| Kommentaarid: 92 loe/lisa |
Heineken
14.04.2010 23:12:17
| Seller kirjutas: |
Päris igas mõttes kõige-kõige see Sapphire Radeon HD 5970 TOXIC 4GB Video Card
nüüd ka ei ole. 4gb kaarte teisigi (quadro FX 5800 4gb)...ainult teise suunitlusega. |
Sügavalt kahtlen et mänge jooksutab see Quadro paremini kui too Sapphire HD 5970 Toxic 4GB . Ega vRAM perfi põhimääraja pole .
| Kommentaarid: 24 loe/lisa |
23 |
CoiL
15.04.2010 07:53:59
Heineken, jutt ei käigi vRAM´st vaid mitte eksisteerivast FireGL kaardist. Tee endale selgeks mis on FireGL kaart
FireGL 4GB Cypress kiibil oleks tõesti üüüüber-shjiiiiit
| Kommentaarid: 95 loe/lisa |
83 |
1dumbpcuser
15.04.2010 08:43:49
Part 2: AMD's Eyefinity Technology Explained
TomsHW
| AJ kirjutas: |
ASUS launches its take on a 2GB pre-overclocked HD 5870 GPU
http://www.hexus.net/content/item.php?item=24044
The 2GB Radeon HD 5870 party got under way last week with the introduction of Sapphire's TOXIC edition, and ASUS is today following up with a card it reckons is the "freshly appointed king".
It's called the Republic of Gamers 5870 Matrix, and as the ROG branding suggests, it's a souped-up take on AMD's fastest GPU to date.
Using a custom PCB, ASUS has attached a 2GB GDDR5 frame buffer to the GPU, and though the memory runs at a standard 4,800MHz, the GPU is pre-overclocked to run at 894MHz - a 44MHz increase over AMD's reference design.
A healthy bump, but seemingly conservative in comparison to Sapphire's TOXIC edition - which remember runs at 925MHz and 5,000MHz, respectively, for core and memory frequencies.
Instead, ASUS throws in what it calls its Super Hybrid Engine (SHE), an automatic overclocking function that promise an average performance boost of 19 per cent whilst gaming at high detail. We'll have to see real-world figures to judge how effective SHE really is, but there's plenty of more overclocking goodies added to the mix, too.
The card's said to feature a 10-phase vGPU and 2-phase vMem, along with independent voltage controllers, and the card-mounted voltage measurement points - combined with ASUS's iTracker2 and ProbeIt software solutions - provide the overclocking crowd with a little extra control.
On top of all that, there's a custom cooler that promises a 22 per cent higher air flow than AMD's reference design, resulting in temperatures dropping by "at least" 13 per cent, says ASUS.
All sounds rather nice, but really, where's the machine gun?
No word on pricing or availability as yet, but we'd expect the card to come in at around the £400 mark. |
ASUS Radeon HD 5870 Overclocks to 1525 MHz
Xtremesystems
_________________ M: MSI B660M MORTAR
O: AM5 ITX emaplaat |
97 |
CoiL
15.04.2010 10:06:58
1525MHz ...jõhker klokk ikka
83 |
Heineken
15.04.2010 10:44:24
CorsairX, ma ei saa aru mis kurat see Cypress FireGL siia puutub . Räägiti nagu teeks 4 GB vRAMi tolle HD 5970 "kõige-kõigemaks" vms ja et too Quadro 5800 oleks veel ägedam . Mängimiseks Quadrod ja FireGL kaardid ei ole mõeldud ja selles mõttes ei ole need kõige ägedamad . Võibolla sain jutu pointist valesti aru muidugi .
Aga kurat , 1525 Mhz , ulme .
23 |
15.04.2010 11:26:44
| Heineken kirjutas: |
Aga kurat , 1525 Mhz , ulme . |
Öeldi justkui, et on ka teise suunitlusega 4GB kaarte ja need kiiremad seega pakkusin välja, et äkki tuleb 4GB FireGL
One
15.04.2010 11:27:08
ei saa ka mina sellest quadro võrdlusest aru...
see quadro maksab ka 1k taala? ega vist.
need klokitud HD5970-d on kõige-kõigemad kaardid ja seda igas mõttes.
728 |
Heineken
15.04.2010 12:33:02
tomorrow, sellest sain aru et 4GB kaarte ka teisigi ja teise suunitlusega , aga ei saa sellest aru kuidas nood teised siis "kõige-kõigemad" on . Või teeb 4 giga rammu kuidagi ägedamaks kaardi ?
