Mafia II hides many secrets. We previously wrote about the discovery of weapons at close range. With full play to get us a surprise, small, big or shocking. We managed to find a map of the Sicilian city of San Celeste. The city is not something small, and if we use the theory, it is possible that in the Second World War did not happen just a 10 minute mission.
For longer periods of exploration, we found also the icons in the game. Definitely worth to mention those not in the game. It is mainly the challenge.
We hit the nadzemku. Actually the game is just not active. This folder contains textures, sounds, etc. Also, we discovered four new artworks. In the folder, there were more, but only changed the car in person, so we have chosen the best.
Yet one more thing. Lots of fans wonder the end of Mafia II, as it happens we will not disclose (to not spoil the experience for those who do not nedohráli), but it remains a question over what comes next. The game also contains three epilogues, again (surprisingly) locked.
Update (August 29 - 20:57): In the game, and there are even free ride, we can change between winter and summer. Function is again the incomprehensible reasons not activated and therefore I can not use it.
Need pealkirjad, mis leiti.. on cutseenide / checkpointide nimed, nii non-sensiks ei maksa ka juba minna et oh mingi 150 misiooni nagu jäeti välja vms
Sitsiilia mapi kohta ei oska kommenteerida... need iconid on PS3 DLC-le. Ilmselt ka Jimmys Vendettale mis tuleb kõikidele platvormidele ja on pmst sama... _________________ Bawse
Hull värk selle Mafiaga ikka, ise ilmselt lähiajal ei kipu seda veel proovima
On jah üks hull s**t storm sellega... osad arvavad, et pool mängu on välja lõigatud aga päris nii see ikka ei ole...
Keegi avastab midagi koodist, kohe karjutakse kooris: SEE CONTENT ON VÄLJA JÄETUD MEELEGA!!! _________________ Bawse
põmst on tyypiline olukord kus võetud suur feature'de list ja kuna tähtajaks ei jõutud kõike valmis siis disableti neid featuure mis olid poolikud.
Mafia2 mängides tekkis miskipärast isu uuesti Saboteur ette võtta...
btw, see on natuke naljakas et Wanted plakatid on mööda ilma laiali _peidetud_ . _________________ /allkiri
viimati muutis mutabor 30.08.2010 20:25:25, muudetud 1 kord
vipu, see on ysna tavaline keiss tarkvara arenduses kus tähtaja saabudes keskendutakse ainult olulistele aspektidele ja nii jääbki mingi osa tööst lõpetamata. neid juhtumeid on oluliselt rohkem kui meile teada antakse.
samuti pole välistatud võll kes peab vastu võtma ebapopulaarseid otsuseid juhul kui projekt hakkab venima. mingi ajahetk kulud lähevad liiga suureks ja saabub aeg hakata kulutatud raha tagasi teenima... _________________ /allkiri
MA olen kindel ,et selliseid asju on igal mängul esinenud aga kuna enamus mängude failid on nii krüpteeritud et neid kuidagi lahti ei saa, siis me ei teagi nendest asjadest. Ma ei välista et Publisheril siin sõna ei olnud teatud aspektides... aga probleem on selle kontendiga mida on avalikult näidatud aga ei ole sees ning ka sellega, et 2K ei julge foorumis sõna võtta või avaliku pöördumist teha kogu selle asja kohta. Mängul pole midagi viga, lihtsalt võiks pikem olla ja selle tõttu on inimesed hakanud otsima ja arvama et see ja see ja pool mängu on välja lõigatud... _________________ Bawse
See ,et pooled asjad kinni on hea nöörimiskoht, nüüd hakkab DLC-si tulema nagu seeni peale vihma. Kaart ees olemas ju nüüd natukene stoorit veel möelda ja missioonid valmis ja saabki uuesti nöörima hakata...tunnen kaasa sellisel juhul nendel kes endale Collectors Editioni ostsid.
