praegune kellaaeg 13.05.2026 20:25:09
trustmann
27.10.2009 21:34:27
Excel 2007 nested IF funktsioon |
Mitte kuidagi ei oska Excel 2007'es tööle saada IF funktsiooni.
Soovitud tulem oleks järgmine:
Kui A1 on suurem või võrdne 90'ga, siis kuvatakse A; kui A1 on suurem või võrdne 80'ga, siis kuvatakse B jne.. lõpuks kui A1 on alla 60'ne kuvatakse FAIL.
Valem, mida kasutan on näha allpool. Seda kasutades teatab Excel: The formula you typed contains an error.
A1 90 =IF(A1>=90,"A",IF(A1>=80,"B",IF(A1>=70,"C",IF(A1>=60,"D","FAIL"))))
A2 82
A3 72
A4 62
A5 52
A6 42
A7 42
A8 22
Sai proovitud ka asjakohast näidet Exceli enda help'ist, aga ei hakanud ka see tööle.
Example 3
The example may be easier to understand if you copy it to a blank worksheet.
Score
45
90
78
Formula Description Result
=IF(A2>89,"A",IF(A2>79,"B", IF(A2>69,"C",IF(A2>59,"D","F")))) Assigns a letter grade to the score in cell A2 F
=IF(A3>89,"A",IF(A3>79,"B", IF(A3>69,"C",IF(A3>59,"D","F")))) Assigns a letter grade to the score in cell A3 A
=IF(A4>89,"A",IF(A4>79,"B", IF(A4>69,"C",IF(A4>59,"D","F")))) Assigns a letter grade to the score in cell A4 C
The preceding example demonstrates how you can nest IF statements. In each formula, the fourth IF statement is also the value_if_false argument to the third IF statement. Similarly, the third IF statement is the value_if_false argument to the second IF statement, and the second IF statement is the value_if_false argument to the first IF statement. For example, if the first logical_test argument (Average>89) evaluates to TRUE, "A" is returned. If the first logical_test argument evaluates to FALSE, the second IF statement is evaluated, and so on. You can also use other functions as arguments.
Lahkele abile ootama jäädes!
| Kommentaarid: 69 loe/lisa |
62 |
raitm
27.10.2009 21:52:36
mul OpenOffices töötab see valem kopeeritult ilusti.
Excelis vist sõltus see kirjavahemärk, kas , või ; masina seadistusest, proovi kasutada seikoolonit ;
| Kommentaarid: 60 loe/lisa |
52 |
trustmann
27.10.2009 22:09:32
| raitm kirjutas: |
Excelis vist sõltus see kirjavahemärk, kas , või ; masina seadistusest, proovi kasutada seikoolonit ; |
Tuhat tänu!
Tuligi komad asendada semikoolonitega. Absurdne viga, ma ei olnud sellest masina seadistusest olenevast tähemärkide erinevusest varem kuulnud.
62 |
raitm
27.10.2009 22:19:10
| mingi kiiks sellega oli, kas regional settings või miski seda mõjutas
52 |
tsihh
27.10.2009 22:46:10
| Regional settings mõjutab seda tõesti. English US korral toimib koma ja Eesti korral semikoolon. Sama teema vist oli ka punkti ja kooloniga
| Kommentaarid: 59 loe/lisa |
58 |
MaitK
24.08.2010 14:04:31
Tervitus,
Ei hakanud uut teemat selleks tegema, kuna läheb sarnaselt selle asjaga kokku.
Point selles, et praegu mul valem selline:
| =IF(G2>=koefitsient!$E$16;"A";"MA") |
See arvutab selle, kas inimene on saanud arvestustatud (A) või on läbi kukkunud (MA), sheetilt koefitsient saab ta vastavalt realt suuruse, millega võrrelda. Kui on suurem või võrdne, siis on tulemus A, kui pole, siis MA.
Nüüd on aga probleem selles, et tahaks seda modifitseerida selliselt, et tulemuste lahter, kuhu ta arvutab, ei näitaks sisestamata tulemuste korral peale tühja lahtri midagi ning kui kirjutataks tulemuste lahtrisse näiteks "Haige", siis see kajastuks ka tulemuste real.
Loodetavasti keegi mõistab mu probleemi.
_________________ Võidab see, kellel on surres kõige rohkem asju!
Kust tuleb tolm ja kuhu kaob raha? |
| Kommentaarid: 68 loe/lisa |
tsihh
24.08.2010 14:39:38
Mitte väga ilus moodus oleks neid IF'e sinna otsa laduda
=IF(G2="Haige";G2;IF(G2="";"";IF(G2>=koefitsient!$E$16;"A";"MA")))
58 |
MaitK
24.08.2010 14:42:03
| tsihh kirjutas: |
=IF(G2="Haige";G2;IF(G2="";"";IF(G2>=koefitsient!$E$16;"A";"MA"))) |
Sellele sain ise ka pihta, kuid see eeldab, et sisestaja kasutab ühte ette antud valikutest. Muidugi neid väga palju pole, kuid siiski.
A.S.
24.08.2010 15:05:16
Aga =IF(ISNUMBER(G2);IF(G2>=koefitsient!$E$16;"A";"");G2)
Või MA ikka peab näitama?
=IF(ISNUMBER(G2);IF(G2>=koefitsient!$E$16;"A";"MA");G2)
E:
Aga kui "0" häirib, siis seadete alt "zero values" eest kustuta linnuke.
viimati muutis A.S. 24.08.2010 15:11:23, muudetud 1 kord |
| Kommentaarid: 34 loe/lisa |
34 |
MaitK
24.08.2010 15:12:09
| A.S. kirjutas: |
Tänud, see viimane toidab küll väga kenasti. Õnneks nullide kaotamine pole probleem.
A.S.
24.08.2010 15:17:26
See vahepeal läbi vilksatanud valem oli isegi parem, et pea nullide kaotamisega ise tegelema, veidi pikem vaid.
=IF(ISNUMBER(G2);IF(G2>=koefitsient!$E$16;"A";"MA");IF(ISBLANK(G2);"";G2))
34 |
