uus teema   vasta Tarkvara »  Arvutimängude foorum »  Mafia 2 märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 69, 70, 71 ... 81, 82, 83  järgmine
-Kaivo-
sõnum 30.08.2010 18:57:48 vasta tsitaadiga
DevConsole-V1-0
Mentide eest annab ära sõita.
Manus
Tonsor
Tonsor
sõnum 30.08.2010 18:58:02 vasta tsitaadiga
-Kaivo- kirjutas:
Tonsor kirjutas:
Ma ainuke, kellel dev console ei tööta?
Tõmba uuem versioon
Dev sain tööle, pidin mafia2.exe Mafia2.exe'ks muutma.
Kommentaarid: 36 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 32
eyelids
sõnum 30.08.2010 20:22:44 vasta tsitaadiga
"Mafia II originally included 180 missions"
http://translate.google.com/translate?u=http://mafia2.scorpions.cz/&sl=cs&tl=en&hl=&ie=UTF-8
Mafia II hides many secrets. We previously wrote about the discovery of weapons at close range. With full play to get us a surprise, small, big or shocking. We managed to find a map of the Sicilian city of San Celeste. The city is not something small, and if we use the theory, it is possible that in the Second World War did not happen just a 10 minute mission.
For longer periods of exploration, we found also the icons in the game. Definitely worth to mention those not in the game. It is mainly the challenge.
We hit the nadzemku. Actually the game is just not active. This folder contains textures, sounds, etc. Also, we discovered four new artworks. In the folder, there were more, but only changed the car in person, so we have chosen the best.
Yet one more thing. Lots of fans wonder the end of Mafia II, as it happens we will not disclose (to not spoil the experience for those who do not nedohráli), but it remains a question over what comes next. The game also contains three epilogues, again (surprisingly) locked.
Update (August 29 - 20:57): In the game, and there are even free ride, we can change between winter and summer. Function is again the incomprehensible reasons not activated and therefore I can not use it.
Update (August 29 - 21:04): We obtained the complete list of missions of the Czech Mafia II. Of what they are and what those should be there. The list can be found here!
http://translate.google.com/translate?hl=en&ie=UTF-8&sl=cs&tl=en&u=http://mafia2.scorpions.cz/clanek/vsechny-mise&rurl=translate.google.com
Kommentaarid: 42 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 42
Andykas
Andykas
sõnum 30.08.2010 20:40:30 vasta tsitaadiga
eyelids,
Kommentaarid: 25 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 22
xxlmaster
xxlmaster
sõnum 30.08.2010 20:46:51 vasta tsitaadiga
Kokkuvõtvalt siis võiks öelda et võeti suur tükk ette ja suu läks lihtsalt lõhki.
asjameez
asjameez
sõnum 30.08.2010 20:50:48 vasta tsitaadiga
Seda poolikut jura siis enam ei viitsitud välja ka visata.
Kommentaarid: 63 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 61
Mafia
Mafia
sõnum 30.08.2010 20:52:07 vasta tsitaadiga
eyelids kirjutas:
Need pealkirjad, mis leiti.. on cutseenide / checkpointide nimed, nii non-sensiks ei maksa ka juba minna et oh mingi 150 misiooni nagu jäeti välja vms icon_rolleyes.gif
Sitsiilia mapi kohta ei oska kommenteerida... need iconid on PS3 DLC-le. Ilmselt ka Jimmys Vendettale mis tuleb kõikidele platvormidele ja on pmst sama...
Bawse
Kommentaarid: 19 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 17
Platinet
sõnum 30.08.2010 20:53:38 vasta tsitaadiga
Hull värk selle Mafiaga ikka, ise ilmselt lähiajal ei kipu seda veel proovima
Mafia
Mafia
sõnum 30.08.2010 21:12:56 vasta tsitaadiga
Platinet kirjutas:
On jah üks hull s**t storm sellega... osad arvavad, et pool mängu on välja lõigatud aga päris nii see ikka ei ole...
Keegi avastab midagi koodist, kohe karjutakse kooris: SEE CONTENT ON VÄLJA JÄETUD MEELEGA!!! icon_rolleyes.gif
Bawse
mutabor
mutabor
sõnum 30.08.2010 21:24:15 vasta tsitaadiga
põmst on tyypiline olukord kus võetud suur feature'de list ja kuna tähtajaks ei jõutud kõike valmis siis disableti neid featuure mis olid poolikud.
