26.06.2010 21:24:09
Heaks kiideti 100 ja 128 gigabaidiste Blu-ray plaatide standard |
link :: minut.ee
Blu-ray arendust teostav organisatsioon BDA on heaks kiitnud uue BDXL standardi - see toob endaga kaasa kas kolmekihilise 100 gigabaidise taaskirjutatava plaadi või ühekordselt kirjutatava 128 gigabaidise neljakihilise plaadi.
Tegemist on mõistliku suurusega ühe plaadi jaoks, kuid hiljuti Blu-ray plaadimängija omandanud isikute jaoks leidub ka mustem noot - heakskiidetud standardi järgi loodud plaadid ei ole ühilduvad nendega ning uute plaatide kasutamiseks peab jällegi (veebi)poodi peatselt ostma minema.
Pressiteade:
Blu-ray Disc Association Approves Final BDXL™ Format Specifications
Licensing Information and Applications Now Available
LOS ANGELES--(BUSINESS WIRE)--The Blu-ray Disc Association (BDA) today announced the finalization and release of the specifications for BDXL™, the new multi-layer recordable Blu-ray Disc™ format with up to 128GB of capacity. With the completion and approval of the specification, manufacturers can now obtain licensing information and license applications needed to begin production of the high capacity write-once and rewritable discs and hardware (http://www.blu-raydisc.info/).
Targeted primarily at commercial segments such as broadcasting, medical and document imaging enterprises with significant archiving needs, BDXL™ provides customers with triple layer 100GB RE (rewritable) and R (write-once) discs and quadruple layer 128GB R discs. Possible consumer applications include capture and playback of HD broadcast and satellite programming in markets where set-top recorders are prevalent.
"The BDA worked diligently to create an extension of the Blu-ray Disc™ format that leverages the physical structure of the design of the disc to create even more storage capacity," said Victor Matsuda, Blu-ray Disc Association Global Promotions Committee chair. "By using the existing Blu-ray™ technologies, we have created a long-term and stable solution for archiving large amounts of sensitive data, video and graphic images. We expect further growth of the Blu-ray Disc™ market as the introduction of 100GB/128GB discs will expand the application of Blu-ray Disc™ technologies."
The BDXL™ specification was developed with specific market segments in mind, and newly-designed hardware addressing such markets will play back or record BDXL™ media. However, because the new media specifications are extensions of current Blu-ray Disc technologies, future BDXL™ capable recorders can easily be designed to play back existing 25GB and 50GB Blu-ray Disc™ formats.
About Blu-ray DiscTM
Blu-ray Disc™ is a trademark owned by the Blu-ray Disc Association (BDA) and licensed for use on discs, players and other products that use BDA's optical disc format for high definition audio-video and high capacity data software applications. A single-layer disc holds up to 25GB of data and a double-layer disc holds up to 50GB of data.
About the Blu-ray Disc Association
The Blu-ray Disc Association (BDA) is responsible for promoting and developing business opportunities for Blu-ray Disc - the BDA's optical disc format for high definition audio-video and high capacity data software applications. The BDA has approximately 170 members. Its Board of Directors consists of individuals affiliated with the following member companies: Apple Inc., Dell Inc., Hewlett-Packard Company, Hitachi, Ltd., Intel Corporation, LG Electronics Inc., Mitsubishi Electric Corporation, Oracle Corporation, Panasonic Corporation, Pioneer Corporation, Royal Philips Electronics, Samsung Electronics Co., Ltd., Sharp Corporation, Sony Corporation, TDK Corporation, Technicolor, Twentieth Century Fox, Walt Disney Pictures and Television, and Warner Bros. Entertainment Inc.
Blu-ray DiscTM and Blu-ray DiscTM logo are registered trademarks of the Blu-ray Disc Association.
BDXL™ is a trademark of the Blu-ray Disc Association.
