01.05.2010 09:44:58
huvitav. eile erinevaid selle oil spilli teemalisi uudiseid lugedes jäi nagu meelde, et sealt sellise hooga üle paari miljoni galloni välja tuhiseda lihtsalt ei saa. s.t. rõhk läheb piisavalt madalale et enam sellise hooga ei tule.
_________________ - londiste
217 |
Chaza!
| Kommentaarid: 59 loe/lisa |
53 |
211 |
Scart
01.05.2010 17:49:47
Seagal ei mahuks enam kahjuks helikopterisse ära. Nad peaksid selle jaoks venelaste käest selle kopteri rentima, mis busse veab.
Mehhiko ja USA piiri peal aset leidev vägivald saab aina hoogu juurde. Arizonas käib tõsine madin illegaalide ja korrakaitsejõudude vahel, mis väljendub viimastena mainitu poolt Black Hawkide ning Apachedega ringi lendamist ja illegaalide püüdmist. Kahju, et NatGuardi poisid ei taha Iraagi videot teha ja natuke illegaalide ridu vähendada. Siis äkki nood hakkaks mõtlema enne politseiniku augustamist AK47ga.
Ma ei vastuta selle teksti õigsuse eest.
A reader who is an engineer of considerable experience says watch this one evolve carefully because it is destined to continue to grow and he shares this long (but worthy explanation why:
"Heard your mention of the oil disaster in the Gulf of Mexico this morning, and you (and most everyone else except maybe George Noory) are totally missing the boat on how big and bad of a disaster this is.
First fact, the original estimate was about 5,000 gallons of oil a day spilling into the ocean. Now they're saying 200,000 gallons a day. That's over a million gallons of crude oil a week!
I'm engineer with 25 years of experience. I've worked on some big projects with big machines. Maybe that's why this mess is so clear to me.
First, the BP platform was drilling for what they call deep oil. They go out where the ocean is about 5,000 feet deep and drill another 30,000 feet into the crust of the earth. This it right on the edge of what human technology can do. Well, this time they hit a pocket of oil at such high pressure that it burst all of their safety valves all the way up to the drilling rig and then caused the rig to explode and sink. Take a moment to grasp the import of that. The pressure behind this oil is so high that it destroyed the maximum effort of human science to contain it.
When the rig sank it flipped over and landed on top of the drill hole some 5,000 feet under the ocean.
Now they've got a hole in the ocean floor, 5,000 feet down with a wrecked oil drilling rig sitting on top of is spewing 200,000 barrels of oil a day into the ocean. Take a moment and consider that, will you!
First they have to get the oil rig off the hole to get at it in order to try to cap it. Do you know the level of effort it will take to move that wrecked oil rig, sitting under 5,000 feet of water? That operation alone would take years and hundreds of millions to accomplish. Then, how do you cap that hole in the muddy ocean floor? There just is no way. No way.
The only piece of human technology that might address this is a nuclear bomb. I'm not kidding. If they put a nuke down there in the right spot it might seal up the hole. Nothing short of that will work.
If we can't cap that hole that oil is going to destroy the oceans of the world. It only takes one quart of motor oil to make 250,000 gallons of ocean water toxic to wildlife. Are you starting to get the magnitude of this?
101 |
01.05.2010 18:37:39
Scart: Mingi päev tagasi oli mingis omamaises meedias juttu sellest, et selle "katte" pealepanek võtab 3-4 nädalat.
Ning, kui see kattevariant ei õigusta, siis hakatakse kõrvale teist, kaldtoru paigaldama, et nafta voolaks sellesse torru.
Kuid sellise toru paigaldus võtab aega - (vist) 4 kuud, kui mul see õigesti meelde jäi.
Nii, et kellel meeles, võiks juurde lisada, et millisest Eesti meediast need variandid läbi jooksid.
211 |
Shelby-SV
Jõulud On Läbi!
01.05.2010 19:04:47
http://www.e24.ee/?id=255777
päris hea ülevaade PIIGS riikidest ja nende probleemide tagamaadest. lihtsalt ja lühidalt ära seletatud
| Kommentaarid: 63 loe/lisa |
55 |
Scart
01.05.2010 19:44:00
link :: kae siit
Pildid puurtornist. Algavad leheküljel 2.
101 |
Ho Ho
86 |
tops
01.05.2010 22:19:57
Väike tähelepanek:
Meedias räägiti 5000 BARRELIST, hr insener räägib GALLONITEST.
1 barrel = 42 gallonit.
destiny12
01.05.2010 22:23:10
Aga mis saab nüüd kui aina juurde seda naftat seal meeletus koguses juurde voolab?
_________________ "Ära mine sinna, kuhu rada viib. Mine selle asemel sinna, kus rada ei ole, ja saa teerajajaks." |
| Kommentaarid: 83 loe/lisa |
77 |
02.05.2010 02:11:13
200 000 gallons =~ 5 000 barrels
Scarti tsiteeritud tekst ei ole tõsiseltvõetav juba pideva mõõtühikutega möödapanemise tõttu. ükski endast lugu pidav tehnilise haridusega inimene selliseid vigu ei tohiks lubada. muus osas on seal omajagu spekulatsioone ja faktiliselt valesid väiteid.
217 |
02.05.2010 09:12:33
| destiny12 kirjutas: |
| Aga mis saab nüüd kui aina juurde seda naftat seal meeletus koguses juurde voolab? |
Suurt midagi ei saa...järjekordne ökokatastroof.
Ega see inimkonnal esimene kord pole.
http://www.oilrigdisasters.co.uk/
In 1979, the Sedco 135F...
