Rajareits
30.11.2010 23:15:45
xxlmaster, kõigil 500k (vähemalt seni mis näinud olen). Töö üks ja sama..
A vähe rohkem võiks tull akui 1160..
| Kommentaarid: 74 loe/lisa |
69 |
xxlmaster
30.11.2010 23:17:01
Rajareits, GT-R näitab 37.5k
Vähe rohkem võiks tulla? Jama selles et teda ei saa tuunida palju. Mootor on tehtud tal juba, turbod on peal.
| Kommentaarid: 83 loe/lisa |
77 |
Bumer
30.11.2010 23:52:22
| ot: |
# Flexible camera angles and “dynamic and wide-area lighting needs” are to blame for the sometimes blocky shadows. Yamauchi admits they are a problem and wants to improve them.
# Yamauchi appears to consider the possibility of removing the in-game HUD (heads-up-display features) at some point in the future.
# Mechanical damage options will be implemented in a new update for GT5 coming “early December”.
# As you may know, many players noticed that GT5’s face-tracking functionality only worked in Arcade mode. According to Yamauchi, it’s not available in GT mode due to memory issues with the PS3.
# Yamauchi wanted to implement a “free roam” gameplay mode in GT5, where players could drive around, respecting speed limits and obeying traffic laws, and even exit the car to walk around and explore the environment on foot.
# The YouTube replay upload feature had to be pulled from the final version of the game because it took a very long time to render and it consumed too much memory. Yamauchi is still considering it, however. |
| Kommentaarid: 51 loe/lisa |
48 |
EstBeast
01.12.2010 00:02:56
GTA:GT5
| Kommentaarid: 89 loe/lisa |
6 :: |
HDTanel
Overclocker
01.12.2010 00:47:04
Youtube teemat ja HUDi eemaldamist ootan väga See Headtrackingu jura on küll valus laks Kuda krt saavad nii ikka teha, et ainult ühes mängu osas see töötab..
_________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel |
496 |
xxlmaster
01.12.2010 01:02:47
ma olen nüüd igatahes Lev20 ja seda lahi lukustatavat damaget ei ole kuskil, kusjuures selline mulje jääb nagu, kui ennem midagi läks vähe kõveraks siis nüüd ei juhtu üldse midagi
Enivei keda huvitama peaks siis extreme seeria on kõva Formula ChampionChip, DreamCars Chp, Nascar Chp, GT car Chp jne jne jne. Ei julgegi nagu kuskilt peale hakata
77 |
HDTanel
Overclocker
01.12.2010 04:08:38
Krt, mis teema selle pidurdamisega on ikka?? Kõik abid maha võtta siis ebanormaalselt käitub auto pidurdamisel, vajutad 5mm piduri pedaali alla ja juba plokkis ning 180 spin
496 |
xxlmaster
01.12.2010 08:35:26
| PlatoonSgtElias kirjutas: |
| Krt, mis teema selle pidurdamisega on ikka?? Kõik abid maha võtta siis ebanormaalselt käitub auto pidurdamisel, vajutad 5mm piduri pedaali alla ja juba plokkis ning 180 spin |
No mõistlik on ikka ABS peale panna. Suure hooga kurvi lennates ilma ABSita piisab väiksest jõnksakast ja juba läheb käest ära.
77 |
Rajareits
01.12.2010 08:53:16
Kuna pedaalidel Force Feedbacki vms asja pole, siis jah ABS peal norm sõita. Ise lasen 1ga.. Siis saab pidurdades veel külje ette lasta mõnusalt.
Aga ABS 0 ei olnud asi ikkagi nii hull kui Tanelil. Vb Sul rooli seaded mööda? Pedaali nupuna ei võta?
