| Kommentaarid: 1156 loe/lisa |
724 |
AJ
08.12.2010 16:29:31
| laurx kirjutas: |
| MSE valikutest mulle piisab ja mida vähem ta edaspidi kasutajaid tüütab, seda mugavam. |
Eks ta õige ole, eriti kui kasutajad pole eriti pädevad.
| Kommentaarid: 37 loe/lisa |
36 |
Märt.
08.12.2010 18:09:15
| laurx kirjutas: |
| avasti uuema põlvkonna kasutajaliides on ullem kui varasemal. eile leidsin oma käes aastaid tagasi käinud masinast uuenenud avasti. MSE peale viia ei vitisinud. |
Täitsa nõus, ressursiõgardiks on ta kah muudetud. W2K masinas tiksub, 1,7 GHz AMD, ja 256 MB RAM ning aeglustus on tuntav. Isegi KIS 2011 1 GHz masinal ei mõtle nii kaua. Lisaks tuli asja 2x installida, esimesel korral autoupdate tööle ei hakanud.
| Kommentaarid: 29 loe/lisa |
23 |
tujula
09.12.2010 13:23:42
| Kas tavakasutajal oleks vaja MSE mingeid muudatusi ka teha? Või piisab default installist?
724 |
| Kommentaarid: 751 loe/lisa |
564 |
AJ
09.12.2010 14:16:59
Kuna siin juba oli Avast-ist juttu
Single software licence shared 770,000 times
TechSpot
Avast Software has discovered that one multi-user license for its Pro Antivirus was at one point being used by 774,651 individuals in over 200 countries. It started as a 14-user license for a small firm in Tucson, Arizona issued on June 30, 2009 but grew exponentially in use by late 2010. Except for the original 14 users, all of the others were pirates.
The speed at which the pirated license spread from Arizona was accelerated by warez sites, and Avast was quick to point out the "paradox" in computer users looking for "free" antivirus programs at locations with a known reputation for spreading malware. The avast Virus Lab has more than once documented examples of warez sites distributing packages of a "cracked" antivirus programs combined with malware.
The pirated license for the pro version gave a quarter of a million computers access to two additional features: a virtualization sandbox and a script shield. Other than that, the users didn't gain much, given that the same antivirus engine is used in the free and pro versions of avast's antivirus. Nevertheless, the identified users were sent a pop-up (pictured above) notifying them that they had a pirated license and that they would be cut off from virus database updates. They were also given the option of converting to the free version or buying the pro version.
"We made a decision to see just how viral this one license for avast! Pro Antivirus could be. The answer is 'very'," Vince Steckler, CEO of AVAST Software, said in a statement. "Now we are in the process of converting these pirates over to legal products." |
36 |
Lord Ami
09.12.2010 17:14:40
Avast!'il uus beta ka saadaval:
http://forum.avast.com/index.php?topic=67141
What's new
Most notable improvements include:
- Boot-time scanner for 64-bit OSes (finally!)
- Behavior Shield improvements - now with more sensors and able to detect exact offenders*
- Improved cleaning of infected computers
- Improved anti-rootkit engine - now capable of dealing with the latest TDL variants, for example
- Web Shield improvements (both stability and performance related)
- Mail and Web Shields not hosted in separate NT services anymore, resulting in much faster starts
- IS: new version of antispam engine
- Sound packs (more info coming later)
*The Behavior Shield functionality is still incomplete in this build. And even in the final v5.1, it will work only in "passive mode", which means that the new sensors will be active but won't be stopping the attacks, just reporting them to our backend infrastructure (unless you have opted out from the avast! community membership). This is to allow us to collect enough data before enabling the real thing in Q1 2011. |
Üritan uued (arvatavasti behavior shield'i puudutavad) tõlked ka ära kontrollida ja arusaadavamaks teha, enne kui final versioon välja tuleb.
| Kommentaarid: 57 loe/lisa |
52 |
sama123
10.12.2010 02:01:28
| Kusagilt jäi silma selline :remove fake antivirus 1.7.2 mõeldud võlts&nakatunud antiviiruste ja muude programmide eemaldamiseks.
| Kommentaarid: 23 loe/lisa |
22 |
Lord Ami
16.12.2010 22:30:30
Kas kellelgi on paremat tõlget soovitada? Justnimelt see "eest" on jama.
