| Kaua oled WoT-i mänginud? Täpsusta teemas. |
| 12-10a |
42% |
[ 27 ] |
| 10-8a |
17% |
[ 11 ] |
| 8-6a |
11% |
[ 7 ] |
| 6-4a |
7% |
[ 5 ] |
| 4-2a |
4% |
[ 3 ] |
| Vähem kui 2a |
15% |
[ 10 ] |
| hääli kokku : 63 |
KrisVr
02.09.2010 16:17:45
Assoo, no ok!
| Kommentaarid: 30 loe/lisa |
Valvejoodik
02.09.2010 16:34:30
Ma plõksisin eile umbes 10 korda Connect peale ja lõpuks sain sisse, ehk peksa connect nuppu
| Kommentaarid: 16 loe/lisa |
15 |
-Vertigo-
02.09.2010 19:16:08
Siin on siis kirjas, mis see patch teeb:
World of Tanks Closed Beta patch v.0.5.4.1
Changelog 0.4.5 - 0.5.4.1 for the EU/US client:
Major changes:
- Introduced new system of waiting list for the battle formation.
- Added squad mode – possibility for two or three players to join the same battle (additional menu selection under the "Battle!" button).
- Introduced expendables – modules that can be used during the battle. Purchase and installations is through 3 slots in the hangar, to the right from the additional equipment slots.
- Reworked additional equipment: now some equipment cannot be uninstalled after being put on the tank, some equipment are divided into classes, introduced different prices for different types of equipment.
- Introduced crosshair settings. So far it's a test version with limited number of settings.
- Added 2 new maps: “Erlenberg” and “Pagorki”.
- Added new German TD level 9 - JagdTiger.
- Reintroduced markers "Attacking" and "Need help".
- Removed possibility of transferring experience from non-elite tank into the free experience.
- Added message when attempting to sell tank with crew or with installed additional equipment on it.
- Removed mortar trajectory for SPG.
- New calculations for the base capturing: large number of tanks at the base doesn't lead to the instant base capture.
- Changed the way the general channel works: now when player starts the game, (s)he does not get connected automatically to the general channel - to connect you need to open the channel window. Also when entering the battle, player gets disconnected from the general chat. When coming back from the battle, player will need to open the general channel window to reconnect.
Balance and gameplay:
- Reworked prices for all tanks and modules.
- Reworked profitability of tanks.
- Multiple balance changes for almost all tanks.
- Changed terms of receiving several medals of "hero of a battle".
- Doubled the price of transferring tank experience into free experience.
- Reduced cost of training crew members for gold.
- Reduced chance of fire for Maus' engine.
- Fixed damage models for several tanks.
- Reworked the influence of the driver on tank speed and maneuverability.
- Fixed possibility of the track to fully absorb the projectile.
- Fixed HE ricochet bug, which also sometimes led to reset of ammo selection into the first type, even though interface indicated that 2nd or 3rd type being used.
- Fixed errors with difficulty to destroy the open-air SPG when shooting into the open section.
- Limited changes in the repair cost for some tanks (to balance game economics).
- Fixed error when sometimes HE projectiles couldn't destroy the tracks.
- Increased number of slots for additional equipment to 3.
Content:
- Improved effects of shots and tank explosions.
- Added destruction for some objects.
- Added new effects for different types of destructible objects.
- Reworked hitpoints of destructible objects.
- Fixed speed of traverse rotation on some tanks.
- Fixed tire rotation on tanks Pz IV and T-28.
- Fixed errors in models of some tanks.
- Fixed excessive gloss of trunks on some trees.
- Improved and added some sounds.
Maps:
- Fixed and reworked minimaps.
- Lakeville: Fixed pass-ability and destruction of several objects.
- Ensk: improved decorations.
- Malinovka: fixed entrances into water.
- Murovanka: fixed appearance of "weird polygons", improved general performance.
- In order to improve performance, some extra objects were removed from the maps.
Interface:
- Added password saving option. The saved password is encoded.
- Fixed bug when settings "notification from other players" would not save.
- Fixed error with desyncing of counters before the start of battle.
- "Guard" vehicles renamed to "Elite".
- Fixed several typos.
- Fixed notification "Battle begins" which is visible throughout the battle.
- Fixed notification when you are trying to buy a tank you don't have enough money for.
- Reworked window with tanker's personal data.
- Added separate setting for wide-screen display mode.
