firemark
27.05.2011 17:24:48
[PS4] SONY PlayStation 4 arutelu |
Natukene riistvara infot:
Console Hardware Specifications
CPU: x86-64 AMD "Jaguar" single-chip custom processor
Number of Cores/Threads: 8/8 [1]
Frequency: speculated to be running a base clock speed of 1.6 GHz on a 2.75 GHz capable chip
Shared L2 Cache: 2 x 2MB [2]
Manufacturing Process: 28nm [3]
GPU: AMD next-generation Radeon based graphics engine
Peak Shader Throughput: 1.84TFLOPS [4]
GPU Cores: 1152 [5]
Memory: 8GB GDDR5
Frequency: 5500MHz [6]
System Memory Bus: 256-bits [7]
System Memory Bandwidth: 176.0GB/s [8]
Storage size: 500GB hard disk drive, user removable*
External dimensions: Approximately 275 x 53 x 305mm
Mass: Approx 2.8kg
BD/DVD drive (read only): BD x 6 CAV, DVD x 8 CAV, Blu-ray and DVD playback, no audio CD support
Input/Output: Super-Speed USBx (USB 3.0) port x2, AUX port x1
Networking: Ethernet x1, IEEE 802.11b/g/n, Bluetooth 2.1 (EDR)
AV output: HDMI out port, digital out optical port. SD output is supported for lower-resolution displays. HD output at 720p, 1080p and 1080i.
Included Peripherals: PlayStation 4 system x1, Wireless controller (DualShock 4) x1, Mono headset x1, AC power cord x1, HDMI cable x1, USB cable x1
Stereoscopic Output: Hardware supported
PS4 PRO:
Main processor: Custom-chip single Processor
CPU: x86-64 AMD "Jaguar," 8 cores
GPU: 4.20 TFLOPS, AMD Radeon™ based graphics engine
Memory: GDDR5 8GB
Storage size: 1TB
External dimensions: Approx. 295×55×327 mm (width × height × length) (excludes largest projection)
Mass: Approx. 3.3 kg
BD/DVD Drive: BD × 6 CAV, DVD × 8 CAV
Input/Output: Super-Speed USB (USB 3.1 Gen.1) port × 3, AUX port × 1
Networking: Ethernet (10BASE-T, 100BASE-TX, 1000BASE-T)×1, IEEE 802.11 a/b/g/n/ac, Bluetooth® 4.0 (LE)
Power: AC 100V, 50/60Hz
Power consumption: Max. 310W
Operating temp: 5ºC – 35ºC
AV Output: HDMI out port (supports 4K/HDR) DIGITAL OUT (OPTICAL) port
viimati muutis firemark 08.09.2016 11:25:33, muudetud 2 korda |
Kommentaarid: 101 loe/lisa |
92 |
iDemon
27.05.2011 17:33:04
Seda kinnitati juba mitu aastat tagasi..
Eelmine aasta oli juba uudis et mängud on arenduses.
Kommentaarid: 122 loe/lisa |
104 |
firemark
27.05.2011 17:35:29
Huvitav palju see seade maksma hakkab kui välja tuleb? 500€?
92 |
iDemon
27.05.2011 17:37:52
firemark, ei.
PS3 oli hinnalt kallis kuna sellega suruti ka uus meedia turule (BD).
Järgmine konsool kasutab sama Blu-ray tehnoloogiat mis on juba praeguseks küllaltki odav. Dual-layer BD plaadid on ca 47,5GB mis on igati piisav.
104 |
aise
27.05.2011 18:04:12
eks see oli teada jah, et arendavad aga mis karul kõhus saab olema oleks huvitav teada.
Kommentaarid: 189 loe/lisa |
172 |
pealuu
27.05.2011 18:32:50
olgu mis on kõhus, peaasi et tearing ära likvideeritakse. või siis vähemalt on miski pedaal mille abil saab öelda "vsync ON"
Kommentaarid: 209 loe/lisa |
168 |
Olaf
27.05.2011 18:48:33
iDemon kirjutas: |
firemark, ei.
Järgmine konsool kasutab sama Blu-ray tehnoloogiat mis on juba praeguseks küllaltki odav. Dual-layer BD plaadid on ca 47,5GB mis on igati piisav. |
Panen punkti maha ja ennustan, et tulevane PS4 on sootuks suuremalt jaolt võrgu põhine. Mänge laetakse alla ja plaadid on teisejärgulised.
Ja seda ennutan ka, et maksab ta algselt ümaralt 650€
Aastate pärast saame näha, kas panin ennustusega pihta või mitte.
Kommentaarid: 81 loe/lisa |
75 |
Erx15
27.05.2011 18:54:51
Huvitav, ei tea kas kuskil mingeid riistvaralisi spekulatsioone kah on?
Kommentaarid: 17 loe/lisa |
16 |
Mercury
27.05.2011 22:29:23
Olaf kirjutas: |
iDemon kirjutas: |
firemark, ei.