"Monitor the system for x"
52 |
16.12.2010 22:37:39
Lord Ami: Mitte sõna eest pole vale ega jama, vaid sõna Jälgi on täiesti vale.
See tekst on tegelikult hoopis "Kaitse...eest".
Tüüpiline mittekorrektse tõlke näide, kus sõnaraamat näpus , sõnad lihtsalt ritta laotakse - adumata, mis see tehniliselt tegelikult tähendab.
211 |
564 |
Lord Ami
16.12.2010 23:00:07
Jah, aga "Kaitse" ja "Monitor" on tegelikult natuke erinevad. Monitor tähendab jälgimist, sest Käitumise kilp ei tööta hetkel nii, nagu peaks. Ta saadab avast!ile ainult infot, seejuures midagi blokeerimata. Kuskil kevadel pidi see vist sisse keeratama...
Saatsin tõlke koordinaatorile ka kirja, et seda seika täpsustada.
52 |
16.12.2010 23:10:26
Aga ega siin eriti midagi arutada pole - jutt käib Avasti Tulemüürist ja tulemüüri ainuülesanne on rünnakute blokeerimine ja tõkestamine. Ning jälgimine-monitoorimine on ainult üks osa sellest blokeerimis-tõkestamisülesandest.
Ja nii on see ka tehniliselt kirjas inglise keeles ja samamoodi peab see siis olema üheselt kirjas olemas ka eesti keeles.
Seega - kui tehakse tehnilist tõlget, siis peab ikka kinnisilmi valdama seda millest üleüldse jutt käib ja kuidas asi töötab.
- või tehakse toortõlge ning siis mõni proff-tehniline keeletoimetaja-korrektor koostab siis lõpliku tõlkevariandi.
Tõsi - sellised proff-tegelased küsivad väga kõva töötasu , aga tulemuseks on tehniliselt õige tõlge.
Edu tehniliste tekstide tõlkimise väga raskel ja väga konarlikul teel.
211 |
Lord Ami
16.12.2010 23:18:21
Tänan! Edu on mul vaja
Inglise keeles on ta antud järgiselt:
Monitor the system for low-level rootkits.
Kui nüüd kaitsest rääkida, peaks ta olema midagi taolist:
Protect system against low-level rootkits.
Ootan Avast!'i vastuse ära ja siis muudan, kui pean seda vajalikuks. Kas see just traditsiooniline tulemüür on, julgen kahelda.
Üldiselt arvan, et saan tehnilistest terminitest päris hästi aru, sest olen erinevaid tooteid kasutanud ja nende tegutsemise viise näinud. Seega oskan ka arvata, mida üks või teine asi võib "kaudselt" tähendada. Antud juhul on tõesti mõnevõrra raske, aga selleks ongi tõlke koordinaatorid kes teevad asja selgemaks. Tõlkides üritan teha tõlget, mis on arusaadav ning ei peegeldu inglise keelsest tekstist sõna-sõnalt.
52 |
Märt.
17.12.2010 09:06:39
"Jälgi arvutit rootkittide rünnakute suhtes" näiteks?
23 |
Lord Ami
17.12.2010 16:40:08
| udusiil kirjutas: |
| "Jälgi arvutit rootkittide rünnakute suhtes" näiteks? |
Vist panengi nii
52 |
andree
17.12.2010 20:24:25
Microsoft väljastas oma turvaratarkvara uue versiooni, ehk siis- Microsoft Security Essentials 2
On keegi selle juba uuendustega saanud, just sain teada, just proovisin uuendada aga polnud veel midagi.
