Mercury
23.02.2011 00:43:00
| otty kirjutas: |
Uus patch. Tundub vahva
* Implemented a new lighting engine with the help of MrMessiahs (can be turned off)
* Changed the options around, added a new “Graphics options” button
* Added beds. If all players in a map sleeps in a bed during night, the game immediately skips until morning
* Added three new half-size blocks
* Added Delay/Repeater redstone dust blocks
* Added whitelisting to the server. To use, enter “whitelist <cmd>” where cmd is “on”, “off”, “add <player>”, “remove <player>”, “list” or “reload”
* New save file format, old maps need to be converted (that might take a while..)
* It’s now possible to have more than five save slots, and to rename saves
* Scrollbars in both the texture pack list, and in the map selection screen
* Replaced the Mojang splash image to reflect the new logo colors
* .. and a bunch of bug fixes and tweaks!
| * Changed the options around, added a new “Graphics options” button |
BetterLight Mod
| * Added beds. If all players in a map sleeps in a bed during night, the game immediately skips until morning |
You can only sleep at night - Päeval ei saagi magada
| * Added three new half-size blocks |
Cobble, Wood, Sandstone
| * New save file format, old maps need to be converted (that might take a while..) |
McRegion FTW!
| * Replaced the Mojang splash image to reflect the new logo colors |
| Kommentaarid: 61 loe/lisa |
60 |
tarts608
otty
23.02.2011 08:23:44
Seda näeb ainult hetkeks ja see nüüd nii jube ka pole imo Uus valgustussüsteem mulle meeldib, ootasingi kuni midagi sellist tuleb Ainuke häda on vist sellega see, et see on vägagi nõudlik. 580 @ 407 Mhz suutis pea 50 % ära võtta videokasutust
| Kommentaarid: 27 loe/lisa |
25 |
Mercury
23.02.2011 16:22:29
| otty kirjutas: |
Seda näeb ainult hetkeks ja see nüüd nii jube ka pole imo Uus valgustussüsteem mulle meeldib, ootasingi kuni midagi sellist tuleb Ainuke häda on vist sellega see, et see on vägagi nõudlik. 580 @ 407 Mhz suutis pea 50 % ära võtta videokasutust  |
Selle featuuri saab kinni keerata. Notch võttis selle MrMessiahs üle. Samuti McRegion. Põhimõtteliselt ise ta mitte midagi juurde ei teinud.
Kuigi BetterLight on ikka parem kui hetkel olev 1.3.
60 |
SinineSiil
23.02.2011 16:53:05
| otty kirjutas: |
Mul läks just fps paremaks. Enne kõikus 30-40 vahel, nüüd on 60-120.
| Kommentaarid: 20 loe/lisa |
19 |
Mercury
23.02.2011 17:10:57
| SinineSiil kirjutas: |
| otty kirjutas: |
Mul läks just fps paremaks. Enne kõikus 30-40 vahel, nüüd on 60-120.  |
Tänu McRegioonile läks ta tõesti paremaks.
60 |
otty
23.02.2011 19:38:52
Lihtsalt mul tunne, et mäng nõudlikumaks muutnud, mängu jooksutamisega ilmseleglt ju probleeme ei tule!
25 |
SinineSiil
19 |
Mikropluos
02.03.2011 17:33:22
| Hommik, kas te kõik maksate selle mängimise eest? Või mingid privaatsed serverid ka olemas?
prtv
02.03.2011 17:35:04
HV-s maksavad kõik.
_________________ |
| Kommentaarid: 82 loe/lisa |
73 |
ertr2
02.03.2011 18:26:12
| mängimine HV serveris on tasuta, aga mäng ise maksab jah
| Kommentaarid: 67 loe/lisa |
65 |
robertzon
02.03.2011 19:42:25
kellelgi mõni ALPHA kood alles on veel?
kui on siis võtke ühendust
puik17
02.03.2011 21:14:54
| Mul selline jant, et kui mängu akent suuremaks venitan, sis crashib. Milles häda võib olla?
| Kommentaarid: 79 loe/lisa |
75 |
Midigi
03.03.2011 20:16:37
oleks soov osta seda mängu aga ei ole krediitkaarti kas keegi oleks nõus mind aitama ostuga kui saab muidugi? annaks ka väikse lisatasu
Tänud
| Kommentaarid: 36 loe/lisa |
34 |
anonymic
03.03.2011 20:31:45
Kas sellest ei saagi läbi või aitab TNT?
17 |
Mercury
03.03.2011 21:00:47
| anonymic kirjutas: |
Miks sellest läbi vaja minna?
60 |
Traf
03.03.2011 21:02:06
Texture packist ei saa aru päris, aga kui sügaval oled, siis see on bedrock, sellest ei saagi läbi.
| Kommentaarid: 49 loe/lisa |
48 |
SinineSiil
03.03.2011 21:03:33
See peaks olema Bedrock. Sellest pole võimalik mitte mingil viisil läbi minna. Milleks sul üldse sellest läbi minna vaja on? Sellest edasi pole mitte midagi, tühjus.
19 |
Maiamees
04.03.2011 16:24:26
Mercury , saad kasutaja "flashsnake" whitelisti lisada ? Sain kah siis mängu
SinineSiil
19 |
Mercury
04.03.2011 23:34:42
Kas seda sama soundtracki tasuta ei saa minecraft.jar'ist?
60 |
SinineSiil
04.03.2011 23:40:51
| Mercury kirjutas: |
Kas seda sama soundtracki tasuta ei saa minecraft.jar'ist? |
Vaatasin just järgi: 14 lugu on Minecraftis olemas .ogg failina. Teisi pole/ei leidnud.
19 |
Hacka
05.03.2011 02:02:26
| Keegi viitsiks aidata mul ka minecrafti osta? Mõnus pela tundub olevat.
SinineSiil
19 |
Nibulik
06.03.2011 18:41:31
Mnjaa, ma ei saa seda PSi saata siin HV-s veel, et kas keegi saaks enda MSNi siia visata kellekaudu saaks mängu ehk osta?
Tänan.
