uus teema   vasta Tarkvara »  WWW »  JOOMLA ja sellega seonduv märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 11, 12, 13 ... 17, 18, 19  järgmine
Eraser
Eraser
sõnum 22.04.2010 16:59:52 vasta tsitaadiga
Kethmar kirjutas:
Keegi ütleks, kuidas oleks kõige efektiivsem configuration.php faili kaitsta?
Kõige elementaarsem on panna faili chmod paika. Joomla dokumentatsioon soovitab:
4. Make sure the configuration.php file is set to permissions of 644.
Võimalik on ka kasutada seda meetodit, aga arvesta, et see pole mõeldud algajaile. icon_wink.gif
Moving sensitive files outside the web root
One challenge in Joomla! is ensuring that certain PHP files in public_html (or otherwise known as httpdocs or www depending on your server setup) containing executable code or confidential data are protected from direct Internet access.
There are various ways to protect such files, but most are not optimal. Many users and developer groups, such as Gallery2 and Apache.org strongly recommend against keeping vulnerable files and confidential data inside public_html.
The following method seems to be the simplest and most elegant way to protect read-only files that, for whatever reason, must be stored in public_html. In this example, we protect configuration.php, perhaps the most confidential file of any Joomla! site. Using this method, even if the Web server somehow delivers the contents of PHP files, for example due to a misconfiguration, nobody can see the contents of the real configuration file.
Directions
WARNING: Do not attempt this procedure unless, after reading several times, you understand it. This is not for beginners, ensure you have a back up of your site before attempting.
1. Create a directory in your domain outside of your public_html directory. You can name it anything you want. We used the name design2-files for the directory name in this example. Note: If you have multiple Joomla installs then each Joomla install you have should have its own directory outside of public_html to contain its configuration.php file.
2. Move configuration.php to the design2-files directory and rename it to whatever you want. We used the name joomla.conf for the configuration file in this example.
3. If your Joomla site is installed in the root of the public_html directory and not in a subdirectory under public_html, then create a new configuration.php file for your joomla install in the public_html directory containing only the following code:
<?php
require( dirname( __FILE__ ) . '/../design2-files/joomla.conf' );
If Joomla has been installed in a subdirectory under public_html ( public_html/subdirectory/ ) then create a configuration.php file containing only the following code.
<?php
require( dirname( __FILE__ ) . '/../../design2-files/joomla.conf' );
Important! Do not include blank lines or any characters (including blank spaces) before the php start tag or after the php end tag. If you make this mistake, you very likely will see the following error.
Warning: Cannot modify header information - headers already sent by (output started at
/home/xxxxx/public_html/configuration.php:2) in /home/xxxxx/public_html/index.php on line 250
4. Make sure the new configuration.php file is set to permissions of 644.
Editing and saving/applying
Warning!! Do not use the Joomla web administrator interface global configuration button to edit the global configuration.
If you need to change configuration settings, do so manually by downloading the relocated joomla.conf file, making the needed edits and uploading it back.
Making edits to the global configuration in the Joomla web administration interface will overwrite the 3 line configuration.php file pointing to the real configuration file with the real configuration.php file contents upon saving or applying the edits. This will undo your efforts to move and protect the configuration.php file by placing it in a directory outside of public_html.
Allikas: http://docs.joomla.org/Security_and_Performance_FAQs#Moving_sensitive_files_outside_the_web_root
Pea kindlasti meeles ka seda, et seadetefaili kaitsmine on ainult väike osa saidi turvalisuse tagamisest. icon_wink.gif
Kommentaarid: 33 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 30
Kethmar
Kethmar
sõnum 22.04.2010 20:35:44 vasta tsitaadiga
Ok, proovin selle asja ära.
Eks ma siiani kõik muud asjad ära proovinud, aga mida rohkem, seda uhkem(vist icon_biggrin.gif ).
Kodulehekülg: http://kethmar.ee/university
Vajad veebilahendust või graafilist abi? Küsi pakkumist. HV Rahvale alati odavamalt.