Krt see DevMenu keeras mu savegame pekki...olin juba suht lõpus
Proovi chapterloaderi, saad sealt loadid kust sul pooleli oli
Arvata on, et need toolid ja häkid on sellised pool-pidused seega tasub kõigest mida muudate backup teha Ka savedest. _________________ Bawse
ma olen saanud tänase õhtu jooksul 3 BSODI selle mänguga saan algusest natuke mängida ja viskab ekraani siniseks Oskab keegi targem mind aidata ? Peal on 197.77 driverid ... demo töötas korralikult :S
SNEAK PREVIEW OF JIMMY'S VENDETTA WITH DENBY AND DAN
PAX Prime is coming up this weekend - and we're going to be at the 2K Booth giving you hands-on time with Jimmy's Vendetta! Not going to be able to make the show? Never fear - we're going to be showing a 1-hour sneak preview of Jimmy's Vendetta on our Ustream channel Wednesday, September 1st at 2 PM PT!
RSVP now and be sure to tune in and ask the guy's questions about the new content for Mafia II!
jah aga mis drivereid te siis soovitaksite ? Need kõik 200 numbrimärgiga ei sobi mulle kuna ei oma kahjuks kõige uuemat nvidia 4 seeria kaarti ühte driverit proovisin mingi 257 v 258 oli ja samamoodi sain osades mängudes mingeid erroreid ja bsode :S
Endal 258.96 ja töödab kõik (kaardiks 896MB 275GTX). Vahel harva hakkab jõnksutama, kuid seda juhtub harva. Paar korda vaid restarti teinud.
Muidu sai täna mäng läbi tehtud. Olen rahul ja ootan jätku, expansion packi vms. Üldmuljena oli mäng minu jaoks kui film, nendele, keda sisu ei huvita ja kes dialooge jälgida ei viitsi, muutub mäng automaatselt oluliselt mõttetumaks. Põhiline mängu juures, et suudeti edastada tõepärane mafia-ajastu atmosfäär ja tegevused toimusid võrdlemisi vahelduvas keskkonnas. Hiilimist ehk stealthi oleks tõesti võinud olla rohkem, aga pole hullu. Negatiivsema poole pealt oli tõesti see, et ~8-9nda chapteri juures hakkas see ühest otsast teise autoga sõitmine pinda käima, aga õnneks vaheldusid aegamööda autod ja oli võimalus aegajalt tuuninguid korraldada. Buge sattus võrdlemisi vähe ette, mõni tõsisem neist vast see, et keegi tegelane põikpäiselt mööda kinnist ust kõndis, kuni ma ise ukse lahti ei teinud või ta ise järsku kadus kuhugi.
Mäng crashis selle koha juures, kus tuleb mingit paksukest taga ajada ja maha tappa inimesi, savegame corrupted
Kellelgi pole savegamet selle koha juurest jagada? _________________
Ma ei kiitnud ei laitnud, lihtsalt objektiivne hinnang oma mätta otsast. Mulle mäng meeldis.
7/10 on üle keskmise mäng
5/10 on hae mäng aga
10/10 on ideaalne, parim jne, sellist mängu pole veel kohanud, igalmängul omad miinused, ehk mafia 3 suudab seda . _________________ Kogun protsessoreid
lühidalt öeldes- mäng üheks korraks. läbisid, kusutuasid. ei olnud rohkem tahtmist niisama sõita kuna freeplayd pole, misiioonide vahel sõita ei ole huvitav.. dünaamilist ilma ja kella vahetust ei ole. aga autod on ägedad.
viimati muutis snap3 31.08.2010 14:12:20, muudetud 1 kord
Sain oma SE kätte... Endale üllatuseks avastasin et: Take-Two Interactive omab kõiki õigusi seoses Mafia, Mafia II ja tema mootoriga lisaks omab ta ka 2K GAMEsi.
zlenard kirjutas:
Kas teiearust on ka lõpp veidi imelik, lõppeb veidi järsku 2ra?
See lõpp on selline huvitav...
... Selline To Be continued mulje jäi... samas lisab hea võimaluse mingi järg teha, expansion pack või DLC. Ennast kül huvitaks mis edasi saab
MOAR!!!
Mafia II Upcoming DLC Packs A Vendetta
Kotaku
Crime game Mafia II is getting its second downloadable add-on called Jimmy's Vendetta.