Mafia2 mängides tekkis miskipärast isu uuesti Saboteur ette võtta...
btw, see on natuke naljakas et Wanted plakatid on mööda ilma laiali _peidetud_ icon_biggrin.gif.
/allkiri
viimati muutis mutabor 30.08.2010 21:25:25, muudetud 1 kord
Kommentaarid: 24 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 22
vipu
vipu
sõnum 30.08.2010 21:24:53 vasta tsitaadiga
või siis mingi võll tuli ja tahtis omamoodi asja väljaanda (näiteks investor vms) ja siis kiirelt keerati kinni mida saadi.
Kommentaarid: 5 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 4
Mafia
Mafia
sõnum 30.08.2010 21:25:22 vasta tsitaadiga
Bawse
mutabor
mutabor
sõnum 30.08.2010 21:31:23 vasta tsitaadiga
vipu, see on ysna tavaline keiss tarkvara arenduses kus tähtaja saabudes keskendutakse ainult olulistele aspektidele ja nii jääbki mingi osa tööst lõpetamata. neid juhtumeid on oluliselt rohkem kui meile teada antakse.
samuti pole välistatud võll kes peab vastu võtma ebapopulaarseid otsuseid juhul kui projekt hakkab venima. mingi ajahetk kulud lähevad liiga suureks ja saabub aeg hakata kulutatud raha tagasi teenima...
/allkiri
Mafia
Mafia
sõnum 30.08.2010 21:40:05 vasta tsitaadiga
mutabor kirjutas:
MA olen kindel ,et selliseid asju on igal mängul esinenud aga kuna enamus mängude failid on nii krüpteeritud et neid kuidagi lahti ei saa, siis me ei teagi nendest asjadest. Ma ei välista et Publisheril siin sõna ei olnud teatud aspektides... aga probleem on selle kontendiga mida on avalikult näidatud aga ei ole sees ning ka sellega, et 2K ei julge foorumis sõna võtta või avaliku pöördumist teha kogu selle asja kohta. Mängul pole midagi viga, lihtsalt võiks pikem olla ja selle tõttu on inimesed hakanud otsima ja arvama et see ja see ja pool mängu on välja lõigatud...
Bawse
Cracker
sõnum 30.08.2010 21:42:04 vasta tsitaadiga
Krt see DevMenu keeras mu savegame pekki...olin juba suht lõpus icon_sad.gif
K3ndu
K3ndu
sõnum 30.08.2010 21:50:53 vasta tsitaadiga
See ,et pooled asjad kinni on hea nöörimiskoht, nüüd hakkab DLC-si tulema nagu seeni peale vihma. Kaart ees olemas ju nüüd natukene stoorit veel möelda ja missioonid valmis ja saabki uuesti nöörima hakata...tunnen kaasa sellisel juhul nendel kes endale Collectors Editioni ostsid.icon_biggrin.gif
Kommentaarid: 130 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 120
LightsabeR
LightsabeR
sõnum 30.08.2010 21:51:33 vasta tsitaadiga
Sai natuke tippkiirust aretatud:
Sellise kiirusega sõites tundub linn ikka väga väike. :p
Rainpoiss
Rainpoiss
sõnum 30.08.2010 22:09:39 vasta tsitaadiga
Mul ei hakanud need autode DLC'd tööle, äkki keegi saab aidata? Autode nimed on garaažis olemas aga autot ennast pole.
Mafia
Mafia
sõnum 30.08.2010 22:29:00 vasta tsitaadiga
Cracker kirjutas:
Arvata on, et need toolid ja häkid on sellised pool-pidused seega tasub kõigest mida muudate backup teha icon_smile.gif Ka savedest.
Bawse
Andykas
Andykas
sõnum 30.08.2010 23:55:04 vasta tsitaadiga
http://mafia-empire.com/forum/index.php?topic=33.msg230#msg230
xxlmaster
xxlmaster
sõnum 31.08.2010 00:03:07 vasta tsitaadiga
ei tea. Jube kole näeb see damage välja icon_confused.gif , see on ikka tsipa juba üle pakutud.
