-FoX-
15.02.2011 21:10:07
| Chidori kirjutas: |
-FoX-, Homme siis sul käes... eile õhtul sai Veerenni esindus Serverist IP blocki ja enamus kaupa jäi väljastamata  |
Ei nuh ma pole midagi veel tellind aga kui homme saan tasuta siis usu mind ega ma tagasi ei saada;)
_________________ Aita suve, söö lund! |
| Kommentaarid: 367 loe/lisa |
6 :: |
307 |
Chidori
15.02.2011 21:46:57
ahsuhh... ei olnudki sinu oma? üks läks täna teele igatahes
99 |
AJ
15.02.2011 22:11:10
See peaks olema väga asjalik toide.
| The main “problem” with this power supply is its price. Two hundred dollars is a lot of money for the average user, but this product is definitely targeted to users that demand “the best of the best” and is willing to pay for it. |
Hardware Secrets
| Kommentaarid: 37 loe/lisa |
36 |
Chidori
16.02.2011 02:01:42
| -FoX-, Kas X760 ei piisa? ca. 35 Eurot odavam ju.
99 |
Auron
16.02.2011 09:45:56
Hea toide on. Ainuke miinus on see, et kui hakkad piiripeal koormama toidet siis vent lõugab. Kui hea hinnaga saad (nagu endaoma sain) siiis tasub võtta.
133 |
AJ
16.02.2011 22:57:39
Corsair unveils the Enthusiast Series TX V2 power supplies
TechConnect Magazine
Corsair has just announced its second-generation Enthusiast Series TX power supply family which consists of 650W, 750W and 850W non-modular units, all featuring an 80Plus Bronze rating and an efficiency of up to 85%.
The new PSUs make use of an updated DC-to-DC converter design to provide tighter voltage regulation, are ATX12V v2.31 and EPS 2.92 compliant, have a single 12V rail, active PFC (Power Factor Correction), SLI certification, a 140mm double ball-bearing fan, and are backed by a five-year warranty.
"For years, the Enthusiast Series TX PSUs have been a favorite of gamers, high-performance PC enthusiasts, and anybody who requires reliable, low-noise power delivery," said Ruben Mookerjee, VP and General Manager for Components at Corsair. "The new TX V2 power supplies are quieter and even more energy efficient, while providing the same legendary reliability, flexibility, and value that customers have loved about the original TX PSUs."
The TX650 V2, TX750 V2 and TX850 V2 power supplies are now shipping in the Americas an Europe, bearing recommended price tags of $99, $119 and $139, respectively. All three are expected to reach Asian markets in March. |
36 |
AtsEst
17.02.2011 19:34:39
Soovitage toidet
GTX 560 Ti OC (tehas)
Q6600
4GB DDR2
2x 7200 rpm Sata HDD
| Kommentaarid: 4 loe/lisa |
martin366
172 |
pohmakas,
käed värisevad
17.02.2011 20:37:25
| Jep, hea valik on sellisele süsteemile.
| Kommentaarid: 167 loe/lisa |
138 |
denis28
| Kommentaarid: 67 loe/lisa |
martin366
172 |
fn
17.02.2011 21:06:35
link :: seasonic
| AtsEst kirjutas: |
Soovitage toidet
Q6600
4GB DDR2
2x 7200 rpm Sata HDD |
võib eestist ka osta: 61,5€
| Kommentaarid: 94 loe/lisa |
84 |
CoiL
| Kommentaarid: 95 loe/lisa |
83 |
AJ
17.02.2011 21:59:00
See oleks ka hea valik.
36 |
AtsEst
17.02.2011 22:48:49
Aitäh hüva nõu osas kõigile.
Pea kõik variandid olid mul enne mõttest läbi käinud
Ise kaldun selle 620W Seasonic'u poole, Pixmaniast selle Sapphire veidi kahtlane tellida(teiste kogemusi lugedes) ja garantii tuleks jõle ebameeldiv ning kallis.
Vana 550W Xilence on nõrgaks jäänud ja ei julge enam väga toite pealt koonerdada ka, kuigi raha vähe.
