26.06.2010 20:24:09
Heaks kiideti 100 ja 128 gigabaidiste Blu-ray plaatide standard |
link :: minut.ee
Blu-ray arendust teostav organisatsioon BDA on heaks kiitnud uue BDXL standardi - see toob endaga kaasa kas kolmekihilise 100 gigabaidise taaskirjutatava plaadi või ühekordselt kirjutatava 128 gigabaidise neljakihilise plaadi.
Tegemist on mõistliku suurusega ühe plaadi jaoks, kuid hiljuti Blu-ray plaadimängija omandanud isikute jaoks leidub ka mustem noot - heakskiidetud standardi järgi loodud plaadid ei ole ühilduvad nendega ning uute plaatide kasutamiseks peab jällegi (veebi)poodi peatselt ostma minema.
Pressiteade:
Blu-ray Disc Association Approves Final BDXL™ Format Specifications
Licensing Information and Applications Now Available
LOS ANGELES--(BUSINESS WIRE)--The Blu-ray Disc Association (BDA) today announced the finalization and release of the specifications for BDXL™, the new multi-layer recordable Blu-ray Disc™ format with up to 128GB of capacity. With the completion and approval of the specification, manufacturers can now obtain licensing information and license applications needed to begin production of the high capacity write-once and rewritable discs and hardware (http://www.blu-raydisc.info/).
Targeted primarily at commercial segments such as broadcasting, medical and document imaging enterprises with significant archiving needs, BDXL™ provides customers with triple layer 100GB RE (rewritable) and R (write-once) discs and quadruple layer 128GB R discs. Possible consumer applications include capture and playback of HD broadcast and satellite programming in markets where set-top recorders are prevalent.
"The BDA worked diligently to create an extension of the Blu-ray Disc™ format that leverages the physical structure of the design of the disc to create even more storage capacity," said Victor Matsuda, Blu-ray Disc Association Global Promotions Committee chair. "By using the existing Blu-ray™ technologies, we have created a long-term and stable solution for archiving large amounts of sensitive data, video and graphic images. We expect further growth of the Blu-ray Disc™ market as the introduction of 100GB/128GB discs will expand the application of Blu-ray Disc™ technologies."
The BDXL™ specification was developed with specific market segments in mind, and newly-designed hardware addressing such markets will play back or record BDXL™ media. However, because the new media specifications are extensions of current Blu-ray Disc technologies, future BDXL™ capable recorders can easily be designed to play back existing 25GB and 50GB Blu-ray Disc™ formats.
About Blu-ray DiscTM
Blu-ray Disc™ is a trademark owned by the Blu-ray Disc Association (BDA) and licensed for use on discs, players and other products that use BDA's optical disc format for high definition audio-video and high capacity data software applications. A single-layer disc holds up to 25GB of data and a double-layer disc holds up to 50GB of data.
About the Blu-ray Disc Association
The Blu-ray Disc Association (BDA) is responsible for promoting and developing business opportunities for Blu-ray Disc - the BDA's optical disc format for high definition audio-video and high capacity data software applications. The BDA has approximately 170 members. Its Board of Directors consists of individuals affiliated with the following member companies: Apple Inc., Dell Inc., Hewlett-Packard Company, Hitachi, Ltd., Intel Corporation, LG Electronics Inc., Mitsubishi Electric Corporation, Oracle Corporation, Panasonic Corporation, Pioneer Corporation, Royal Philips Electronics, Samsung Electronics Co., Ltd., Sharp Corporation, Sony Corporation, TDK Corporation, Technicolor, Twentieth Century Fox, Walt Disney Pictures and Television, and Warner Bros. Entertainment Inc.
Blu-ray DiscTM and Blu-ray DiscTM logo are registered trademarks of the Blu-ray Disc Association.
BDXL™ is a trademark of the Blu-ray Disc Association.
HV valuutakalkulaator |
| Kommentaarid: 472 loe/lisa |
13 :: |
7 :: |
359 |
JediMihkel
26.06.2010 21:48:50
isegi kui kogu rull kokku ajada ja neid plaate ostma ja kribama hakata. Siis kui vastupidavad nad on ? On ta tihedaks kasutamiseks (nädalas paar korda dvd mängijasse või rohkem kappi hoiustamiseks?)
