WäntWõll
make.believe
300 |
CoiL
17.11.2010 13:58:40
wanawoll, vana uudis ju:
| G80 kirjutas: |
| AJ kirjutas: |
ME4ME sets 3DMark Vantage WR with GeForce GTX 580
Nordichardware
The world's fastest graphics card was made even faster during the weekend and the man who did it was well known overclocker and NHOC team member Henry "ME4ME" de Kruijf. Using liquid nitrogen and a quick Zotac GeForce GTX 580 card Henry broke the world record in 3DMark Vantage by scoring 40,268 points.
Henry reached some very impressive results with his Zotac card under air cooling and even if most would be very careful with just installing a $450 graphics card it didn't take long before Henry whipped out the soldering iron.
The card is regular retail that was volt-modded to increase to some truly unhealthy levels, but it required some additional modifications to make it stable at very low temperatures, which is quite common with liquid nitrogen.
According to Henry the card didn't scale that well with neither extreme temperatures nor high voltages, but with some stubbornness, hard work and even extremer voltages (1.4V+ GPU and 1.85V memory) he managed to break the single GPU world record in 3DMark Vantage Performance. The clock frequencies had been pushed to 1,250 MHz GPU and 5,052 MHz memory, far above the stock frequencies of 782/4000 begin_of_the_skype_highlighting 782/4000 end_of_the_skype_highlighting MHz. The final score was P40286 and is about 100 points higher than the previous record by Asian overclocker NickShih.
System specifications:
Intel Core i7 980X @ 5.75 GHz (LN2)
ASUS Rampage III Extreme
Zotac GeForce GTX 580 @ 1250/5052 MHz (LN2 with 1.4V GPU voltage)
Corsair Dominatior GT 1866C6 DDR3
Enermax Revolutions85+ 1050 watt |
[img]http://www.nordichardware.com/images/labswedish/artiklar/NHOC/ZotacGTX580/largethumbnails/resultat.jpg[/img]
Suurema pildi vaatamiseks klikkige pildile.
4X GTX 580 = UUS WR
http://hwbot.org/community/submission/1078564_ |
| Kommentaarid: 95 loe/lisa |
83 |
WäntWõll
make.believe
17.11.2010 14:03:36
CorsairX, Selge, ma vaatasin et BOT-is viimane uudis ja kuupäevadesse ei süvenenud
300 |
Go Kane!
17.11.2010 19:18:12
Nii. Sain täna omale masinasse GTX470.-i.
Tõmbasin netist driverid (kuigi masin leidis ise ka samad juba ise, win7 peal)
Installisin ära ja Gpuz näitab kõiki andmeid ilusti.
Proovisin 06 ja 03 3Dmarki lasta ja pillub sealt väkja, lööb mingi kirja ette.
Gridi ka proovisin sama jama pillub välja.
Milles asi võib olla?
Vana kaart oli GTX260 (DX10 kaart)
_________________ Vajad midagi Würthist , küsi julgelt 😉 https://eshop.wuerth.ee/et/EE/EUR/
taavi.jahu@wuerth.ee +37258309618 |
| Kommentaarid: 1842 loe/lisa |
1345 |
siinus
17.11.2010 19:33:37
| -cocain- kirjutas: |
Vana kaart oli GTX260 (DX10 kaart) |
ma arvan, et see "mingi kiri" võiks ka avalikuks saada . Muidu vist mõttetu üldse selle peale mõtlema hakata...
_________________ suck less | no slop grenade
| Kommentaarid: 70 loe/lisa |
63 |
Go Kane!
17.11.2010 19:38:30
Display kernel Mode driver has been stopped workin vms. lõi windows ise ette.
3Dmark 06 ütleb errori: IDirext3DDevice)::Present failed:Device lost (D3DERR_DECICELOST)
1345 |
Gap
17.11.2010 19:52:54
| äkki midagi DirectX seoses... rumal küsimus aga kas viimane DirectX on peal ? Selle DirectX on igasuguseid jamasi küll endalgi mõni ette tulnud ...
| Kommentaarid: 21 loe/lisa |
17 |
MMx
17.11.2010 19:52:55
Help!
Mul ka ab vaja.
Sain täna oma MSI 460GTX kätte. Topin kaardi masinasse, siis esimesel bootupil võttis pildi ette. Lasin driverid peale, nõuab restarti, teen resa ja pilt kadunud. Isegi bootup kirju ega pilti pole...
