uus teema   vasta Vaidlused »  Võitlustanner »  3DMark Vantage skoorid märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 65, 66, 67 ... 79, 80, 81  järgmine
meelo
sõnum 13.03.2011 20:32:04 vasta tsitaadiga
Kas see on normaalne kui sama raua ja clocki juures on selline vahe GTX 275 ja 5870-l? Kas prose jääb juba nii suureks piduriks, tegemist profiil kastiga.
Kommentaarid: 30 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 27
1dumbpcuser
sõnum 13.03.2011 20:47:06 vasta tsitaadiga
meelo kirjutas:
M:
Kommentaarid: 101 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 96
eXceed
eXceed
sõnum 13.03.2011 23:00:24 vasta tsitaadiga
GTX 275 on PhysX sees.Aga üldiselt jääb prose jalgu jamh(vantage tahaks rohkem kui 2 tuuma)
Endast uuematele/vähem tehinguid teinud inimestele, ei saada raha ega kaupa ette...
Seda enam kui pole isegi ID-kaardiga autentimist.
Kommentaarid: 190 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 153
AJ
AJ
sõnum 15.03.2011 23:27:33 vasta tsitaadiga
Futuremark Releases 3DMark Vantage v1.1.0
techPowerUp
3DMark Vantage seems to be becoming the new "3DMark 06", as the benchmark becomes passable by even the most entry-level DirectX 10 supportive GPUs. Rather Unexpectedly, Futuremark released a new update, v1.1.0, that comes with significant changes. To begin with, there's no more "trial edition". The Basic Edition, which cost $6.95, is now free. Users can now freely put their GPUs through all four of the main tests, view their scores online, and compare their scores with others' on the ORB.
Display scaling is added to improve display compatibility. By default a PhysX processor won't accelerate CPU tests. The Futuremark SystemInfo component is updated to detect the latest hardware, such as CPUs, GPUs, etc. The entire application is recompiled on Microsoft Visual Studio 2010. An expert developer we spoke to doesn't believe it brings about any change. 3DMark Vantage is a comprehensive 3D graphics hardware benchmarking suite that uses DirectX 10 API.
One
sõnum 07.04.2011 09:48:11 vasta tsitaadiga
CPU: Intel Core i5 2500K @ 4.988GHz / 1.4v
MBD: MSI P67A-C45 B3
RAM: 2 x 2GB Kingston HyperX KHX1600C8D3K2/4GX @ 1600MHz / 8-8-8-23-1T / 1.6v
GFX: BBA Radeon HD5550 512MB GDDR5 550/1000(4000) @ 900/1100(4400)
3D Mark Score: 6757
Mask
Mask
sõnum 09.04.2011 16:23:45 vasta tsitaadiga
2500K @ 5,2GHz
HD 6850 1080/1210
19668
Kommentaarid: 523 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 435
Drizzle
Drizzle
sõnum 09.04.2011 16:59:12 vasta tsitaadiga
Mask kirjutas:
2500K @ 5,2GHz
HD 6850 1080/1210
19668
kaugemale ei lähe ?
Sven Suigussaar Photography
Kommentaarid: 93 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 82
kaidtor
OC GURU
kaidtor
sõnum 09.04.2011 17:06:53 vasta tsitaadiga
Mask kirjutas:
2500K @ 5,2GHz
HD 6850 1080/1210
19668
Kommentaarid: 173 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 136
One
sõnum 09.04.2011 18:49:44 vasta tsitaadiga
Mask, palju prosele volti andsid?
Mask
Mask
sõnum 09.04.2011 19:02:53 vasta tsitaadiga
Winterwind, 1,52 biosis, linx ka 10 min lastu, stabiil.
2500K @ 5,2GHz
HD 6850 def CF 16x ja 4x
omgwtf
omgwtf
sõnum 09.04.2011 19:19:59 vasta tsitaadiga
Mis emaplaadiga tegu,et üks PCI-E on 4x peal? icon_rolleyes.gif See margis peaks pidurdama juba suht märgatavalt. Isegi 16x+8x 3dm11 annab tunda päris märgatavalt vs 16x16x.
kaidtor
OC GURU
kaidtor
sõnum 09.04.2011 19:31:39 vasta tsitaadiga
Mask kirjutas:
2500K @ 5,2GHz
Mul oli sellega koguaeg mingi jama täiesti lambist kord töötas siis jälle ei tohtinud midagi muuta oli kohe pilt sinine ees
Mask
Mask
sõnum 09.04.2011 19:56:19 vasta tsitaadiga
kaidtor kirjutas:
täpselt. ega mingit alternatiivi sellele leidnud?
