meelo
| Kommentaarid: 30 loe/lisa |
1dumbpcuser
97 |
eXceed
14.03.2011 00:00:24
GTX 275 on PhysX sees.Aga üldiselt jääb prose jalgu jamh(vantage tahaks rohkem kui 2 tuuma)
_________________ Endast uuematele/vähem tehinguid teinud inimestele, ei saada raha ega kaupa ette...
Seda enam kui pole isegi ID-kaardiga autentimist. |
| Kommentaarid: 190 loe/lisa |
153 |
AJ
16.03.2011 00:27:33
Futuremark Releases 3DMark Vantage v1.1.0
techPowerUp
3DMark Vantage seems to be becoming the new "3DMark 06", as the benchmark becomes passable by even the most entry-level DirectX 10 supportive GPUs. Rather Unexpectedly, Futuremark released a new update, v1.1.0, that comes with significant changes. To begin with, there's no more "trial edition". The Basic Edition, which cost $6.95, is now free. Users can now freely put their GPUs through all four of the main tests, view their scores online, and compare their scores with others' on the ORB.
Display scaling is added to improve display compatibility. By default a PhysX processor won't accelerate CPU tests. The Futuremark SystemInfo component is updated to detect the latest hardware, such as CPUs, GPUs, etc. The entire application is recompiled on Microsoft Visual Studio 2010. An expert developer we spoke to doesn't believe it brings about any change. 3DMark Vantage is a comprehensive 3D graphics hardware benchmarking suite that uses DirectX 10 API. |
| Kommentaarid: 37 loe/lisa |
36 |
One
07.04.2011 10:48:11
CPU: Intel Core i5 2500K @ 4.988GHz / 1.4v
MBD: MSI P67A-C45 B3
RAM: 2 x 2GB Kingston HyperX KHX1600C8D3K2/4GX @ 1600MHz / 8-8-8-23-1T / 1.6v
GFX: BBA Radeon HD5550 512MB GDDR5 550/1000(4000) @ 900/1100(4400)
3D Mark Score: 6757
728 |
Mask
09.04.2011 17:23:45
2500K @ 5,2GHz
HD 6850 1080/1210
19668
| Kommentaarid: 523 loe/lisa |
435 |
Drizzle
09.04.2011 17:59:12
| Mask kirjutas: |
2500K @ 5,2GHz
HD 6850 1080/1210
19668
kaugemale ei lähe ?
_________________ Sven Suigussaar Photography |
| Kommentaarid: 93 loe/lisa |
kaidtor
OC GURU
09.04.2011 18:06:53
| Mask kirjutas: |
2500K @ 5,2GHz
HD 6850 1080/1210
19668
Ütleks et pole paha
136 |
One
09.04.2011 19:49:44
| Mask, palju prosele volti andsid?
728 |
Mask
09.04.2011 20:02:53
Winterwind, 1,52 biosis, linx ka 10 min lastu, stabiil.
2500K @ 5,2GHz
HD 6850 def CF 16x ja 4x
23619
trixxis klokki t6stes jookseb millegi p2rast kokku
435 |
omgwtf
09.04.2011 20:19:59
Mis emaplaadiga tegu,et üks PCI-E on 4x peal? See margis peaks pidurdama juba suht märgatavalt. Isegi 16x+8x 3dm11 annab tunda päris märgatavalt vs 16x16x.
137 |
kaidtor
OC GURU
09.04.2011 20:31:39
| Mask kirjutas: |
2500K @ 5,2GHz
23619
trixxis klokki t6stes jookseb millegi p2rast kokku  |
Mul oli sellega koguaeg mingi jama täiesti lambist kord töötas siis jälle ei tohtinud midagi muuta oli kohe pilt sinine ees
136 |
Mask
09.04.2011 20:56:19
| kaidtor kirjutas: |
Mul oli sellega koguaeg mingi jama täiesti lambist kord töötas siis jälle ei tohtinud midagi muuta oli kohe pilt sinine ees |
täpselt. ega mingit alternatiivi sellele leidnud?
435 |
kaidtor
OC GURU
09.04.2011 21:17:47
| Mask kirjutas: |
| kaidtor kirjutas: |
täpselt. ega mingit alternatiivi sellele leidnud? |
Ainul Msi afterburneriga sai midagi teha ainult siis tuleb kaardid üle flasida ,et kellasi korralikult tõsta
136 |
Mask
11.04.2011 01:22:16
26449 marks with 2x Radeon HD 6850 at 925/1100MHz
Core i5 2500K @ 5 301MHz
435 |
esseker
16.05.2011 23:15:47
Sai üle pika aja midagi põnevat tehtud jälle
I7 930 @ 3496.9mhz
3x1gb 799.7mhz cl9-9-9 28
2xGTX260 @655/1055
Score: 20000
110 |
Juan Pablo
18.05.2011 07:33:42
esseker,
930-nest peaks tublisti rohkem saama.. alla 4.2ghz poleks ilus eriti postitada
29 |
esseker
20.05.2011 00:41:14
| janek5 kirjutas: |
esseker,
930-nest peaks tublisti rohkem saama.. alla 4.2ghz poleks ilus eriti postitada  |
Eks ma sinnapoole püüa aga pole ennem i7 OC kokku puutunud
Kõik on teistsugune võrreldes Soc 775-ga
I7 930 @ 4000.5mhz
3x1gb 914.3mhz cl9-9-9 28
2xGTX260 @677/1107
Score: 21391
Üle 4ghz muutub asi ikka ebastabiilseks
Keegi ennem kokku puutunud Asus P6T SE- ga ?
110 |
20.05.2011 10:28:25
Mul tiksub 920 1,3v peal@ 4GHz
Et 4,5ghz saada pidin volti ikka suht julmalt juurde andma.
Kui sul mälud 1600 def, siis äkki peaks kordajat alla laskma
Mõni targem teab täpsemalt mida teha
Juan Pablo
20.05.2011 11:59:57
| esseker kirjutas: |
| janek5 kirjutas: |
esseker,
I7 930 @ 4000.5mhz
2xGTX260 @677/1107
Score: 21391
Keegi ennem kokku puutunud Asus P6T SE- ga ? |
mul käis 1.72 volti i930... 4.8ghz 3dmark06.. väga palju oleneb isendist ja jahutusest
29 |
Evil
Hull
20.05.2011 12:08:06
| esseker kirjutas: |
I7 930 @ 4000.5mhz
2xGTX260 @677/1107
Score: 21391
Testimise asi. Turbod ja muu sarnane jura lülita biosist välja. Proovi kasutada 21x kordajat, mul 22x mingilt maalt enam ei taha klokkuda.
Mälukordaja alla, pane manuaalselt näiteks 1,45v prosele ja kindlasti klokkub kaugemale.
202 |
20.05.2011 13:19:20
Mul ka turboga ei tahtnud klokkuda ja bus speed peaks lõtva 200 ära tegema
esseker
23.05.2011 21:53:20
janek5, 1.72v on ikka nati jõhker õhkjahutusega i7-le ( suht kuum on ta ikka) kardan et ei suuda ära jahutada
Evil, kordaja proovin järgi aga manuaalselt volti anda ? mida ma omaarust siiani olen teinud ? 1.45v läheb ta üpris kuumaks ja ei suuda lõpetada runni !
jeesus188, krt pole kuskil tähelepanu põõranud selle turbole ( uurin) Mäludes asi ei ole !
Tänud nõuannete eest mida platel biosist maha keerata Nüüd loodetavasti targem
110 |
Juan Pablo
23.05.2011 22:52:02
esseker,
mul käis veega.... sorry... et ei ytelnud
29 |
fixtix
