XeStAiSy
Aeg Maha 2a
16.10.2010 09:36:18
| NATAS999 kirjutas: |
| Margus, mis sa sogad, pildilt ju ilusti näha, et mälud on ju täpselt samas kohas, kus 58xx seerial ju |
x2 suhtes ei ole pidasin silmas 4k. Juba 5k suhtes on jah sama. Kuigi voolukontra hakkab nüüd praadima.
| Kommentaarid: 12 loe/lisa |
AJ
17.10.2010 21:35:29
XFX Radeon HD 6850 & HD 6850 'suffer' through a photo shoot
TechConnect Magazine
Former Nvidia BFF XFX will be ready next week with two reference cards based on AMD's Barts 40nm GPU - one Radeon HD 6870 and one Radeon HD 6850. Both second-generation DirectX 11 products are read to take on the GeForce GTX 460 but before going to war they had to sit still and smile for a camera.
Seen below, both cards take up two slots and boast two 6-pin PCIe power connectors, feature a 256-bit memory interface, 1GB of GDDR5 VRAM, and are CrossFire compatible.
The Radeon HD 6870 provides two DVI, one HDMI 1.4 and two mini DisplayPort 1.2 outputs and is supposed to have 1280 Stream Processors, a GPU clock of 900 MHz and a memory clock of 4200 MHz, while the Radeon HD 6850 packs two DVI, one HDMI and one DP, 1120 SPs, and GPU/memory frequencies of 725(or 775 MHz, depending on who you ask)/4000 MHz. But we'll let you enjoy the pics now. |
| Kommentaarid: 37 loe/lisa |
36 |
siinus
17.10.2010 21:42:27
mõlemad on suht peldiku välimusega
_________________ suck less | ANNA MU SAI!
| Kommentaarid: 70 loe/lisa |
63 |
NATAS999
17.10.2010 21:54:14
| djpvx kirjutas: |
mõlemad on suht peldiku välimusega  |
midrange stuff nagunii, suht pohh, milline see välja näeb. ja pealegi näed seda ainult siis, kui sisse paned ja välja võtad ning ülejäänd 99,999% istub nagunii kastis ja mängimise/benchi ajal pilk monitorile suunatud, mitte ei uuri kaardi jahutuse ümber oleva platsiku kujundust.
| Kommentaarid: 41 loe/lisa |
39 |
Kristoferr
216 |
AJ
17.10.2010 22:06:48
On 6850 6870; A rice face it!
PCOnline.com.cn
36 |
arvutiH YT
17.10.2010 22:22:02
| djpvx kirjutas: |
Välimus on alati vaataja silmades. Minu meelest näiteks 6870 on vägagi kena välimusega
Flavius
17.10.2010 22:31:05
Näevad paremad/soliidsemad välja kui eelmise põlvkonna batmobiilid.
118 |
kalluka
17.10.2010 22:47:34
Jumala ilusad ja kui ei sobi tee ise meshist ümbris peale see ka kena.
| Kommentaarid: 16 loe/lisa |
12 |
pohmakas,
käed värisevad
18.10.2010 06:45:44
Odav plastik tundub olevat
| Kommentaarid: 165 loe/lisa |
137 |
18.10.2010 07:07:02
NV fännitarid ei leia veel midagi millest kinni hakata seega tehakse välimust maha
Kaardid on igati kenad ja nüüd jääb benchmarke ootama
_________________ Win11 25H2 upgrade skriptid neile kelle masin ise ei taha 23H2 või 24H2 pealt ennast uuendada:
https://foorum.hinnavaatlus.ee/viewtopic.php?p=11720738#11720738 |
| Kommentaarid: 92 loe/lisa |
kalluka
18.10.2010 07:07:53
See on sinu arvamus.Jumala poogen mis materjalist kas peab fakk kullast olema
?Tee ise siis korpus mida sa vingud.Peaasi et perf ja hind oleksid head.Ma ka tahan head välimust aga palju ma ikka seda kaarti vahin ja pealegi see kole plastik on ju keissis tagurpidi.
12 |
One
18.10.2010 07:39:40
eks see välimuse pärast vingumine ole alati olnud.
samas paljud tahavad parema välimuse eest rohkem maksta?
0-2% inimestest kui sedagi.
728 |
Killhoven
OC`er
18.10.2010 09:16:52
Hea kiri on lõpus, et temp langeb 2C kui on XFX kujuga õhuava. Huvitav, nad mõtlesid ikka, et väljapuhutaval õhul ehk rohkem kuumust jääb kaarti sisse?
Mida tähendab "CF support: Single" ?
_________________ Foorumis on ühe lolli kohta kümme tarka, nii et jõud on enam-vähem võrdsed.™ |
| Kommentaarid: 408 loe/lisa |
351 |
Flavius
18.10.2010 09:44:11
| Kaartidel 1xCF silla koht.
118 |
WäntWõll
make.believe
18.10.2010 14:54:21
IMO päris nunnud, eriti 6870
Samas 6850 on täpselt nagu GTX460
300 |
NATAS999
18.10.2010 14:58:14
huvitav, ei tea kas see tsentrifuug on siis mõnevõrra kallim, et ei raatsita nõrgematele kaartidele peale panna seda. efektiivsus ja müra tsentrifuugil ju parem.