kaidtor
OC GURU
kaidtor
sõnum 09.04.2011 20:17:47 vasta tsitaadiga
Mask kirjutas:
kaidtor kirjutas:
Ainul Msi afterburneriga sai midagi teha ainult siis tuleb kaardid üle flasida ,et kellasi korralikult tõsta
Mask
Mask
sõnum 11.04.2011 00:22:16 vasta tsitaadiga
26449 marks with 2x Radeon HD 6850 at 925/1100MHz
Core i5 2500K @ 5 301MHz
esseker
esseker
sõnum 16.05.2011 22:15:47 vasta tsitaadiga
I7 930 @ 3496.9mhz
3x1gb 799.7mhz cl9-9-9 28
2xGTX260 @655/1055
Score: 20000
Kommentaarid: 126 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 110
Juan Pablo
sõnum 18.05.2011 06:33:42 vasta tsitaadiga
esseker,
930-nest peaks tublisti rohkem saama.. alla 4.2ghz poleks ilus eriti postitada icon_wink.gif
Kommentaarid: 33 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 29
esseker
esseker
sõnum 19.05.2011 23:41:14 vasta tsitaadiga
janek5 kirjutas:
esseker,
Eks ma sinnapoole püüa aga pole ennem i7 OC kokku puutunud icon_rolleyes.gif
I7 930 @ 4000.5mhz
3x1gb 914.3mhz cl9-9-9 28
2xGTX260 @677/1107
Score: 21391
Keegi ennem kokku puutunud Asus P6T SE- ga ?
sõnum 20.05.2011 09:28:25 vasta tsitaadiga
Mul tiksub 920 1,3v peal@ 4GHz
Et 4,5ghz saada pidin volti ikka suht julmalt juurde andma.
Kui sul mälud 1600 def, siis äkki peaks kordajat alla laskma
Juan Pablo
sõnum 20.05.2011 10:59:57 vasta tsitaadiga
esseker kirjutas:
janek5 kirjutas:
esseker,
I7 930 @ 4000.5mhz
2xGTX260 @677/1107
Score: 21391
mul käis 1.72 volti i930... 4.8ghz 3dmark06.. väga palju oleneb isendist ja jahutusest
Evil
Hull
Evil
sõnum 20.05.2011 11:08:06 vasta tsitaadiga
esseker kirjutas:
I7 930 @ 4000.5mhz
2xGTX260 @677/1107
Score: 21391
Testimise asi. Turbod ja muu sarnane jura lülita biosist välja. Proovi kasutada 21x kordajat, mul 22x mingilt maalt enam ei taha klokkuda.
Mälukordaja alla, pane manuaalselt näiteks 1,45v prosele ja kindlasti klokkub kaugemale. thumbs_up.gif
Kommentaarid: 242 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 202
sõnum 20.05.2011 12:19:20 vasta tsitaadiga
Mul ka turboga ei tahtnud klokkuda ja bus speed peaks lõtva 200 ära tegema
esseker
esseker
sõnum 23.05.2011 20:53:20 vasta tsitaadiga
janek5, 1.72v on ikka nati jõhker õhkjahutusega i7-le ( suht kuum on ta ikka) kardan et ei suuda ära jahutada icon_eek.gif
Evil, kordaja proovin järgi aga manuaalselt volti anda ? mida ma omaarust siiani olen teinud ? 1.45v läheb ta üpris kuumaks ja ei suuda lõpetada runni !
jeesus188, krt pole kuskil tähelepanu põõranud selle turbole ( uurin) Mäludes asi ei ole !
Tänud nõuannete eest mida platel biosist maha keerata thumbs_up.gif Nüüd loodetavasti targem icon_lol.gif
Juan Pablo
sõnum 23.05.2011 21:52:02 vasta tsitaadiga
esseker,
mul käis veega.... sorry... et ei ytelnud icon_redface.gif icon_redface.gif icon_redface.gif
fixtix
sõnum 02.06.2011 08:24:32 vasta tsitaadiga
Default skoor
http://3dmark.com/3dmv/3212567
uus teema   vasta Vaidlused »  Võitlustanner »  3DMark Vantage skoorid mine lehele eelmine  1, 2, 3 ... 65, 66, 67 ... 79, 80, 81  järgmine