...The well was initially flowing at a rate of 30,000 barrels per day (1 barrel = 42 US gallons = 159 litres), which was reduced to around 10,000 bpd by attempts to plug the well. Two relief wells were drilled to relieve pressure and the well was eventually killed nine months later on 23 March 1980. Due to the massive contamination caused by the spill from the blowout (by 12 June, the oil slick measured 180km by 80km)... |
Kes tahab võib sealt edasi lugeda.
Ime veel, et varsti tankimiseks ämbritäiest mereveest ei piisa
Offshore Blowouts
Five Worst Blowouts Volume Released
1. Sedco 135F and the IXTOC-1 Well - 3,500,000 barrels
2. Ekofisk Bravo Platform - 202,381 barrels
3. Funiwa No. 5 Well - 200,000 barrels
4. Hasbah Platform Well 6 - 100,000 barrels
5. Union Oil Platform Alpha Well A-21 - 80,000 barrels |
Tundub, et see rekord seekord ka lüüakse
viimati muutis Etz 02.05.2010 10:34:39, muudetud 1 kord |
196 |
destiny12
02.05.2010 10:15:28
Kuskilt jäi kõrva, et seal ka mingi looduskaitse piirkond vms. Seega see lööb ökosüsteemi sassi.
77 |
Scart
02.05.2010 10:25:38
| Etz kirjutas: |
Kes tahab võib sealt edasi lugeda. | |
Väike erinevus. Praegune nafta ei ole ookeanis ning tuuled ei vea seda rannikult minema.
101 |
02.05.2010 10:47:01
| Scart kirjutas: |
| Etz kirjutas: |
Väike erinevus. Praegune nafta ei ole ookeanis ning tuuled ei vea seda rannikult minema. |
Hmm, küsiks siis vastu, et kas Mehhiko laht ei olegi ookeaniga ühenduses...vaid omaette "jalapesukauss", mis piirneb igast küljest igasuguse asustuseta rannikuga...ning on sama elundkonna tühi nagu surnumeri?
See et tuul ja ilmastik seda hetkel rannikule kannab on veidi teine ja nukram teema
BTW...minu teada siiani päris kesk ookeane ei puuritagi...
196 |
02.05.2010 10:48:08
Etz: Sealkandi hoovused ja tuuled kimavad alati ranna poole, mitte vastupidi. Ja sellep2rast nad seal ka nii hirmsasti paanitsevad, et kogu "merekraam" kimab ranna poole.
Postitatud mobile device
211 |
02.05.2010 11:22:16
| tahanteada kirjutas: |
Postitatud mobile device |
Ei vaidle vastu, aga ma ei näe erilist vahet kus selline naftalaik lahti lasta...
Ökokatastroof oleks see ikka...
196 |
Scart
101 |
02.05.2010 20:54:41
The British oil giant faces questions over how much it knew about previous problems with “blowout preventers”, the giant underwater valves designed to shut down oil flow in the event of accidents.
The valves on the rig failed to work after it exploded on April 20. BP technicians have been unable to activate them even though they appear to be undamaged by the blast.
BP has calculated that it might take up to three months to sink a new well that could cut off the flow of the Deepwater Horizon’s oil.
The worst oil spill affecting US waters was caused by a 1979 blowout aboard the Ixtoc, a Mexican rig that discharged at least 130 million gallons, 600 miles south of the Texas coast. It took nine months to plug the leak. |
_________________ HV-s ID-kaardiga autentimine
HV valuutakursid |
7 :: |
360 |
tops
03.05.2010 09:03:15
Kreeka abipaketi suurus kolme aasta jooksul siis umbes 110 mrd €, millest IMF´i osa on 30 mrd € ja 15. EU riiki osa 80 mrd €. Saksamaa osa 22,4 mrd €. Intressimäär umbes 5%. Esimesed rahad peaksid laekuma enne 19. maid, millal Kreeka peab laene tagasi maksma.
IMF´i Kreeka projekti pikkuseks arvestatakse 10 aastat.
Kreeka kavatseb säästa 3 aasta jooksul 30 mrd € ning saada defitsiit 3% piirini aastaks 2014.
Käibemaks tõuseb 10% ja samuti ka alkoholi- ja kütuseaktsiis 10%.
Pensioniiga tõuseb 60 aastani.
13 ja 14 kuu palka ja pensione kärbitakse nii, et palka makstakse 1000 € nendele kelle brutokuupalk ei ületa 3000 € ning pensionärid, kelle pension ei ületa 2500 €/kuu, saavad aastas 800 €.
Kreeka võlakoormus kasvab praeguselt 115% SKP´st tasemelt 150%-ni aastal 2013.
Allikad: Reuters.de, N24.de, Ta Nea
http://www.lhv.ee/forums/index.cfm?id=313091&start=51
HV valuutakursid |
7 :: |
360 |
Scart
03.05.2010 11:25:19
| Mitte mingit abipaketti pole. Saksamaa ei ole oma osalemist veel hääletusele pannudki.
101 |
Elof
175 |
7 :: |
360 |
03.05.2010 19:09:10
| Tanel kirjutas: |
Soome vajab Kreeka abistamiseks lisaeelarvet
Päris huvitav kommentaar:
| Eurotsoonis olles võib ka Eestil tekkida reaalne kohustus laenudega aidata neid riike, kes vajavad abi riigivõlgade refinantseerimiseks. Tekib paradoksaalne olukord, et selliste abilaenude andmiseks võime olla sunnitud riigivõlakirju ise emiteerima. |
Antud juhul saadaksin ise ka selle euro kukele... see ei käi meie majandusmudeliga kokku. Antud juhul, siis tuleks valida savikas ja sebida endale hea riigitöö.
201 |
