icon_lol.gif
Riddim
Riddim
sõnum 28.05.2011 13:32:36 vasta tsitaadiga
http://www.destructoid.com/sony-to-no-longer-make-ps3-like-expensive-consoles-202162.phtml
firemark
firemark
sõnum 28.05.2011 13:38:12 vasta tsitaadiga
icon_razz.gif aga mine sa tea, selleks ajaks kui PS4 välja tuleb, äkki on langenud SSD kettad mõistlikule hinnale ning vb sony saab mingeid häid diile nende ketaste tootjatelt
Olaf
Olaf
sõnum 28.05.2011 13:50:14 vasta tsitaadiga
firemark kirjutas:
Hea diili saaks nad kindlasti, kuna kogused on meeletud.
Ja jällegist julgen ennustada, et tulevasel konsoolil siiski on SSD. Eks see SSD pealetung tuleb samuti nagu tuli veidi aega tagasi läpaktele LED valgustusega ekraan. Ja kui vaadata kuidas viimase 5. aasta jooksul on hinnad muutnud ja asjad "võimsamaks" läinud, siis .. cmon .. see pole loogiline, et uue Playstation'i ajaks SSD igapäevaseks asjaks ei saa.
firemark
firemark
sõnum 28.05.2011 14:11:23 vasta tsitaadiga
Sony võiks tegelt isegi juba minna üle http://en.wikipedia.org/wiki/Holographic_Versatile_Disc nende ketaste peale icon_razz.gif
EvilKatarn
diivanilill
EvilKatarn
sõnum 28.05.2011 14:18:52 vasta tsitaadiga
Blu-Ray jääb meediaks raudselt. Sony selle alla liiga palju raha pannud ja mängud pole isegi ligidal 50gb täitmiseni. Ainus miinus on aeglane lugemiskiirus. BDXL kasutussemineku puhul oleks vist kohustuslikud installid vältimatud.
Kommentaarid: 110 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 81
kala1
kala1
sõnum 28.05.2011 14:26:53 vasta tsitaadiga
firemark, teeb piraatidel plaadile kirjutamise raskeks icon_biggrin.gif Sai kuskilt loetud, et kirjutaja 18k dollarit icon_lol.gif
M: LG 29wk500-p
The German soldier has impressed the world, however the Italian Bersagliere soldier has impressed the German soldier.
Kommentaarid: 52 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 48
486
sõnum 28.05.2011 14:30:50 vasta tsitaadiga
Huvitav kas riistvara jääb sama põhimõttele, et ikka see sama ebamugav pult või mõtlevad midagi ergonoomilisemad välja. Ja mis saab motion control´ist?
BL edasi kasutamine on küll nõme võiks alternatiiv olla, et mänge saaks ka digitaalselt netist osta, mis oleksid ka odavamad kui plaadi versioonid.
Ma loodan väga, et uued konsoolid toovad enamad, kui vaid kiirem prose ja rohkem mälu. Wii konsoolide hiigel müük algus aegadel näitas, mida inimesed tegelikult ootavad.
zero
Braien
Braien
sõnum 28.05.2011 14:34:22 vasta tsitaadiga
486, Eks see pult sõltub inimesest, minule meeldib igastahes ps pult väga.
firemark
firemark
sõnum 28.05.2011 14:56:45 vasta tsitaadiga
Ma vist ka vanakooli mees veel,et tahan samasugust pulti:D
Mercury
sõnum 28.05.2011 17:04:27 vasta tsitaadiga
firemark kirjutas:
Isegi, kui muretseks 4G siis vaevalt saab tõmmata suuremahulisi mänge nii kergelt
flake
sõnum 02.06.2011 21:26:54 vasta tsitaadiga
Mercury kirjutas:
Olaf kirjutas:
iDemon kirjutas:
firemark, ei.
Elioni hüperkiirega sain mina 32GB tunnis tirida ... kiirem kui mäng poest tellida, või poodi sõita ja füüsiliselt osta icon_razz.gif
Kommentaarid: 63 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 60
firemark
firemark
sõnum 03.06.2011 14:08:24 vasta tsitaadiga
päris hea oleks jah,et paned tuleviku PSNist tõmbama mingi 10 mängu õhtul ning hommikul kõik olemas icon_biggrin.gif
Mercury
sõnum 03.06.2011 14:13:40 vasta tsitaadiga
firemark kirjutas:
firemark
firemark
sõnum 03.06.2011 14:20:40 vasta tsitaadiga
Välja vist ei paneks, tuvid lasevad täis:P
Ho Ho
Ho Ho
sõnum 03.06.2011 14:37:24 vasta tsitaadiga
SSD'd näeb konsoolides parimal juhul mõne gigase cache'na kui sedagi aga mitte mingil juhul peamise andmekandjana. Pigem lihtsalt torgatakse kasti 3-4G ram'i ning loetakse kama plaadilt-hdd'lt nagu ikka.
DD saab kindlasti olema kõvasti olulisem kui praegu ning ehk saab ka ära nähtud mingid SE/slim versioonid kust plaadiseade puudub kuid üsnagi kindlasti on kõigil aparaatidel olemas mingit sorti väline andmekandja mille kaudu mänge levitada. Võimatu pole ka see, et kasutatakse mälukaarte ehkki nonde ühikuhind tuleb 8G kohta kusagil 3-5$ vs mõnikümmend senti BD plaadi kohta.
prtv
sõnum 08.06.2011 09:15:43 vasta tsitaadiga
Ei tea, kas PS4 default kontrollerisse pannakse Move ka kuidagi sisse?
rabzer
rabzer
sõnum 08.06.2011 23:03:03 vasta tsitaadiga
Kuskil lugesin ,et PS3 pult mis on sixaxis on nagu move . See Move kaamera jälgib seda tulekest punast mis on kontrolleril ja sonyl on patent selle peale. Vb ongi tulevikus saabki sellest move pult ...
