uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  LCD monitorid ( lisatud küsitlus monitori suuruse kohta 10.04.2022 ) märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 143, 144, 145 ... 415, 416, 417  järgmine
Mitu tolli on sinu peamine igapäevases kasutuses olev monitor?
10-15"
0%
 0%  [ 3 ]
15-20"
2%
 2%  [ 7 ]
20-25"
17%
 17%  [ 53 ]
25-30"
41%
 41%  [ 126 ]
30-35"
25%
 25%  [ 77 ]
35" või suurem
12%
 12%  [ 37 ]
hääli kokku : 303
az
sõnum 23.01.2011 14:15:17 vasta tsitaadiga
Sooviks kiirelt arvamusi selle Samsungi kohta: SAMSUNG MONITOR LCD 23" BX2350/W/LED
http://arvutikeskus.ee/est/TOOTEKATALOOG/MONITORID/SAMSUNG-MONITOR-LCD-23-BX2350-W-LED-LS23B5HVFH-EN-SAMSUNG-58520
Kommentaarid: 20 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 18
tqz
tqz
sõnum 23.01.2011 15:53:12 vasta tsitaadiga
az kirjutas:
Positives
High luminance brings bright whites to many applications
Good ‘natural’ colour reproduction, especially for a TN panel
Solid build quality and aesthetically pleasing design
Very responsive even for a ‘2ms’ grey-to-grey monitor
LED backlighting provides better energy efficiency and high luminance with less flicker
Negatives
Whites are not entirely uniform in large white spaces, appearing cooler at the bottom than the top
Colours sometimes lack vibrancy and the ‘wow’ factor
Black luminance a little higher than the XL2370
Viewing angles and colour uniformity are restricted by TN panel technology
There are cheaper options out there but we think this could be worth the extra
PC Monitors score – 72%
http://www.pcmonitors.org/monitor-reviews/samsung-syncmaster-bx2350
Isiklikult arvan, et hind on 23-tollise TN paneeli kohta pisut soolane, kui võtta arvesse, et sama hinnaga saaks VA paneeli:
http://arvutikeskus.ee/est/TOOTEKATALOOG/MONITORID/Ben-LCD-EW2420-24anduot-LED-169-1920x1080-250-cdm-DCR-20M1-typ-30001-25ms-97177
Positives
Excellent contrast with deep blacks, brilliant whites and good distinction of shades between
LED backlit for increased energy efficiency, longer backlight lifetime and lower heat output
Good colour reproduction with pleasing vibrancy – semi-gloss coating reduces ‘dulling’ effect
Good viewing angles (no significant colour shift)
Very attractive price tag
Negatives
Stand lacks height, swivel and rotation adjustment
OSD navigation could be (a lot) better
Minor reflections from semi-gloss coating
Slight gamma shift may limit suitability for colour-critical work
Responsiveness is not quite as good as ‘TN’ panels of similar price
PC Monitors score – 83%
http://www.pcmonitors.org/monitor-reviews/benq-ew2420
http://www.tftcentral.co.uk/reviews/benq_ew2420.htm
Kommentaarid: 74 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 71
ECMadis
ECMadis
sõnum 23.01.2011 20:06:58 vasta tsitaadiga
Kust saada tallinnas DVI-D kaablit soodsalt ja mugavalt ?
Miki-Hiir
sõnum 23.01.2011 22:51:41 vasta tsitaadiga
ECMadis kirjutas:
Mida ja mis pikkuses aga vaja.
http://opood.ee/?a_k=MONITJUHE&t=k_ak&i=MONITJUHE
Kommentaarid: 46 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 43
ECMadis
ECMadis
sõnum 23.01.2011 23:04:16 vasta tsitaadiga
http://www.arvutikeskus.ee/est/TOOTEKATALOOG/MONITORID/VIEWSONIC-VA2231W-LED-22-LED-5MS-DVI-FHD-74029
Ostsin selle monitori ja DVI-D juhet kaasa ei tulnud. Milline kasulik osta oleks? Kuulsin, et single link ja dual link on erinevad ( Midagi resolutsiooniga oli ) ning peab üldse kindel juhe olema.
edit: sain juba icon_smile.gif
viimati muutis ECMadis 28.01.2011 09:25:57, muudetud 1 kord
sergi
sõnum 28.01.2011 01:26:53 vasta tsitaadiga
kaspir kirjutas:
Vajaks monitori vanemale inimesele. Ehk siis suurus 20" või peale. Hind 100€.
onoff vist pakkus 20 t molu 1600x900 kuskil 100 raha eest
Kommentaarid: 65 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 58
Killerwave
Killerwave
sõnum 29.01.2011 14:48:21 vasta tsitaadiga
ECMadis kirjutas:
Kuidas pilt on üldiselt, värvid, kontrastsus, kuidas must pimedas/valges toas on. Bleeding?