AJ
18.12.2010 00:35:50
Minul ütleb ka, et kasutusel uusim versioon. Tegelikult siis MSE 1.xxx. Kui tahad kohe uuemat versiooni, siis tõma alla ja installi.
http://www.microsoft.com/security_essentials/
36 |
Marie
19.12.2010 11:20:30
Milline tasuta viirusetõrje hetkel kõige vähem arvuti ressurssi võtab (sobiks vanemal arvutil kasutamiseks), enda viimased katsetused lõppesid Avira võiduga, Comodo 5.0 tundus paras jama, kogu aeg piinas protsessorit, mälu kasutusega erilist probleemi polnud
| Kommentaarid: 83 loe/lisa |
74 |
andree
19.12.2010 11:54:47
| Avira vist ongi see õige tee kuhu poole minne, kui otsida sellist antiviirust mis arvutit ei koorma. Avira läheb ka Windowsi versioonidele mis juba unustusse vajumas.
AJ
20.12.2010 12:02:07
Avira: 25 pct of PC users disable antivirus software
Yahoo!
A new survey from German antivirus and computer security firm Avira finds that about one in four PC users admit to turning off virus protection on their PCs because they thought the programs were slowing down their computers. Furthermore, more than three out of five (62.8 percent) have tried multiple computer security products in the span of a year on the same computer, hoping to find one they like, and nearly one in eight (12 percent) have considered getting off the Internet altogether for safety reasons.
“The scary take-away from this survey is that 25 percent of the respondents admitted to just turning off their security products because they feel that it hurt the performance of the machine,” said Avira’s Sorin Mustaca. “That’s not a good idea because such a practice leaves the computer totally exposed to the even simplest of viruses, allowing the bad guys to include it in a botnet used to distribute malware and phishing.”
Avira says the survey questions were put to more than 100 million Avira customers around the world during November 2010, although the results are based on 9,091 respondents. Avira says the margin of error for the responses is between 0.28 and 1 percent…although, if the respondents were self-selecting, it’s difficult to know how well the results apply to general computer users, or even to Avira’s customers. (For instance, most Mac OS X users don’t use any antivirus software at all, since the universe of malware targeting the Mac is a tiny fraction of that targeting Windows—for now, anyway.)
Avira is interpreting the results as a sign that antivirus vendors need to take special care not to impact overall system performance—even if that means staying out of users faces, drawing less attention to themselves, or even providing less protection. “It is better to have minimal protection which goes unnoticed than protection with all whistles and bells which the user deactivates in order to be able to use his computer,” Mustaca noted.
If Avira’s survey results can be generalized to a broad group of Windows users, it is also interesting that the majority of Windows users try multiple antivirus and security products on the same computer during the course of a year, indicating that the majority of people who are interested in keeping their PCs secure are dissatisfied with the antivirus products they’re using. Avira’s results don’t go into respondents’ reasons for switching security products: system performance could certainly be one, but factors like pricing play a role. |
Ma arvasin tegelikult, et see protsent on suurem kui 25%.
36 |
exciter
21.12.2010 23:36:22
| Kasutan NOD32 juba aastaid, parim!
564 |
22.12.2010 08:42:24
Betamax, talle vist on, ta ilmselt pirab seda mingi igikestva pätsiga, mis mitte kunagi mitte midagi ei leia..
uuendusega pole seda mse2 hte veel ühtegi masinasse saanud, enne uut aastat ilmselt tuleb. samas eile õnnestus see ühte masinassse lehelt alla laadida. kasutajaliidest on natuke tuunitud, muu silma ei hakanud.
avira vist vanadesse masinatesse parim lahendus jah. MSE l jääb vanas masinas buutides ühe teenuse käivitamine natuke liiga hiljaks ja ta tahab siis, et kaitse käsitsi käima pannakse.
724 |
564 |
AJ
36 |
andree
22.12.2010 20:09:42
| Kui instaleerimiseks vajalik fail tõmmatud ei pea vana versiooni MSEst hakkama uninstallima, selle olmasolu korral toimub see nagu upgrader. Upgrade ise toimub nii, et eelmise versiooni seaded jäevad samaks, nii, et mis enne oli paigas see on ka jätkuvalt nii.