Tänud kiirete vastuste eest.
AJ
17.02.2011 22:52:50
Üks Corsair TX V2 seeria toiteka ülevaade
Corsair TX850 V2 850W
JonnyGURU
36 |
karuke
| Kommentaarid: 42 loe/lisa |
41 |
CoiL
18.02.2011 09:37:14
| karuke, sinu meedia-arvutile kärab tollest soovitatud Corsair`i toitest küllaga! Aga kui mõtled veits tuleviku peale ja plaanis uus arvuti ehitada jne. siis oleks sul juba korralik toide võtta selle 620W seasonic`u näol.
83 |
karuke
18.02.2011 14:37:06
Jep just tuleviku silmas pidades kuna plaan kunagi TV kaart + Helikaart + Videokaart juurde panna.
| CoiL kirjutas: |
| karuke, sinu meedia-arvutile kärab tollest soovitatud Corsair`i toitest küllaga! Aga kui mõtled veits tuleviku peale ja plaanis uus arvuti ehitada jne. siis oleks sul juba korralik toide võtta selle 620W seasonic`u näol. |
41 |
CoiL
18.02.2011 20:10:12
| karuke, kõik oleneb ka sellest mis video sa sinna sisse plaanid osta. Kui mingi mänguri high-end kaart siis jah mõttekas vast see 620W võtta aga muidu kui mingi mid-range kaart ja cpu kah suht nõrguke ning kellamata ,siis kärab ka see corsair.
83 |
TXX
19.02.2011 21:17:55
Igastahes minu Seasonic x-850 Gold töötas täpselt 2 päeva ning peale seda enam arvuti käima ei läinud. Käis reedel Arvutikeskuse garantiiosakonnast läbi ja sealt helistati, et toiteplokk täiesti töökorras (müstika). Käisin reede õhtul järel ja laupäeva hommikul panin arvutisse ja ennäe imet ikka ei tööta. Lammutasin komponendid kastist välja ja ühendasin lauapeal ära. Tulemus sama. Proovisin ka teises "lahjemas" arvutis, mis esimest korda proovides, ega ka teist korda, tööle ei läinud. Sõbra käest sain korra testimiseks Zalmani 850W toite (näeb väga väga hea välja), mis käivitas arvuti koheselt. Viisin sõbrale toiteploki tagasi ja testisime Seasonicut ka tema masina peal. Tulemus zero. Jätsin asja sinnapaika ja läksin linnapeale asendus toiteplokki otsima. Kuna midagi normaalselt laupäeval on raske saada, tuli leppida Chiefteciga, mis tõmbas mu arvuti kohe käima.
Õhtul otsustasin veelkord Seasonicut proovida "lahjema" arvuti peal. Pärast mitut korda toiteploki sisse ja välja lülitades õnnestus arvutil ventilaatorid tööle saada, aga pilti ette ei saanud. Kuna masnin "nagu töötas" aga pilti ette ei võtnud järsku tuli hea idee tester välja otsida ja pinged ära mõõta 5V oli 5,06V aga 12V oli 10,65V. Mõõtsin ka pci-e pinge ära sama 10,65V. Pole ka ime, et sellise pingega videokaarti järgi ei võta. Esmaspäeval uuesti garantiisse minek.
See toiteplokk on mulle juba maksma läinud 185,60 € + asendusplokk garantiiajaks 89,80 € + hulgaliselt närvikulu.
Esimene ja arvatavasti ka viimane Seasonic. Säh sulle kvaliteetoidet.
| Kommentaarid: 91 loe/lisa |
85 |
angel
19.02.2011 21:37:00
kõigil juhtub aga...
tühjalt kah tööle ei hakka koos paari vendi vms ebavajaliku seadmega koormuseks? Ehk siis 24 pin otsikul roheline ja must omavahel kokku ja käima. Huvitav kuidas AK siis seda testis, et asi töötavaks märgiti
Aga ole õnnelik, et midagi kaasa ei võtnud vms jamasid ei põhjustanud... enamasti kui toided ei tööta või "otsad annavad" armastavad teatud tootjate plokid enesega midagi kaasa võtta
157 |
omgwtf
19.02.2011 22:06:50
Antud veaga ei võta ta miskit endaga kaasa kuna pinge lihtsalt madalam kui olema peaks.