- Fixed bug with blurry messages in hangar.
- Penetration "traffic light" (red-yellow-green will you penetrate or not) now does not work through the obstacles.
- Fixed small errors in the purchase window of a tank.
- Now in hangar only the tanker's experience will be reflected, without the commander's bonus.
- Added separate icons for premium HE shells.
- Improved icons of tankers in the hangar.
- When you click RMB in the strategic mode turret/gun will stop rotation.
- Return of the tip about in-game help (F1) to the loading screen.
- Added display of prices for all operations as floating messages in the hangar
- Added display of spread in armor-piercing and damage in the interface.
- Fixed switching from email to password by pressing TAB in the login window.
- Improved player's stats window.
- Expanded display of stats for other players and their tanks.
- Fixed error: "list of modules does not fit the edges of the window in the window mode".
- Fixed error with opening 2x information windows for modules when clicking RMB once.
- Fixed messages when unable to install turret because of weight limit.
- Removed confirmation window when leaving the battle waiting room.
- Added dialog window to turn on speed up crew training.
- Reworked display of tanker's personnel file and their training.
- Added possibility of changing face and name of the crew member.
- Added description of achievements/medals.
- Added description of secondary skills.
- Fixed error when some modules wouldn't display in the depot.
- Removed ticked off position of "ready for battle" square box in the tank lineup filter in the hangar.
- Fixed error with resizing of the tank after every hangar update.
- Added display of slot price on the slot itself.
- New hangar "header".
- Fixed error with display of Tip99.
- Fixed "compression" of the game window after switching from full screen into window mode by pressing Alt+Enter.
- Added images of medals to mark player's achievements.
- Fixed errors with display of side armor of some "open-air" SPGs.
- Fixed error: "When entering some amount of gold for exchange from a keyboard the key "exchange" stays inactive".
- Fixed error: «Entering the amount of experience on "elite" tank from a keyboard stays blocked.»
- Fixed wrong information on armor thickness of the tank in the store.
- Fixed error of exiting into the hangar without interface instead of entering the battle.
- Fixed some errors in the interface texts.
System:
- Fixed "black skies" bug.
- Fixed game crash when closing messages in the hangar.
- Fixed game crash with wrong tank coordinates.
- Fixed error with tank being moved beyond the edge of the map in the final stats of the battle.
- Reduced usage of system and video memory (approximately by 10-20% on different maps).
- Removed possibility of starting two clients at the same time.
- Reworked mechanics of memory cleanup. Now when the maximum RAM reached the game decreases texture resolution. And when it reaches the limit again - the game offers to restart the client.
Tõmmata saab siit: http://www.megaupload.com/?d=XQ52APF6
puik17
02.09.2010 19:52:20
| Kust koodi saada?
| Kommentaarid: 79 loe/lisa |
75 |
KrisVr
02.09.2010 20:04:59
C34C067405-989EF5EF83-2239B3B83D-W93855
Kribu
02.09.2010 20:18:08
| Niih, uus patch peal ja mõni lahing tehtud. Tänu sellele wipele on kõigil sellised tankid käes, et paha hakkab. Ma enda VK3001 olen pidevalt järjekorras viimaste seas. Ei oskagi kohe öelda, kas tehti asi paremaks või halvemaks, aga mis mulle meeldivad on need nö consumables, aitavad lahingus päris palju.
| Kommentaarid: 10 loe/lisa |
9 |
KrisVr
02.09.2010 20:25:45
Mul näitab ikka, et "Server busy".
Valvejoodik
02.09.2010 20:27:41
| Kas ainult mul tõmbab patchi teokiirusel?
15 |
KrisVr
02.09.2010 20:39:42
| Üleval oleva lingiga sai täitsa normaalse kiirusega allalaetud.
Valvejoodik
02.09.2010 20:47:37
Oleks vaid see link varem postitatud...
Mul tõmbab clienti kaudu ca. ~40kb/s Õnneks on varsti valmis ka.
15 |
-Vertigo-
02.09.2010 20:54:04
| Sain ka ennem ühe lahingu tehtud, aga nüüd koguaeg server busy..
Valvejoodik
02.09.2010 23:02:11
Mingi patch tuli veel 5,55Mb, loodetavasti tuli nüüd ka USA, kuna eelmise patchga seda ei lisandunud
Jube download sellel ikka, väidab, et aega läheks 200 minutit
EDIT: hakkas liikuma
15 |
KrisVr
02.09.2010 23:12:54
Kahjuks ei tulnud USAt! Aga vähemalt saab nüüd mängida!