69 |
Anisse
01.12.2010 14:38:47
mida rooli seadetes maha keerata - kui riivad piiret siis rool hakkab ise keerama sinna kuhu tahab ning enda arust proovib vist sirgeks ajada, jõuga ka ei saa enam sirgeks. peab ootama mil auto täiesti seisma jäänud ja siis tagurpidi käik, et piirdest eemale ja lootus et rool ei keera end jälle tagasi vaid saab sirgeks. Selle ajaga on kõik autod kaugel ees
Rooliks Logitech Driving Force GT
hentz
01.12.2010 16:23:17
| kas g27 on rooli seadetes olemas?
| Kommentaarid: 424 loe/lisa |
9 :: |
342 |
Shade
01.12.2010 17:09:25
GT5 fannid võiksid tulla esmaspäeval rocca euronicsisse võistlustele. Auhinnad on kobedad:
1 koht - Signature edition
2 koht - Collectors edition
3 koht - tava versioon
_________________ GT: janrist
PSN: janrist
Just for fun: Mängupunker |
| Kommentaarid: 23 loe/lisa |
21 |
Rajareits
01.12.2010 17:13:49
| Shade, mis toimub? Mis kell?
69 |
Shade
21 |
Rajareits
01.12.2010 17:29:06
| Shade, ei saand väga palju targemaks. GT5 võistlus hakkab kell 14:00? Kaua kestab?
69 |
HDTanel
Overclocker
01.12.2010 18:06:10
Nojah, ma siis kämpima euronicusse kes sõidab minust paremini? Mäletan, et viimasel võrgupeol kus GT5 pidi mängima sõitsin kolme ringiga kiireima aja mingi 15inimese seast puldiga.
496 |
ps2e hull
01.12.2010 21:07:28
Ohoh, endal GT5 pole, aga väga tahaks ja mul on mõnes kohas ostukuulutus ka üleval, kuna poest osta ei taha, sest seal liiga kallid hinnad. Nii, et peaks vist ka sinna kohale minema.
Shade, kust sa seda tead, et auhindadeks on GT5 mängud, seal lihtsalt kirjas, et auhinnafond 5000 krooni ning ma eeldan, et paljud kes seal osalevad omavad juba GT5-te nii et suht mõttetu oleks anda auhind sellisele inimesele.
Äkki keegi teab, et kas seal on võimalik valida millega autot juhid (rool või pult) või peab ainult rooli/puldiga sõitma? Mul pole rooliga absoluutselt kogemusi ja ilmselt ma saaks sellega väga halva aja, ega ma puldiga ka just kõige parem sõitja ei ole, aga äkki veab ja teised on veel halvemad :p
Ja kas keegi teab täpsusdada, mis kell GT5 võistlus algab ja lõpeb. Ei taha päev läbi ka kuskil poes passida :/
rocky-b
01.12.2010 21:12:22
* Flexible camera angles and “dynamic and wide-area lighting needs” are to blame for the sometimes blocky shadows. Yamauchi admits they are a problem and wants to improve them.
* Yamauchi appears to consider the possibility of removing the in-game HUD (heads-up-display features) at some point in the future.
* To unlock the Red Bull X1, you’ll need to complete the “Sebastian Vettel Challenge”, which appears at Level 30.
* Online “lounge” functionality and other features will be added “one by one”.
* Polyphony Digital continues to work on fully supporting the Logitech G25 and G27, though Yamauchi admits he would like a “new steering device soon”…
* Mechanical damage options will be implemented in a new update for GT5 coming “early December”.
* As you may know, many players noticed that GT5’s face-tracking functionality only worked in Arcade mode. According to Yamauchi, it’s not available in GT mode due to memory issues with the PS3.
* In-game rewards (such as the monetary prize in GT5 Prologue) for your performance in online events is something Polyphony Digital is considering, and may be implemented in a future update.
* Gran Turismo 5’s official, 2-disc sound-track will be released soon.
* Yamauchi wanted to implement a “free roam” gameplay mode in GT5, where players could drive around, respecting speed limits and obeying traffic laws, and even exit the car to walk around and explore the environment on foot.
* The YouTube replay upload feature had to be pulled from the final version of the game because it took a very long time to render and it consumed too much memory. Yamauchi is still considering it, however.