23 |
Seller
15.04.2010 12:41:57
Ma ütlesin, et päris igas mõttes kõige kõige see ati ei ole........lihtne või kuidas ?? See tähendab, et ati on mängimiseks kõige kõige, kuid mitte enamaks.
Samas quadro kaart on mängimiseks mittekõlbulik aga cad-cam progede ja muu säärase jaoks ideaalne.
xxlmaster
15.04.2010 19:32:54
No ei saa mina aru milles on jama.
Kõik variandid läbi proovitud aga 2D olles on ühe gpu kellad 2d-l, teisel nii gpu kui ka mälu 3Dl.
Kui panna Gpuz käima ja vaadata seda "vigast" Gpud siis läheb ilusti 2dle. CCC all ei näita tempe ega ka activitit kui gpuz jällegi ei käi
Kas võib juba arvama hakata et tegemist vigase kaardiga?
BIOSeid juba oma miljon läbi proovitud.
| Kommentaarid: 83 loe/lisa |
77 |
omgwtf
15.04.2010 19:35:30
x2 rõõmud Taoline 2D/3D jama oli ka eelmise x2 ja asi vist fixiti alles sada kuu hiljem Küll KUNAGI ehk tuleb ka sellele asjale lahendus..
137 |
xxlmaster
15.04.2010 19:39:54
| omgwtf kirjutas: |
x2 rõõmud Taoline 2D/3D jama oli ka eelmise x2 ja asi vist fixiti alles sada kuu hiljem Küll KUNAGI ehk tuleb ka sellele asjale lahendus.. |
No imelik on see et NEED rõõmud just ainult minul esinevad
HV s pole veel kedagi kurtmas näinud
77 |
HDTanel
Overclocker
15.04.2010 19:40:53
xxlmaster, ära muretse, neid on tegelt kõikjal kellel need kaardid on, osad tunnistavad seda, osad mitte ATI on ju parim
_________________ Minu Youtube - HDTanel |
496 |
xxlmaster
15.04.2010 19:49:00
Vähe siis sellest, proovisin täna siis selle 10.4 beta ära. Tundus nagu päris ok olema kuni hakkas display driver stoped working ette loopima. Uninstall ja proovisin siis 10.3 tagasi panna, huiat, ei saagi peale enam. Peale resa viskab ette küll et soovita oma cräpi regada... aga ccc avama hakates(parema hiireklõpsuga rippmenüüst leiab selle nüüd siis) ütleb et kas pole kaarti või puudub driver
Ei tea kas win hakkab juba hapuks minema või peab tõesti raketi teadlane olema tänapäeval et videokaardi drivusid installida
77 |
One
15.04.2010 19:57:33
millest sa seda võtad, et teisel gpu-l 3d klokid?
paljud probleemid algavad sellest, et kasutatakse mingit x 3rd party softi mis
näitab aiateibaid
728 |
xxlmaster
15.04.2010 20:00:13
Winterwind,
Gpuz, MSI afterburner, Cpuz. Kõik nüüd siis näitavad aiateibaid jah
77 |
One
15.04.2010 20:29:26
anna andeks aga nii sul kui platvormil on xfx-i black edition
ning arvestades FAKT-i, et erinevad tootjad ei viitsi eri kaartide
klokkide/voltide profiilidega piisavalt vaeva näha on probleem selgelt
tootjas mitte seerias endas.
ehk siis hetkel tundub probleem olevat selles, et xfx-i bios on tiba kahtlane
ja OSADEL kasutajatel esineb igasugu imelikke probleeme.
Sellegipoolest on "järeldus", et terve kaardiseeria = praak bs
ning probleem on otseseslt konkreetse tootja biosis.
ps ükski neist sinu loetletutest programmidest ei ole ei ATi/AMD ega ka XFX-i tehtud,
ehk siis tegu on tõesti lambi 3rd party progedega mis tihtipeale näitavadki lambinumbreid ja põhjustavad eri probleeme.
analoogne kala oli ka gpuz-i ja hd4870 x2 ampritega.. paljud kägisesid, et 2d/3d klokid ei tööta
kuna gpu-z näitab ulmeampreid.
lõppkokkuvõttes selguski kurb tõsiasi ja w1zzard tunnistas, et proge kuvab LAMBINUMBREID
728 |
xxlmaster
15.04.2010 20:29:43
| Winterwind kirjutas: |
ehk siis tegu on tõesti lambi 3rd party progedega mis tihtipeale näitavadki lambinumbreid ja põhjustavad eri probleeme |
Sinu teooria puhul oleks siis tookord kui MSI BIOSt proovisin, afterburner selgeid numbreid näitama
Mis muidugi oli sama tulemus.