Kuidas kiiretes mängudes lippab?
ECMadis
ECMadis
sõnum 29.01.2011 15:45:35 vasta tsitaadiga
Arvestades seda, et ma tulin enne suht väikse monitori pealt siis minujaoks on kõik väga viis hetkel, et suht raske kommenteerida. Pimedas toas pilti muidu igaltpoolt ilusti näha.
Killerwave
Killerwave
sõnum 29.01.2011 16:32:26 vasta tsitaadiga
Mõtlen et kas pimedas bleeding normide piires?
Endal ka 17'' molu ja kavatsus selle aasta sees fullHDle üle kolida. Iseasi kas 22 või 24
Lisaks sellele et värvid peaksid olema paigas ning kirkad ja kontrastsus hea, peaks input lag võimalikult väike sest mängin põhiliselt FPS-e.
Põhiidee ongi leida hea molu mängimiseks(põhiliselt FPS) ning ka pildi/foto töötluseks ning loomulikult korralikuks filmi näitajaks.
Wiltz
sõnum 30.01.2011 00:31:22 vasta tsitaadiga
keegi on ostnud või mõtleb samsungi 2333T ostmise peale?
tundub specide poolest väga hea ja hinna poolest lausa fantastiline molu. aga ei tea kuidas sellega mängida kannatab kah...8ms.
sõnum 30.01.2011 03:19:37 vasta tsitaadiga
Wiltz kirjutas:
Wiltz
sõnum 30.01.2011 04:01:22 vasta tsitaadiga
no mill milliks, ega ma selle numbri kui sellise pärast otseselt ei põe ka...aga kui asi ikkagi reaalsuses rõvedalt ghostib siis on nutune värk.
teatavasti need avaldatud numbrid ei vasta enamasti reaalsusele ka, asi võib tegelikkuses olla täiesti okei, samas võib olla ka täiesti vabalt palju hullem kui 8ms. sellepärast olekski eriti hea kuulda kellegi kasutaja neutraalset arvamust. aga eks vist peab ka ise kuskile poodidesse minema vaatama, äkki saab testida seda molu vms.
sõnum 30.01.2011 04:07:45 vasta tsitaadiga
Wiltz kirjutas:
ei oska otseselt vastata, enda ekraan normaalne. Kas pidurdav/mitte kes seda teab
Sa ei sa seda ennem teada kui 2 erinevat ekraani võrdled :lol
Wiltz
sõnum 30.01.2011 04:36:45 vasta tsitaadiga
et siis sa kasutad seda konkreetset monitori?
tqz
tqz
sõnum 30.01.2011 22:45:36 vasta tsitaadiga
Wiltz kirjutas:
Oleneb vast, kui tundlik ise ghostingu suhtes oled. Mõnda inimest häirib rohkem, mõnda vähem. Tegu on VA paneeliga, seega reaktsiooniaeg ongi selle monitori nõrgem külg.
Mõned võrdlused 2333T ja LG W2363D (üks kiiremaid TN paneele) vahel:
Wiltz
sõnum 30.01.2011 23:28:58 vasta tsitaadiga
hmm, huvitav mis reaalselt olulisem näitaja on, 100-0-100 või 20-80-20? ühe järgi nagu pole vahet miskit sisuliselt, teise järgi 4x erinevus on päris tõsine icon_neutral.gif
linki saad anda, kust need andmed pärinevad ja kas seal oli äkki veel mingit muud põnevat juttu?
ega ei teagi kui tundlik ghostingu suhtes olen. pole näinud ühtegi LCD'd kus mingi ghosting oleks häirinud, samas olen põhimõtteliselt mänginud ainult ühe - oma praeguse TN paneeliga LG taga. sellepärast ongi raske hinnata.
küll peab tunnistama, et praeguse molu puhul häirivad mind natuke overdrive artifactid, aga neid selle samsa molu puhul vist jällegi väga kartma ei pea.
tqz
tqz
sõnum 30.01.2011 23:43:24 vasta tsitaadiga
Reviewsid 2333T kohta pole ma leidnud, andmed leidsin siit:
http://nl.hardware.info/productgroep/8/monitoren#tab:products
2333T:
http://nl.hardware.info/productinfo/105915/samsung-syncmaster-2333t#tab:testresultaten
Kui tõesed sealsed tulemused on, ma ei tea. Osad asjad tunduvad küll kahtlased (input lag paljude monitoride tulemustes 0 ms). Samas need reaktsiooniaja tulemused tunduvad enam-vähem reaalsed.
