-FoX-
15.02.2011 21:10:07
Chidori kirjutas: |
-FoX-, Homme siis sul käes... eile õhtul sai Veerenni esindus Serverist IP blocki ja enamus kaupa jäi väljastamata  |
Ei nuh ma pole midagi veel tellind aga kui homme saan tasuta siis usu mind ega ma tagasi ei saada;)
_________________ Aita suve, söö lund! |
Kommentaarid: 365 loe/lisa |
6 :: |
306 |
Chidori
15.02.2011 21:46:57
ahsuhh... ei olnudki sinu oma? üks läks täna teele igatahes
Kommentaarid: 114 loe/lisa |
98 |
AJ
15.02.2011 22:11:10
See peaks olema väga asjalik toide.
tsitaat: |
The main “problem” with this power supply is its price. Two hundred dollars is a lot of money for the average user, but this product is definitely targeted to users that demand “the best of the best” and is willing to pay for it. |
Hardware Secrets
Kommentaarid: 37 loe/lisa |
36 |
Chidori
16.02.2011 02:01:42
-FoX-, Kas X760 ei piisa? ca. 35 Eurot odavam ju.
98 |
Auron
16.02.2011 09:45:56
Hea toide on. Ainuke miinus on see, et kui hakkad piiripeal koormama toidet siis vent lõugab. Kui hea hinnaga saad (nagu endaoma sain) siiis tasub võtta.
Kommentaarid: 152 loe/lisa |
129 |
AJ
16.02.2011 22:57:39
Corsair unveils the Enthusiast Series TX V2 power supplies
TechConnect Magazine
tsitaat: |
Corsair has just announced its second-generation Enthusiast Series TX power supply family which consists of 650W, 750W and 850W non-modular units, all featuring an 80Plus Bronze rating and an efficiency of up to 85%.
The new PSUs make use of an updated DC-to-DC converter design to provide tighter voltage regulation, are ATX12V v2.31 and EPS 2.92 compliant, have a single 12V rail, active PFC (Power Factor Correction), SLI certification, a 140mm double ball-bearing fan, and are backed by a five-year warranty.
"For years, the Enthusiast Series TX PSUs have been a favorite of gamers, high-performance PC enthusiasts, and anybody who requires reliable, low-noise power delivery," said Ruben Mookerjee, VP and General Manager for Components at Corsair. "The new TX V2 power supplies are quieter and even more energy efficient, while providing the same legendary reliability, flexibility, and value that customers have loved about the original TX PSUs."
The TX650 V2, TX750 V2 and TX850 V2 power supplies are now shipping in the Americas an Europe, bearing recommended price tags of $99, $119 and $139, respectively. All three are expected to reach Asian markets in March. |
36 |
AtsEst
17.02.2011 19:34:39
Soovitage toidet
GTX 560 Ti OC (tehas)
Q6600
4GB DDR2
2x 7200 rpm Sata HDD
Kommentaarid: 4 loe/lisa |
martin366
Kommentaarid: 185 loe/lisa |
172 |
pohmakas,
käed värisevad
17.02.2011 20:37:25
Jep, hea valik on sellisele süsteemile.
Kommentaarid: 164 loe/lisa |
136 |
denis28
Kommentaarid: 67 loe/lisa |
martin366
172 |
fn
17.02.2011 21:06:35
link :: seasonic
AtsEst kirjutas: |
Soovitage toidet
Q6600
4GB DDR2
2x 7200 rpm Sata HDD |
võib eestist ka osta: 61,5€
Kommentaarid: 91 loe/lisa |
CoiL
Kommentaarid: 95 loe/lisa |
83 |
AJ
17.02.2011 21:59:00
See oleks ka hea valik.
36 |
AtsEst
17.02.2011 22:48:49
Aitäh hüva nõu osas kõigile.
Pea kõik variandid olid mul enne mõttest läbi käinud
Ise kaldun selle 620W Seasonic'u poole, Pixmaniast selle Sapphire veidi kahtlane tellida(teiste kogemusi lugedes) ja garantii tuleks jõle ebameeldiv ning kallis.
Vana 550W Xilence on nõrgaks jäänud ja ei julge enam väga toite pealt koonerdada ka, kuigi raha vähe.
Tänud kiirete vastuste eest.
AJ
17.02.2011 22:52:50
Üks Corsair TX V2 seeria toiteka ülevaade
Corsair TX850 V2 850W
JonnyGURU
36 |
karuke
Kommentaarid: 42 loe/lisa |
41 |
CoiL
18.02.2011 09:37:14
karuke, sinu meedia-arvutile kärab tollest soovitatud Corsair`i toitest küllaga! Aga kui mõtled veits tuleviku peale ja plaanis uus arvuti ehitada jne. siis oleks sul juba korralik toide võtta selle 620W seasonic`u näol.