Vb valesti power juhtmed külge pandud? On vahet üldse kummale Pci power pesale kumb juhe külge panna, kaardi power pesadel pole kah kirju peal, et kumb on nr 1 ja kumb nr 2... Mul OCZ 600W toide ja sellel PCI-E1 ja PCI-E2 (samas need tegelt sama juhtme küljes vist, tundub, et 1 juhe lihtsalt kaheks jagatud, ei saa hästi aru kah, kuna juhtmel kenasti võrk ümber tehase poolt).
| Kommentaarid: 81 loe/lisa |
G80
210 |
omgwtf
17.11.2010 20:29:15
Päris haige Nüüd võiks mingi MSI püss ka tulla mis 1400+ core läheb
137 |
martin366
17.11.2010 20:31:27
| MMx kirjutas: |
Help!
Mul ka ab vaja.
Vb valesti power juhtmed külge pandud? On vahet üldse kummale Pci power pesale kumb juhe külge panna, kaardi power pesadel pole kah kirju peal, et kumb on nr 1 ja kumb nr 2... Mul OCZ 600W toide ja sellel PCI-E1 ja PCI-E2 (samas need tegelt sama juhtme küljes vist, tundub, et 1 juhe lihtsalt kaheks jagatud, ei saa hästi aru kah, kuna juhtmel kenasti võrk ümber tehase poolt). |
proovi mõlemat moodi, veendu, et korralikult sees on
172 |
Go Kane!
1345 |
One
17.11.2010 20:51:58
võib olla küll vigane, eks ikka juhtub.
alles oli mul üks XFX-i high end kaart mis karbist võttes surnud oli
728 |
MMx
17.11.2010 20:58:38
| martin366 kirjutas: |
proovi mõlemat moodi, veendu, et korralikult sees on  |
No pesas peaks ikka korralikult olema, juhtmeid olen kah nüüd proovinud ümber tõsta...
Vana video toimib ilusti.
Samas karbi pealt loen Min Sys Req alt, et tarvist 12V ja 24A, mul toitel 12V ja 18A kirjad peal, seega toide lahja we???
martin366
17.11.2010 21:19:37
| MMx kirjutas: |
Samas karbi pealt loen Min Sys Req alt, et tarvist 12V ja 24A, mul toitel 12V ja 18A kirjad peal, seega toide lahja we??? |
krt, ei usu, et selles asi. Mul ka 18A aga jooksutab kenasti GTX470 Mõni targem oskab öelda ehk milles jama on
E: asi ikka nii, et 2 x 18A = 36A, seega sul peaks okei olema, aga mul suht piiripeal
viimati muutis martin366 17.11.2010 21:27:15, muudetud 1 kord |
172 |
One
17.11.2010 21:25:03
| 400w Nexus-ega jookseb GTX460 Cyclone vabalt.. seega proobleem mujal
728 |
MMx
17.11.2010 21:41:26
| No mul igatahes mõistus otsas hetkel... Proovinud igast asendist. 1 power juhtmega, 2 power juhtmega, üldse ilma juhtmeta (võtab voolu siis ainult PCI-E siinilt), monitori olen proovinud mõlemasse DVI-sse toppida, samuti telekat. Ja pilti polegi enam ühestki asendist saanud, ainult esimene kord, kui võtsin vana kaardi masinast välja, lasin draiverid maha ja siis panin uue kaardi sisse. Uued draiverid peale, restart ja oligi pilt kadunud.
martin366
17.11.2010 21:43:33
aga pane vana sisse tagasi, lase kõik nvdiaga seonduvad driverid maha, ning lükka uus kaart sisse tagasi. Lase mingid teised driverid peale, suts vanemad
172 |
MMx
17.11.2010 21:59:47
aga pane vana sisse tagasi, lase kõik nvdiaga seonduvad driverid maha, ning lükka uus kaart sisse tagasi. Lase mingid teised driverid peale, suts vanemad  |
Hetkel ongi seis selline, et panin vana kaardi sisse, lasin draiverid maha ja kui uue sisse panen, siis ei saagi enam pilti ei draiveritega ega ilma, seega mingeid muid draivereid proovida ilma pildita on suht raske
martin366
17.11.2010 22:05:58
kaputt ?