Kui ma see 100 GB filme täis kriban ja plaadi 5 a pärast kapist välja võtan ja oma mängijasse suran, kas ta hakkab lugema ja filme mängima ?
| Kommentaarid: 42 loe/lisa |
38 |
timok
26.06.2010 23:46:51
| Loodame, et PS3 seda ikka toetab. Või vajab see uut spetsiaalset laserit?
120 |
26.06.2010 23:52:00
13 :: |
7 :: |
359 |
Goon
27.06.2010 09:27:43
| Tanel kirjutas: |
Et regiooni koodist veel vähe oleks. Kui lähed 5 aasta pärast poodi filmi ostma siis ei tea kas see bluray film ühildub SINU bluray mängijaga
Sai 1,5 aastat tagasi bluray kirjutaja ostetud ja ps3l on ka bluray mängija - loodetavasti tuleb mingi firmware või misiganes selle bs ära lõpetab.
Pikkkõrv
27.06.2010 10:20:53
| Kui ikka uued plaadikihid mängus siis on üsna kahtlane, et mingi firmware sellest üksi jagu saab. Päris tõenäoliselt toob see kaasa ka mingid muudatused rauas elik kõik vanad seadmed peavad paraku oma liistude juurde jääma. Ainsaks lohutuseks vaid see, et kuna tegu alles standardi heakskiiduga, siis jõuavad vanad seadmed selleks ajaks juba nii füüsiliselt kui moraalselt vananeda kui probleem tegelikult aktuaalseks muutub.
27.06.2010 10:56:28
BluRay jääb viimaseks ODD formaadiks .Täiesti mõttetu.Kavliteeditõus on nullilähedane võrreldes DVD-ga ja hinnad on ikka veel liiga kõrged tavakasutajate jaoks.
NAND Flash võtab üle varem või hiljem
| Kommentaarid: 92 loe/lisa |
1dumbpcuser
27.06.2010 11:08:33
Mõtled ketta füüsilist kvaliteeti?
_________________ M: |
95 |
27.06.2010 11:11:50
| 1dumbpcuser kirjutas: |
Mõtled ketta füüsilist kvaliteeti? |
Mõtlen pildikvaliteeti mida ma ekraanil näen.
Tegelikult mõtlen rohkem raha hulka mida panustada DVD--->BR üleminekul(Uus lugeja/kirjutaja + toorikud) ja millise pildikvaliteedi tõusu selle eest saab.See ei tasu ära
13 :: |
7 :: |
359 |
JediMihkel
27.06.2010 11:54:42
Isegi kui kogu rull kokku ajada ja neid plaate ostma ja kribama hakata. Siis kui vastupidavad nad on ? On ta tihedaks kasutamiseks (nädalas paar korda dvd mängijasse või rohkem kappi hoiustamiseks?)
Kui ma see 100 GB filme täis kriban ja plaadi 5 a pärast kapist välja võtan ja oma mängijasse suran, kas ta hakkab lugema ja filme mängima ? |
Edit! Kas keegi oskab lähemalt rääkida nende vastupidamisest ja tugevusest?
38 |
27.06.2010 12:11:18
| JediMihkel kirjutas: |
Edit! Kas keegi oskab lähemalt rääkida nende vastupidamisest ja tugevusest? |
Sa pead silmas siis seniseid 25GB ja 50GB plaate?
Sest 100GB standard alles kiideti heaks, seega massiliselt võivad nad levima hakata alles ehk järgmisel aastal.
13 :: |
7 :: |
359 |
Freeman
27.06.2010 15:20:20
| tomorrow kirjutas: |
NAND Flash võtab üle varem või hiljem  |
mismõttes? kuna blu-ray maht on DVD omast oluliselt suurem kuidas saab kvaliteeditõus nullilähedane olla? kõik loeb ju sellest mida sa sinna peale kirjutad
| Kommentaarid: 8 loe/lisa |
Braien
27.06.2010 15:22:04
No kui sa oma 10" ekraaniga vaatad, siis võibolla jah kvaliteedi vahet pole.
