RCC
08.03.2011 18:03:52
sa oleks nagu see delfi valvekommar, et kiidad kah ainult ühte parteid . conner oskas teha vägagi häid ja kõik väiksemad firmad kes on "konsolideerimise" käigus ära "kaotatud" quantumi seeriad, samsung nüüd, hitachi veidi vähem, fujitsu jne -et tolmu koguvad, ei kogu, käibes on koguaeg.
Kommentaarid: 185 loe/lisa |
9 :: |
147 |
08.03.2011 19:13:31
RCC kirjutas: |
sa oleks nagu see delfi valvekommar, et kiidad kah ainult ühte parteid . conner oskas teha vägagi häid ja kõik väiksemad firmad kes on "konsolideerimise" käigus ära "kaotatud" quantumi seeriad, samsung nüüd, hitachi veidi vähem, fujitsu jne -et tolmu koguvad, ei kogu, käibes on koguaeg. |
Mina lähtun enda ja tuttavate kogemustest.Tuttavatel on jah ka WD kettaid läinud aga mitte rohkem kui mõne teise tootja toodangut.
Kommentaarid: 92 loe/lisa |
AJ
08.03.2011 21:31:10
Samsung HDDs reach 1TB per platter areal density
TechSpot
tsitaat: |
Samsung has announced a new breakthrough in HDD areal density, pushing up to one terabyte of data per platter in a new line of drives being shown off at this year's CeBIT convention in Hanover, Germany. The company demonstrated a 3.5-inch two-terabyte, two-platter model during the event that will launch as part of its Spinpoint EcoGreen series of drives featuring 5400RPM spindle speeds, 32MB of cache and SATA 6Gbps connectivity.
The achievement will eventually lead to lower cost, high-speed 3TB and 4TB models. But the bump in platter densities isn't just for desktop class drives, as Samsung is also showing 1TB 2.5-inch HDDs for laptops, which integrate two 500GB platters along a 8MB cache and 3Gbps SATA interface. The upshot is that this new drive will be standard-sized for compatibility with most laptops rather than 12.5mm tall as last year's model.
The 1TB notebook drive could debut as early as April, according to reports, while an estimated launch date or price for the newest member of Samsung's Spinpoint EcoGreen (5400 RPM) desktop series remains unknown. |
Kommentaarid: 37 loe/lisa |
36 |
08.03.2011 22:11:59
4TB selle aasta lõpus?
AJ
08.03.2011 22:13:53
tomorrow kirjutas: |
4TB selle aasta lõpus?  |
Paistab küll nii
tsitaat: |
While Samsung is naturally tight-lipped about the shipments date for the novelty, the company reportedly did confirm intentions to ship the 4TB hard disk drive in calendar 2011. |
Samsung Shows Off Prototype of 4TB Hard Disk Drive.
X-bit labs
36 |
SurfData
09.03.2011 14:49:03
no ise ootasin ka, et 4tb tuleb selle aasta teises pooles. Umbes nii võis arvata septembris, kui liikusid juba jutud et 1-2 kuu jooksul tulevad 3TB kettad.
Kommentaarid: 84 loe/lisa |
74 |
DVDRW
09.03.2011 15:10:57
10tb ketas ehk aastal 2020?
Kommentaarid: 28 loe/lisa |
SurfData
09.03.2011 15:15:30
DVDRW kirjutas: |
10tb ketas ehk aastal 2020?  |
pakun 2014-2015 aasta kanti pigem
74 |
09.03.2011 20:50:49
SurfData kirjutas: |
DVDRW kirjutas: |
pakun 2014-2015 aasta kanti pigem  |
Liiga vara ma arvan.2016-2017
Chaza!
10.03.2011 00:55:37
Uurisin siin läpaka 1tb kettaid ning kas mõni on õhuke ka või kõik on paksukesed?