Kõige rohkem ootaks seda esimest parandust, kuna praegu chase camiga GT5-es on see kaamera nagu kinni naelutatud . Võiks selline Chase Cam tulla nagu GT1-GT3-es oli . Flexible camera angles - või ma olen sellest kuidagi valesti aru saanud .
| Kommentaarid: 13 loe/lisa |
beastbeats
01.12.2010 21:13:40
ps2e hull, ta on ostujuht seal firmas
M: Cannondale Tract MIPSkiiver (uus; Polar White; Large) - 40€ |
284 |
angel
01.12.2010 21:19:18
| ps2e hull kirjutas: |
Shade, kust sa seda tead, et auhindadeks on GT5 mängud, seal lihtsalt kirjas, et auhinnafond 5000 krooni ning ma eeldan, et paljud kes seal osalevad omavad juba GT5-te nii et suht (<font size=-1><i>tegelikult tahtsin kirjutada</font></i> =>)<b>mõ<font color=red>tt</font>etu</b> oleks anda auhind sellisele inimesele.
Ja kas keegi teab täpsusdada, mis kell GT5 võistlus algab ja lõpeb. Ei taha päev läbi ka kuskil poes passida :/ |
välismaal tellides saad kusagil suts alla 800.- kätte, oleneb kohast ja mis posti nõutakse. Aga eriti odavamalt seda asjandust vast ei leia kui just keegi olematu hinnaga oma koopiat maha ei taha ärida.
157 |
ps2e hull
01.12.2010 21:29:20
| angel kirjutas: |
välismaal tellides saad kusagil suts alla 800.- kätte, oleneb kohast ja mis posti nõutakse. Aga eriti odavamalt seda asjandust vast ei leia kui just keegi olematu hinnaga oma koopiat maha ei taha ärida. |
Nojah, ma üritan 650 krooni eest ära osta ja ega see ei pea uus olema. Ma loodan, et kellelgi on vaja enda mängu mingil põhjusel ära müüa
angel
01.12.2010 22:16:41
650.- oleks pool muidu saadud, kui just ei leia neti poodi kes sellise hinnaga selle sulle kohale toimetab ja vaevalt nii pea kasutatud koopiaid müüki tekib. Vast need müüvad asja maha kes ootasid sellest graafilist meistriteost millena asja kohati reklaamiti ja ei ole väljas selle mängu sisu ja gameplay peale.
Siiski ei jaga matsu mis selle mängu menüüdel viga on... lugenud reviewdes et kole segane. imo on kõik suht koht selge. Tea kas siis Codepasa Dirt 2 jms crap'i menüüd on paremad kus pool päeva käib siuh... siauh... yo yo yo, wow... ja terve ekraan lendab ringi ja peeretab sinist tossu...
ps: mis sai nendest ultra detailsetest auto sise vaadetest mida vahepeal vist reklaamiti? mängus on asi küll suht.. meh. GTR2, NFS Shift (suht samad asjad tegelt) on asi imo kah kenam
157 |
Wilts
01.12.2010 22:22:18
| angel kirjutas: |
prologuest kehvem graafika?
| Kommentaarid: 31 loe/lisa |
30 |
eeromees
01.12.2010 22:27:20
Ise ostsin TheHut.com-ist preorderiga, maksis koos saatmisega 730 EEKu. Praegu vast 20-30 EEKu kallim samas kohas. Kohal nädalaga.
_________________ PSN: eestimees |
| Kommentaarid: 10 loe/lisa |
9 |
ivokas
01.12.2010 22:42:42
Installin Homme ei pea õnneks ka arstile minema, on aega pühenduda.