Märt.
23 |
Marie
23.12.2010 03:44:16
Vanemate arvutite omanikud võivad ka MSE nimekirjast välja jätta
Nii-et peale Avira polegi vanasse masinasse midagi mõistlikku panna.
Soetasin just endale tasulise NOD32 ja seal saab sama võtmega kasutada ka nii uusimat ESET NOD32 Antivirus 4.2, pisut vähem ressurssi võtvat ESET NOD32 Antivirus 3.0 kui ka vana ESET NOD32 Antivirus 2.7, kõigile on lingid antud ja sisestades kasutajanime ja parooli, saab kenasti alla laadida.
74 |
HacaX
23.12.2010 04:25:36
Vanarauale PrevX CSI äkki? Ei ole kindel mis staatus tal täpselt oli (kas koduversioon on jaosvara või piiratud funktsionaalsusega priivara, IIRC näägutamist proge peale kuuajalist kasutamist igal juhul ei harrastanud) ja kas ta päris AV mõõtu välja annab (ise promovad nad end pigem kui lisaskännerit AVle), aga mälu tahtis IIRC 2 koopia peale (2 koopiat jooksis omal masinal, ma pole küll kindel kas see on ilmtingimata nii või sõltus sätetest) ca. 20-60MB saada ning proset kah suurt ei söönud (sai üksjagu aega 266MHze PII peal käiatud ning ei kurtnud, masinast lendas välja ainult seetõttu et seal jooksis muud kraami mis mõttetult palju mälu tahtis).
Teemast: sai vahepeal Comodo Cloud Scannerit ning Panda Clound AVd proovitud (mis peaks mõlemad tasuta olema) ja... ei teagi mis öelda. Comodo sellist muljet ei jäta et ta aktiivselt faile skänniks, Panda seda vist siiski tegi. Proset IIRC kumbki suurt ei koormanud samas mälu tahtsid mõlemad samapalju saada kui täisväärtuslikud AVd
| Kommentaarid: 24 loe/lisa |
22 |
andree
23.12.2010 13:28:31
Mis maalt hakkab vanem arvuti? Arvuti vanus on individuaalne, kui sa saad sellega teha seda mis sul vaja on, piisava kiirusega millega sa lepid, pole see sinu jaoks vana.
MSE on näide sellest, et kui Microsoft tahab teha midagi korralikult, leiab inimesed kes seda teha suudavad on tulemus üllatavalt hea. Avira on arvuti käima minemisel kuidagi uimane, lisada juurde veel see uuendamisel ette kargav aken (jah, seda saab ära võtta). Avira pole enam ammu see mis ta kunagi oli, tema plussiks hakkab vaikselt jääma arvuti väike koormamine ja vanemad OSid, millel ta joosta suudab.
MSE võiks tihendada uuendamist, ideaalne oleks pulseeriv nagu Nortonil, võiks vähem arvutit koortmata, olen nõus. Võiks saada panna, et viiruse leidmisel pannakse see kohe karantiini, inimeselt ei küsita üldse midagi. Boot Time scan oleks juba ehk liig paluda ja midagi liivakasti taolist aga see teeks MSE juba sellise arvuti sööja, et siis ta hoiaks juba viiruseid sellega ära, et enne jookseb masin kokku kui miski veel seal tööle läheb.
Metsjeesus
23.12.2010 13:50:00
On's see microsofti enda MSE tõesti täiesti soovitamist väärt kaup? Avira?
Vahest satub ikkagi tumedamatesse internetiaukudesse ära ja hea kui miski oleks kaitsemas, samas tilulilu ei vaja - ainult kaitse ja istu vaikselt oma nurgas. Masin pole küll vana, aga boot võiks endise kiiruse juurde jääda jne, sama mälu/prose kasutusega.