The DLC follows Jimmy, who is described as "the guy the other guys call when they need to finish the job". Jimmy cleans up the messes made in Empire Bay, and the game features 30 new quests that run the gamut of assassinations to car chases.
Jimmy's Vendetta also has online rankings where players can posts points scored with combos and multipliers.
Priced at $9.99/800 Microsoft Points, Jimmy's Vendetta will be released on the PlayStation Network, Xbox Live Arcade and PC on September 7.
minuarust selle mängu stoori pole kuidagi seotud mafiaga ehk organiseeritud kuritegevusega. stoori koosneb kahest töllist kes teevad mingeid täiesti imelikke missioone. kui sellest mängu stoorist oleks vändatud film, siis seda kinno keegi vaatama ei läheks. mafias olemise eesmärk on võim, palju raha, elupõletav eluviis. selles mängus polnud mitte midagi, polnud mafiat, polnud org. vahelisi sõdasid.
jään ise siiski 5/10 hinde juurde. tehniline ja visuaalne lahendus on mängul super.
stoori on sulepeast imetud käkerdis, mingeid tegevusi sa ise mängus aretada ei saa, mingi vestlus dialooge ka sul ei ole. teed mängus nii nagu pead tegema...
See koht kus, Henry lubab kerget kasumit, kuid siis lüüakse maha ning Vito ja Joe peavad 55k kuskilt leidma 1 päevaga on küll nagu mingist filmist.
Aga selliseid misioone oleks võinud ka ikka olla, kus mingi kambaga lähed teed mingi koha tühjaks, samuti panka oleks võinud röövida või raha autot jne. kusjuures imelik on see, et raha autost üldse raha ei saa , tagumisi uksi on väga raske esiteks juba lahti saada, korra on see ainult õnnestunud aga pappi ikka ei saa _________________
mulle siiski ühtegi konkreetset filmi ette ei tekkinud. filme on ka mustmiljon, kusagilt kaudselt võib tõesti sarnasust leida. nad oleks võinud vähem videosid teha ja selle energia sisusse laduda ja jätta puzzle kokkupanemine mängija hooleks. puzzle oleks võinud ikka raske olla, just ise mõtlemist ja planeerimist.
Läbi ta saigi Terve nädala suutis sisustada õhtaid mõne tunni kaupa Igatahes väga 5+ pela oli,ei nurise millegi üle,või siis ei oska nuriseda Mingi Gotyga tegemist vast pole,kuid kindlasti üks asi mida mainida
katsu sa mafia teemalist mängu teha nii, et näiks täiesti originaalsena välja ja absoluutselt midagi poleks üheski nendest sajast mafiafilmist laenatud või sarnane
muidugi sellise originaalse lähenemisega vastab vipu nagu ta just muidugi vastas
vipu kirjutas:
kuidas mängu stoori ei ole seotud mafiaga, kui peategelased kuuluvad mafia perekonda ning üldse kogu temaatika käib erinevate perekondade ja võitlusest nende vahel
raha oli mängus palju, oska vaid teha
elu põletav eluviis - naised, relvad ja kuritegevus, midaiganes
võimust rääkides, siis mitte iga naga mafias pole võimukas tegelane
ausalt öeldes oligi hea, et näidati made man vaatepunktist kogu stoorit - draamat jätkus lõpuni
kusjuures ka esimene mafia jäi samale tasemele - ei mingit don angelot polnud _________________ ☠
vipu kirjutas:
ma ei näinud mängus mafiat siiski ja see ei tulnud kusagilt ka välja. ma arvan et isegi mingi keskkooli õpilane kirjutaks mingi parem käsikirja mängule kui see filmike oli.
esimene mäng oli rohkem mafia perekonnast kui see. oli oma autoparandaja, relvaekspert, omad liikmed jne.
maifias karjääri tegemine on nagu eeldatav.
noh lõpp oli natuke mafia moodi. lõpp oli isegi mängitav, kõmmutamine on nii mõnus, surevad kõik ise moodi. mingi jobu jooksis mulle trepipealt vastu ja mul õnnestus kohe pähe lasta. mehel raam vajus alt nagu päriselt oleks inimest lasknud. ei tehnilisele osale annaks tõesti medali.