172 |
Wtf
17.11.2010 22:06:18
| MMx kirjutas: |
| No mul igatahes mõistus otsas hetkel... Proovinud igast asendist. 1 power juhtmega, 2 power juhtmega, üldse ilma juhtmeta (võtab voolu siis ainult PCI-E siinilt), monitori olen proovinud mõlemasse DVI-sse toppida, samuti telekat. Ja pilti polegi enam ühestki asendist saanud, ainult esimene kord, kui võtsin vana kaardi masinast välja, lasin draiverid maha ja siis panin uue kaardi sisse. Uued draiverid peale, restart ja oligi pilt kadunud. |
Kui võimalik on siis proovi seda videokaarti mõnes teises arvutis käima saada.
PS ära lase mingid auto draivereid peale lasta, kohe tõmba nvidia kodulehelt kõige uuemad. Mul ka esimest korda GTS 450 panin sisse win7 lasi mingid 2006 aasta draiverid fermi kaardi peale, pilt peksis küll väga segast:D ei teind restarti lasin kohe internetist kõige uuemad draiverid peale ja asi ants.
_________________ wat? |
20 |
MMx
17.11.2010 22:13:54
| Wtf kirjutas: |
| MMx kirjutas: |
PS ära lase mingid auto draivereid peale lasta, kohe tõmba nvidia kodulehelt kõige uuemad. Mul ka esimest korda GTS 450 panin sisse win7 lasi mingid 2006 aasta draiverid fermi kaardi peale, pilt peksis küll väga segast:D ei teind restarti lasin kohe internetist kõige uuemad draiverid peale ja asi ants. |
No hekel ei saa ma enam mingeid draivereid uuele kaardile lasta, kuigi kui vaadata, kausta suurust vana kaardi driveritel 64bit win xp vers 260.99 ja uuel, siis kõik on täpipealt sama. Hetkel arvutis mingeid video draivereid Nvidia omasid ei ole. Pildi saan ette ainult vana kaardiga. Ja proovingi juba leida sõpra/tuttavat, kelle arvutis saaks uut kaarti proovida ja siis välistada või kinnitada, et probleem on või ei ole kaardis endas.
Äkki peaks hoopis teist PCI-E pesa proovima? Praegu olen proovinud ainult esimest ehk siis ülemis sinist, teine on all ja musta värvi.
viimati muutis MMx 17.11.2010 22:25:34, muudetud 1 kord |
Go Kane!
17.11.2010 22:22:03
Ei saa mina ka oma murele lahendust.
Tegin isegi värske Win7 installi aga ikka pillub kohe kui 3Dmark mõni käivitada välja, windows lööb kirja et driver has stopped working.
1345 |
Wtf
17.11.2010 22:28:46
Proovi mingit teist draiveri versiooni, proovi kasutada dx10.1, 10 või isegi dx9 kui võimalik
20 |
Go Kane!
17.11.2010 22:30:09
| Wtf kirjutas: |
Proovi mingit teist draiveri versiooni, proovi kasutada dx10.1, 10 või isegi dx9 kui võimalik |
DX.-e ei pea minuarust ise eraldi installima? Varem küll ma pole.
Originaaldrivereid ka proovisin, ei funganud.
1345 |
Wtf
17.11.2010 22:37:32
Mai öelnudgi et proovi installida. Tõmba nt heaven 2,1 benchmark test, sealt valid dx9 või 10 ja vaata kas nondega töötab.
20 |
MMx
17.11.2010 22:40:29
Oeh, hetkel sain pildi ette uue kaardiga, kui tõstsin kaardi alumisse PCI-E pessa, eks nüüd paistab kas ja kuidas draiverid peale saab.
Krt, nii pole vist ikka ka päris õige. Võtsin emaplaadi manuali lahti ja Primary PCI-E pesa on sinine x16 (ülemine, kus ka vana kaart toimetas), alumine musta värvi on Universal PCI-E slot ja max x4.
viimati muutis MMx 17.11.2010 22:52:06, muudetud 1 kord |
Go Kane!
17.11.2010 22:42:49
| Wtf kirjutas: |
| Mai öelnudgi et proovi installida. Tõmba nt heaven 2,1 benchmark test, sealt valid dx9 või 10 ja vaata kas nondega töötab. |
Ei viitsi enam jebida, terve õhtu juba nässu sellepärast läinud. Viin kaarti homme müüjale tagasi
1345 |
Wtf
17.11.2010 22:45:09
20 |
Go Kane!
18.11.2010 00:02:18
martin366 proovis ka oma arvutis ja sama jama. Mõni sekund saab mängida siis must ekraan.
Olen nüüd 100% kindel et asi konkreetses kaartis kuna Martinil ka masinas GTX470.
Ei tahaks uskuda et MSI oma võtab vähem voolu kui Club3D oma.