Mind ennastki huvitaks kuis AK testis asja
137 |
TXX
19.02.2011 22:10:29
| Tühjalt ma ka juba mitu korda proovisin ja nii õnnestus paaril korral ka 12 Vent käima saada. Aga pinget mõõtes näitas 10 volti kopikatega ja see ei ole teps mitte normaalne kui lubatud on 3% ulatuses kõikumine. Seega lubatud vahemik oleks 11,40-12,60 volti. Enamasti tegi klõpsu ja vent tööle ei hakanud.
85 |
martin366
19.02.2011 22:12:38
AK spetsialistid kontrollisid seda vist viimase tööpäeva viimastel minutitel Saada uuesti sinna ja anna neile ikka vihje ka, et millega mida kontrollima peab
172 |
Go Kane!
19.02.2011 22:29:17
TXX
Kindlasti saada uuesti garantiisse
See poleks esimene kord kui garantiisse saadetud katkine asi terveks tunnistatakse, Ordis on endalgi seda paar korda juhtunud.
Saatsin uuesti ja ennäe imet, asendati uuega.
Aga ajakulu ja rahakulu suhtes jääd küll kahjuks miinusesse, midagi pole teha
_________________ Vajad midagi Würthist , küsi julgelt 😉 https://eshop.wuerth.ee/et/EE/EUR/
taavi.jahu@wuerth.ee +37258309618 |
| Kommentaarid: 1842 loe/lisa |
1345 |
19.02.2011 22:29:54
Väikse ääremärkusena - igasugused ventilaatoritega tekkivad koormamised on uuemat tüüpi võimsate toiteplokkide korral liialt väiksed ning sellise pisikoormusega samuti ei peagi toide käima minema.
Nii, et sellised moodsa aja 800-1000W tahavad kusagil 200-300W ja koormatud pevad olema kõik kolm pinget: 12V, 5V ja 3,3V - alles siis võib uskuma hakata pingete numbreid.
Ja ei räägi niisama - ehitan ise praegu tasapisi vähe suuremat koormust 850W Chiefteci toite remondi tarbeks.
Pisikoormusega, nagu ainult ventolaator, lülitab toiteskeemis olev kontroller toiteploki kohe välja ja kogu lugu.
211 |
TXX
19.02.2011 22:42:19
| Täiesti võimalik. Proovin homme 850W zalmani peal ka kas too tahab ka enamat kui ainult 1 ventilaator. Eks homme annan testi tulemusest teada. Ahjaa mõõdan ka seal pinged ära.
85 |
angel
19.02.2011 22:44:43
to tahanteada:
mes asja sa ajad... ise olen seni igasugu koormusega toited tühjalt tööle saanud (paar venti ainult küljes kuna väidetakse, et tühjalt ei tohi asja lasta).
Ja mis moodi saab arvuti hakata kohe 200-300w koormust andma kui toide ei löö talle pilti ette. Ehk siis ideeliselt... selleks et toide tööle hakkaks peaks tal olema 200-300w koormus taga... aga kuramuse kohast see tal tekkida saab kui arvuti ei tööta kuna toide peaks ta tööle panema mis vajab omakorda 200-300w koormust
Oma Corsair HX850 ei ole pidanud tühjalt tööle laskma aga olen seni lasknud -> 620W Corsair, 650TX Corsair, 600W OCZ PowerStream. Kõik kenasti tühjalt tööle kuna oli mingi hetk vaja testida. Ei kahtle eriti, et kui 850 lahti ühendan, vajalikud juhtmed omavahel ära ühendan hakkab seegi tööle.