_________________ Füsioteraapia alane hindamine & nõu ¤ treeningfilosoofia & toitumine ¤ kaela- ja õlavöötme lihaspingete leevendamine |
94 |
lightbluefox
23.12.2010 14:00:47
| Endiselt Immunet-i kasutaja, arvutikasutus minimaalne (nii cpu, ram kui hdd, kuna veebipõhine), kunagi midagi ei küsi, töötab vaikselt, tegevusest saab aimu vaid karantiinilogi vaadates.
| Kommentaarid: 45 loe/lisa |
44 |
andree
23.12.2010 14:20:59
Just seda MSE teeb, kaitseb ja istub oma nurgas, see on selline lihtne asi, just neile kes tahavad kaitset viiruste vastu ei mingit üleliia näppimist ja seadistamist. Elab ise ja laseb teistel ka elada. Usun, et on, siin HV foorumis võib leida üsna palju inimesi, kes kasutavad ja rahul.
Üks Microsofti asi mille kallal nagu ei saagi väga iriseda, kui just tõsist tahtmis pole.
Kas Avira või MSE, ühele ema, teisele tütar jne. Nii palju kui on inimesi on ka maitseid. Aviral on pikem kogemus seega ka suurem kasutajate arv, mis annab jälle eelise. Avira istub ka nurgas ja teeb seda mis vaja, seadistamist pole sealgi just pead murdvalt palju, tavalisel kasutajal pole seal nagu midagi muuta. Ikka ja jälle on räägitud Avire valehäirete suurest arvust, pole ammu kasutanud, ei oska öelda, kas midagi muutunud või mitte.
Lihtsam on vist kätte võtta ja proovida mõlemat, elad temaga nädala koos ja vaatad kas kooselu sünnib olla või mitte.
Marie
23.12.2010 14:45:21
| andree kirjutas: |
Need katsed mida mina viimaste viirusetõrjete otsingul tegin, oli arvuti näitajad sellised, protsessor Celeron 2,4 soc 478, int sis 32mb video ja mälu oli 256mb, millest osa läks int videole, masin ei suutnud netiski normaalselt käia, siis lisasin teise sama palju mälu juurde, viirusetõrjed tegid netis käimise pea võimatuks, Windows sai uus XP SP3 pandud, mida rohkem uuendusi seda aeglasemaks masin läks, kui SP2 panna ja kõik uuendused kinni keerata, siis ehk veel kuidagi saaks selline masin netis käimisega ilma viirusetõrjeta hakkama, muud üldiselt selle arvutiga ei soovitud teha. Aga probleem oligi arvuti turvalisuses, ilma uuendusteta, ei julgeks just eriti pangakontotel asju ajada, lisaks tahavad pangad, et arvutis oleks kaasaegne brauser IE8 või viimane Firefox, mõlemad võtavad samuti päris palju ressursi, paljud pangad saadavad Opera kasutajad pikalt, nii-et egas eriti palju brausereid pole millega netis pangatoiminguid saaks teha ja mis saaks vähese mäluga hakkama. Celeron 2,4 võimekuse üle ei oska midagi arvata, Windows läheb kiirelt käima, kuid netis käimisel oleks nagu suur pidur, mul veel üks sarnane arvuti, seal protsessoriks P4 1,6GHz inteli int video ja 526mb mälu ja tundub, et on sellest C2,4 võimekam, samas kastis testitud ka C2,4 ja kõikides testides jäi P4 1,6GHz peale, nii-et vana on suhteline mõiste, mõne arvates on kindlasti Celeron 2.40 GHz, 128K Cache, 400 MHz FSB võimas protsessor ja see paks netis lenates liikuma, kunagi oli ka AMD 2500+ 512mb mälu ulme võimas masin, kuid nüüd leiame teema kus seegi ei tule netis käimiste asjadega toime
74 |
Lord Ami
23.12.2010 15:52:46
Vanemale raalile soovitaks Prevx SafeOnline (googelda Prevx SafeOnline facebook ja saad selle tasuta) koos Chrome brauseriga. Prevx hoiab nii süsteemil silma peal kui kaitseb igasugu andmelekke eest (andmed, mida sisestatakse brauseris).
