xpander
26.08.2010 00:05:52
katsetasin ka utorrentit vahepeal. mingi jama jah 2.xx versiooniga. uut alphat pole veel proovinud.
hetkel kasutan siiski edasi Deluge 1.3 rc2
| Kommentaarid: 18 loe/lisa |
16 |
karts3
29.08.2010 09:12:01
| Kas keegi on juba 2.0.4 proovinud. Tsiteerin ühest kinnisest trackerist..- Today uTorrent 2.0.4 build 21586 was released, which fixes a tracker retry bug.
| Kommentaarid: 62 loe/lisa |
61 |
29.08.2010 09:46:17
| 2.0.4 on ka Windowsi turvaaugu parandus.
| Kommentaarid: 85 loe/lisa |
Ainivana
29.08.2010 14:01:11
mul töötab siiani korralikult ja nii kui pakub uut versiooni tirin kohe ja kõik tiptop
_________________ Ei aktsepteeri: Ei saa, lihtsalt motiiv puudub! |
8 :: |
91 |
Heineken
29.08.2010 14:14:43
2.0.4 töötab siiani korralikult...
| Kommentaarid: 24 loe/lisa |
23 |
martin366
13.09.2010 13:53:41
| Just tuli 2.2 (21882) beta välja millel palju paremad kiirused. Eelmisega tõmbas 300 kanti, nüüd laseb 600-1200kb/sek.. eitea mis magic see on, kas mingi kokkusattumus vms.. aga igastahes ma rahul. Vähe teistsugune kujunus on kah. 5+
172 |
Ra*
| Kommentaarid: 135 loe/lisa |
123 |
11.12.2010 02:28:05
Eriti see VLC oma on täielik jama.Lugege seda kommi ja saate aru miks :
I’m sadly forced to agree with those describing µTorrent’s VLC-app as useless bloat. I tried it out and I’m very relieved it’s a purely optional download.
µTorrent has labels for sorting files and playback controls built into it by default (you can already use it to run whatever application you want for whatever file you want), so µTorrent+VLC seems entirely redundant to begin with.
The app insisted on installing it’s own complete version of VLC – it didn’t seem to want to use my existing installation.
Once it finished installing, I started the app and it started searching the files in µTorrent to see what it could play. I waited. Eventually, I tried to click on one of the other icons. I got an Internet Explorer error message: “A script on this page has stopped responding.”
On cancelling the error message, the actual files listing appeared, which was very simplistic and rather ugly. I saw no options not already easily achievable in normal, vanilla µTorrent. There was a button in the top-right corner which seems to be some sort of communications option, but all it did for me was produce another identical error message.
The thing was so horrible to look at that I no longer cared whether it would play a file and so slow I’d forgotten what it was I actually wanted to watch. I uninstalled it.
After uninstalling the µTorrent-app (cancelling the app’s attempt to forcibly uninstall VLC itself), I tried VLC to see if it had interfered with my preferences. It hadn’t, but I checked and found the app-installed VLC wasn’t even the latest version, so I had to update that again.
What a complete and utter waste of time and bandwidth.
I can see no current advantage whatsoever to having VLC bolted into the torrent client – as far as I can see, it does absolutely nothing that the two separate applications can’t already do far, far better.
µTorrent = good. VLC = good.
µTorrent + VLC app = the top dictionary definition of crap sandwich. |
| Kommentaarid: 92 loe/lisa |
14.12.2010 09:56:18
| Mul 2.2 uuendatud, aga testida pole jõudnud. Üldiselt uTorrent on ikka väga stabiilne ja lollikindel torrent.
200 |
martin366
14.12.2010 12:48:28
2.2 stable on siiamaani parim olnud minuarust, tuleb kenasti alla. Samas ennem kasutasin viimast betat (eitea kas enam on see sama viimane) mis oli paras pask, jooksis kokku jnejne..
172 |
19.04.2011 23:29:15
Muutsin teema pealkirja ja esimese posti
Ühtlasi läksin kuskil 3 nädalat tagasi lõpuks uuema peale üle.Varem olin 1.8.5 peal, kuna 2.0 ei kõlvanud (minu meelest) kassi saba alla kah.