_________________ Linux - Future
1984 was not supposed to be instruction manual |
Kommentaarid: 58 loe/lisa |
53 |
10.03.2011 08:28:13
Chaza! kirjutas: |
Uurisin siin läpaka 1tb kettaid ning kas mõni on õhuke ka või kõik on paksukesed? |
Nagu AJ lingitud uudisest selgub, siis varsti peaks ka õhukesi saama:
tsitaat: |
Samsung is also showing 1TB 2.5-inch HDDs for laptops, which integrate two 500GB platters along a 8MB cache and 3Gbps SATA interface. The upshot is that this new drive will be standard-sized for compatibility with most laptops rather than 12.5mm tall as last year's model. |
AJ
14.03.2011 21:44:25
Seagate Barracuda 7200.11 1.5TB review
TechRadar
E.
Hitachi's Deskstar 7K3000 3TB hard drive
The Tech Report
36 |
DVDRW
15.03.2011 16:03:16
Chaza! kirjutas: |
tsitaat: |
Oleks juba aeg jah, kuna 1 platteriga 2,5" 500GB ketas oli juba kaua aega tagasi olemas.
Chaza!
17.03.2011 01:55:27
Vaatan jälle siin neid 1tb läpaka kettaid ja tekkis küsimus, et kas praegu osta või oodata, et äkki lööb hinda alla kui midagi uut peale tuleb?
http://www.galador.ee/catalog/view/115-suelearvutile-2-5/filter/4353
Siin on WD ja Samsung, tasub vist ikka wd-d eelistada või mis te arvate?
53 |
toivos
17.03.2011 09:44:48
Chaza! kirjutas: |
Siin on WD ja Samsung, tasub vist ikka wd-d eelistada või mis te arvate? |
Enne kontrolli kas nad sinu note sisse mahuvad.
_________________ Taastan datat katkistelt ketastelt ja katkistelt Flash(USB) mäludelt. Nüüd ka katkistelt SSD ketastelt. |
Kommentaarid: 69 loe/lisa |
65 |
DVDRW
17.03.2011 10:09:47
1TB 2,5" on jah paks, st enamustesse läpakatesse ei mahu - mõeldud rohkem välisena kasutamiseks.
Chaza! kirjutas: |
et äkki lööb hinda alla kui midagi uut peale tuleb? |
Hinnad HDDdel pole mitmeid kuid eriti muutunud, SSD hinnad viimasel ajal pidevas väikses tõusus, niiet midagi loota eriti pole
Chaza!
17.03.2011 11:58:47
toivos kirjutas: |
Chaza! kirjutas: |
Enne kontrolli kas nad sinu note sisse mahuvad. |
Sisse ma ei tea kas mahub aja mõõtes tundub, et peaks mahtuma dvd-romi koha peale.
53 |
AJ
21.03.2011 15:48:34
Seagate 3TB Barracuda XT Review (ST33000651AS)
StorageReview
36 |
RiTa
29.03.2011 11:55:00
Kuna ei ole eriti aega süvitsi minna ja netiavarused läbi kammida siis uurin targemate käest. Pean uue välise ketta soetama. Vana( Verbatim 320gb) hakkab täis saama ja peab midagi uut leidma. Vajan just sellist millel ei ole välist toidet. Verbatim on ülihästi vastu pidanud ja vaikne,mis on väga oluline. Oman veel kahte WD 500gb ja 1,5tb ketast mis on toite pealt. Neid kobakaid aga läpakaga kaasas ei tassi:)
Siin foorumis ringi uurides jääb mulje, et WD pole just soositud. Minu kaks WD on õnneks olnud väga tublid kuigi see 500gb on hirmus lärmaja:)
Annan mõned lingid mille suunas vaatan. Igasugune abi oodatud ja soovitage, ehk on veel midagi paremat(vahemikus 750-1000gb).
1. WD - http://disney.com/s1byq
2. Seagate - http://disney.com/1try7
Kommentaarid: 3 loe/lisa |
AJ
30.03.2011 08:43:36
Gigabyte "Unlocks" 3TB+ Hard Drives on 32-Bit Systems
X-bit labs
tsitaat: |
Gigabyte Technology, one of the world's largest makers of mainboards and graphics cards, has announced a new utility, which will help to utilize large hard disk drives on 32-bit systems. At present the utility allows to utilize drives with 3TB and higher capacity on the most advanced mainboards, but eventually it will support all shipping platforms from Gigabyte.