Kui arvutis on viirus, peaks Prevx seda näitama ning vähemalt tead, et arvuti on nakatunud.
Üks asi: By default on ajastatud kontroll sisselülitatud. Selle soovitan välja lülitada.
52 |
sama123
24.12.2010 04:44:13
| Marie kirjutas: |
| andree kirjutas: |
Need katsed mida mina viimaste viirusetõrjete otsingul tegin, oli arvuti näitajad sellised, protsessor Celeron 2,4 soc 478, int sis 32mb video ja mälu oli 256mb, millest osa läks int videole, masin ei suutnud netiski normaalselt käia, siis lisasin teise sama palju mälu juurde, viirusetõrjed tegid netis käimise pea võimatuks, Windows sai uus XP SP3 pandud, mida rohkem uuendusi seda aeglasemaks masin läks, kui SP2 panna ja kõik uuendused kinni keerata, siis ehk veel kuidagi saaks selline masin netis käimisega ilma viirusetõrjeta hakkama, muud üldiselt selle arvutiga ei soovitud teha. Aga probleem oligi arvuti turvalisuses, ilma uuendusteta, ei julgeks just eriti pangakontotel asju ajada, lisaks tahavad pangad, et arvutis oleks kaasaegne brauser IE8 või viimane Firefox, mõlemad võtavad samuti päris palju ressursi, paljud pangad saadavad Opera kasutajad pikalt, nii-et egas eriti palju brausereid pole millega netis pangatoiminguid saaks teha ja mis saaks vähese mäluga hakkama. Celeron 2,4 võimekuse üle ei oska midagi arvata, Windows läheb kiirelt käima, kuid netis käimisel oleks nagu suur pidur, mul veel üks sarnane arvuti, seal protsessoriks P4 1,6GHz inteli int video ja 526mb mälu ja tundub, et on sellest C2,4 võimekam, samas kastis testitud ka C2,4 ja kõikides testides jäi P4 1,6GHz peale, nii-et vana on suhteline mõiste, mõne arvates on kindlasti Celeron 2.40 GHz, 128K Cache, 400 MHz FSB võimas protsessor ja see paks netis lenates liikuma, kunagi oli ka AMD 2500+ 512mb mälu ulme võimas masin, kuid nüüd leiame teema kus seegi ei tule netis käimiste asjadega toime |
Endal soc.478 P4 3.06 RAM 2GB siin 533 arvuti Aspire1700 läppar lauaarvuti juppidega.Opsystem XP SP3 270MB moditud variant.On töötanud sellega üle aasta ja vaata,et kiirem&parem kui cor2 1,83.Antiviiruseks on jäänud AVG mis on resursiõgija aga sellele vaatamata on OK.Vahepeal kasutasin antiviirust mis võttis andmeid "pilvest" aga ei meeldinud.Tekib küsimus mis on nõrk arvuti?Minu oma ka peaks sellesse kriteeriumisse sobima aga saab kasutada veel üksjagu.
22 |
Marie
24.12.2010 10:11:50
| sama123 kirjutas: |
| Marie kirjutas: |
| andree kirjutas: |
Endal soc.478 P4 3.06 RAM 2GB siin 533 arvuti Aspire1700 läppar lauaarvuti juppidega.Opsystem XP SP3 270MB moditud variant.On töötanud sellega üle aasta ja vaata,et kiirem&parem kui cor2 1,83. Antiviiruseks on jäänud AVG mis on resursiõgija aga sellele vaatamata on OK.Vahepeal kasutasin antiviirust mis võttis andmeid "pilvest" aga ei meeldinud.Tekib küsimus mis on nõrk arvuti?Minu oma ka peaks sellesse kriteeriumisse sobima aga saab kasutada veel üksjagu. |
Sa vist ei tea arvuti võimekusest üldse mitte midagi, mina räägin, et Celeron 2.40 GHz, 128K Cache on nõrk koos oma 256 mäluga, jäädes alla P4 1,6, sina tuled võrdlema kaks korda võisama P4 3.06GHz RAM 2GB, juba mälu kogus on selline sul mis kannatab kõiki jooksutada, lisaks võib arvata, et sul ka eraldiseisev videokaard, nii-et sinu arvuti kül täna veel netis käimiseks nõrk pole, GTA 4 mängu su masin vedada ei jõua, ses suhtes on ta sul nõrk ja kui sinna Elioni Arvutikaitse viirusetõrje peale paneksid, siis võib olla hakkab ka ennast tunduvalt aeglasemalt liigutama
74 |
24.12.2010 12:46:08
ma hetkel otsin tõrjet läpakale, milles tiksub win2k, masinas on p3 600mhz prose ja mälu on 128mb mse sellel käima ei hakka.