157 |
omgwtf
19.02.2011 23:03:00
Kuula tema juttu.. Kohati jutt mõistlik ja igati ok ja samas kohati läheb väga metsa
Võin homme huviga täitsa ära proovida mida mul 1.5Kw teeb 1 ventikaga
Samas olen enam kui kindel,et suvalt valitud 1KW toitega tõmbad mingi Intel Atomi käima nagu naksti
137 |
TXX
19.02.2011 23:35:01
Nii tegin uue katse võtsin õe arvuti ja lisasin sinna kõvasti vente ka kõvakettaid ehk siis testi conf millest kahju ei ole Abiti AN7, Xp3200 Barton, 3 Gb DDR, GeForce 7800GS AGP, 6 kõvaketast ja 4x80 venilaatorit ja 2x 120 ventilaatorit.
Tulemus: vajustasin poweri nuppu korra tõmbas ventikad ringi no go. Teist korda no go. Kolmandat korda no go... seitsmendat korda tõmbas kõvakettad järgi ja jäi tööle nii paariks kolmeks sekundiks. Pc speekeer kukkus karjuma, kuna 12V (testriga mõõtes 10,6V) on liiga madal antud emaplaadi guru funktsioon võttis üle ja shutdownis masina
Ekraanile pilti ette ei saanud. Panin tagasi tt 360W toite buutis masin nagu tavaliselt
Ahjaa tt 360 tegin jumpstarti ja see lasi kohe ennast tööle isegi ilma ventikata.
Cheafteci 750W teen ka testi ära kas too kannatab ka jumpstarti ilma ventikata ehk ilma midagi järgi ühendamata.
Edit: 750W Chieftec sai kenasti jumpstardiga hakkama ilma et tal midagi järgi oleks olnud 12V oli 12.10V
tt 360W 12V oli 12.12V
85 |
sant
19.02.2011 23:36:46
TXX,
Sa ei pea selliseid asju tegema et midagi tõestada, kui toide on pees siis ta on pees ja sa pead garantiikorras uue saama. Tõestamine oligi see et ei sinu ega teise inimese arvuti ei läind tööle, mis seal toitel viga on pole sinu asi tegelt, see on tehase mure.
_________________ So, at the end of the day, after I have butchered all the nvidiots all around me, standing alone in a pool of blood surrounded by the corpses of my victims, a horrible truth reveals itself to me: I am an amd\ati fänboy...and I must do my dark masters bidding, for I am damned for all eternity... |
60 |
angel
19.02.2011 23:38:02
See su nupust "käivitus" meenutab mulle kunagi tööl olevat juhtumit kus mingi "viiking" toiteplokk, mis oli oma 5-10 aastat vana ehk, ei suutnud ühte arvutit käima lasta. Tükk aega punnisid ja peksid siis lõpuks hakkas tööle. Viisin toiteplokki ühe tööl oleva elektriku juurde ja too ütles et konded vms oli täiesti peetis või siis kuivad. Väitis, et kui kaua oleksin sedasi masinat tööle sundinud oleks kusagilt otsast lõpuks asi otsad andnud.
Ehk siis EHK on tegemist praagiga või on seal toites mingi asi "lahti" või omadega "puru". Garantii ja uuele katsele.
Toide nagunii "jumpstardib" kui selline "käsk" antakse... seda "200-300w mulli ei tasu uskuda... siis, nagu mõtisklesin, ei tohiks ju arvuti üldse töölegi hakata
157 |
TXX
19.02.2011 23:59:47
| Ega jah nüüd vähemalt olen 101% kindel, et toide kutu ja edasi tegeleb sellega garantii.
85 |
CoiL
20.02.2011 00:53:47
Mäletan, et ma ei saanud ka kusjuures oma kunagist Fortron BSII-te ühe-kahe ventikaga tööle kuna koormus oli liialt väike Aga kahju, et sul TXX sedasi läks selle toitega... peaks küll krdi kvaliteet olema aga võta näpust
83 |
martin366
20.02.2011 01:03:26
Absull igal tootjal juhtub mõni praak tehasest välja tulema, ega sellepärast Seasonic nüüd mingi saast pole, hoopis vastupidi
172 |
TXX
21.02.2011 16:36:25
Toide vahetati uue vastu välja peale 30 minutit. Kiidusõnad Veerennis töötavale noormehele, kes kuulas mu jutu ära ja läks tehnikutele seda edasi andma. Aga tehnikud seal kardina taga pildusid küll häid lauseid omavahel. Hetkel neid välja tooma siia ei hakka.