Nüüd siis uusima stabiilse 2.2.1 peal.Üldiselt on kiirem kui 1.8.5 kui uTP välja lülida (sellest allpool juttu).
UI muutsin küll teema abil tagasi 1.8.5 peale, et veidi kodusem oleks ja statistika tõin kah üle .
Nüüd siis kiirusetestid mis ma loetud nädalad tagasi jooksutasin, et otsutada kas ülemineku kasuks või kahjuks:
2.2.1 uTP sisselülitatud:
1.8.5:
2.2.1 sätted üle toodud ja uTP väljas:
Nagu näha pole vaja kaugelt otsida põhjust miks ma uTP välja lülitasin.Tegu on täieliku jamaga .Isegi kui taustal ei toimu testi ajal mittemingisugust võrguliiklust suudab see raip ikka allalaadimiskiirustele põntsu panna
1.8.5 vs 2.2.1 kaks viimast testi mahuvad pmst statistilise vea piiresse, kuna 3 sekundit pole teab mis märgatav vahe.
Siiski UDP tracker support mulle meeldib + veel mõned uuendused 2.2.1-s
EDIT 20.04.2011:
uTorrent 3.0 Adds Ratings, Comments and Streaming
http://torrentfreak.com/utorrent-3-adds-ratings-comments-and-streaming-110419/
Tegin ühe ettepaneku kah:
http://uservoice.com/a/fWRZf
WäntWõll
make.believe
19.04.2011 23:44:18
sulle on üsna üheselt vastatud
300 |
WAV
23.04.2011 15:35:27
| See 2.2.1 tundub juba paras bloat olema, vähemalt Windowsi all. Isegi kui installimisel selektida maha kõik linnukesed, et mitte lubada tal lisaks crap-toolbar'i installida, siis pärast selgub et ta on ikkagi selle salamahti ära installinud. Selle mahasaamiseks tuleb siis eraldi remove-software alt utorrent-toolbar eemaldus teha ja lisaks samast listist veel "conduit engine" (mille ta ka lisanud on) ka maha võtta, muidu ei aita.
| Kommentaarid: 7 loe/lisa |
Vahur
23.04.2011 15:43:05
| WAV, ei tea, minule ta küll midagi sellist installinud pole. Vast jäi sul mõni linnuke kahe silmavahele.
388 |
23.04.2011 15:58:19
| WAV kirjutas: |
| See 2.2.1 tundub juba paras bloat olema, vähemalt Windowsi all. Isegi kui installimisel selektida maha kõik linnukesed, et mitte lubada tal lisaks crap-toolbar'i installida, siis pärast selgub et ta on ikkagi selle salamahti ära installinud. Selle mahasaamiseks tuleb siis eraldi remove-software alt utorrent-toolbar eemaldus teha ja lisaks samast listist veel "conduit engine" (mille ta ka lisanud on) ka maha võtta, muidu ei aita. |
Proovi käsurealt installida selle käsuga:
Hetkel ei mäleta kas eemaldasin käsitsi või neid ei paigaldatud, kuna kasutasin käsurida.
Siiski jah bloat kohe üldse ei meeldi
Kuidas teistel 2.2.1 sulgemiskiirusega on?.Mul istub veel kümmekond sekundit pärast sulgemist.Kui bt.graceful_shutdown true panna siis veelgi kauem
EDIT:
Ei hetkel seda probleemi polnud kummagi sättega.Ju siis mingi one-off insident
WäntWõll
make.believe
23.04.2011 15:59:48
Ei tule mingit bloati kaasa, user ise hämab midagi
Sulgemisel sulgub 1-2 sek.
W7 64bit ja nüüdseks juba 3.xxxx beta peal.