_________________ Erakopeerimistasu tõstmise ettepaneku tagasilükkamine
7 :: |
360 |
JediMihkel
26.06.2010 22:48:50
isegi kui kogu rull kokku ajada ja neid plaate ostma ja kribama hakata. Siis kui vastupidavad nad on ? On ta tihedaks kasutamiseks (nädalas paar korda dvd mängijasse või rohkem kappi hoiustamiseks?)
Kui ma see 100 GB filme täis kriban ja plaadi 5 a pärast kapist välja võtan ja oma mängijasse suran, kas ta hakkab lugema ja filme mängima ?
| Kommentaarid: 42 loe/lisa |
38 |
timok
27.06.2010 00:46:51
| Loodame, et PS3 seda ikka toetab. Või vajab see uut spetsiaalset laserit?
120 |
7 :: |
360 |
Goon
27.06.2010 10:27:43
| Tanel kirjutas: |
Et regiooni koodist veel vähe oleks. Kui lähed 5 aasta pärast poodi filmi ostma siis ei tea kas see bluray film ühildub SINU bluray mängijaga
Sai 1,5 aastat tagasi bluray kirjutaja ostetud ja ps3l on ka bluray mängija - loodetavasti tuleb mingi firmware või misiganes selle bs ära lõpetab.
Pikkkõrv
27.06.2010 11:20:53
| Kui ikka uued plaadikihid mängus siis on üsna kahtlane, et mingi firmware sellest üksi jagu saab. Päris tõenäoliselt toob see kaasa ka mingid muudatused rauas elik kõik vanad seadmed peavad paraku oma liistude juurde jääma. Ainsaks lohutuseks vaid see, et kuna tegu alles standardi heakskiiduga, siis jõuavad vanad seadmed selleks ajaks juba nii füüsiliselt kui moraalselt vananeda kui probleem tegelikult aktuaalseks muutub.
| Kommentaarid: 92 loe/lisa |
1dumbpcuser
97 |
7 :: |
360 |
JediMihkel
27.06.2010 12:54:42
Isegi kui kogu rull kokku ajada ja neid plaate ostma ja kribama hakata. Siis kui vastupidavad nad on ? On ta tihedaks kasutamiseks (nädalas paar korda dvd mängijasse või rohkem kappi hoiustamiseks?)
Kui ma see 100 GB filme täis kriban ja plaadi 5 a pärast kapist välja võtan ja oma mängijasse suran, kas ta hakkab lugema ja filme mängima ? |
Edit! Kas keegi oskab lähemalt rääkida nende vastupidamisest ja tugevusest?
38 |
27.06.2010 13:11:18
| JediMihkel kirjutas: |
Edit! Kas keegi oskab lähemalt rääkida nende vastupidamisest ja tugevusest? |
Sa pead silmas siis seniseid 25GB ja 50GB plaate?
Sest 100GB standard alles kiideti heaks, seega massiliselt võivad nad levima hakata alles ehk järgmisel aastal.
7 :: |
360 |
Freeman
27.06.2010 16:20:20
| tomorrow kirjutas: |
BluRay jääb viimaseks ODD formaadiks .Täiesti mõttetu.Kavliteeditõus on nullilähedane võrreldes DVD-ga ja hinnad on ikka veel liiga kõrged tavakasutajate jaoks.
NAND Flash võtab üle varem või hiljem  |
mismõttes? kuna blu-ray maht on DVD omast oluliselt suurem kuidas saab kvaliteeditõus nullilähedane olla? kõik loeb ju sellest mida sa sinna peale kirjutad
| Kommentaarid: 8 loe/lisa |
Braien
27.06.2010 16:22:04
No kui sa oma 10" ekraaniga vaatad, siis võibolla jah kvaliteedi vahet pole.
90 |
Getomees
27.06.2010 17:03:25
Iseensesest on see uudis juba ligi kolm kuud vana ja teiseks ei lähe need plaadid tavapärasesse masskasutusse (filmide/PS3 mängude levitamine) vaid on suunatud pigem meediatööstusele.