Ise pakun, et 20-80-20 on olulisem näitaja, kui 0-100-0, kuna tavakasutuses ei vahetu pikslid pidevalt valge ja musta vahel, vaid pigem just heledamate ja tumedamate toonide vahel.
Wiltz
sõnum 31.01.2011 00:51:39 vasta tsitaadiga
huvitav koht, aga jah kui vaatan sealt enamvähem sarnase molli andneid, mis mul endal hetkel on siis see teeb alla 10ms mõlemad, 0-100-0 ja 20-80-20...nii et jah, need numbrid on ikkagi hoopis midagi muud icon_rolleyes.gif ilmselt jääb 2333T mängudes siiski päris uimaseks. kahju, kuna kontrasti näitajad ja natural black level on samas väga head! ja kuradima odav on see molu icon_biggrin.gif
wifebeater
sõnum 31.01.2011 13:59:01 vasta tsitaadiga
tqz kirjutas:
Input lag 0 ms tähendab üldiselt seda, et hilistus võrreldes VGA-sisendiga CRT monitoriga on vähem, kui 0.5 kaadriperioodi (1 / kaadrisagedus). Täpsemalt on seda lihtsate vahenditega raske mõõta.
sõnum 13.02.2011 00:38:47 vasta tsitaadiga
Keegi mingit normi 24" FULLHD resoga monitori oskab soovitada 3000eek (?€) summa kandis.
Sellist mida oleks normaalne ka monitorist madalamalt vahtida (et pilti väga tumedaks ära ei läheks).
Peaks ka vist HDCP vms toetama kuna eesmärk on digiboxi taha toppida.
Samuti võiks 2 sisendit olla (1 neist vähemalt digitaalne). Kõlareid pole vaja.
Kuna mängimine tolle monitoriga nagunii ei toimuks siis sobiks vast VA paneel? IPS-i vaevalt selle raha eest leidub.
Mõttetu mees
sõnum 15.02.2011 11:35:34 vasta tsitaadiga
Tuttav ostis omale sellise LG IPS paneeliga monitori.
http://arvutikeskus.ee/est/TOOTEKATALOOG/ips+lg/LG-IPS226V-PN-IPS-LED-215anduot-1920x1080-250cdm-50000001-typ-10001-8ms-GTG-105426
Igatahes mina olen suht pahviks löödud. Pilt jääb samasuguseks, vaata kus nurgast tahad. Pole varem ka ühelgi monitoril nii palju erinevaid värvitoone eristanud, samas pole ma ka arvatavasti varem ühtegi IPS paneeliga monitori näinud. 23 tolline on umbes 15 eurot kallim. Kui ise endale praegu peaks monitori ostma, võtaks kindlasti selle 23 tollise.
http://arvutikeskus.ee/est/TOOTEKATALOOG/ips+lg/LG-23-LED-E-IPS-VGA-DVI-6MS-SPEAKER-LGIPS231P-BN-105812
Kommentaarid: 649 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 527
von Wu
von Wu
sõnum 15.02.2011 16:19:40 vasta tsitaadiga
Endal on HP ZR24w, mis on ka IPS paneeliga, aga sellel küll pilt samasuguseks ei jää. Kui monitor on laual ja ise seisad püsti ning vaatad küljelt, siis läheb pilt ikka päris tuhmiks.
Samas mitu aastat vanem PVA paneeliga Samsung T214 pilt jääb tõesti muutumatuks ükskõik millise nurga alt vaadates. See on mul praegu ka telerina kasutuses.
See Samsung on muidugi kunagine tippklass (aastaid tagasi 15000kr) ja HP praegune odavklass (~320€). Aga vaatenurk pidavatki VA-l kõige parem olema.
Värvide osas vist jällegi IPS parem ja kallimal IPSil ka vaatenurk parem.
Müüa igasugu asju
Saab 9-3 oksjonil
Kommentaarid: 889 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 668
zer0
sõnum 15.02.2011 22:26:10 vasta tsitaadiga
Samsungi SyncmasterBX2331 - http://www.atf.ee/monitorid/monitorid/samsung_bx2331/
Kas kellelgi mingeid häid nõuandeid on monitori konrtastist viimase välja võtmiseks?