Valvejoodik
03.09.2010 00:31:30
Tõsi, sain omale Panzer IV ja KV ja nüüd läks alles mänguks lahti
Kahjuks valisin KVle üliaeglase kahuri, laeb vist mingi pool minutit. Ma ei kujuta ette, mida meeskond seal tankis nii kaua teeb, mängivad turakat või?
15 |
Roomik
03.09.2010 12:10:21
KV laadimine võtab sellepärast kaua aeg, et mürsk on kahest osast
Tuletegija
03.09.2010 16:45:42
Raudselt lasevad hundijalavett tornis.
_________________ Rolling Thunder |
| Kommentaarid: 28 loe/lisa |
26 |
MONGO
03.09.2010 17:36:58
Keegi mingi kiviajast kaardi peal on seda jooksutanud? Pean veel natuke aega GMA950-e peal elama aga see on ikka väga paljutõotav mäng, teeks isegi mõned raundid kui välja jookseks kuidagi
| Kommentaarid: 26 loe/lisa |
21 |
Paganarh
03.09.2010 18:09:58
olen kah nüüd sees (kasutaja nimega Turvas)
kas mingi keyboardmapping ka kuskil on? ilmselt liigun kuidagi valesti- ei saanud kiirust kuidagi üles
edit: nevermind, sain pihta
viimati muutis Paganarh 03.09.2010 18:16:40, muudetud 1 kord |
| Kommentaarid: 15 loe/lisa |
Tuletegija
03.09.2010 18:12:53
ingame F1 kui ma ei eksi on juhend mis nupp kuskil on, mappingut ei olnud vist hetkel
26 |
Paganarh
03.09.2010 22:46:41
jep, f1 oligi. nüüd olen siis liikuv märklaud oma traktoriga. ohwell
edit: pole midagi öelda, ammu juba pole nautinud mõnda pvp mängu niipalju. counterstrike roomikutel
Roomik
03.09.2010 23:17:04
On paar asja mis mängu juures häirivad:
1. Suurtüki kaartuli on snaipri täpsusega, samas annab see mängule vürtsi juurde kui tead, et sitsimine põõsas lõpeb suitsusambaga
2. Peale seda kui sind on avastatud, oled nähtav ka paksu metsa sees (punane kontuur), mis on ebaloomulik.
Muidu on mäng ülilahe ja vahel kui on õnne, on skoor selline:
Victory!
Battle: Murovanka 3. september 2010. a. 23:02:42
Tank: VK3601(H)
Earned:
1 785 Experience
37 231 Credits
Valvejoodik
04.09.2010 11:18:02
Teevad vist jälle mingit updatet
15 |
Lovvi
04.09.2010 11:26:33
| Valvejoodik kirjutas: |
Teevad vist jälle mingit updatet  |
Peaasi et iga update-ga tuleb rohkem kulda
| Kommentaarid: 61 loe/lisa |
58 |
Scart
04.09.2010 11:31:30
Tundub maas olevat jah. Öösel sai paugutatud natuke ja päris äge oli. Muidugi need alguse tankid on päris
101 |
puik17
04.09.2010 12:18:32
Sai ka vähe öösel ja täna hommikul lahmitud. Täitsa huvitav.
Aga mille eest seda kulda saab? Eile öösel oli 150, 50 kulutasin ära, ja täna hommikul oli 250 jällegi.
75 |
-Vertigo-
04.09.2010 12:30:45
iga päev saab 150 kulda
Paganarh
04.09.2010 12:39:21
abiks natuke veel, siis saan lõpuks medium tangi peale, siiber sellest light'ist.
siis tänu kullale on klotsi ka mille eest osta, muidu grindiks siniseks
viimati muutis Paganarh 04.09.2010 12:46:56, muudetud 1 kord |
Valvejoodik
04.09.2010 12:44:28
XPd läheb minu kogemuse põhjal kõvasti rohkem vaja, kui raha/kulda.
150G saamiseks pead päevas vähemalt ühe lahingu tegema Kusagilt käis läbi ka jutt, et kui sul on 3000G, siis "päevaraha" ei saa.