Eraser
Eraser
sõnum 25.04.2010 21:35:58 vasta tsitaadiga
Kethmar kirjutas:
Jõudu! thumbs_up.gif Aga ära unusta siis enne katsetusi varukoopiat tegemast.
Kui sul seal midagi metsa poole läheb, siis võib see ka su saidi paremaile jahimaile saata. icon_razz1.gif
k11lakas
sõnum 13.05.2010 20:00:25 vasta tsitaadiga
Eraser kirjutas:
alecoqprem kirjutas:
Eraser kirjutas:
Proovi sellist pluginat nagu Admin Approval Plugin.
See peaks selle nipi ära tegema.
Lihtsalt infoks olgu öeldud, et üks plugin on nüüd siis ka korralikult mitekeelsena ka olemas - Multilingual registration approval. Eestikeelne tõlge peaks pluginaga koheselt kaasas olema, aga tõlge on saadaval ka eraldi allalaadimisena.
Heii ! Sellel multilingual-il eks. seal viskab sellekirja et admin peab aktiveerima su konto. aga tahaks sinna midagi juurde lisada. kuidas ma seda saan? Nt et kui tahad et admin aktiveeriks siis võta adminiga yhendust vms:D
Eraser
Eraser
sõnum 16.05.2010 01:17:30 vasta tsitaadiga
k11lakas kirjutas:
sosssepp
sosssepp
sõnum 06.06.2010 10:55:08 vasta tsitaadiga
Kas keegi on kasutanud mõnda nn. allkirjade kogumise rakendust joomla all? Veidike surfasin ja üks jäi silma, ainult et selle kohta leidsin arvamusi, et kohati on prantsuse keelne jäigalt. Ise katsetanud veel pole.
Tegelikult vaja lihtsat tekstiväljadega vormi, tekkivast tabelist siis näidatakse valitud veergusid ka avalikul lehel. Spämmi vältimiseks asjalik piltmõistatud vms ka vajalik.
Adminni poolt ilmselt vajalik ka valeallkirjade kustutamise või märkimise võimalus. Hetkel rohkemat ei oska tahta.
Kommentaarid: 87 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 75
Eraser
Eraser
sõnum 06.06.2010 13:21:06 vasta tsitaadiga
sosssepp kirjutas:
Oma silma järgi vaadates oli komponent Joomla Petition täitsa kenasti tõlgitav. Poolik tõlge on omal siin isegi olemas. icon_wink.gif
sosssepp kirjutas:
Kõik nimetatud asjad peaks saama kenasti tehtud ka näiteks komponendiga CK Forms. Sellega saad teha vormi vastavalt oma vajadustele ning näidata lehel ka sinna sisestatud andmeid. icon_wink.gif
sosssepp
sosssepp
sõnum 06.06.2010 20:57:06 vasta tsitaadiga
Saan ma õigesti aru, et CK Forms peaks valutum ja võimalusterohkem variant olema? Kui nii, siis alustan selle uurimisega. Tänud ka beer_yum.gif
Eraser
Eraser
sõnum 06.06.2010 22:50:12 vasta tsitaadiga
sosssepp kirjutas:
Valutuma kohta ei tea öelda, kuna ka esimene toimis minul siin muretult out-of-box ilma eriliste lisaliigutusteta.
Samas on CK Forms siiski kindlasti paindlikum kui Joomla Petitions. Aga olgem ka ausad - Joomla Petition ongi ju konkreetselt selle ühe asja jaoks kirjutatud ja punkt. CK Forms on aga lihtsalt üldine vormide loomise komponent. icon_smile.gif
sosssepp kirjutas:
sosssepp
sosssepp
sõnum 07.06.2010 13:31:55 vasta tsitaadiga
Ma kas ei oska otsingusse õiget rida panna või pole sellele tükile (CK Forms) eestikeelset tõlkefaili veel tehtud?