1345 |
martin366
18.11.2010 00:10:52
Väga imelik värk igastahes.. 10s saab mängida siis 3s pilt must jne.. (proovisin just cause 2, batman, grid) Garantiipauk
172 |
1dumbpcuser
18.11.2010 07:38:30
Win7-l Dx9-t installitud pole, seega see on üldjuhul siiski vaja installida
_________________ M: MSI B660M MORTAR
O: AM5 ITX emaplaat |
97 |
18.11.2010 10:14:10
| 1dumbpcuser kirjutas: |
Win7-l Dx9-t installitud pole, seega see on üldjuhul siiski vaja installida  |
Tegelikult on küll.Tegu on DX9L vms eriversiooniga mida Vistast alates on kasutatud.Seega vaikimisi ei pea DX9 mängude jaoks midagi juurde installima.Uusima DX paketi pealelaskmine on siiski soovitatav alati, et vältida võimalikke probleeme
Samamoodi saab Vistale DX11 peale lasta
| Kommentaarid: 92 loe/lisa |
MMx
18.11.2010 12:07:16
No nii, sain siis enda GTX460 toimima universal PCI-E x4 pesas. Aga primarys pilti ette ei võta. Fallout New Vegas jookseb ultras nüüd, aga F1 2010 benchmark oli avg vist mingi 20fps ja samadel seadetel sain vana 8800GT'ga 45fps kanti.
Nüüd siis saadetud kiri Arvutikeskusesse ja ka Asuse Eesti esindajatele (http://support.asus.com/contact/contact_right.aspx).
Asusest (Servisa ICT info@servisaict.ee) vastati, et nemad ei teosta lauaarvuti komponentide hooldust ja ma peaksin müüja poole pöörduma.
Gap
17 |
MMx
18.11.2010 17:59:13
Sain siis lõpuks arvutikeskusest kah vastuse... Soovitati Bios update teha ja arvati, et kala võib olla primary PCI-E pesas. Bios'i lasin just täna hommikul viimase peale ja primary pesa viga ei taha ise uskuda, kuna vana kaart töötab just selles pesas nii nagu peab.
Sai ka MSI supporti e-mail saadetud ja nüüd ootan veel sealt vastust.
Vaja veel siiski proovida kusagil teises masinas seda kaarti, aga hetkel ei ole veel ühtegi sobivat varianti leidnud.
sipsic001
| Kommentaarid: 9 loe/lisa |
9 |
denis28
18.11.2010 18:29:59
| see ei ole hinnasula see ongi kaardi esialgne hind... hind peaks kukkuma tõesti ss kui 6970 tuleb välja...
| Kommentaarid: 67 loe/lisa |
G80
18.11.2010 18:34:43
400EUR eest oleks päris püss.
Kui ATI just parem hinnaga kiiremat kaarti ei paku.
210 |
SogegaTyyp
18.11.2010 19:34:45
| Mnjah, kui hind veel pisut kukuks, tasuks juba mõtlema hakata. Samas vist tõesti enne ATI kaartide resultaate pole osta mõtet.
| Kommentaarid: 54 loe/lisa |
51 |
AJ
18.11.2010 23:03:56
The Fox Out-Foxed,GTX 580 “Real Power Consumption&Temperature” Surfaced
Expreview
| Kommentaarid: 37 loe/lisa |
36 |
18.11.2010 23:31:48
olen ma ainuke, kes expreview linkidelt saab vaid errori?
error establishing a database connection
_________________ - londiste
217 |
xxlmaster
| Kommentaarid: 83 loe/lisa |
77 |
AJ
19.11.2010 00:33:31
Expreview üsna tihti maas.
36 |
19.11.2010 00:52:46
| londiste kirjutas: |
error establishing a database connection |
19.11.2010 00:54:52
217 |
19.11.2010 00:59:00
| ot: |
millega vaatad? ma IE-ga
niiikaua kui ma juba elioni netti oman (ca 3 aastat) , pole ma suutnud cnetist asju lugeda.
ja kõik, no totaalselt kõik muud lehed avanevad |
KrisVr
19.11.2010 01:01:16
| ot: |
Mina ei näe sealt ühtegi ja seal samas programmide downloadimine on ka, et hästi läheb siis saad! Tavaliselt ei lähe hästi! Ahjaa FF4-ga vaatan! |
| Kommentaarid: 30 loe/lisa |
19.11.2010 01:04:47
| DefXtreme kirjutas: |
| ot: |
| ot: |
saast leht järelikult |