Loodetavasti kestab see toide nüüd igavesti.
85 |
Go Kane!
21.02.2011 16:42:15
| TXX kirjutas: |
Loodetavasti kestab see toide nüüd igavesti. |
Väga tore
Tehnikutel peaks häbi olema
1345 |
21.02.2011 18:22:15
angel: Aeg on selle peale mõtlema hakata, et suure võimsusega toited polegi mõeldud liialt väikeste koormuste töölerakendamiseks.
Õigemini - saaks kah, aga siis tuleb toiteploki sisse ehitada kaks sõltumatut toitegeneraatorit, üks mis toidab a 0-30%-ni ja teine, mis toidab a 30-st 100% võimsuseni.
Aga vaevalt sa tahad maksta kahe toiteploki eest, mis on ühte korpusesse kokku pekstud ja mille eest 2x rohkem hinda küsitakse.
martin366: See katkine toide, mis minu käes on, selle on mingi eelmine / või üle-eelmine omanik liigkoormusega maha põletanud.
Muidu ei saaks ehk aru, kuid 24-se pistiku 12V ja 3,3V klemmid on nii koormuse alll nii kuumaks köetud, et plastik on ümbert ära sulanud.
- Ja selle üles sulanud pesa äravahetus saab veel omaette ooper olema.
211 |
Jaan
22.02.2011 15:46:36
| tahanteada kirjutas: |
| angel: Aeg on selle peale mõtlema hakata, et suure võimsusega toited polegi mõeldud liialt väikeste koormuste töölerakendamiseks. |
Aeg on sul võtta kätte mõni uuem normaalne toide ja ise uurida-proovida- asi on täpselt vastupidi.
Tule oma 5+a. vanast low-end toitemaailmast välja juba, aeg ja toiteplokkide siseehitus on vahepeal edasi läinud.
| Õigemini - saaks kah, aga siis tuleb toiteploki sisse ehitada kaks sõltumatut toitegeneraatorit, üks mis toidab a 0-30%-ni ja teine, mis toidab a 30-st 100% võimsuseni. |
100% jama. Kui on mõnel võimsamal (1000+W) kaks toidet sees 12V ahelale, siis ALATI on nad ühesuguse võimsusega.
Veelkord,- kui sa teed oma punase kirjaga väiteid, too mingi link või pilt juurde, pole mõtet niisama lahmida.
123 |
pohmakas,
käed värisevad
22.02.2011 17:01:00
| ot: |
Jaan, ega ta siis ilmaasjata lõuapoolik ole  |
138 |
22.02.2011 17:45:58
Selles teemas pole, kahjuks, midagi eriti vaielda - need, kes füüsikareeglid ja tootmis-koostereeglid ära unustavad, imetlevad kas:
- surnud toiteplokke
- või imetlevad tehnikat, mille toiteplokk maha tappis.
Kes on miljonär, või kellel on rikkad mamma-papa olemas, neil on savi, kui tuhandeid kroone maksev tehnika sureb, kes ei ole miljonär, see valab tükk aega raskeid pisaraid.
Karm tõde, aga nii see kahjuks on....
211 |
CoiL
22.02.2011 18:00:05
tahanteada, selle asemel ,et siin demagoogiaga tegeleda võiksid tõesti reaalseid linke/pilte/dokumentatsiooni oma väidetele kinnituseks tuua
83 |
22.02.2011 19:12:11
Edit eelnevale: kuna mu Lp. head oponendid ei taha midagi kuulda sellest, et toiteplokki ei tohi koormata lubatud miinimumkoormusest väiksema koormusega, siis täpselt sama jutt Lp. oponentide IT-Piiblist, nimega Internet.
Minimum Load Current. The smallest amount of current (in amps) that must be drawn from a particular output for that output to function. If the current drawn from an output falls below the minimum, the power supply could be damaged or automatically shut down.