mse töötab neil vanadel keleronidel kah, päris mitu sellist on jooksus. nende 128kb / 64kb (duron) asjade peal tuleb ossi natuke servistest tuunida nii ehk nii. 478 asjad on päris võimsad, katsetamiseks võtke vanad alla 1ghz asjad. väikest proset kompenseerib sellisel juhul natuke rohkem mälu, kiire prose pidurdab ka vähese mälu otsas, sest swappi kirjutatakse kettale ja loetakse sealt.
724 |
24.12.2010 14:23:46
| laurx kirjutas: |
| ma hetkel otsin tõrjet läpakale, milles tiksub win2k, masinas on p3 600mhz prose ja mälu on 128mb mse sellel käima ei hakka. |
Ma ei tea... Avira ehk sobiks? Ma viimaste versioonidega pole muidugi kokku puutunud ja ei tea nende ressursinõudlust...
Mälu on kuramuse vähe muidugi, 384 või 512MB-ga saaks isegi NOD32 seal kasutada (jajah, see pole tasuta, aga võrdluseks nimetasin lihtsalt)
Pigem loobuks AV-st ja paneks mingi vähenõudliku liinuski sinna. Xubuntu või mis see netbookidele mõeldud asi oligi... Ubuntu Netbook Remix? Prooviks vähemalt.
724 |
Märt.
26.12.2010 14:06:05
laurx, tasuta tõrjetest olen W2K-le leidnud vaid Avast!, muud tahavad vähemalt XP-d.
23 |
724 |
Märt.
27.12.2010 10:47:45
laurx, vanadest aegadest jäi Avirast halb mekk suhu, isegi pärast erandi tegemist (teades, et see info oli false positive), suutis ta ikka miljon-ziljon korda uuesti sellesama faili kohta üle küsida ja popuppe ette visata, lõpuks viskas kopa ette. Avast oli ennem funktsionaalsema GUI-ga, mõnus, aga poogen see GUI, vähemalt pole nii loll kui Avira. Koduserveris tiksuval W2K-l on nii SP4 kui ka rollup peal, vähemalt Avasti sai kobinata pääle.
23 |
724 |
andree
29.12.2010 23:16:39
CIS või MSE, ei oska üldse valida. Üheks arvuti mille taga istun harva mida kasutab rohkem ema ja kuna siin ise enam väga pole siis oleks vaja midagi kindlat, sellega tehakse tööasju, raamatupidamine ja mu selle juurde kuuluv. Teine sülearvuti, mida kasutan ise ja kui mitte mina siis tüdruksõber, sellised tavalised asjad- suhtlusvõrgustikud, messenger, kooliasjad jne.
Mõlemat ise proovinud, aga valida nagu ei suuda, targemate nõu, otsustamaks.
724 |
564 |
andree
29.12.2010 23:37:02
| Hetkel on ka MSE peal mõlemal, aga MSE 2.0... vaid arvutil millel XP aga seda siin kaasas pole, plaanis siia ka panna (arvutis Windows Vista), et uuendustega tutvuda. Keegi midagi öelda oskab selle kohta, mida oodata, mida "karta". XP masinal ei olnud aega väga sellega tutvuda, seal pole ka kõiki uusi asju mis Vista või 7`me puhul.