The hard disk drives (HDDs) with higher than 2.19TB capacity have to use 64-bit operating system, new logical block addressing (LBA) standard along with new UEFI (universal extensible firmware interface) replacement for BIOS (basic input-output system) and sometimes 4KB sectors (up from 512 bytes on the vast majority of current drives),. While it is not hard to install a 64-bit operating system onto any more or less new personal computer, changing a mainboard with BIOS onto a mainboard with UEFI (which are not available widely) is a problem for a majority of PC owners and transiting from BIOS to UEFI is a headache for motherboard manufacturers. One of the solutions to make 3TB and similar drives work under 32-bit operating system, or on a PC that does not support UEFI is to utilize a special controller for large-capacity hard disks. Another one is to use special software that lets users to split the large drives into partitions and create virtual drives.
The Gigabyte 3TB+ Unlock Utility allows Gigabyte motherboards without Hybrid EFI to recognize and use unallocated space on new 3TB and larger hard disc drives (HDDs).
The utility lets the user to create a virtual drive with space that exceeds 2.19TB, the maximum amount of storage recognized by 32-bit versions of operating systems, such as Windows XP. The virtual drives are limited to 2048GB, and the user can create up to 128 partitions, as long as there is additional unallocated space on the HDD. 3TB+ Unlock supports both GPT (GUID Partition Table) and MBR (Master Boot Record) partition styles, however with MBR the number of partitions are limited to 8. The utility is similar to the one that Seagate ships along with its 3TB desktop HDD.
The 3TB+ Unlock currently supports new high-end motherboard models based on the Intel X58, Intel 6-series and AMD 8-series chipsets, and is in the process of being ported to older chipset models so that it will support all motherboards that are currently shipping. Even though end-users of mainboards featuring latest core-logic sets will hardly use 32-bit operating systems, far not all modern mainboards support EFI in thus may not support 3TB hard drives, which is why the utility from Gigabyte seems to be a useful one.
The utility is freely available from the utilities page of the official Gigabyte website. |
36 |
karuke
31.03.2011 17:24:43
Tahtsin küsida, et kas see on normaalne, et RAID 1 pandud arvuti boottime peabki pikemaks minema, et miski RAID menüü käib peale BIOS'i veel eest läbi, et ennem käivitas masin sirka 30 seki nüüd 50. On see normaalne. Ahja system on SSD peal hetkel raid on siis andmete jaoks.
Kommentaarid: 42 loe/lisa |
41 |
smurfer
31.03.2011 17:53:43
karuke kirjutas: |
Tahtsin küsida, et kas see on normaalne, et RAID 1 pandud arvuti boottime peabki pikemaks minema, et miski RAID menüü käib peale BIOS'i veel eest läbi, et ennem käivitas masin sirka 30 seki nüüd 50. On see normaalne. Ahja system on SSD peal hetkel raid on siis andmete jaoks. |
Jep, see ongi normaalne
Kommentaarid: 351 loe/lisa |
299 |
karuke
31.03.2011 18:05:01
Kurb , SSD kettast pole siis käivitamisel mitte essugi kasu
smurfer kirjutas: |
karuke kirjutas: |
Jep, see ongi normaalne  |
41 |
olc
31.03.2011 18:36:33
Võtsid SSD selleks et masin kiiremini käima käiks? Ära pane masinat üldse kinni siis
karuke kirjutas: |
smurfer kirjutas: |
karuke kirjutas: |
Kommentaarid: 137 loe/lisa |
125 |
karuke
31.03.2011 20:16:51
Noh mis ma masinast ikka koguaeg jooksutan, kuigi tegemist on HTPC'ga ja voolu just palju ei tarbi. Noh muidugi muud programmid jooksevad siga kiirelt ja kui ta lõpuks wini laadima hakkab siis on kiire aga ikkagist
olc kirjutas: |
karuke kirjutas: |
smurfer kirjutas: |
karuke kirjutas: |
41 |