Ja kui DVD ja Blu-ray puhul videokvaliteedis erinevust ei näe, tasuks uus ekraan/projektor osta või silmaarsti juures nägemist kontrollimas käia.
_________________ Sinikiir: Blu-ray temaatiline foorum |
| Kommentaarid: 59 loe/lisa |
7 :: |
30 |
Freeman
27.06.2010 19:03:32
| oot siis, tahate te mulle väita, et kui kirjutada DVD plaadile nt 5 minuti pikkuse muusikavideo, mis on full HD resolutsiooniga siis on see kuidagi erinev kui sama video kirjutada blu-ray plaadile?
Getomees
27.06.2010 19:30:56
| Freeman kirjutas: |
| oot siis, tahate te mulle väita, et kui kirjutada DVD plaadile nt 5 minuti pikkuse muusikavideo, mis on full HD resolutsiooniga siis on see kuidagi erinev kui sama video kirjutada blu-ray plaadile? |
Saan aru küll, et sa tahad siin targutada, kuid kvaliteedi osas ei käinud jutt Blu-ray'st kui andmekandjast vaid filmide levitamise ja taasesitamise meediumist. Tutvu palun DVD video ja BD video standarditega.
7 :: |
30 |
Goon
27.06.2010 19:43:33
| Freeman kirjutas: |
Ei ole erinev kuid peab arvestama, et 1080p resolutsiooniga 1 minutine video on umbes 1 giga suur. Et dvd singleside plaadile (mis on tavaliselt 4,7 - 8,5 giga) pole mõtet selliseid asju lasta.
Freeman
27.06.2010 20:36:33
| Goon kirjutas: |
| Freeman kirjutas: |
Ei ole erinev kuid peab arvestama, et 1080p resolutsiooniga 1 minutine video on umbes 1 giga suur. Et dvd singleside plaadile (mis on tavaliselt 4,7 - 8,5 giga) pole mõtet selliseid asju lasta. |
*facepalm* seda ma ju väitsingi!
+ ma pole sõnagi öelnud filmide leviku kohta, vaid postitasin oma esialgse väite kasutaja "Getomees" sõnavõtu kohta, mis oli järgmine:
| Ja kui DVD ja Blu-ray puhul videokvaliteedis erinevust ei näe, tasuks uus ekraan/projektor osta või silmaarsti juures nägemist kontrollimas käia. |
ja mis ajast on targutamine õigete faktide edasiandmine?
27.06.2010 21:13:38
| Getomees kirjutas: |
| Iseensesest on see uudis juba ligi kolm kuud vana. |
Kolm kuud tagasi oli teada standardi arendamisest ja lõpusirgele jõudmisest, käesolev uudis puudutab lõpliku standardi ametlikku aktsepteerimist ja väljakuulutamist
June 25, 2010 – Los Angeles, CA. The Blu-ray Disc Association (BDA) today announced the finalization and release of the specifications for BDXL™, the new multi-layer recordable Blu-ray Disc™ format with up to 128GB of capacity.
7 :: |
360 |
JediMihkel
27.06.2010 23:17:19
| Tanel kirjutas: |
Sest 100GB standard alles kiideti heaks, seega massiliselt võivad nad levima hakata alles ehk järgmisel aastal. |
Praegusel hetkel piisaks isegi neist 25-50 gb plaatide kohta infost, pole ise ühtegi käes hoidnud ega ka kogemust pole.
38 |
28.06.2010 07:54:50
tomorrow, 25GB on single-layer, double-layer on 50GB. Miks tood välja DVD puhul double-layer aga Blu-ray puhul single-layer suuruse?
Filmide puhul on väga vähe levinud single-layer plaadi kasutus ka Blu-ray korral.