Enda ligi 5 aastat vana CTX läks lõpuks läbi. (tüüpiline sahina reiv, valge pilt jne.. kui 15 korda toitekat taasühendas, siis oli kerge lootus pildi taastumiseks) Sai igastahes ostetud peale mõningaid otsinugid (mõneti kiirustades) Samsungi ''23 SyncmasterBX2331, poes tundus kõik väga tipp-topp (aga oleks pidanud vast sukelduma sügavamale nende poolt pakutud esinduslikest ülephotoshopitud piltidest).. Sai ka andmeid uuritud ja mõnelt "arvutiinimesest" sõbralt nõu küsitud, kiideti heaks täitsa. Kodus tabas veidikene pettumus, kontrast on üsnagi nõrk ja täiesti puhast valget ja musta ei paista välja võtvat. Olin muidugi oma peas mingi oletusliku maailma loonud, et kui mu vana juust monitor juba korraliku pilti näitas, peaks uus Samsung veel paremat näitama. Contrast ratio poolepealt oli vanal monitoril näiteks 450:1 vs. praegu 1000:1 .. ometigi tundub pilt juram. (ehk viitsib mõni tark inimene seda lahtiseletada? saan vähemalt targemaks. tagant järgi)
Sai igastahes driverid tõmmatud ja installitud (ei tahtnud originaalplaati väljalugeda millegipärast), displei seadete alt sai värvikvaliteet kõige kõrgema peale pandud ja resolutsioon paikasäitud. Samuti ka monitori küljes olevatest nuppudest näpitud veidikene. Kogu menüü seal olemas, kus brightness/conrast/sharpness ja erinevate värvide suhe. (+võimalus mingiks mitmeks veidraks mode'iks, millest reaalselt tolku pole.. kes tahaks pilti läbi grayscalei või läbi mingi muu ebapraktilise varjundi vaadata?).. Midagi muud suurt nagu teha vist ei annagi? Kontrast sai 100 peale põhja lükatud, brightnessiga täiesti lõpuni ei läinud. Kõige normaalsem "värvimode" sai kah valitud.
Loo põhipoint: enne ostmist tuleks siiski mõelda ja uurida ja vaadata(mida ilmselt enamik tehnikateadlikumad HV inimesed vast nii või naa teevad).. olude sunnil oli kiire ja nagu näha siis kiirustamisel/teadmatusel tagajärg kah.
Mõni sõna monitorist veel: tundub üsnagi keskpärane pilt, ebanaturaalsed/tuhmid toonid, välimuselt on täiesti soliidne, ei ole vilkuivad suuri tulukesi, üks pisem vaid. (aga olgem ausad, ega see välimus väga ei huvita) Võimalus nurka korrigeerida (nagu igal monitoril tänapäeval vist) .. led, full hd. Taustavalgus võiks ehk suurem isegi olla, või peale mõningast kasutamist tekib kuidagi liialt hämar tunne. Kasutajamugavusest: puutetundlikud menüünupud on veidikene imelikult paigutatud monitori serva alla, ebamugav kergelt, aga see on pisidetail.
tqz
tqz
sõnum 16.02.2011 00:50:47 vasta tsitaadiga
zer0 kirjutas:
Tootjad valetavad, muud midagi. Dünaamilise kontrasti arvudeks märgitakse ju lausa mingid jaburad 10 miljonit jms. Reaalseid tulemusi leiab review'dest.
Kontrast säti paika selle järgi:
http://www.lagom.nl/lcd-test/contrast.php
Ideaalsel juhul on nii heledad kui tumedad toonid eristatavad.
Froggy
Froggy
sõnum 16.02.2011 15:26:20 vasta tsitaadiga
Oskab keegi soovitada FullHD monitori hinnaga kuni 250€?
Ise vaatasin seda: http://www.arvutikeskus.ee/est/TOOTEKATALOOG/LS24LRZKUV%2FEN/SAMSUNG-MONITOR-LCD-24-P2450H-LS24LRZKUV-EN-SAMSUNG-73968
Oleks OK?
uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  LCD monitorid ( lisatud küsitlus monitori suuruse kohta 10.04.2022 ) mine lehele eelmine  1, 2, 3 ... 143, 144, 145 ... 415, 416, 417  järgmine