Link ise: http://geekscomputer.blogspot.com/2008/07/power-supply-specifications.html
PS: Näiteks rahva lemmikul 500W BSII-l on Minimum load 1A ja kui kasutada koormamiseks ventilaatorit, mis on 0,5A, siis ei saa mitte kuidagi seda 1A nõuet täita.
211 |
elukaz
22.02.2011 19:41:20
Jajah, paned paned liiga võimsa toite ja arvuti põleb maha.
Kus su revjuud on?
| martin366 kirjutas: |
1.Toiteka valmistaja ja mudel
2.Mis head/halba
3.lisada mõni pilt
158 |
Jaan
22.02.2011 20:10:28
Vaatasin huvipärast jonnyguru viimaseid psu ülevaateid- 5 viimati testitud toidetest igatahes ei keelanud 0A-ga põhiväljundeid koormata, osadel on lausa see kirjas küljel.
näide:
Ehk ükskõik mis väljundit võib mitte koormata muude kasutuse juures.
Täpselt sama on ka minu toitel (Antec TPQ-1200W) ja olen seda võimalust ka testinud, töötab kenasti.
Üldiselt selle teema arutus ei vii kuskile- reaalselt ei kasutata arvuti toiteid sellisel viisil.
Tegelikult tavalise PWM väljundi mittekoormamine pole tõesti hea mõte, samas kallimates toidetes on skeem selline, mis selle vabalt "ära seedib"
Ilmselt tuleb see sellest, et kaasaegsel toitel on väljundiks sisuliselt ainult võimas 12V ahel, mis igajuhul on koormatud-
3,3 ja 5V DC-DC konverterid istuvad selle väljundis igal juhul ja 100% kasuteguriga nad pole, seega voolutarve olemas.
Kahe trafoga toitesiseehitusest ja ka muudest kaasaegsetest võttetsest effektiivsuse tõstmiseks Enermax-i näitel:
http://www.xbitlabs.com/articles/cases/display/antec-enermax-seasonic-psus_8.html#sect0
Sinu mainutud FSP toide erineb viimasest umbes samapalju nagu vana lada uuest mersust paraku, ehk see pole hea näide pehmelt öeldes.
Ja kui sa tood mingi lingi, siis vaata mis aastast see on 3a on suht pikk aeg arvutimaailmas, raud muutib päris kiirelt..
123 |
Chidori
22.02.2011 20:18:56
| omgwtf kirjutas: |
Mind ennastki huvitaks kuis AK testis asja  |
Pandi testarvuti külge ja arvuti toimis koormustestidega - hiljem kui vastavat mainiti, siis mõõdeti ka pinged üle... Hiljem kui mahti saan siis vaatan ise kah selle isendi üle ja pärin mis tootja arvab...
99 |
22.02.2011 20:49:31
OT: Üks huvitav tabel interneti-piiblist - Anandtechi foorumist - et ikkagi millise minimaalse võimsusega toiteplokki vajatakse.
Vaadake - kas Lp. oponentidel on kah vajaliku võimsusega PSU olemas.
PS: ja kui toodud andmed ei meeldi, siis saab alati väidelda selles samas Anandtechi foorumis.