Gap
Gap
sõnum 31.08.2010 00:17:18 vasta tsitaadiga
ma olen saanud tänase õhtu jooksul 3 BSODI selle mänguga icon_cry.gif saan algusest natuke mängida ja viskab ekraani siniseks icon_sad.gif Oskab keegi targem mind aidata ? Peal on 197.77 driverid ... demo töötas korralikult :S
mutabor
mutabor
sõnum 31.08.2010 00:44:16 vasta tsitaadiga
Gap, 197.77 on ju mai kuu omad...
/allkiri
Mafia
Mafia
sõnum 31.08.2010 00:53:43 vasta tsitaadiga
SNEAK PREVIEW OF JIMMY'S VENDETTA WITH DENBY AND DAN
PAX Prime is coming up this weekend - and we're going to be at the 2K Booth giving you hands-on time with Jimmy's Vendetta! Not going to be able to make the show? Never fear - we're going to be showing a 1-hour sneak preview of Jimmy's Vendetta on our Ustream channel Wednesday, September 1st at 2 PM PT!
RSVP now and be sure to tune in and ask the guy's questions about the new content for Mafia II!
http://www.ustream.tv/2kgameslive
Arvestades ,et seal on live question... siis ei tea mis s**tstorm sealt küll tuleb... icon_razz1.gif
Bawse
Gap
Gap
sõnum 31.08.2010 01:00:30 vasta tsitaadiga
mutabor kirjutas:
jah aga mis drivereid te siis soovitaksite ? Need kõik 200 numbrimärgiga ei sobi mulle kuna ei oma kahjuks kõige uuemat nvidia 4 seeria kaarti icon_sad.gif ühte driverit proovisin mingi 257 v 258 oli ja samamoodi sain osades mängudes mingeid erroreid ja bsode :S
Tolka15
sõnum 31.08.2010 01:32:22 vasta tsitaadiga
Gap kirjutas:
mutabor kirjutas:
Endal 258.96 ja töödab kõik thumbs_up.gif (kaardiks 896MB 275GTX). Vahel harva hakkab jõnksutama, kuid seda juhtub harva. Paar korda vaid restarti teinud.
Muidu sai täna mäng läbi tehtud. Olen rahul ja ootan jätku, expansion packi vms. Üldmuljena oli mäng minu jaoks kui film, nendele, keda sisu ei huvita ja kes dialooge jälgida ei viitsi, muutub mäng automaatselt oluliselt mõttetumaks. Põhiline mängu juures, et suudeti edastada tõepärane mafia-ajastu atmosfäär ja tegevused toimusid võrdlemisi vahelduvas keskkonnas. Hiilimist ehk stealthi oleks tõesti võinud olla rohkem, aga pole hullu. Negatiivsema poole pealt oli tõesti see, et ~8-9nda chapteri juures hakkas see ühest otsast teise autoga sõitmine pinda käima, aga õnneks vaheldusid aegamööda autod ja oli võimalus aegajalt tuuninguid korraldada. Buge sattus võrdlemisi vähe ette, mõni tõsisem neist vast see, et keegi tegelane põikpäiselt mööda kinnist ust kõndis, kuni ma ise ukse lahti ei teinud või ta ise järsku kadus kuhugi.
M: Philips õuevalgustid 4tk
prtv
sõnum 31.08.2010 11:29:50 vasta tsitaadiga
Mäng crashis selle koha juures, kus tuleb mingit paksukest taga ajada ja maha tappa inimesi, savegame corrupted thumbs_up.gif icon_lol.gif
Kellelgi pole savegamet selle koha juurest jagada?
kri5to
sõnum 31.08.2010 11:38:06 vasta tsitaadiga
Mismoodi neid uuemaid autosi saada?Just mõtlen mingeid võimsaid hotrode,seda sõjaväe autot?Mingisuguseid koode vms ei leidu?
trip
trip
sõnum 31.08.2010 11:38:51 vasta tsitaadiga
gan3b
savegame pole vaja, olemas selline asi
Andykas kirjutas:
Debug missionid lahti:
http://mod.gib.me/mafia2/loadchapter.zip
sellega võid alustada mis iganest osast/ osa missionist
viimati muutis trip 31.08.2010 11:41:45, muudetud 1 kord
K3ndu
K3ndu
sõnum 31.08.2010 11:40:02 vasta tsitaadiga
kri5to kirjutas:
Loe eelmisi lehti, jah koode ei leidu.
