SCREAMER
06.11.2003 14:35:16
4 ATI 9700 pro in 1 |
link :: simFUSION 6000 specs
simENGINE 6000q graphics cards
ATI graphics processors, R300 x 4(Quad)
6000q: 9.6 Gpix/sec peak
256MB x 4 unified memory
Antialiasing
6000q: 2 to 24 samples
Video outputs
Triple DVI-I on 6000q (dual supported)
DVI video input for ganging chassis to increase AA or performance
Polygons (on-chip geometry engine) 150M tri/sec peak
Selectable screen resolution up to 1600x1200 @ 85 Hz or 1920x1080 @ 60 Hz
ChanLock - channel synchronization
Trilinear mipmap texture antialiasing
Large texture maps (up to 2048x2048)
256MB unified memory
Texture compression
User-programmable video timing
Order-independent (screen-door) or alpha transparency
Complementary mask fade LOD (24 levels)
32-bit true color (128 bits internal)
24-bit Z, 8-bit stencil
Gamma correction
Stereo signal capable
Evans & Sutherland (http://www.es.com)
_________________ [img:]https://foorum.hinnavaatlus.ee/images/200x40_HV.gif[/img:]
viimati muutis SCREAMER 06.11.2003 18:04:07, muudetud 2 korda |
| Kommentaarid: 440 loe/lisa |
392 |
One
06.11.2003 16:25:08
mis selle teema point on? see on 100% fake! keegi ei teeks 4 gpu-ga ati kaarti kui isegi kahega ei pidavat korralikult töötama - pealegi kes topiks veel 4 x r9700pro chippi kokku? pigem ikka tehtaks nii ati praeguse lipulaevaga
ennemgi sellist jura nähtud, näiteks 32gpu-ga voodoo 6 jne, 100% fake - pealegi on sel väga rõve kuju kah - voodoo-l oli palju ilusam
728 |
moser
06.11.2003 16:43:02
| Nii väga fake see ei olegi. Selle kaardi taga on sihuke firma nagu Evans&Sutherland (Visual systems for commercial and military simulation and training).
| Kommentaarid: 68 loe/lisa |
tobler
06.11.2003 16:46:27
| isiklikult ilma lisa tekstita ei usu...
| Kommentaarid: 16 loe/lisa |
12 |
moser
moser
06.11.2003 17:03:08
| Täpsema kirjelduse leiad siit
tobler
06.11.2003 17:16:16
| äkki annaksid lingi kus kirjeldadakse täpselt seda kaarti...
12 |
moser
daman
06.11.2003 18:00:59
See mulle meeldib, et asi sööb 1 AGP ja 1 PCI pesa. Väga viis. Ega perfoormantsil ka vist väga viga pole.
_________________ Täna on see homme, mida sa eile kartsid. |
| Kommentaarid: 47 loe/lisa |
44 |
One
06.11.2003 18:01:23
endiselt arvan, et fake 256MB x 4 unified memory r9700pro on vaid 128 megane ju
samuti on väga ebatõenäoline see, et kaardi pcb kannataks 4x256 mb mälu... need mälud kütaks selle kaardi nii kuumaks, et asi sulaks lihtsalt ära selle pärast ei ole ju ka r9800 sama pcb-ga kui r9700 - klokid suuremad, temp kasvab, pcb ei ole enam stabiilne
728 |
moser
06.11.2003 18:28:02
| Siin siis firma kodukal olev pisut täpsem kirjeldus. See firma on mulle ennegi haruldustega silma jäänud. Mingi aeg tagasi nägin netis sama firma spetsiaalselt profilennusimudele mõeldud mitmeprotsessorilist graafikakaarti: Ei mäleta enam täpselt, kas VPU-sid oli kas kaks või neli. Muide 9800se prose, mis põhineb just selsamal 9700 pcb-l, töötab mul kodus sellise klokiga - 450/360 - ja ei sulamist mingit ega ebastabiilsust. Võiks ka teist vist pisut rohkem kellata, aga eesmärgiks on siiski kvaliteetne pilt ja stabiilne süsteem.
moser
06.11.2003 18:40:55
| Aga samas võib sul, Voltc, muidugi õigus olla - ma pole seda kaarti ju oma silmaga näinud ja netis leiab igasugust lausvalet kuhjaga.
moser
06.11.2003 19:09:46
| Tsekkasin siin pisut selle firma tausta ja see pilt ei tohiks küll fake olla, kuna see firma on juba mõnda aega tootnud mitmeprotsessorilisi ATI kiipidel põhinevaid graafikakaarte. Vähemalt leidub selle kohta netis palju viiteid üsnagi tuntud ja hea renomeega saitidelt.
Beanladen
11.11.2003 09:01:27
Peaks ka US sõjaväkke minema, saab õhtuti Max Payne 2-te mängida 24xAA suurel ekraanil
lamp
11.11.2003 13:29:35
btw voltc - r3** kivid peaks kõik suutma adresseerida ilusti vähemalt kuni 256M mälu, samuti
on neil kõigil ddr2 tugi sees.
omal ajal polnud 9700pro'd 256M'ga lihtsalt sellepärast, et tol ajal polnud see majanduslikult kasulik.
samas on ka minevikus kinnitatud ati enda tevelooperite poolt, et r300-seeria on tehtud multichip konfidele
mõeldes.
ja miks kasutusel on r300 kivid? loomulikult sellepärast, et taolise kaardi väljatöötamine ei ole nädalate kysimus..
ja ma ei usu ka, et too kaart maksaks sandikopikaid
Aga huvitav asi on seal veel-
API
OGL 1.3
DX 9 compliant capable
OS
Windows® 2000 Pro (Server, Advanced Server Available)
Linux & XP (future)
Et siis teoorias oleks võimalik selle asjaga kuskile ORBI etteotsa maanduda nii aastaks-pooleks.. ?
| Kommentaarid: 191 loe/lisa |
168 |
traks
304 |
Scart
13.11.2003 15:22:24
eks ilmselt samasugused loomad neid sõjaväe ja merelaevanduse simulatsioone veavadki
101 |