Link: http://forums.anandtech.com/showthread.php?p=31179172
Tabel siis:
nVidia
GeForce GTX 580 - 40A and a 600W PSU minimum
GeForce GTX 570 in SLi - 55A and a 750W PSU minimum
GeForce GTX 570 - 35A and a 550W PSU minimum
GeForce GTX 470 and 480 in SLi - 55-60A and a 850W PSU minimum
GeForce GTX 480 - 42A and a 600W PSU minimum
GeForce GTX 470 - 38A and a 550W PSU minimum
GeForce GTX 465 in SLi - 46A and a 700W PSU minimum
GeForce GTX 465 - 30A and a 500W PSU minimum
GeForce GTX 460 in SLi - 42A and a 650W PSU minimum
GeForce GTX 460 - 26A and a 450W PSU minimum
GeForce GTS 450 in SLi - 35A and a 600W PSU minimum
GeForce GTS 450 - 24A and a 450W PSU minimum
GeForce GT 430 - 22A and a 350W PSU minimum
GeForce GTX 295 in Quad SLi - 70A and a 1000W PSU minimum
GeForce GTX 295 - 50A and a 700W PSU minimum
GeForce GTX 285 - 46A and a 550W PSU minimum
GeForce GTX 280 in SLi - 55A and a 800W PSU minimum
GeForce GTX 280 - 40A and a 550W PSU minimum
GeForce GTX 275 in SLi - 50A and a 800W PSU minimum
GeForce GTX 275 - 40A and a 550-600W PSU minimum
GeForce GTX 260 OC in SLi - 50A and a 700W PSU minimum
GeForce GTX 260 OC - 40A and a 550W PSU minimum
GeForce GTX 260 in SLi - 50A and a 700W PSU minimum
GeForce GTX 260 - 38A and a 500W PSU minimum
GeForce GTS 250 - 32A and a 500W PSU minimum
GeForce GT 240 - 35A and a 400W PSU minimum
GeForce GT 220 - 30A and a 350W PSU minimum
GeForce 9800 GX2 - 35A and a 550W PSU minimum
GeForce 9800 GTX+ - 32A and a 500W PSU minimum
GeForce 9800 GTX - 25-30A and a 450W PSU minimum
GeForce 9600 GT - 26A and a 450W PSU minimum
GeForce 9600 GSO - 26A and a 450W PSU minimum
GeForce 8800 Ultra - 35A and a 500W PSU minimum
GeForce 8800 GTX - 30A and a 450W PSU minimum
GeForce 8800 GTS 512MB - 28A and a 500W PSU minimum
GeForce 8800 GTS 320/640MB - 26A and a 400W PSU minimum
GeForce 8800 GT in SLi - 36A and a 500W PSU minimum
GeForce 8800 GT - 26A and a 450W PSU minimum
GeForce 8600 GT/GTS - 24A and a 350W PSU minimum
GeForce 8500 GT - 22A and a 350W PSU minimum
GeForce 7950 GX2 - 27A and a 400W PSU minimum
GeForce 7950 GT - 22A and a 350W PSU minimum
GeForce 7900 GTX - 22-26A and a 350-400W PSU minimum
GeForce 7900 GTO - 22-26A and a 350-400W PSU minimum
GeForce 7900 GT - 22-26A and a 350-400W PSU minimum
GeForce 7900 GS - 22-23A and a 350W PSU minimum
GeForce 7800 All - 26A and a 400W PSU minimum
GeForce 7800 GS AGP - 20A and a 400W PSU minimum
GeForce 7600 GT - 22-26A and a 350W PSU minimum
GeForce 7600 GS - 15-17A and a 350W PSU minimum
GeForce 7300 GT - 15A and a 300W PSU minimum
GeForce 7300 GS - 15A and a 300W PSU minimum
ATI/AMD
Radeon HD 6970 - 34A and a 550W PSU minimum
Radeon HD 6950 - 30A and a 500W PSU minimum
Radeon HD 6870 CrossfireX - 38A and a 650W PSU minimum
Radeon HD 6870 - 28A and a 500W PSU minimum
Radeon HD 6850 CrossfireX - 35A and a 600W PSU minimum
Radeon HD 6850 - 25A and a 450W PSU minimum
Radeon HD 5970 CrossfireX - 70A and a 900W PSU minimum
Radeon HD 5970 - 50A and a 600W PSU minimum
Radeon HD 5870 CrossfireX - 55-60A and a 700W PSU minimum
Radeon HD 5870 - 40A and a 500W PSU minimum
Radeon HD 5850 CrossfireX - 55-60A and a 650W PSU minimum
Radeon HD 5850 - 35-40A and a 500W PSU minimum
Radeon HD 5830 - 35-40A and a 500W PSU minimum
Radeon HD 5770 - 34A and a 500W PSU minimum