Eraser
Eraser
sõnum 07.06.2010 13:39:56 vasta tsitaadiga
sosssepp kirjutas:
sosssepp
sosssepp
sõnum 07.06.2010 13:41:17 vasta tsitaadiga
Tõmbasin inglise keelepaki ja vaatasin. Tekkis küsimus, et miks on seal pakis site kataloogis kolm sama sisuga faili? Väike mõte on, et tõlgiks äkki ise ära, kui vaga keerukaks ei kujune. Tõlget vaja frontendile ainult.
Eraser
Eraser
sõnum 07.06.2010 13:53:01 vasta tsitaadiga
sosssepp kirjutas:
Faili site/en-GB.com_ckforms.ini tõlkimisest peaks aga täiesti piisama. Pane sellele failile siis uus nimi et-EE.com_ckforms.ini ja pane see kausta languages/et-EE/ icon_wink.gif
sosssepp kirjutas:
Kui nüüd tegelikult päris täpne olla, siis tõlkefaili pole sul vaja isegi 100% tõlkida, kuna väljade ja nuppude nimed ja nende kirjelduse sisestad sa ju ise ning seega paned sa nad ise kohe eestikeelsena. icon_wink.gif
sosssepp
sosssepp
sõnum 07.06.2010 14:04:24 vasta tsitaadiga
Veel üks väike küsimus CK Forms kohta, et kas avatud lehel kuvatavale sisestuste tabelile saaks kuidagi ka lisaks esimese lahtri tekitada, mis kirjete järjenumbreid näitaks?
Eraser
Eraser
sõnum 07.06.2010 14:31:00 vasta tsitaadiga
Vormile peaks saama lisada peidetud lahtri koos unikaalse ID-ga. See peaks sul siin asja ära ajama. icon_wink.gif
sosssepp
sosssepp
sõnum 07.06.2010 15:40:09 vasta tsitaadiga
Kaevasin ise ka vahepeal CK Form foorumis ning jäi silma, et murdjad kimbutavad seda komponenti. Kuskilt ei leia ka otsest vastust (võimalik, et viga minus jälle), et kas praegu laadimiseks pakutav pakk omab juba parandusi. http://www.cookex.eu/phpbb/viewtopic.php?f=5&t=585 viimases postis toodud koodinäited on samad ka minu käes olevates failides.
Eraser
Eraser
sõnum 07.06.2010 19:08:17 vasta tsitaadiga
Kui kasutad viimast CK Formi versiooni (1.3.4), siis ei tohiks muret olla.
Vares
Vares
sõnum 10.06.2010 15:38:17 vasta tsitaadiga
Hädas sellise asjaga et ei suuda luua peamenüüs tühja linki st. sellist linki, millele vajutades ei avaneks mingi leht (nagu tavaliselt) vaid tuleksid nähtavale selle alla käivad menüüpunkti alammenüüd. Veidi segane jutt ehk aga äkki keegi sai aru ja oskab aidata. Kui jäi arusaamatuks, siis võin põhjalikumalt seletada.
ValiHeli - Eesti suurima kodukino- ja stereokõlarite ning kõrvaklappide valikuga helitehnika salong!
Kommentaarid: 71 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 66
Eraser
Eraser
sõnum 10.06.2010 15:40:23 vasta tsitaadiga
Vali menüülingi tüübiks Eraldaja
Vares
Vares
sõnum 10.06.2010 22:41:49 vasta tsitaadiga
Eraser kirjutas:
Proovisin oma mõistusega seda juba enne ka. Proovisin nüüd uuesti. Aga midagi teen valesti, sest see menüülink ei muutu üldse lingikski, jääb nagu oleks tavalise tekstiga tegu. JA alammenüüde näitamisest pole haisugi.
www.arratt.ee lehel peaks "Teenused" see kõneallolev menüü olema.
gowgirl
sõnum 05.08.2010 19:45:10 vasta tsitaadiga
Esitan oma küsimuse siia mammutteema alla siis.
Kas oskab keegi seletada "mitte IT keeles", kuidas saada tööle järgmist asja:
Community builder, Kunena foorum, joomgallery, sünnipäevamoodul, privaatsõnumite saatmine. Kõik peaks olema selline ühtne süsteem, aga ei saa tööle kuidagi.