Aastate pärast saame näha, kas panin ennustusega pihta või mitte.  |
Ei kujuta ette kui peaks tõmbama 25GB mängu neti pealt
Kommentaarid: 61 loe/lisa |
60 |
firemark
27.05.2011 22:36:14
No ütleme nii,et kui need teenusepakkujad lubavad lähitulevikus ulmelisi kiiruseid nagu 4G võrgud jne ning 100mb/s allalaadimisi, siis pole see 25gb midagi nii suur.
92 |
Riddim
27.05.2011 22:38:31
Suuremaid kettaid on ka vaja ju.
_________________ LEVEL1.EE - Videomängudest eesti keeles! |
Kommentaarid: 5 loe/lisa |
firemark
27.05.2011 22:40:56
TB suuruseid kettad levivad ju praegugi müügil, seega nende lisamine masinale ei ole küll erilne vaev. Hea oleks kui Sony paigaldaks hoopis suured SSD kettad, siis jookseks kogu süsteem kiiremini
92 |
TombcaT
28.05.2011 13:28:05
firemark kirjutas: |
TB suuruseid kettad levivad ju praegugi müügil, seega nende lisamine masinale ei ole küll erilne vaev. Hea oleks kui Sony paigaldaks hoopis suured SSD kettad, siis jookseks kogu süsteem kiiremini |
Jeeesh..... muidugi võiks panna "suured" SSD kettad...... siis hakkab maksma tulevane konsool samapalju kui pereauto.
Igaljuhul põnevad ajad on tulemas uute konsoolide näol.
Kommentaarid: 2 loe/lisa |
Riddim
firemark
28.05.2011 13:38:12
aga mine sa tea, selleks ajaks kui PS4 välja tuleb, äkki on langenud SSD kettad mõistlikule hinnale ning vb sony saab mingeid häid diile nende ketaste tootjatelt
92 |
Olaf
28.05.2011 13:50:14
aga mine sa tea, selleks ajaks kui PS4 välja tuleb, äkki on langenud SSD kettad mõistlikule hinnale ning vb sony saab mingeid häid diile nende ketaste tootjatelt |
Hea diili saaks nad kindlasti, kuna kogused on meeletud.
Ja jällegist julgen ennustada, et tulevasel konsoolil siiski on SSD. Eks see SSD pealetung tuleb samuti nagu tuli veidi aega tagasi läpaktele LED valgustusega ekraan. Ja kui vaadata kuidas viimase 5. aasta jooksul on hinnad muutnud ja asjad "võimsamaks" läinud, siis .. cmon .. see pole loogiline, et uue Playstation'i ajaks SSD igapäevaseks asjaks ei saa.
75 |
firemark
92 |
EvilKatarn
diivanilill
28.05.2011 14:18:52
Blu-Ray jääb meediaks raudselt. Sony selle alla liiga palju raha pannud ja mängud pole isegi ligidal 50gb täitmiseni. Ainus miinus on aeglane lugemiskiirus. BDXL kasutussemineku puhul oleks vist kohustuslikud installid vältimatud.
Kommentaarid: 109 loe/lisa |
80 |
kala1
28.05.2011 14:26:53
firemark, teeb piraatidel plaadile kirjutamise raskeks Sai kuskilt loetud, et kirjutaja 18k dollarit
_________________ M: LG 29wk500-p
The German soldier has impressed the world, however the Italian Bersagliere soldier has impressed the German soldier. |
Kommentaarid: 49 loe/lisa |
45 |
486
28.05.2011 14:30:50
Huvitav kas riistvara jääb sama põhimõttele, et ikka see sama ebamugav pult või mõtlevad midagi ergonoomilisemad välja. Ja mis saab motion control´ist?
BL edasi kasutamine on küll nõme võiks alternatiiv olla, et mänge saaks ka digitaalselt netist osta, mis oleksid ka odavamad kui plaadi versioonid.
Ma loodan väga, et uued konsoolid toovad enamad, kui vaid kiirem prose ja rohkem mälu. Wii konsoolide hiigel müük algus aegadel näitas, mida inimesed tegelikult ootavad.
_________________ zero |
Kommentaarid: 46 loe/lisa |
39 |
Braien
28.05.2011 14:34:22
486, Eks see pult sõltub inimesest, minule meeldib igastahes ps pult väga.
Kommentaarid: 102 loe/lisa |
90 |
firemark
28.05.2011 14:56:45
Ma vist ka vanakooli mees veel,et tahan samasugust pulti:D
92 |
Mercury
60 |
flake
02.06.2011 21:26:54
Mercury kirjutas: |
Olaf kirjutas: |
iDemon kirjutas: |
firemark, ei.
Ei kujuta ette kui peaks tõmbama 25GB mängu neti pealt  |
Elioni hüperkiirega sain mina 32GB tunnis tirida ... kiirem kui mäng poest tellida, või poodi sõita ja füüsiliselt osta
_________________ ..||.. |
Kommentaarid: 63 loe/lisa |
60 |
firemark
03.06.2011 14:08:24
päris hea oleks jah,et paned tuleviku PSNist tõmbama mingi 10 mängu õhtul ning hommikul kõik olemas
92 |
