ceemic
24/7@kalal
08.09.2010 19:38:25
trip, oot lähen toon 20L LN2 ja teen Vmodi
322 |
ceemic
24/7@kalal
08.09.2010 23:32:12
| Kas telefoni GPSi saaks üle Bluetoothi ka läpakaga ühendada, et Regioga kasutada?
322 |
KrisVr
08.09.2010 23:35:27
Netis midagi leidsin, ise väga ei süvenenud ja ei tea kuidas täpsemalt asi käib, aga äkki on abiks!
k, i figured out how to do it. i have only done it with the USB cable, as i do not have a bluetooth receiver on my laptop, but the bluetooth is supposed to work too if you select it. first get GPS2Blue http://users.skynet.be/hofinger/GPS2Blue.html install that on your PDA and then follow the directions at http://users.skynet.be/hofinger/GPS2BlueFAQ.html#USB
where it says "How to use with TCP/IP over USB" step 3 is supposed to work, but i have x64 and HW VSP does not work for me. so i use eltima serial to ethernet connector http://www.eltima.com/products/serial-over-ethernet/ i had to change my GPS com from com3 to com2 on my mogul to get it to work.
you just use the first option "Share serial port for incoming connections (server)".
where it says "Select Serial Port" choose what virtual port you want to create (i used com5).
click the "advanced mode" button in the top right corner then click on the "Connection prefs" then unclick the "Start listening for incoming connections only when local virtual port is open"
click "Create connection" from there go back to http://users.skynet.be/hofinger/GPS2BlueFAQ.html#USB and start back at step 4.
now you should be able to open your GPS software on your PC and use it. i have tested it with streets and trips, and it worked fine.
| Kommentaarid: 30 loe/lisa |
ceemic
24/7@kalal
322 |
Piipz
10.09.2010 09:40:37
krt kuidas ma tahaks juba toimiva 2.2 spica peale saada
| Kommentaarid: 37 loe/lisa |
34 |
zaitz
11.09.2010 17:00:59
| Keegi seda Frozen Eclair kombinni ka kasutab ? Kui jah siis millist ja kuidas on - bugid, tundlikkus ?
| Kommentaarid: 36 loe/lisa |
34 |
kiilacas
12.09.2010 15:19:18
tundub, et kõik töötab nagu peab. kõik appsid töötavad ja fc pole olnud. peaks olema V7 kuigi telefonis näitab V9. kaamerat pole palju katsetanud - see vist pidavat vähe bugine olema
ja üks hea mugav app
| Kommentaarid: 4 loe/lisa |
ceemic
24/7@kalal
13.09.2010 11:30:11
| kiilacas kirjutas: |
| ja üks hea mugav app |
"Oop! Sorry, but your kernel does not have all necessary features for running this application, you need rooted phone."
Mis see tähendab?
322 |
DigeBeni
13.09.2010 11:45:48
... pead oma telefon ära root'ima, sellest on siin juttu olnud vähemalt üks kord liiga palju vastasel korral ei saa paljud app'id lihtsalt kõigile süsteemsetele seadetele ligi ...
| Kommentaarid: 194 loe/lisa |
160 |
ceemic
24/7@kalal
13.09.2010 11:52:12
| DigeBeni, oled sa seda varem teinud? Googeldasin veits, aga ei tihka ise näppima hakata...
322 |
DigeBeni
160 |
kiilacas
13.09.2010 17:50:07
rootimisega peab vist muidugi sellega arvestama, et eeldatavasti jäta oma garantiiga hüvasti kui midagi peaks telefoniga juhtuma.
edit. 2.2 audio olemas Bluetooth, GPS, Sensors, Camera veel puudu.
link
ceemic
24/7@kalal
13.09.2010 22:08:51
Kas asi on minus, või tõesti selle mobla 3,2Mpix kaamera on nii kehv?
