One
10.11.2010 22:39:29
AK-s on Vapor-X väga hea hinnaga müügil jah.
CF töötaks selle toitega lõdvalt ja jõudlus kasvaks ka igati korralikult.
Kommentaarid: 1009 loe/lisa |
728 |
Chidori
11.11.2010 00:13:01
Sobivusprobleeme pole mingeid kuna VaporX ja Toxic vahe on mõneskümnes megahertsus - ise olen mänginud ja testinud igasugu CFX kombosid (kaks tuuma, kaks tuuma + 1 tuum, erinevad tuumad jne) ja pole veel mingeid anomaaliaid näinud.
Kommentaarid: 114 loe/lisa |
98 |
AJ
11.11.2010 01:12:16
“Warmly Welcome” GTX 580,HD 5970 Drop to €389
Expreview
tsitaat: |
Yesterday NVIDIA has just released GeForce GTX 580,in response to this,its opponent AMD certainly won’t sit back,lowering the price of Radeon HD 5970 to meet the challenge,as
Fudzilla reported.
Now we can just spend €389 to get AMD Radeon HD 5970 in Austria,we hope in the near future the price can be seen in other market.Although we can’t confirm the suggested retail price of HD 5970,but it is most likely that the price is €389.
This time the price reduction is large,as HD 5970 is originally priced at around €500,now the price is €100 lower.In some games,HD 5970 can match or even exceeds GTX 580.
This price cut more or less poses a threat to NVIDIA,it might be a good idea to lower the price of HD 5970 for AMD before emergence of Cayman and Antilles. |
Kommentaarid: 37 loe/lisa |
36 |
WäntWõll
make.believe
11.11.2010 03:17:25
tsitaat: |
5970 Drop to €389
Kommentaarid: 374 loe/lisa |
300 |
Flavius
11.11.2010 03:23:45
Sama teema oli 4870x2'ga kunagi.
Lõpupoole maksid ~5k kanti.
Kommentaarid: 126 loe/lisa |
118 |
One
728 |
rainer7
11.11.2010 10:19:59
ja tänud vastuste eest!
Kommentaarid: 4 loe/lisa |
AJ
14.11.2010 02:07:23
XFX ATI Radeon HD5670 1GB Passive Heatpipe CFx Review
KitGuru
36 |
G80
14.11.2010 11:22:21
tsitaat: |
5970 Drop to €389 |
Kommentaarid: 256 loe/lisa |
210 |
angel
08.12.2010 00:13:08
oskaks keegi öelda kuidas saaks HD5450 kaarti kasutades, saada nõnda, et videode mahamängimisel kasutatakse gpu'd? Ehk siis mis codec'eid või playereid kasutama peaks? Praeguse seisuga on prose kasutus suht kõrge, samas gpu z näitab, et vga on tegevuseta.
Nvidiaga oli lihtne, nn "linnuke" cuda ette ja vsio. Aga ei mõika mis trikiga AMD'l selle asja peaks tööle ajama, sain algselt aru, et AMD kaartidel sama vigur mingis mõttes olemas, et võetaks proselt koormust maha.
Kommentaarid: 175 loe/lisa |
157 |
WäntWõll
make.believe
08.12.2010 00:15:49
uuel VLC peaks sedates valik olema
300 |
angel
08.12.2010 00:26:13
proovisin, kui panin @ vlc codec'eid kasutades siis osa formaadis pilte hakkas katkuma ja ei suutnud maha mängida (aitas see kui panin linnukese ette, et kasuta süsteemi vms installitud codec'eid). Samas mõlemal juhul on prose kasutus suht kõrge. Ehk siis pole päris see mis lootsin
157 |
Chidori
08.12.2010 00:39:46
Tuleb natuke nokkida ja 5450 ei ole parim FullHD filminduse jaoks.
Ise kasutan MPC'd justnimelt põhjusel, et tal EI OLE oma kodekeid.
98 |
One
08.12.2010 00:46:59
stagna aegne mpc oskas juba hd-d video pealt jooksutada.
728 |
Chidori
08.12.2010 01:17:03
ei tea - MPC HomeTheater ei ole midagi hullu.
98 |
angel
08.12.2010 01:36:08
Chidori kirjutas: |
Ise kasutan MPC'd justnimelt põhjusel, et tal EI OLE oma kodekeid. |
ehk siis media player clasic?
peaks proovima.
ja kui 5450 ei suuda full hd filme välja vedada koos prosega siis tea mis "süsteemi" see jama veel vajaks. Ega see full hd nii ulme ei ole...
157 |
Chidori
08.12.2010 01:48:45
Full HD'd on ju igasugust... Filmidega on mul vähem jama olnud kui HD Anime/3D filmidega - need on tunduvalt karmimad.
GMA HD ei suutnud isegi üht 720p HD Animed jooksutatud normaalselt... Nad ikka tahavad päris palju.
98 |
1dumbpcuser
Kommentaarid: 100 loe/lisa |
95 |
angel
08.12.2010 13:10:01
ehk siis see pms? http://mpc-hc.sourceforge.net/
ei mõika vene keelt seega ei hakka sealt ka tirima kuigi versiooni nr tundub teine oleat.
157 |
08.12.2010 13:54:21
/OT/ angel, sel venekeelsel lehel on mõnevõrra uuem arendusversioon. Ning igal lingil/tekstil on seal ju ka ingliskeelne selgitus taga.
Kommentaarid: 168 loe/lisa |
157 |
egert
08.12.2010 20:06:31
Sai endalegi soetatud HV-st üks HD5850, kuid nüüd on üks probleem...
Ennem oli HD4870, millele olin teinud catalyst 10.4'ga Rivatuneri kaudu selle HW, mille kaudu sain jälgida CPUd, GPU tempi, FPSi jne; nüüd ei leia rivatunerist ülesse hardware monitori ega saa teha uut.. ideid ??
Uue kaardiga on samuti 10.4 peal.
_________________ I need about tree fiddy.
Egert |
Kommentaarid: 102 loe/lisa |
89 |
WäntWõll
make.believe
08.12.2010 20:08:47
msi afterburner
drivud pane ikka viimased HD5 seeriale.
300 |
egert
08.12.2010 20:22:48
wanawoll kirjutas: |
msi afterburner
drivud pane ikka viimased HD5 seeriale. |
MSi afterburner näitab rakenduses ka tempi ja asju ? E: Näitab vist jah , tänud
E:Muidu rivatuner 2.24 ei toeta mul Hd5850i..sellepärast ei tööta ..
Egert |
89 |
1dumbpcuser
08.12.2010 21:08:09
angel kirjutas: |
ei mõika vene keelt seega ei hakka sealt ka tirima kuigi versiooni nr tundub teine oleat. |
Põhimõtteliselt küll, sel SF lehel on "ametlik" versioon, minu antud lehele lisatakse arendusversioone ja seal on ju ilusti ingliskeelne tekst ka olemas (kuigi kohati tõlgitud veidi konarlikult).
MPC-HC Doom9 foorumi teema link kah: LINK
_________________ O: Low-profile pci bracket |
95 |
angel
08.12.2010 21:11:00
ot
nu ise olen huvitatud stabiilsetest "final" versioonidest, sain kenasti aru jah mis kohast sealt vene lehelt tirida aga kuidagi kahtlane tundus, keelt ei mõista seega otsisin muidugist nn"arusaadavas keeles" koha ülesse.
157 |