_________________ "Kuidas on see hea?"
-Auto kirurgia kliinik |
39 |
Heineken
18.10.2010 15:05:22
| Tsentrifuugil peaks müra just kõrgem olema. Efektiivsus selles mõttes parem, et puhub kuuma õhu otse kastist välja, mitte ei puhu otse peale jahutile ja siis jätab sooja õhu korpusesse.
| Kommentaarid: 24 loe/lisa |
23 |
pohmakas,
käed värisevad
18.10.2010 16:26:25
| Winterwind kirjutas: |
0-2% inimestest kui sedagi. |
Esialgu muud peale välimuse ju teada pole. Õigemini on, aga õigeid testitulemusi pole, niiet hetkel saab vaid välimust kommenteerida
137 |
WäntWõll
make.believe
18.10.2010 18:25:45
| Mida seal ikka oodata sama kaart tiba teised klokid.
300 |
Killhoven
OC`er
19.10.2010 06:26:05
Arutaks natuke AMD väiteid selle kohta, kuidas uued kaardid vanu asendama hakkavad.
Jutt 6850/70 -> 5770; 6950/70 -> 5850/70; 6990 -> 5970 ei pea ju paika.
| Killhoven kirjutas: |
Ärge seda unustage, et hinnad tulevad vastavalt jõudlusele. Midagi tasuta juurde ei saa. 5770 hinna eest uut kaarti ei saa. 5850`ga samaväärne uus kaart hakkab vastavalt kah maksma. AMD võib küll väita, et 6850/70 hakkab asendama 5770 klassi ning 6950/70 siis 5850/5870, aga tegelikult taandub kõik hinnale. 3+k kaart ei saa hakata asendama 2k kaarti. Hinnale vastavalt saab 6950/6970 olema omaette hinnaklassis ning 6850/70 siis 5850/5870 hinnaklassis ja järelikult nad ka asendavad neid kaarte.
Teisisõnu tekib vaid võimalus "uusi" 5850-sid (Barts Pro/XT näol) 5850 kanti hinnaga osta (formaalne kopikas ehk odavam) ning tekib Cayman Pro/XT näol võimalus soetada 5870-st parem kaart vastava hinnaga. Ei mingit odavväljamüüki. |
https://foorum.hinnavaatlus.ee/viewtopic.php?p=6098751#6098751
Peaks paika kui spekuleeritava toreda jõudluse kasvu saaks vana hinna eest kätte (mis oleks ka normaalne, et uus põlvkond pakub sama hinna eest paremat võimekust). AMD üritaks justkui uute nummerdamise süsteemidega vett sogaseks ajada ning vaikimisi kaartide hinnaklasse tõsta. Praegu maskab 5770 x summa, siis 6850/70 hakkab sellest selgelt rohkem maksma ja järelikult ei asenda 5770-t vaid on tegelikult 5850 asendaja hinnas ja jõudluses.
351 |
NATAS999
19.10.2010 06:58:22
ehhh. kui 6870 asendaks 5870't, siis peab 6870 olema 6xxx seeriast kiireim single GPU kaart. kui ta seda pole, siis ei saa rääkida siin 1:1 asendamisest. see, kui 6870 tuleb sama jõudlusega, mis 5870, on BS marketing rebranding clusterfuck ja otseselt tarbijatele näkku kusemine. isegi, kui hind samaks jääb.
39 |
One
19.10.2010 07:47:50
pole seal ju midagi keerulist, asi pmst lihtsalt refresh kuna gpu-d jäävad ikka 40nm peale.
HD6750/HD6770(arvatavasti lihtsalt renametud HD5750/HD5770)
HD6850/HD6870(uus gpu, Barts)
HD6950/6970(uus gpu, Cayman)
HD6990(uus gpu, Antilles)
HD5 seeriaga pole mõtet asja võrrelda kui just renametavat HD57x0-i mitte arvestada.
Suht loogiline, et vana seeria korjatakse lihtsalt ära ja pannakse uus asemele.
HD57x0 renametakse selleks, et too on oma olematu suuruse juures suht viisaka jõudlusega ja selle kaardi hinda saab kenasti langetada.
728 |
AJ
19.10.2010 08:50:16
AMD’s Radeon HD 6800 Series & Llano “Fusion” APU: A Story in Pictures
AnandTech
AMD Reveals Radeon HD 6800 Series, Demos Llano Fusion-Based Processor
HotHardware
36 |
erick
19.10.2010 10:04:41
| ehhh. kui 6870 asendaks 5870't, siis peab 6870 olema 6xxx seeriast kiireim single GPU kaart. kui ta seda pole, siis ei saa rääkida siin 1:1 asendamisest. see, kui 6870 tuleb sama jõudlusega, mis 5870, on BS marketing rebranding clusterfuck ja otseselt tarbijatele näkku kusemine. isegi, kui hind samaks jääb. |
No mida te lendate selle nime peale üle võlli ikka veel Ammu ju ära seletatatud, et AMD puhul märgista kolm viimast numbrit mitte GPU kohta marketingihierarhias, vaid selle PINDALA ruutmillimeetrites. Jah, kiiremad GPU'd on reeglina ka suurema pindalaga, aga see on lihtsalt kokkusattumus.
Seda, et hinnad jäävad samaks kui HD5800 seerial, ei tohiks juhtuda. Sa ei tee marginaalselt nõrgema performanciga refreshi aasta aega hiljem, et seda sama hinna eest müüa kui enne kiiremat ja vanemat kaarti. Seda ma ei loodaks, et HD6850 asendab HD5770ne, aga tema hind on kindlasti tunduvalt madalam kui HD5850-l.
viimati muutis erick 19.10.2010 10:11:27, muudetud 1 kord |
96 |