77 |
One
15.04.2010 20:33:04
anna andeks aga minu käest on läbi käinud kuus eri tootjate HD5970-i, samuti
hunnikute viisi HD5750/HD5770/HD5850/HD5870-e ja lambiprobleeme pole ühelgi olnud
kui välja arvata fakti, et erinevad tootjad kasutavad tihtipeale erinevaid ja non reference
2d kloki/voldiprofiile ja tihtipeale ongi mõne kasutaja probleem seal.
ehk siis enamusel töötab ja MÕNEL ei tööta
xxlmaster.. mis see msi bios päästab?
sama asi ka mõne msi kaardiga kus tootja väidab, et
softi baasil voldimuutmine töötab aga REAALSUSES ei tööta,
ülevaatelinke leiad kasvõi siitsamast teemast
| xxlmaster kirjutas: |
| Winterwind, ja kõigil neil kuuel erineval HD5970 esines sama jama mis minulgi hetkel? |
ei, probleeme ei esinenud ühelgi kaardil nagu võib tõdeda ka erinevaid ülevaateid lugedes.
ehk siis jutu point on endiselt selles, et enamusel asjad töötavad ja mõnel ei tööta,
on siis viga softis, tihendis või juppide sobivuses.
viimati muutis Winterwind 15.04.2010 20:41:06, muudetud 3 korda |
728 |
xxlmaster
15.04.2010 20:36:54
77 |
omgwtf
15.04.2010 20:47:41
Vevalt,et ta kõik 6 omale masinasse pistis ja testis ja vahtis neid kellasi..
Täpselt sama biosi iba olen juba kuulnud eelmise seeria kohta,et näe teise tootja bios süüdi.. Osta tohiks siis ainult Ati(või mis iganes see õige siis on) toodetud kaarte? Eri nali..
137 |
G80
15.04.2010 21:48:16
xxlmaster, mida hekki ei saa aru, krt endal oli kuuaega 5970 mingit jama polnud, muidugi kasutasin ka 9.12 drivut ja mingit betat.
Peale uninstalli ei lase driverit peale installida?
210 |
xxlmaster
15.04.2010 22:09:43
| G80 kirjutas: |
Peale uninstalli ei lase driverit peale installida? |
Pikka aega sweepides ja järjest "surudes" õnnestus peale jälle saada
Ja no see pilt siis ka muidugi vägev.
77 |
AJ
| Kommentaarid: 37 loe/lisa |
36 |
Heineken
16.04.2010 12:36:10
Sellise hinnaks tuleb raudselt mingi 4500-5000 siin .
23 |
16.04.2010 12:48:46
Sellise hinnaks tuleb raudselt mingi 4500-5000 siin . |
1xDVI jälle
196 |
1dumbpcuser
97 |
16.04.2010 12:58:17
| 1dumbpcuser kirjutas: |
HDMI ja DP on ju olevik/tulevik  |
Et siis nüüd on uus trend?
Uue Videokaardiga pead uued monitorid ostma
196 |
Heineken
16.04.2010 15:53:50
Kui ma õigesti aru olen saanud siis peaks DP saama miski adapterijubinaga DVI pesasse ühendada ?
Kuigi jah , 2xDVI võiks olla küll , ega need 2 ekstra jahutusribi nüüd küll midagi sellise jahutiga juurde anna .
23 |
omgwtf
16.04.2010 16:00:05
Vaevalt,et asi selles jahutuse ribis,pigem teeks asja kallimaks ja keerulisemaks vms
137 |
Heineken
16.04.2010 16:01:55
| Reference HD 5850-del on küll 2xDVI ja 1DP ja 1HDMI .
23 |
1dumbpcuser
16.04.2010 16:07:08
Nagu ka HDMI
97 |
AJ
36 |
Heineken
17.04.2010 12:37:23
| Nii vähe äääää .
23 |
kaidtor
OC GURU
17.04.2010 15:08:55
| tomorrow kirjutas: |
| Nii vähe äääää . |
On kellelgi rohkem DX11 kaarte müüdud või?  |
isegi olek huvitatud ühest 5850-st
136 |
Scart
17.04.2010 15:25:58
Üks on selge. DX11 on juba massides.
101 |
NATAS999
17.04.2010 15:48:41
Scart, kus massides ei tea? paar mängu ja 1 bench, mis masina ülikooma tõmbab. kus need massid sul siin on ei tea.