300 |
WAV
23.04.2011 16:15:24
| [VaHuR] kirjutas: |
| WAV, ei tea, minule ta küll midagi sellist installinud pole. Vast jäi sul mõni linnuke kahe silmavahele. |
Ei oska enam tagantjärgi täpselt arvata. Uuesti proovida ka ei julge enam. Samas tundub, et ma pole ainus sellise probleemiga:
http://forum.utorrent.com/viewtopic.php?id=90382
Võimalik, et kuidagi kasutaja enda süsteemiga ka seotud.
23.04.2011 16:31:26
| WäntWõll kirjutas: |
| W7 64bit ja nüüdseks juba 3.xxxx beta peal. |
µT betasi küll ei julge kasutada.Need on minevikus ikka väga bugised olnud
Õnneks saab testida kah:
Encapsulated "Installation"
While %AppData%\uTorrent is the default directory for storing the settings, µTorrent actually searches the directory that the executable file is located in first before looking in %AppData%\uTorrent. As such, so long as the directory that the executable is located in contains a settings.dat file (even a blank one), µTorrent will look no further, and use only the files located in its current directory instead. With this behavior, it is possible to create encapsulated µTorrent "installations" for use on portable flash drives, or just to have an isolated copy for any other reason.
If you don't already have an encapsulated install, you can manually move the contents of %AppData%\uTorrent into the same directory as the µTorrent executable to create such an install. |
WäntWõll
make.believe
23.04.2011 17:43:48
Pseudoprobleem ja minevikus ei viitsi nagunii eriti elada
300 |
23.04.2011 22:03:18
Pseudoprobleem ja minevikus ei viitsi nagunii eriti elada  |
Vaata fix liste releasede juures ja näed palju asju alati Beta-Release parandatud on.See on ikka pikk list.
Minu arvamus on ja jääb, et µT betad ei kõlba muuks kui korra näppimiseks aga oma profiili ei usalda kasutada sellega.
d3t
23.04.2011 23:10:08
Millegipärast pole mul uTorrentiga mingeid jamasid. Käivitamisel valin et on 10mbit ühendus ja edasi töötab kõik kenasti. 1MB sekundis download on niiehknaa maksimum mida mu ühendus võimaldab ja see on pidevalt ees kah.
_________________ next.Insiders - koht mängijatele ja tehnikahuvilistele toredaks ajaveetmiseks.
72 |
WäntWõll
make.believe
23.04.2011 23:22:00
| tomorrow kirjutas: |
Minu arvamus on ja jääb, et µT betad ei kõlba muuks kui korra näppimiseks aga oma profiili ei usalda kasutada sellega. |
Ei tea ikkagi, äkki sul mingid jamad browsimisega FF pole just kõige tugevam tarkvara
Siiani siin kõik ok ja kiiruste vahed olematud, võrreldes eelnevatega.
Usun et tihendi viga või kinni keeratud W bygid, edu
300 |
HukkunudAlpinist
26.07.2011 20:30:30
UUes arvutis uus U-Torrent ja ma ei leia kuidagi üles seda kohta kust saaks ära muuta torrentite automaatse käivitamise? Kui ühe torrenti all on näiteks kümme kausta aga ma tahan ainult alla laadida ühe siis ma ei saa ülejäänud üheksal linnukesi eest ära võtta.Vanas arvutis sain.
_________________ Me kõik oleme ise valinud kellena siia maailma sündida. |
26.07.2011 20:49:36
| HukkunudAlpinist kirjutas: |
| UUes arvutis uus U-Torrent ja ma ei leia kuidagi üles seda kohta kust saaks ära muuta torrentite automaatse käivitamise? Kui ühe torrenti all on näiteks kümme kausta aga ma tahan ainult alla laadida ühe siis ma ei saa ülejäänud üheksal linnukesi eest ära võtta.Vanas arvutis sain. |
Options - Preferences - UI Settings - Don't start the download automatically - linnuke ette.
Selleks, et valida ainult osa asju failide nimekirjas hoia CTRL klahvi all samal ajal kui sa nende peale klikkad.Siis Don't download ja neid ei laetagi alla.
Ma ei tea aga 2.2.1 versioonis mul linnukesi küll ees pole failide ees seal nimekirjas.