(Vabandused lapse sassis juuste pärast)
2a vana SE K530i 2,0Mpix kaamera teeb ka paremaid pilte
ISO on 100 peale pandud, aga ikka meeletult mürane. WB proovisin nii Auto, kui manuaalselt, eriti vahet ei ole...
322 |
DigeBeni
13.09.2010 22:23:56
... mida sa siis ootasid I5700 pole ju kaugeltki enam ei uus ega kindlasti mitte highend mudel pealegi, SE föönid on alati keskmisest natuke paremaid pilte teinud ja megapixli number pole seejuures kunagi suurt midagi näidanud ...
160 |
ceemic
24/7@kalal
13.09.2010 22:39:52
| Noh, ega ma fotoka pärast seda telefoni ei ostnudki, aga eeldasin, et vähe pädevam pilt võrreldes kõvasti vanema riistapuuga...
322 |
jaani8
14.09.2010 15:08:11
1.5 cupcake tegi kehvasid pilte, aga 2.1.1 pole müra enam nii hull kui varem. Isegi ühe fotovõistluse olen võitnud i5700'ga.
http://www.ttu.ee/nasa/tipi-siseou/
või siis see kass.
Kasutan ka muidugi Vignette't.
| Kommentaarid: 19 loe/lisa |
19 |
ceemic
24/7@kalal
14.09.2010 15:28:28
| Siis veel selline küsimus I5700 omanikele, et kas äratuskella ei olegi võimalik kasutada, kui telefon väljalülitatud?
322 |
zaitz
15.09.2010 17:02:22
| Ei ole jah, kuna äratuskell pole ilmselt mingi süsteemne protsess vaid tavaline app. Kaamera kohalt nõustus, see on üsna nadi. Rootimise kohapealt on mulle selline mulje jäänud, et see aparaat on suht "unbrickable" ehk iga nässu läinud flashimise saab ikka kuidagi jälle elustada. Ja mis puutub XDA foorumisse, siis pädevam selle aparaadi jaoks on ikka samdroidi foorum.
34 |
trip
15.09.2010 23:51:03
milleks üldse vaja välja lülitada
303 |
ceemic
24/7@kalal
15.09.2010 23:55:08
trip, et aku kauem peaks?
"Vanadest" mobla-aegadest sisseharjunud võte, et ööseks (või niisama uneajaks) telefon välja.
322 |
Enenaat
18.09.2010 09:57:59
Kas keegi oskab öelda, kus saab telefoni menüüs, kui üldse saab, 3G andmevahetust välja lülitada. Ei soovi, et netiarved tulema hakkaksid. Nagu ma aru olen saanud, sis iga mingi aja tagant, ta uuendab end vms. Või tuleb mingi programm tõmmata?....Androidiks sis 1.5
Ette tänades juba
DigeBeni
18.09.2010 10:45:04
... ma päris pead ei annaks, kuid minu mälu järgi 1.5 ja 1.6 puhul oli vist ainuke võimalus APN seaded maha kustutada, alates 2.1 saab ka eraldi andmeside välja lülitada. Teine võimalus on telefon ära rootida ja kasutada APN välja lülitamiseks mõnda Marketist leiduvat appi ...
160 |
ceemic
24/7@kalal
18.09.2010 10:56:42
APNdroid töötab ka rootimata telefoni peal
322 |
Nu
18.09.2010 11:35:41
| ceemic kirjutas: |
"Vanadest" mobla-aegadest sisseharjunud võte, et ööseks (või niisama uneajaks) telefon välja. |
aku peaks ikka paremine siis kestma kui ööseks lihtsalt võrguvabasse reziimi panna. sisse/välja lülitamistega koormab rohekm.
_________________ DO you want it.. And if you had it would you flaunt it...
ss
viimati muutis Nu 18.09.2010 11:37:29, muudetud 1 kord |
157 |
ceemic
24/7@kalal
18.09.2010 11:37:01
| Nu, ehk siis "Lennurežiim"?
322 |