_________________ "Kuidas on see hea?"
-Auto kirurgia kliinik |
| Kommentaarid: 41 loe/lisa |
39 |
chulo
17.04.2010 15:55:02
| NATAS999, misasja sa soiud?! Lõpeta joomine või võta peale! Silmas peeti DX11 GPU-de jõudmist tarbijateni, keegi pole mängudest midagi rääkinudki. Ehk nüüd hakkab ka mänge tulema, kui DX11 rauda piisavalt kodudes.
| Kommentaarid: 20 loe/lisa |
18 |
NATAS999
17.04.2010 15:59:53
chulo, DX10 rauda on ka minu arust piisavalt kodudes. palju meil siis neid WoW vinge DX10 gfx mänge on? kõik käib praegu vana 9c peal edasi.
39 |
Flavius
17.04.2010 16:06:46
Selge see, et ATI'l parema hinna/jõudluse suhtega kaardid, mis müüvad. DX11 on mainitud reklaami eesmärgil, mitte praktilise kasutuse tõttu.
Samuti võib öelda, et USB3 ja SATA3 on massides kuna emaplaatidel vastavad liidesed - paraku sobivaid seadmeid/rakendusi annab otsida.
118 |
chulo
17.04.2010 16:08:07
| NATAS999, ja mis sa sellega öelda tahad? Et ilmselt sureb DX11 samamoodi ää nagu DX10? No elame näeme, võibolla on tõesti nii. Fakt on see, et rauda mis DX11 ringi veaks on juba piisavalt, et mänguarendajad seda ära kasutada võiks.
18 |
NATAS999
17.04.2010 16:38:09
chulo, vaevalt, et ära sureb. ju ikka selle tessellationiga midagi kõvemat ette ka võetakse kunagi, aga selleks vaja 1, max 2 gen edasi minna, kuni seda reaalselt saab hakata ära kasutama, ilma, et FPS kannataks rämedalt. oma osa mängib siin kindlasti ka konsooli raud, mis oma võimalustelt jalgu jääb ajale. üsna kindlalt võib väita, et järgmise konsooli generatsiooniga paraneb ka PC mängude graafika hüppeliselt.
39 |
CoiL
17.04.2010 17:05:48
NATAS999, mis krdi next gen sa jahud? HD5970 saab küll ju ilusti tessellationiga hakkama. Või räägid sa jälle mingitest üüber-suurtest resodest mida enamus inimesi eales ei kasuta?
OpenGL`il on näiteks ammuilma tesselation olemas. Pigem on probleem selles ,et enamus mängutegijaid lasevad lõdva londiga vana rasva (dx9) peal edasi ja lüpsavad lihtsalt raha. Tõsiselt häid mänge ju siiski ainult käputäis imo
83 |
NATAS999
17.04.2010 17:14:46
ega häid mänge pole jah viimastel aastatel toodetud eriti.
1920x1200 peaks olema norm reso. 800x600 on minevik.
mis sul see 5970 teeb heaven 2.0 benchis ja metro 2033?
huvipärast küsin, mitte nöökimise pärast. huvitab just 1920x1200. mul pole madalama resoga kottigi teha.
39 |
xxlmaster
17.04.2010 17:45:55
| NATAS999 kirjutas: |
huvipärast küsin, mitte nöökimise pärast. huvitab just 1920x1200. mul pole madalama resoga kottigi teha. |
Ega ta midagi silmi punni ajavat ei tee.
Heaveni lasin kiirelt ilma klokita.
Naljaks oli see et ei olegi veel vaadanud kuidas DX11 seal välja näeb ja tulemus oli minu jaoks ikka
NB: väike klokk asjale juurde muudab avg fpsi 10-15
Metro 2033 tulemusi võin sulle õhtu poole v homme visata
77 |
G80
17.04.2010 18:12:04
| chulo kirjutas: |
| NATAS999, misasja sa soiud?! Lõpeta joomine või võta peale! Silmas peeti DX11 GPU-de jõudmist tarbijateni, keegi pole mängudest midagi rääkinudki. Ehk nüüd hakkab ka mänge tulema, kui DX11 rauda piisavalt kodudes. |
Ära pane teda tähele.
DX11 mänge juba 4-5 kui mitte rohkem
210 |
Scart
17.04.2010 18:14:32
| Scart, kus massides ei tea? paar mängu ja 1 bench, mis masina ülikooma tõmbab. kus need massid sul siin on ei tea. |
Tegelikult võiks enne soiguma hakkamist ja hala ka teada, mis erinevus on DX10l võrreldes nüüd uue DX11 versiooniga ning miks DX11 on siin, et jääda. Tasub ära.
101 |