83 |
karuke
18.02.2011 14:37:06
Jep just tuleviku silmas pidades kuna plaan kunagi TV kaart + Helikaart + Videokaart juurde panna.
CoiL kirjutas: |
karuke, sinu meedia-arvutile kärab tollest soovitatud Corsair`i toitest küllaga! Aga kui mõtled veits tuleviku peale ja plaanis uus arvuti ehitada jne. siis oleks sul juba korralik toide võtta selle 620W seasonic`u näol. |
41 |
CoiL
18.02.2011 20:10:12
karuke, kõik oleneb ka sellest mis video sa sinna sisse plaanid osta. Kui mingi mänguri high-end kaart siis jah mõttekas vast see 620W võtta aga muidu kui mingi mid-range kaart ja cpu kah suht nõrguke ning kellamata ,siis kärab ka see corsair.
83 |
TXX
19.02.2011 21:17:55
Igastahes minu Seasonic x-850 Gold töötas täpselt 2 päeva ning peale seda enam arvuti käima ei läinud. Käis reedel Arvutikeskuse garantiiosakonnast läbi ja sealt helistati, et toiteplokk täiesti töökorras (müstika). Käisin reede õhtul järel ja laupäeva hommikul panin arvutisse ja ennäe imet ikka ei tööta. Lammutasin komponendid kastist välja ja ühendasin lauapeal ära. Tulemus sama. Proovisin ka teises "lahjemas" arvutis, mis esimest korda proovides, ega ka teist korda, tööle ei läinud. Sõbra käest sain korra testimiseks Zalmani 850W toite (näeb väga väga hea välja), mis käivitas arvuti koheselt. Viisin sõbrale toiteploki tagasi ja testisime Seasonicut ka tema masina peal. Tulemus zero. Jätsin asja sinnapaika ja läksin linnapeale asendus toiteplokki otsima. Kuna midagi normaalselt laupäeval on raske saada, tuli leppida Chiefteciga, mis tõmbas mu arvuti kohe käima.
Õhtul otsustasin veelkord Seasonicut proovida "lahjema" arvuti peal. Pärast mitut korda toiteploki sisse ja välja lülitades õnnestus arvutil ventilaatorid tööle saada, aga pilti ette ei saanud. Kuna masnin "nagu töötas" aga pilti ette ei võtnud järsku tuli hea idee tester välja otsida ja pinged ära mõõta 5V oli 5,06V aga 12V oli 10,65V. Mõõtsin ka pci-e pinge ära sama 10,65V. Pole ka ime, et sellise pingega videokaarti järgi ei võta. Esmaspäeval uuesti garantiisse minek.
See toiteplokk on mulle juba maksma läinud 185,60 € + asendusplokk garantiiajaks 89,80 € + hulgaliselt närvikulu.
Esimene ja arvatavasti ka viimane Seasonic. Säh sulle kvaliteetoidet.
Kommentaarid: 87 loe/lisa |
81 |
angel
19.02.2011 21:37:00
kõigil juhtub aga...
tühjalt kah tööle ei hakka koos paari vendi vms ebavajaliku seadmega koormuseks? Ehk siis 24 pin otsikul roheline ja must omavahel kokku ja käima. Huvitav kuidas AK siis seda testis, et asi töötavaks märgiti
Aga ole õnnelik, et midagi kaasa ei võtnud vms jamasid ei põhjustanud... enamasti kui toided ei tööta või "otsad annavad" armastavad teatud tootjate plokid enesega midagi kaasa võtta
Kommentaarid: 175 loe/lisa |
157 |
omgwtf
19.02.2011 22:06:50
Antud veaga ei võta ta miskit endaga kaasa kuna pinge lihtsalt madalam kui olema peaks.
Mind ennastki huvitaks kuis AK testis asja
Kommentaarid: 155 loe/lisa |
137 |
TXX
19.02.2011 22:10:29
Tühjalt ma ka juba mitu korda proovisin ja nii õnnestus paaril korral ka 12 Vent käima saada. Aga pinget mõõtes näitas 10 volti kopikatega ja see ei ole teps mitte normaalne kui lubatud on 3% ulatuses kõikumine. Seega lubatud vahemik oleks 11,40-12,60 volti. Enamasti tegi klõpsu ja vent tööle ei hakanud.
81 |
martin366
19.02.2011 22:12:38
AK spetsialistid kontrollisid seda vist viimase tööpäeva viimastel minutitel Saada uuesti sinna ja anna neile ikka vihje ka, et millega mida kontrollima peab
172 |