Kommentaarid: 77 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 71
firemark
firemark
sõnum 08.06.2011 23:06:34 vasta tsitaadiga
Jep sixaxis puldis on liikumisandurid mis reageerivad kallutamistele
Ho Ho
Ho Ho
sõnum 08.06.2011 23:10:49 vasta tsitaadiga
rabzer pidas silmas Move'i stiilis pulgakommi kaameraga jälitamist.
beastbeats
beastbeats
sõnum 09.06.2011 00:25:11 vasta tsitaadiga
rabzer kirjutas:
Igasugust jama, mida internetis kirjutatakse, ei tasuks uskuda...
10.10.10
10.10.10
sõnum 26.06.2011 14:20:43 vasta tsitaadiga
Alles hiljuti sain PS3-me omanikus, aga no teades kaua neid asju valmis "ehitatakse" siis vast aasta-paar mureta veel.
firemark
firemark
sõnum 26.06.2011 14:28:16 vasta tsitaadiga
Praegu ongi hea aeg ps3 osta, saab niipaljusid erinevaid mänge proovida mis on aegade algusest sellele toodetud
ppg
ppg
sõnum 26.06.2011 17:18:42 vasta tsitaadiga
Kas mingeid umbkaudseid väljalskmise aegu ka välja öeldud?
Kommentaarid: 171 loe/lisa Kasutajad arvavad:  :: 1 :: 5 :: 138
xxlmaster
xxlmaster
sõnum 26.06.2011 17:30:12 vasta tsitaadiga
ppg kirjutas:
ahh, onon. Pilt millega teemat on alustatud on ka pmst õhust võetud. Sarnaseid ulmekaid on liikunud juba aastaid.
Mõttetu on siin veel üldse midagi oletada kui asi nii lapse kingades...
Ho Ho
Ho Ho
sõnum 26.06.2011 17:44:56 vasta tsitaadiga
ppg kirjutas:
Wiiu millagil järgmise aasta Q2 lõpp-jõulud ajavahemikus, XB tõenäoliselt 2013 jõulud või 2014, PS kas koos XB'ga või suts hiljem.
10.10.10
10.10.10
sõnum 26.06.2011 18:01:02 vasta tsitaadiga
Nu WiiU-ga vast koos jah mitte , kuid usun, et Xkastiga tuleb ka uus PS , vaevalt konkurendile kuldne võimalus kliente üle teisele poolele lastakse.
iDemon
iDemon
sõnum 04.07.2011 12:23:27 vasta tsitaadiga
wat
http://kotaku.com/5817874/report-the-playstation-4-will-have-kinect+style-motion-controls
firemark
firemark
sõnum 04.07.2011 12:27:10 vasta tsitaadiga
Selle sama uudise järgi jah võib öelda,et ps4 tuleb järgmine aasta icon_biggrin.gif
siin lehel juba counter ka pandud millal jõuab ps4 välja
http://www.ps4playstation4.com/ps4-release-date-countdown-begins
xxlmaster
xxlmaster
sõnum 04.07.2011 13:57:11 vasta tsitaadiga
iDemon kirjutas:
wat
2012? kinecti sarnane süsteem? teh <b>piix</b> icon_lol.gif
Ma oleks just üllatunud olnud kui sellist asja poleks tulnud. Süsteemi põhimõte saab olema kinectile sarnane aga tegumood kindlasti more advanced icon_neutral.gif
beastbeats
beastbeats
sõnum 04.07.2011 14:08:02 vasta tsitaadiga
Sony'l oli ju põhimõtteliselt juba enne Kinect'it analoogne tehnoloogia kasutusel - PS2 Eye Toy icon_wink.gif
http://www.gamespot.com/ps2/action/eyetoy/video/6078176/eyetoy-play-video-review?tag=summary%3Bwatch-review
Ho Ho
Ho Ho
sõnum 04.07.2011 14:23:55 vasta tsitaadiga
Asjal oleks jumet kui nad kombineeriks kinecti ja move'i, kumbki eraldi on suht nigelavõitu.
firemark
firemark
sõnum 04.07.2011 14:28:02 vasta tsitaadiga
randmetele kinnitatavad mingid sensorid võiksid olla nagu. nagu paelad vms
Riddim
Riddim
sõnum 04.07.2011 14:52:39 vasta tsitaadiga
firemark kirjutas:
nagu 2:30?
Link
beastbeats
beastbeats
sõnum 04.07.2011 14:53:09 vasta tsitaadiga
Riddim, või nagu EA Sports Active...
viimati muutis beastbeats 04.07.2011 14:55:41, muudetud 1 kord
xxlmaster
xxlmaster
sõnum 04.07.2011 14:53:15 vasta tsitaadiga
firemark kirjutas:
saab olema nagu jõulupuu laternad. Topid ennast kuljuseid täis ja hakkad UFCd teleka ees keksima.
firemark
firemark
sõnum 04.07.2011 15:01:11 vasta tsitaadiga
icon_biggrin.gif, vähemalt saad pealtvaatajatele lõbu pakkuda enda keksimisega
Ho Ho
Ho Ho
sõnum 04.07.2011 15:06:30 vasta tsitaadiga
beastbeats kirjutas:
Rohkem infot kui ainult ühe punkti asukoht ruumis.
uus teema   vasta Raud »  Mängukonsoolid ja konsoolimängud »  [PS4] SONY PlayStation 4 arutelu mine lehele 1, 2, 3 ... 128, 129, 130  järgmine