Wikipedias muide selline huvitav tekst:
| Blu-ray Disc kirjutas: |
Although these numbers represent the standard storage for Blu-ray Disc drives, the specification is open-ended, with the upper theoretical storage limit left unclear. 200 GB discs are available, and 100 GB discs are readable without extra equipment or modified firmware.
In January 2007, Hitachi showcased a 100 GB Blu-ray Disc, consisting of four layers containing 25 GB each. Unlike TDK and Panasonic's 100 GB discs, they claim this disc is readable on standard Blu-ray Disc drives that are currently in circulation, and it is believed that a firmware update is the only requirement to make it readable to current players and drives.
In December 2008, Pioneer Corporation unveiled a 400 GB Blu-ray Disc (containing 16 data layers, 25 GB each) that will be compatible with current players after a firmware update. Its planned launch is in the 2009–10 time frame for ROM and 2010–13 for rewritable discs. Ongoing development is under way to create a 1 TB Blu-ray Disc as soon as 2013.
On Jan. 1, 2010, Sony, in association with Panasonic, announced plans to increase the storage capacity on their Blu-ray Discs from 25GB to 33.4GB via a technology called i-MLSE (Maximum Likelihood Sequence Estimation). The higher-capacity discs, according to Sony, will be readable on current Blu-ray Disc players with a firmware upgrade. No date has been set to include the increased space, but according to Blu-ray.com "it will likely happen sometime later this year." |
viimati muutis mikk36 28.06.2010 07:59:26, muudetud 1 kord |
| Kommentaarid: 85 loe/lisa |
28.06.2010 07:59:17
| mikk36 kirjutas: |
| Although these numbers represent the standard storage for Blu-ray Disc drives, the specification is open-ended, with the upper theoretical storage limit left unclear. 200 GB discs are available, and 100 GB discs are readable without extra equipment or modified firmware. |
No ma võin ju välja tuua ka DVD puhul SL suuruse 4GB ja BR puhul DL suuruse 50GB aga siis tähendaks see, et suuremat teravust saada pead muretsema 1000% suurema meedia
Insanity on juba sõna mis meenub sellega seoses
28.06.2010 08:08:30
tomorrow, sul vist prillid puudu et sa ei näe kvaliteedivahet HD teleka taga DVD vs Blu-ray?
Või istud sa kusagil kaugel 6-7 meetri peal?
heretic666
28.06.2010 08:19:34
| mikk36, kes see sul 40+ tollist televiisorit 1-2m kauguselt vaatab. Eemalt tugitoolilt oma 4m kauguselt tõepoolest ei tee vahet tavalisel DVD filmil ja 1080p.
| Kommentaarid: 73 loe/lisa |
Pikkkõrv
28.06.2010 08:23:23
Selleks panna 100% mahtu juurde, et saada veidi parem teravus on täielik bullshit imo
Kui DVD tuli, siis oli põhjust CD pealt üle minna kuna selged eelised olid.BR on nagu aja jäänuk mida üritatakse veel kurku toppida. Ainus kus ma reaalset kasu selles näen on Multi-DVD mängud.Suuremad mängud on tänasel päeval juba 15GB+ ja seal oleks kasu sellest kui need oleks ühe BR plaadi mitte mitme DVD peal  |
Sinu loogika järgi poleks ju ka mängude puhul rohkem ruumi vaja, sest sealgi toob selle suurendamine kaasa vaid veidi rohkem teravust ehk detailsema ja realistlikuma pildi. Kogu muu luustik mahuks enamuse mängude puhul ilmselt juba ka flopile ära ! Aga kui mängijad ei taha lõputult kriipsujukusid vahtida, siis miks peaksid filmisõbrad sinu arvates tahtma vahtida hägusaid värvilaike, mida DVD-l olev pilt suuremalt ekraanilt või natuke lähemalt vaadates tegelikult on.