_________________ Reisijate ja fekaali vedu kahekorruselise bussiga.
Praepelmeenid ja Vana Tallinn suudavad nii mõndagi muuta! |
| Kommentaarid: 65 loe/lisa |
61 |
Vombat
01.12.2010 22:47:06
| eeromees kirjutas: |
| Ise ostsin TheHut.com-ist preorderiga, maksis koos saatmisega 730 EEKu. Praegu vast 20-30 EEKu kallim samas kohas. Kohal nädalaga. |
Hetkel on Shopto.net'is pakkumine 34,85 + 2,50 naela = 37,35 naela, mis kroonidesse ümber arvestatuna teeb umbes 708 krooni kanti. Seal on küll märgitud, et tuleb tellimuse peale kuna ilmselt on need hetkel miskipärast otsas .
| Kommentaarid: 35 loe/lisa |
gj
212 |
angel
01.12.2010 23:02:15
| Wilts kirjutas: |
| angel kirjutas: |
prologuest kehvem graafika? |
ei ole just sitem aga kohati on osad rajad imo nagu viletsama kvaliteediga ja osad paremad. graafikal ei ole nagu püsivust. Menüüsid uurides aga ei mõika mis neil väga mäda on. See loading pidevalt käib jah pinda aga õnneks ei ole see mul väga pikk mingil põhjusel. Loodaks, et mäng fixitakse pätsidega ära ja ei hakata DLC lüpsimasinat käivatama. Siis teaks kas see "investeering" tasus end ära või mitte.
Vähemalt sõita on lahe kuigi õhtuti sõites on huvitav nähtus alati... silm vajub kinni Paar korda juba "rooli" ehk siis puldi taga tukkuma jäänud peaaegu ja seina külastanud
157 |
xxlmaster
01.12.2010 23:21:36
kas see tuleb üllatusena v? Too ükskõik mis teine automäng, ükskõik mis platvormil mis shifti seest vaate üle lööb...
Nendele kes kõik arvasid et mäng hakkabki selline välja nägema nagu piltidel enne reliisi, soovin tõsiselt edu edaspidi
Kui praegu loen miks headtracking GT mode-st välja jäeti ja miks youtube üleslaadimise võimalus ära katkestati olen päris õnnelik tegelt et selline asi üldse suudeti valmis teha. Mäng on ju tohutul suur tegelt ja vaadake mis rauda PS3 omab, eriti nalja koht on mälu.
77 |
angel
01.12.2010 23:58:20
nu osati kiideti ju seda purki taevani ning kes oskab see suudab ka seda purki kasutada (Naughty Dog, SCE Santa Monica näiteks). optimiseerimis ja kasutus oskuses on asi vast kinni mõnes osas. Teised tootjad ju suudavad parema grafaga mänge PS3 peale teha. Aga jah kui mänguga rohkem tutvuda siis leiab igasugu "vidinaid" seega oletaks, et mindi välja gameplay peale. Mingit crapmasters jms tootajate paska kah samas ei tahaks kus 5 originaal rada ja paar autot. Ja siis sõidad igavesti ühte ja sama rada ühe ja sama ilmastikuga.
GT5 tegijad oleksid siis võinud natuke rohkem nokitseda ja mitte rahvast hype'ida photomode 'i piltidega mille puhul tehakse kiire AA jms tüüning. Samas hea seegi, vähemalt kenad pildid tulevad
Keegi teab mis värk üldse GT5 selle grafaga on? S.t kohati on mingi puhas 2D inimesed jne ja siis täiesti lampi mõnes teises, suht sama mõõtmega rajal, on terve kari neid 3D's pandud. Tekib juba tunne, et mäng on erineva dev. staatusega ja alguses topiti 2D'd sisse ning hiljem hakati 3D mudeleid kasutama aga ei hakatud enam vanu radu uuendama vms.
157 |
ppg
02.12.2010 00:19:56
Kahe päevaga tuli siis GT5 bundles ps3-ga Soomes koju, proovimiseks läheb peale jõulupidu laupäeval siis just hea passiivne olek selleks , eks muljetan kuna võrdlus olemas FM3-ga korralik. Kas tuunimis osa on muidu võrdne või parem FM3-ga?
138 |
tteam
02.12.2010 00:22:52
keegi oskab öelda, et kas seal on võimalik kuskilt neid paint carde osta ka?? Tahaks oma RS6 ära värvida aga vajaliku värvi pole
| Kommentaarid: 36 loe/lisa |
31 |
xxlmaster
02.12.2010 00:25:57
| angel, uncharted2-l jookseb ikka palju vähem möllu tagataustal ka. Hetkel ma ei näegi ühtegi head mängu millega seda võrreldagi.