Kustav
Kustav
sõnum 31.08.2010 12:45:09 vasta tsitaadiga
Ma ei kiitnud ei laitnud, lihtsalt objektiivne hinnang oma mätta otsast. Mulle mäng meeldis.
7/10 on üle keskmise mäng icon_wink.gif
5/10 on hae mäng aga
10/10 on ideaalne, parim jne, sellist mängu pole veel kohanud, igalmängul omad miinused, ehk mafia 3 suudab seda icon_biggrin.gif .
Kommentaarid: 175 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 160
snap3
snap3
sõnum 31.08.2010 14:18:50 vasta tsitaadiga
njh.. 25-26.08 läbisin mängu lõpuni..
viimati muutis snap3 31.08.2010 15:12:20, muudetud 1 kord
Kommentaarid: 71 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 66
Sven
Sven
sõnum 31.08.2010 15:06:55 vasta tsitaadiga
Kommentaarid: 35 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 32
zlenard
sõnum 31.08.2010 15:45:11 vasta tsitaadiga
Kas teiearust on ka lõpp veidi imelik, lõppeb veidi järsku 2ra?
Mafia
Mafia
sõnum 31.08.2010 16:26:40 vasta tsitaadiga
Sain oma SE kätte... Endale üllatuseks avastasin et: Take-Two Interactive omab kõiki õigusi seoses Mafia, Mafia II ja tema mootoriga lisaks omab ta ka 2K GAMEsi. icon_rolleyes.gif
zlenard kirjutas:
See lõpp on selline huvitav...
MOAR!!!
Mafia II Upcoming DLC Packs A Vendetta
Kotaku
Crime game Mafia II is getting its second downloadable add-on called Jimmy's Vendetta.
The DLC follows Jimmy, who is described as "the guy the other guys call when they need to finish the job". Jimmy cleans up the messes made in Empire Bay, and the game features 30 new quests that run the gamut of assassinations to car chases.
Jimmy's Vendetta also has online rankings where players can posts points scored with combos and multipliers.
Priced at $9.99/800 Microsoft Points, Jimmy's Vendetta will be released on the PlayStation Network, Xbox Live Arcade and PC on September 7.
http://store.steampowered.com/news/?appids=50130
Bawse
prtv
sõnum 31.08.2010 16:27:04 vasta tsitaadiga
vipu
vipu
sõnum 31.08.2010 17:21:40 vasta tsitaadiga
minuarust selle mängu stoori pole kuidagi seotud mafiaga ehk organiseeritud kuritegevusega. stoori koosneb kahest töllist kes teevad mingeid täiesti imelikke missioone. kui sellest mängu stoorist oleks vändatud film, siis seda kinno keegi vaatama ei läheks. mafias olemise eesmärk on võim, palju raha, elupõletav eluviis. selles mängus polnud mitte midagi, polnud mafiat, polnud org. vahelisi sõdasid.
jään ise siiski 5/10 hinde juurde. tehniline ja visuaalne lahendus on mängul super.
stoori on sulepeast imetud käkerdis, mingeid tegevusi sa ise mängus aretada ei saa, mingi vestlus dialooge ka sul ei ole. teed mängus nii nagu pead tegema...
gretchin
gretchin
sõnum 31.08.2010 17:24:04 vasta tsitaadiga
enamus stoorit on legendaarsetest maffia filmidest välja imetud
Kommentaarid: 43 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 38
vipu
vipu
sõnum 31.08.2010 17:46:47 vasta tsitaadiga
ma küll ei kohanud ühtegi sellist kohta mis oleks nagu kusagilt filmist võetud.
tige kala
tige kala
sõnum 31.08.2010 17:56:13 vasta tsitaadiga
vipu,
Aga selliseid misioone oleks võinud ka ikka olla, kus mingi kambaga lähed teed mingi koha tühjaks, samuti panka oleks võinud röövida või raha autot jne. kusjuures imelik on see, et raha autost üldse raha ei saa icon_biggrin.gif, tagumisi uksi on väga raske esiteks juba lahti saada, korra on see ainult õnnestunud aga pappi ikka ei saa icon_rolleyes.gif
Kommentaarid: 66 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 64
vipu
vipu
sõnum 31.08.2010 18:01:16 vasta tsitaadiga
mulle siiski ühtegi konkreetset filmi ette ei tekkinud. filme on ka mustmiljon, kusagilt kaudselt võib tõesti sarnasust leida. nad oleks võinud vähem videosid teha ja selle energia sisusse laduda ja jätta puzzle kokkupanemine mängija hooleks. puzzle oleks võinud ikka raske olla, just ise mõtlemist ja planeerimist.