Ja neil kes väidavad, et blueray filmide pilt pole parem kui DVD-l olevatel tasuks esmalt veenduda, et ka kõik nende seadmed ikka DRM-iga hästi läbi saavad, muidu võibki olla tulemuseks vaid DVD kvaliteedini piiratud pilt!
viimati muutis Pikkkõrv 28.06.2010 08:40:02, muudetud 1 kord |
28.06.2010 08:36:17
heretic666, ka 32 tollise pealt tegin 3m pealt veel vahet.
23 tollise monitoriga testides läks miski 2.5 meetrit vist vaja et ei teeks enam erilist vahet.
28.06.2010 08:58:44
| mikk36 kirjutas: |
Või istud sa kusagil kaugel 6-7 meetri peal? |
Ma ei ütle, et ma ei näe kvaliteedivahet.Ma ütlen, et kvaliteeditõus pole võrdeline mahu suurenemisega
| Pikkkõrv kirjutas: |
| Sinu loogika järgi poleks ju ka mängude puhul rohkem ruumi vaja, sest sealgi toob selle suurendamine kaasa vaid veidi rohkem teravust ehk detailsema ja realistlikuma pildi. |
Jah kui mängu suurus muutub nt 10GB-->15GB ja on detailsem siis ei kaeble aga kui muutuks 10-->25 ja detailsuse tõus jääks samaks, siis poleks tegu võrdelise suurenemisega.
| Ja neil kes väidavad, et blueray filmide pilt pole parem kui DVD-l olevatel tasuks esmalt veenduda, et ka kõik nende seadmed ikka DRM-iga hästi läbi saavad, muidu võibki olla tulemuseks vaid DVD kvaliteedini piiratud pilt! |
DRM ja regioonipiirangud on veel eraldi teema siinkohal.Ei hakka seda arutama, kuna siis läheks teema väga pikaks
korsten
28.06.2010 09:07:42
tomorrow, meil kiiret ei ole Regioon üksi vast ikka kvaliteeti ei mõjuta.
_________________ Ma ei kuuluta jumalikku tõde vaid avaldan oma isiklikku subjektiivset arvamust.
God Hates Us All |
| Kommentaarid: 62 loe/lisa |
58 |
Pikkkõrv
28.06.2010 09:21:48
| Jah kui mängu suurus muutub nt 10GB-->15GB ja on detailsem siis ei kaeble aga kui muutuks 10-->25 ja detailsuse tõus jääks samaks, siis poleks tegu võrdelise suurenemisega. |
Noh vaevalt neile uutele 100GB plaatidele keegi praeguseid blueray filme üks-ühele ringi tõstma hakkab. Seega loob see ikka eeldused järgnevaks hüppeks kvaliteedis ja võimaluse salvestada juba täna pikemaid filme ühele plaadile. Seega saab eesmärgiks olla ikka vaid just võrdeline suurenemine. Või kuidas?
Butcher
28.06.2010 09:52:28
Kus Te seda 100gigase blueray pilti juba nägite? Enamus viimased postitused on sellest, et kvaliteedi tõus oli liiga väike võrreldes mahu suurenemisega...
1dumbpcuser
97 |
28.06.2010 10:36:01
tomorrow, loomulikult ei ole võrdeline mahu suurusega. Mahud suurenevad sellistel asjadel kahjuks eksponentaalselt.
Näiteks 100x100 pikslit pilt, kokku 0.01MP.
Nüüd tahad "2x paremat pilti", 200x200 pikslit, tuleb juba 0.04MP.
Sellest veel 2x paremaks, 400x400 pikslit teeb omakorda 0.16MP.
720x576 (DVD) on 0.41MP
1920x1080 (Blu-ray) on aga 2.01MP
Laiupidi 2.67x suurem, kõrguses 1.875x suurem, mahus aga 4.9x suurem.