90 |
Getomees
27.06.2010 16:03:25
Iseensesest on see uudis juba ligi kolm kuud vana ja teiseks ei lähe need plaadid tavapärasesse masskasutusse (filmide/PS3 mängude levitamine) vaid on suunatud pigem meediatööstusele.
Ja kui DVD ja Blu-ray puhul videokvaliteedis erinevust ei näe, tasuks uus ekraan/projektor osta või silmaarsti juures nägemist kontrollimas käia.
_________________ Sinikiir: Blu-ray temaatiline foorum |
| Kommentaarid: 59 loe/lisa |
7 :: |
30 |
Freeman
27.06.2010 18:03:32
| oot siis, tahate te mulle väita, et kui kirjutada DVD plaadile nt 5 minuti pikkuse muusikavideo, mis on full HD resolutsiooniga siis on see kuidagi erinev kui sama video kirjutada blu-ray plaadile?
Getomees
27.06.2010 18:30:56
| Freeman kirjutas: |
| oot siis, tahate te mulle väita, et kui kirjutada DVD plaadile nt 5 minuti pikkuse muusikavideo, mis on full HD resolutsiooniga siis on see kuidagi erinev kui sama video kirjutada blu-ray plaadile? |
Saan aru küll, et sa tahad siin targutada, kuid kvaliteedi osas ei käinud jutt Blu-ray'st kui andmekandjast vaid filmide levitamise ja taasesitamise meediumist. Tutvu palun DVD video ja BD video standarditega.
7 :: |
30 |
Goon
27.06.2010 18:43:33
| Freeman kirjutas: |
Ei ole erinev kuid peab arvestama, et 1080p resolutsiooniga 1 minutine video on umbes 1 giga suur. Et dvd singleside plaadile (mis on tavaliselt 4,7 - 8,5 giga) pole mõtet selliseid asju lasta.
Freeman
27.06.2010 19:36:33
| Goon kirjutas: |
| Freeman kirjutas: |
Ei ole erinev kuid peab arvestama, et 1080p resolutsiooniga 1 minutine video on umbes 1 giga suur. Et dvd singleside plaadile (mis on tavaliselt 4,7 - 8,5 giga) pole mõtet selliseid asju lasta. |
*facepalm* seda ma ju väitsingi!
+ ma pole sõnagi öelnud filmide leviku kohta, vaid postitasin oma esialgse väite kasutaja "Getomees" sõnavõtu kohta, mis oli järgmine:
| Ja kui DVD ja Blu-ray puhul videokvaliteedis erinevust ei näe, tasuks uus ekraan/projektor osta või silmaarsti juures nägemist kontrollimas käia. |
ja mis ajast on targutamine õigete faktide edasiandmine?
27.06.2010 20:13:38
| Getomees kirjutas: |
| Iseensesest on see uudis juba ligi kolm kuud vana. |
Kolm kuud tagasi oli teada standardi arendamisest ja lõpusirgele jõudmisest, käesolev uudis puudutab lõpliku standardi ametlikku aktsepteerimist ja väljakuulutamist
June 25, 2010 – Los Angeles, CA. The Blu-ray Disc Association (BDA) today announced the finalization and release of the specifications for BDXL™, the new multi-layer recordable Blu-ray Disc™ format with up to 128GB of capacity.
13 :: |
7 :: |
359 |
JediMihkel
27.06.2010 22:17:19
| Tanel kirjutas: |
Sest 100GB standard alles kiideti heaks, seega massiliselt võivad nad levima hakata alles ehk järgmisel aastal. |
Praegusel hetkel piisaks isegi neist 25-50 gb plaatide kohta infost, pole ise ühtegi käes hoidnud ega ka kogemust pole.