CB peaks nagu peal olema, kui midagi installimisel nihu ei läinud.
Soovisin panna Kunenas Profiili seadetes Profiiliks CB, kuid annab järgmise teate:
* Community Builderiga integreerumisel tekkis mingi viga:
* Community Builderi profiiliga integreerimine töötab ainult siis, kui Community Builder kasutajaprofiil on nähtav.
* Kunena seadete salvestamine lülitab integreerimise välja ning peidab ka selle hoiatuse.
JoomGallerys peaks tulemus olema selline, et registreeritud kasutajad saavad lisada fotod etteantud kategooriatesse ning kasutajale klikkides näitaks kõiki tema lisatud pilte.
Ühesõnaga kõik on pudru ja kapsad, pane või sait kinni icon_confused.gif icon_lol.gif
EDIT
Kethmar
Kethmar
sõnum 08.08.2010 13:32:13 vasta tsitaadiga
Keegi oskab öelda, kuidas VirtuEmarti e-maili välimust muuta? Tahaks konto andmed sinna panna jne. Joomla kodukal olid kõik head asjad tasulised.
//Ei leidnud komponenti, kuid fail asub siin:
components/com_virtuemart/themes/default/templates/order_emails/confirmation_email.tpl.php
Sealt saab asja ilusti muuta.
centraaL
centraaL
sõnum 12.08.2010 10:42:27 vasta tsitaadiga
Keegi oskaks öelda, kuidas filtreerida erinevaid lehti sectionite alusel? Täpsemini sõnastades on vaja saavutada järgmine:
Lehe ülaosas on 3 tabi, oletame, et "Kassid," "Koerad" ja "Hamstrid". Kui vajutada "kassid," muutub kogu lehe sisu (kaasa arvatud menüüd) kassidega seonduvale contentile. Kui koerad, siis muutuvad kõik uudised ja menüüd koertega seonduvaks. Esiteks ei leia ma juba seda üles, kuidas saaks kas või contenti filtreerida nupuga, new menu ei paku sellist variantigi, et kategooriat või sectioni sorteerida, veel vähem siis menüü ja kogu contenti sortimisest.
Kommentaarid: 121 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 108
tom1245
sõnum 12.08.2010 20:59:02 vasta tsitaadiga
centraaL kirjutas:
kas mitte ei tulnud selleks teha uus menüümoodul vms?
Ehitusteemalised arutelud:
https://www.ehitusfoorum.com
Kommentaarid: 84 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 78
Mr.D
sõnum 09.09.2010 23:28:19 vasta tsitaadiga
centraaL kirjutas:
Siin oleks üks robustne lahendus ülal olevale probleemile. (üsna robustne)
1. Teha menüü, mis sisaldab ülal olevaid valikuid : Kassid ; Koerad ; Hamstrid.
2. Teha igale sektsioonile menüü, mida soovid näha, kui valik tehakse. (näiteks kassid valides ilmutab ennast kasside menüü)
3. Teha just tekitatud menüüdele moodulid, mida näidatakse ainult juhul, kui valitakse vastav sektsioon (antud juhul kassid)
Seda saab valida vastava mooduli muutmise lehelt : Menu Assignment ;Menus: Select Menu Item(s) from the List
Ülejäänu on juba liinitöö, vlalid lihtsalt kasside menüüst Uudised ning paned selle Category Blog Layout ning valid siis sealt kassid ning ongi ainult uudised kasside kohta.
Kui on soovi mingeid X mooduleid, mis näitaksid ainult infot vastavalt kas siis Kassid ; Koerad ; Hamstrid, tuleb lihtsalt teha sellest moodulist kokku 3 koopiat ning igale koopiale anda üks sektsioon, kus teda kuvatakse ning kõik.
See lahendus iseenesest toimiks, kui sain probleemist õigesti aru.
uus teema   vasta Tarkvara »  WWW »  JOOMLA ja sellega seonduv mine lehele eelmine  1, 2, 3 ... 11, 12, 13 ... 17, 18, 19  järgmine