Fatal1ty
28.06.2010 11:47:46
mul 40" TV full hd1080p kui vaadata dvd siis pilt t4piline ja ruuduline, aga kui vaadata 1080p filmi, siis oopis teine maailm, miks inimesed v4idavad et pole vahet DVD ja blue rail, v6ibolla 720p formaadil ja tavalisel dvd pole vahet, aga kas mitte see mingi HD DVD sellel vist oli 720p formaat olemas, siis nagu vaga vahet pole, aga 1080p filmil on ikka vaga suur vahe, suure TV peal. seda enam et kui korralik sound system siis heliga on kah hoopis teine teema
_________________ jou mis värk on |
DVDRW
28.06.2010 12:50:38
Palju Blu-ray filmid Eestis maksavad? ikka mingi 500kr?
Njaah 50GB toorik maksab >500kr. 100tk torn = 1 auto hind
Samas 25GB toorik 35kr
Proovisin neid odavaid, tulevad välja küll.
| Kommentaarid: 28 loe/lisa |
Getomees
28.06.2010 13:18:30
No need on küll täiesti mõttetud võrdlused, kus Blu-ray pilt on skaleeritud DVD pildiga sama madalale resolutsioonile (kuigi juba siin on erinevus selgelt näha). Pigem tuleks teha hoopis vastupidi: DVD pilt tuleks skaleerida 1920x1080 resolutsioonile ja siis Blu-ray'ga võrrelda.
7 :: |
30 |
SurfData
28.06.2010 13:24:13
| DVDRW kirjutas: |
Proovisin neid odavaid, tulevad välja küll. |
filmid üldiselt 224-300 krooni maksavad. Eks kasutatult müüakse ka nõksa odavamalt.
50gb toorik muidu alla 200.- maksab, lihtsalt pole igal pool väljas ja kirjas, kuna nagunii eritellimuse peale.
| Kommentaarid: 84 loe/lisa |
74 |
elukaz
28.06.2010 14:19:47
100GB jääb ka tegelt väikseks kui vaadata et praegu 3D filmid on suurusjärgus 100GB tund, neid peab siis ikka hakkama ruudulisemaks pressima.
Ise usun ka et tulevik on flashi päralt.
158 |
28.06.2010 17:03:59
| Goon kirjutas: |
No selleks ei pea viite aastakest ootama, sellised kirjed on DVD plaatide müügikohtades üldjuhul alati olemas
Kui DVD tuli, siis oli põhjust CD pealt üle minna kuna selged eelised olid.  |
No loomulikult oli suur samm inimkonnale, Helile lisandus Pilt
Avatar oli juba ilma mingite lisadete pea 50Gb mahtuvusega plaadile pandud. Kas sügisene lisadega väljalase toob ka kaks BR plaati karbis, ilmselt jah.
130 |
meybo
28.06.2010 17:35:18
| heretic666 kirjutas: |
| mikk36, kes see sul 40+ tollist televiisorit 1-2m kauguselt vaatab. Eemalt tugitoolilt oma 4m kauguselt tõepoolest ei tee vahet tavalisel DVD filmil ja 1080p. |
Teeb ikka küll, ja kuidas veel. Soovitan silmaarsti külastada.
_________________ www.meybo.ee |
| Kommentaarid: 22 loe/lisa |
20 |
28.06.2010 18:04:49
| mikk36 kirjutas: |
Laiupidi 2.67x suurem, kõrguses 1.875x suurem, mahus aga 4.9x suurem. |
Sõltub ikka formaadist.Näiteks mina saan BMP pildi mahtu vähendada 98% ilma nähtava kvaliteedikaota .jpg-sse konvertides
Ok see on pilt ja teiseks see ei toimi iga pildi puhul
K3ndu
28.06.2010 18:07:53
| Blurayl pole siiamaani minekut ju tehku suuremaks need mahud või mitte ,aga mina ei tea tutvusringkonnas ühtegi kellel oleks Blu Ray mängija nii ,et mõttetu ta siiamaani on ja selleks ta ka jääb lähenevate aastate jooksul kui just asi odavamaks ei lähe.