77 |
kjaups
MeesKesTuliMetsast
02.12.2010 00:28:21
Kas kellegi pool oleks võimalik homme harjutamas käia GT5-te?
Kui asukoht kusalgi mustamäel, siis võin õlle sõbrale kraami kaasa kiskuda ja siis hea sõites koos limpsida
Kui kusalgi kaugemal, siis endale jääb Dont drink and drive.
On juhitavus võrreldes GT2 ja GT3-ga väga erinev või suht sama?
GT2s vana lammutaja ja GT3s nii palju kui mängisin siis oli ilusti asi käpas.
Võiks soojal maal olla, sealt sai mänge 59 daala eest
_________________ M: korter Mustamäel
YAGA müügiputka |
| Kommentaarid: 174 loe/lisa |
143 |
angel
02.12.2010 00:32:01
| xxlmaster kirjutas: |
| angel, uncharted2-l jookseb ikka palju vähem möllu tagataustal ka. Hetkel ma ei näegi ühtegi head mängu millega seda võrreldagi. |
tiah mis action siingi käib v.a autod kes vist reaalselt kah sõidavad kuna ajad pannakse kirja siis kui üle joone saavad (vähemalt siis kui ootad, teist "viisi" pole lähemalt vaadanud) ning saad ka individuaalselt igat autot replay ajal jälgida.
Tausta graafika jms asjad on suht vana kooli värk. Või siis auto füüsika jms asju peetakse silmas? Osad nagu väidaks et tegemist ei ole ka "tõsise" simuga. GTR2 puudub korralik Xbox360 puldi tugi seega seda ei saa proovida (mingi kamm oli tal sellega et ei olnud päris õige mekk).
157 |
xxlmaster
02.12.2010 01:20:37
võrreldes unchartediga, hmmm, terve üks suur level on sul pmst lahti laetud erinevalt UC kus leveleid laetakse peale cutsceene. 1280x1080 reso ja PIDAVAT olema 60 fpsi caps.
Ise sa juba jõudsid lisada veel ühe olulise faktori, reaalselt sõitev AI, nii et ma arvan et tegevust toimub rohkem tagataustal kui meie silmad üle kapoti näevad.
Kuid siiski kui ma poleks shift cocpit vaadet näinud peaksin siiani GT5 oma parimaks hetkel
Noh, igatahes ei tahaks küll hõisata aga tundub et tootajad tegelevad mängu paramaks arendamise kallal hoogsalt ja vast on oodata uusi vidinaid kunagi juurde. G25/27 profiili lisamine oleks küll hea
77 |
haldz
02.12.2010 01:51:20
| ppg kirjutas: |
Kahe päevaga tuli siis GT5 bundles ps3-ga Soomes koju, proovimiseks läheb peale jõulupidu laupäeval siis just hea passiivne olek selleks , eks muljetan kuna võrdlus olemas FM3-ga korralik. Kas tuunimis osa on muidu võrdne või parem FM3-ga? |
Kust siis tellisid ja plju kokku maksma läks?
| Kommentaarid: 153 loe/lisa |
138 |
HDTanel
Overclocker
02.12.2010 08:18:42
Huh, krt terve öö lasin GT5 tegin kolm litsentsi ära, kõik ilma abideta ja kullale Kuigi pean mainima, et kolmanda litsentsi viimast rada ei suutnud ilma traction controlita võita Haige ülesanne
Igatahes tegin paar kena pilti
496 |
Rajareits
02.12.2010 08:27:30
| PlatoonSgtElias, ise proovisin mõnda raskemat teha abid peal, aga need hakkavad ju rämedalt sõitmist segama. Lõpuks oli ikka see et hakkasin asju maha võtma, et sõidetud saaks.
69 |
Shade
02.12.2010 12:57:55
Seoses GT5 võistlusega:
Kõik hästi läheb siis sõidmae G27 rooliga ikka
Miks auhinnad sellised on? miks mitte parimale anda eksklusiivne GT5 komplekt? Kes mängu võidab saab ju selle kas maha müüa või ma ei tea mida teha.