omgwtf
omgwtf
sõnum 31.08.2010 18:10:03 vasta tsitaadiga
Läbi ta saigi thumbs_up.gif Terve nädala suutis sisustada õhtaid mõne tunni kaupa icon_smile.gif Igatahes väga 5+ pela oli,ei nurise millegi üle,või siis ei oska nuriseda icon_smile.gif Mingi Gotyga tegemist vast pole,kuid kindlasti üks asi mida mainida thumbs_up.gif
libe
kvaliteetne mees
libe
sõnum 31.08.2010 18:45:35 vasta tsitaadiga
tige kala kirjutas:
vipu,
on küll nagu mingist filmist
katsu sa mafia teemalist mängu teha nii, et näiks täiesti originaalsena välja ja absoluutselt midagi poleks üheski nendest sajast mafiafilmist laenatud või sarnane
muidugi sellise originaalse lähenemisega vastab vipu nagu ta just muidugi vastas icon_lol.gif
vipu kirjutas:
kuidas mängu stoori ei ole seotud mafiaga, kui peategelased kuuluvad mafia perekonda ning üldse kogu temaatika käib erinevate perekondade ja võitlusest nende vahel
raha oli mängus palju, oska vaid teha
elu põletav eluviis - naised, relvad ja kuritegevus, midaiganes
võimust rääkides, siis mitte iga naga mafias pole võimukas tegelane
ausalt öeldes oligi hea, et näidati made man vaatepunktist kogu stoorit - draamat jätkus lõpuni
kusjuures ka esimene mafia jäi samale tasemele - ei mingit don angelot polnud
KuriVaiM1
KuriVaiM1
sõnum 31.08.2010 19:07:00 vasta tsitaadiga
vipu, Paralleelselt suitsuäri ning keelust hoolimata narkotsiäri analoogselt "Goodfellas" filmiga
icon_arrow.gif "Mõtle kriitiliselt"
libe
kvaliteetne mees
libe
sõnum 31.08.2010 19:33:39 vasta tsitaadiga
KuriVaiM1 kirjutas:
need olid puhtalt ajastuteema, mis nad oleks pidanud matrjoškasid äritsema, et millegagi mitte sarnane olla icon_question.gif
vipu
vipu
sõnum 31.08.2010 19:53:58 vasta tsitaadiga
libe kirjutas:
tige kala kirjutas:
vipu,
vipu kirjutas:
ma ei näinud mängus mafiat siiski ja see ei tulnud kusagilt ka välja. ma arvan et isegi mingi keskkooli õpilane kirjutaks mingi parem käsikirja mängule kui see filmike oli.
esimene mäng oli rohkem mafia perekonnast kui see. oli oma autoparandaja, relvaekspert, omad liikmed jne.
maifias karjääri tegemine on nagu eeldatav.
libe
kvaliteetne mees
libe
sõnum 31.08.2010 20:00:49 vasta tsitaadiga
tige kala
tige kala
sõnum 31.08.2010 20:25:39 vasta tsitaadiga
xxlmaster
xxlmaster
sõnum 31.08.2010 20:47:57 vasta tsitaadiga
tige kala kirjutas:
vipu
vipu
sõnum 01.09.2010 00:24:30 vasta tsitaadiga
noh lõpp oli natuke mafia moodi. lõpp oli isegi mängitav, kõmmutamine on nii mõnus, surevad kõik ise moodi. mingi jobu jooksis mulle trepipealt vastu ja mul õnnestus kohe pähe lasta. mehel raam vajus alt nagu päriselt oleks inimest lasknud. ei tehnilisele osale annaks tõesti medali.
uus teema   vasta Tarkvara »  Arvutimängude foorum »  Mafia 2 mine lehele eelmine  1, 2, 3 ... 69, 70, 71 ... 81, 82, 83  järgmine