120 |
SurfData
28.06.2010 18:10:00
| mikk36 kirjutas: |
Ok see on pilt ja teiseks see ei toimi iga pildi puhul  |
no blu-ray -> mkv teeb ka asja 5-6x väiksemaks ja kvaliteedikadu pole just kõige suurem
74 |
NATAS999
28.06.2010 18:16:49
ärge ajage jama siin. DVD on ajast ja arust ja mängude vägistamine sinna peale tuleks ka üldse ära keelata.
kui fullHD ja dvd (ehk vhs) vahet ei tee, siis oled juba selle viimase aja mahamagand silmaarstile minekuga.
need näited, tomorrow, mis sa tõid siia, no ma ei tea, debiilsemat asja ei oskagi kohe nii paugust välja mõelda. paintis 1920x1080 pilt wide pal downscaletult ja siis vingub, et vahet pole.
10m ja 26" monitorilt on juba selgelt dvd vs FullHD vahe ilmselge.
ammu oleks juba aeg suurema reso jaoks. 30" molle küll, mis tugevalt üle FullHD. 32" HDredy on ikka udukogu ausaltöelda ja ei julgeks öelda, et 50" fullHD parem on. nii suurtel telkudel peaks kõvasti rohkem olema reso. jah, alati võib kaugemale istuda, samas võib ka vabalt seljaga teleka poole olla, näeb ka selgemat pilti.
DVD pealt FullHD klippi vaadata, no maitia. Powerpointi soovitan soojalt sulle sel juhul. (vihje: dvd lugemiskiirus vs. BD oma)
_________________ "Kuidas on see hea?"
-Auto kirurgia kliinik |
| Kommentaarid: 41 loe/lisa |
39 |
28.06.2010 20:10:21
| mikk36 kirjutas: |
Samamoodi saad sa ka DVD peal pilti kokku pakkida, ikkagi jääb vahe 8.5GB ja 50GB vahel sisse.
DVD video max bitrate: 9.8Mbps
Blu-ray video max bitrate: 48Mbps
viimati muutis mikk36 28.06.2010 20:16:13, muudetud 1 kord |
28.06.2010 20:13:37
| K3ndu kirjutas: |
| Blurayl pole siiamaani minekut ju tehku suuremaks need mahud või mitte ,aga mina ei tea tutvusringkonnas ühtegi kellel oleks Blu Ray mängija nii ,et mõttetu ta siiamaani on ja selleks ta ka jääb lähenevate aastate jooksul kui just asi odavamaks ei lähe. |
Sama ka siin.Ka minu tutvusringkonnas pole kellelgi seda.Mõnedel on PS3 aga eraldi BR lugejat/kirjutajat pole toorikutest rääkimata.On ka plasmatelekad jms kraam seega ei - pole vaene tutvusringkond kes ei jõua osta
heretic666
28.06.2010 20:22:41
| djstallion kirjutas: |
Teeb ikka küll, ja kuidas veel. Soovitan silmaarsti külastada. |
Seal olen tihedamini käinud kui arvatagi oskad, pikemat aega kõik korras viimasel ajal. Ära aja kelbast oma "ja kuidas veel" jutuga, vahe on eemalt ikka marginaalne.
Le Inc
28.06.2010 20:51:48
FullHD ja DVD formaadi vahel on tuntav kvaliteedi erinevus, juhul kui vaatad suure fullhd telekaga. Blu-ray on sutsu toores ja kallis. Kui asi jõuab rohkem massidesse saame ka 25 GB tooriku 10.- kr kätte (siis vist EUR juba).
Ennast huvitab just 25 ja 50 GB kettad infi salvestamiseks. Sinna saab ka kokkupakitud *.mkv hd kino päris hea mitu tundi peale lasta.
| Kommentaarid: 56 loe/lisa |
54 |