Radeon HD 5750 - 30A and a 450W PSU minimum
Radeon HD 5670 - 26A and a 400W PSU minimum
Radeon HD 5570 - 24A and a 350W PSU minimum
Radeon HD 5450 - 22A and a 300W PSU minimum
Radeon 4890 - 32A and a 550W PSU minimum
Radeon 4870 X2 CrossfireX - 1000W PSU minimum
Radeon 4870 X2 - 600W PSU minimum
Radeon 4870 - 32A and a 500W PSU minimum
Radeon 4850 - 30A and a 450W PSU minimum
Radeon 4830 - 26A and a 400W PSU minimum
Radeon 4770 Crossfire - 34A and a 750W PSU minimum
Radeon 4770 - 26A and a 400-500W PSU minimum
Radeon 4670 - 26A and a 400W PSU minimum
Radeon 4650 - 24A and a 350-400W PSU minimum
Radeon 4550 - 20A and a 300W PSU minimum
Radeon X3870 X2 - 30A and a 550W PSU minimum
Radeon X38xx series - 28A and a 450W PSU minimum
Radeon X2900 XT Crossfire - 45A and a 800W PSU is recommended for high-end rigs
Radeon X2900 XT - 35A and a 500W PSU is recommended for high-end rigs
Radeon X2900 Pro - 35A and a 500W PSU minimum
Radeon X2600 XT - 25A and a 400W PSU minimum
Radeon X2400 XT - 20A and a 350-400W PSU minimum
Radeon X1950 XTX - 20A and a 420W PSU minimum
Radeon X1950 Pro - 20A and a 420W PSU minimum
Radeon X1900 XTX - 25A and a 520W PSU minimum
Radeon X1900 XT - 22-25A and a 520W PSU minimum
Radeon X1900 GT - 22A and a 400W PSU minimum
Radeon X1650 Pro - 18A and a 350W PSU minimum
700W - 1000W
Enermax Revolution 85+ ERV1250EGT 1250W - 104A from 6 +12v rails
Enermax Revolution 85+ ERV1050EWT 1050W - 87A from 6 +12v rails
OCZ Z Series 1000W - 83A on a single +12V rail
Corsair TX 950W - 78A on a single +12V rail
PC Power & Cooling Silencer 910W - 74A on a single +12V rail
Corsair HX 850W - 70A on a single +12V rail
Corsair TX 850W - 70A on a single +12V rail
OCZ Z Series 850W - 71A on a single +12V rail
XFX 850W Black Edition - 62A on a single +12V rail
Corsair TX 750W - 60A on a single +12V rail
XFX 750W Black Edition - 62A on a single +12V rail
PC Power & Cooling Silencer 750W Quad - 60A on a single +12V rail
300W - 650W
Corsair TX 650W - 52A on a single +12V rail
Seasonic X-Series 650W - 54A on a single +12V rail
XFX 650W XXX Edition - 52A on a single +12V rail
Corsair CX 600W - 40A on a single +12V rail
Corsair VX 550W - 41A on a single +12V rail
Corsair CX 500W - 34A on a single +12V rail
Corsair VX 450W - 33A on a single +12V rail
Corsair CX 430W - 28A on a single +12V rail
PC Power & Cooling Silencer 420W ATX - 30A on a single +12V rail
Corsair CX 400W - 30A on a single +12V rail
PC Power & Cooling Silencer 370W ATX - 27A on a single +12V rail
^found this on tomshardware
211 |
22.02.2011 21:11:08
Tabel siis: |
Oleks äkki nii kena ja pistaks selle spoilerisse?
196 |
Jaan
22.02.2011 21:13:26
See on tõesti OT- anandi foorumisse postitatud jutt, mis päris tomshardwarest, mis omakorda on videotootjate soovituslik toiteploki võimsus, mis omakorda tuleneb nii, et arvutatkse teoreetiline KOGU masina tarbitav võimsus, kusjuures kast on teoreetiliselt kooskõlas videokaardi võimsusega, ehk tippkaardil on ka tippprose jne.
Reaalne maailm on hoopis midagi muud:
(jälle see link, mida sa kuidagi lugeda ei taha )
http://www.xbitlabs.com/articles/cases/display/system-wattage.html
Ja näide reaalselt ja õieti mõõdetud videokaardi voolurabest:
http://www.xbitlabs.com/articles/video/display/gigabyte-gv-n460oc-768i_4.html#sect0
Tabel siis:
nVidia
123 |