38 |
28.06.2010 05:59:34
| Freeman kirjutas: |
mismõttes? kuna blu-ray maht on DVD omast oluliselt suurem kuidas saab kvaliteeditõus nullilähedane olla? kõik loeb ju sellest mida sa sinna peale kirjutad |
No täpselt.Suurem maht ei tähenda automaatselt paremat kvaliteeti.Loeb ikka see mis sinna topitud on.
Samas kui aus olla, siis ma ei näe mõet.DVD on palju?.Ok ehk 8GB per film kuskil ja Blu-Ray on miski 20GB kanti aga ainus vahe on veidi suurem teravus.
Võrdlused:
http://www.zonadvd.com/modules.php?name=Sections&op=viewarticle&artid=761
http://www.zonadvd.com/modules.php?name=Sections&op=viewarticle&artid=710
http://www.zonadvd.com/modules.php?name=Sections&op=viewarticle&artid=1129
Selleks panna 100% mahtu juurde, et saada veidi parem teravus on täielik bullshit imo
Kui DVD tuli, siis oli põhjust CD pealt üle minna kuna selged eelised olid.BR on nagu aja jäänuk mida üritatakse veel kurku toppida.
Ainus kus ma reaalset kasu selles näen on Multi-DVD mängud.Suuremad mängud on tänasel päeval juba 15GB+ ja seal oleks kasu sellest kui need oleks ühe BR plaadi mitte mitme DVD peal
Samas digitaalne müük järjest suureneb(Steam jms) seega seegi pole enam niivõrd tähtis
28.06.2010 06:54:50
tomorrow, 25GB on single-layer, double-layer on 50GB. Miks tood välja DVD puhul double-layer aga Blu-ray puhul single-layer suuruse?
Filmide puhul on väga vähe levinud single-layer plaadi kasutus ka Blu-ray korral.
Wikipedias muide selline huvitav tekst:
| Blu-ray Disc kirjutas: |
Although these numbers represent the standard storage for Blu-ray Disc drives, the specification is open-ended, with the upper theoretical storage limit left unclear. 200 GB discs are available, and 100 GB discs are readable without extra equipment or modified firmware.
In January 2007, Hitachi showcased a 100 GB Blu-ray Disc, consisting of four layers containing 25 GB each. Unlike TDK and Panasonic's 100 GB discs, they claim this disc is readable on standard Blu-ray Disc drives that are currently in circulation, and it is believed that a firmware update is the only requirement to make it readable to current players and drives.
In December 2008, Pioneer Corporation unveiled a 400 GB Blu-ray Disc (containing 16 data layers, 25 GB each) that will be compatible with current players after a firmware update. Its planned launch is in the 2009–10 time frame for ROM and 2010–13 for rewritable discs. Ongoing development is under way to create a 1 TB Blu-ray Disc as soon as 2013.
On Jan. 1, 2010, Sony, in association with Panasonic, announced plans to increase the storage capacity on their Blu-ray Discs from 25GB to 33.4GB via a technology called i-MLSE (Maximum Likelihood Sequence Estimation). The higher-capacity discs, according to Sony, will be readable on current Blu-ray Disc players with a firmware upgrade. No date has been set to include the increased space, but according to Blu-ray.com "it will likely happen sometime later this year." |
viimati muutis mikk36 28.06.2010 06:59:26, muudetud 1 kord |
| Kommentaarid: 85 loe/lisa |
28.06.2010 06:59:17
| mikk36 kirjutas: |
| Although these numbers represent the standard storage for Blu-ray Disc drives, the specification is open-ended, with the upper theoretical storage limit left unclear. 200 GB discs are available, and 100 GB discs are readable without extra equipment or modified firmware. |
No ma võin ju välja tuua ka DVD puhul SL suuruse 4GB ja BR puhul DL suuruse 50GB aga siis tähendaks see, et suuremat teravust saada pead muretsema 1000% suurema meedia
Insanity on juba sõna mis meenub sellega seoses
28.06.2010 07:08:30
tomorrow, sul vist prillid puudu et sa ei näe kvaliteedivahet HD teleka taga DVD vs Blu-ray?
Või istud sa kusagil kaugel 6-7 meetri peal?