PSN: janrist
21 |
Rajareits
02.12.2010 13:15:32
Shade, aga ikkagi, räägi kellaaegadest..
Pean hommikul Tartus olema, et kas jõuan või ei?
69 |
Shade
02.12.2010 13:22:46
| Rajareits kirjutas: |
Pean hommikul Tartus olema, et kas jõuan või ei?  |
Kell 14:00 alustame aegade registreerimisega ja võitja kuulutame välja kell 21:00. KUni 21:00 saab aga sõita. Võib ka mitu korda sõitmas käia.
Mis rada ja mis autoga sõidame, see jääb minu teada hetkel ainult
Kui veel küsimusi siis tulistage
Muidugi toimub ka muid võistlusi
PSN: janrist
21 |
redemption
02.12.2010 14:25:05
Keegi Gran turismo all stars sõidu ka ära võitnud on? Experdi all. Proovin sõita vette z01 race modiga aga iga kord on üks tüüp kiireim ja sõidab alati mult eest ära, teistega sõidan ise vahe sisse. Mida teha?
Kas see üldiselt, et ainult ühe korra saab sõidu eest exp. ja special eventide eest saad ainult ka ühe korra raha ja exp (iga medali eest saab muidugi ka).
Kust leida endale classic race car? Diileri juures maksavad mingi 10 milli krediiti aga seda pappi mul pole.
_________________ PS! |
33 |
Negative
02.12.2010 14:31:59
| redemption kirjutas: |
Kust leida endale classic race car? Diileri juures maksavad mingi 10 milli krediiti aga seda pappi mul pole. |
Ühe korra saab raha ja exp. punkte, kui kohe kullale teed, jah. Auto saad kasutatult osta, pead lihtsalt peale passima, neid vanu võidusõidukaid liigub seal vahest.
| Kommentaarid: 49 loe/lisa |
42 |
EstBeast
02.12.2010 15:06:49
| Shade, Seoses GT5 võistlusega paar küsimust. Kas tartus kh sellist võistlust esineb, või on tegu Tallinnlaste privileegiga? Sõidetakse puldi või rooliga? Tahaks osa võtta aga ekstra sellepärast Tallinnasse ei vaevu tulema.
6 :: |
Shade
02.12.2010 15:29:05
| EstBeast kirjutas: |
| Shade, Seoses GT5 võistlusega paar küsimust. Kas tartus kh sellist võistlust esineb, või on tegu Tallinnlaste privileegiga? Sõidetakse puldi või rooliga? Tahaks osa võtta aga ekstra sellepärast Tallinnasse ei vaevu tulema. |
Asi toimub Tallinnas Rocca keskuses ainult. Sõidame rooliga G25
PSN: janrist
21 |
hentz
02.12.2010 16:29:05
| Selge pilt, lähen harjutama:D
9 :: |
342 |
HDTanel
Overclocker
02.12.2010 16:55:22
hentz, soovitan kõik litsentsi testid kullale ära sõita ise kavatsen seda teha, kuna ei tea, mis masin ja mis rada. Kõige rohkem siiski huvitab, et kas peab SIDURIGA sõitma?
edit: Ilmselt siiski ei pea ma arvan kuna keegi peaks pidevalt jälgima kas vajutatakse siduri töös olek sisse või mitte Igatahes jah, may the best "man" win haha
496 |
Shade
02.12.2010 17:20:45
| Igatahes jah, may the best "man" win haha |
Tundub et veri hakkab lendama
Ma ise seal nagunii terve päeva ja pool ööd samamoodi (wow cataclysmi rahvas vaja ka vastu võtta).
PSN: janrist
21 |
HDTanel
Overclocker
02.12.2010 19:10:34
Shade, nu siis sain vastuse ühele küsimusele juba, et kas sa seal oled Pane omale name tag vms peale saab tere öelda. Jagasin selle võistluse infot facebooki kah
496 |