15 |
Roomik
04.09.2010 12:51:18
Võin öelda,et saab. Endal jäi eilse seisuga 3000G pihku ja täna on lisandunud 150G. 20000EXP veel siis saan Tiigri
-Vertigo-
04.09.2010 12:56:52
jep, endal sama, 5000+ kulda ja ikka saan päevas 150 preagusel hetkel proovin siis ka Tiigrit endale saada Venelaste tanke pole peaaegu üldse kasutanud...
Paganarh
04.09.2010 13:16:53
krt, kahju et raha kantida ei saa üksteisele, võtaks laenu võimidagi
Tuletegija
04.09.2010 14:17:47
Muidu kohalike le tankistidele on nüüd genereerunud ka eesti kanal: Eesti eest edasi
26 |
Valvejoodik
04.09.2010 14:39:06
Oi, peab uurima
Vene tankide eeliseks on kiirus ja suur toru, sakslastel on hea armor ja kiire reload.
15 |
Paganarh
04.09.2010 15:14:42
| tõmmati juhe välja vist. unable to connect. keset lahingut lendas välja
Valvejoodik
04.09.2010 15:21:44
Sama asi. krt küll, premium lihtsalt seisab
15 |
Tuletegija
04.09.2010 15:23:16
Arvestades et asi on ikkagist BEta veel siis hää et niigiaplju toimib.
26 |
Renyr
04.09.2010 15:29:22
Võtan endale siis Vene Heavy Tankid, sai proovitud ka BT-2 kuid see väga ei istu...proovin veel AT-1 ja seda SPG SU-18
Natuke olen seal möllanud, sihtimine on nii nagu ta on.... avastasin, et parema hiire klahviga saab autotarget panna(ei ole 100% täpne)
Kuidas lasta liikuvaid tanke? proovisin täpselt tanki lasta-ei midagi...lasin natuke temast ette-samuti mitte midagi..
Üks asi mis väga häirib on lag..enamus warpivad ringi ja ei tea kuhu ta mõne sekundi pärast kaob
Valvejoodik
04.09.2010 15:45:19
Lugesin huvi pärast FAQi ja leidsin sellise huvitava asja:
| Infantry will be implemented further on. |
Et kas on lootust ka MP40ga ringi joosta?
15 |
Paganarh
04.09.2010 15:50:53
läks lahti jälle
KrisVr
04.09.2010 16:00:33
| Paganarh, Kellel? Aa oih, mängida saab!?
Marx112
05.09.2010 12:47:21
| Ilgelt kõva mäng raisk. Tahaks ise ka juba lightist edasi saada. Jubeded juustud tangid on ikka alguses. Üldse ei pööra, ei liigu, puhas surm lahinguväljal. Mõni kiirem tank seljtaha saab oled kutu ka.
puik17
05.09.2010 13:08:27
Tuuniära sis tank
Leichttraktori sai päris nobedaks.
75 |
Scart
05.09.2010 14:47:24
| Renyr kirjutas: |
Kuidas lasta liikuvaid tanke? proovisin täpselt tanki lasta-ei midagi...lasin natuke temast ette-samuti mitte midagi. |
See ka minu jaoks hetkel kerge müstika. Lasen 100 meetri pealt minu poole küljega tanki, mis liigub aegluubis ja no ei saa pihta Flakiga ja kõik. Effective range on kirjade järgi 300 meetrit aga no sellega ei lase kümne meetri pealt küüni seina ka maha.
101 |
villu70
05.09.2010 15:39:18
Regasin ka ära, soft tõmmatud ja installitud.
Millal nad reg. koodi mulle saadavad.
122 |
veso
05.09.2010 16:14:20
| võtas-uxu kirjutas: |
Millal nad reg. koodi mulle saadavad.  |
Ise samas staadiumis.
knoxxx
05.09.2010 16:16:51
| mul on probleem sellega, et kui tõmban mängu ära,siis panen selle file peale,et hakkaks installima, siis läheb arvuti aeglaseks ja WOT ei tule ise ka lahti, juba mitu korda, kas keegi saaks aidata?
Scart
101 |
villu70
05.09.2010 16:38:11
| tra küsib ju mingit invite code, ise sünnitan selle või.
122 |
veso
05.09.2010 16:45:37
Selle võtadki MMOHUT lingilt mille Scart linkis ju.
MorRAW
Ei ole Guru
| Kommentaarid: 376 loe/lisa |
317 |
