08.04.2010 19:38:36
| Killhoven kirjutas: |
5830 on juba päris ahvatleva hinnaga (<3k) pixmanias.  |
Igatahes normaalsem kui see algne hind aga vahe ~2k 5770-ga on veel tsipa suur
| Kommentaarid: 92 loe/lisa |
Killhoven
OC`er
08.04.2010 19:57:03
Vahe ju alla 1k
_________________ Foorumis on ühe lolli kohta kümme tarka, nii et jõud on enam-vähem võrdsed.™ |
| Kommentaarid: 405 loe/lisa |
349 |
CoiL
08.04.2010 19:59:56
Tundub, et hinnasula hakkas ati kaartidel vaikselt otsast pihta
| Kommentaarid: 95 loe/lisa |
83 |
08.04.2010 20:15:41
Vahe ju alla 1k  |
Pidasin silmas, et 5770 maksab seal ise ~2k mitte, et 5770 ja 5830 vahe oleks ~2k
Kehv sõnastus
AJ
| Kommentaarid: 37 loe/lisa |
36 |
08.04.2010 21:50:29
Tänud
AJ
08.04.2010 22:12:58
GIGABYTE lets loose Radeon HD 5870 Super Overclock edition
http://www.hexus.net/content/item.php?item=24162
GIGABYTE's custom card, pictured above, is designed with the overclocking crowd in mind and qualifies for "Super Overclock" status by passing through a process dubbed GPU Gauntlet Sorting - a series of tests through which GIGABYTE cherry picks the best GPUs.
That GPU is then attached to a Ultra Durable VGA board, which brings all the usual high-end GIGABYTE goodies to the table - including a 2oz copper PCB, first tier Samsung/Hynix memory, Japanese capacitors, ferrite core chokes and five NEC proadlizers.
All that should combine to provide ample overclocking headroom, and GIGABYTE even gets you started with a core pre-overclocked to 900MHz (up from 850MHz) and 1GB of GDDR5 memory overclocked to an effective 5,000MHz (up from 4,800MHz).
Voltage read points are available to help keep things under control beyond those out-the-box levels, and the custom cooler - which features a duo of inclined fans - claims to lower temperatures by around 13°C when compared to AMD's reference design.
There's no mention of pricing and availability, but with the card likely to go head to head with something like an MSI 5870 Lightning, we reckon it'll fetch around £380 at retail.
Hoping for something a little more mainstream? Turns out you're in luck, as GIGABYTE tells us a Super Overclock edition of the Radeon HD 5770 is in the works. |
36 |
08.04.2010 22:51:56
| AJ kirjutas: |
Mälud pole küll parimad.Saaks veel vingemad peale lajatada
AJ
09.04.2010 08:13:36
| tomorrow kirjutas: |
| AJ kirjutas: |
Mälud pole küll parimad.Saaks veel vingemad peale lajatada  |
Vingemad mälud tulevad Giga HD 5870 Hyper Super Overclock E dition-i peale.
36 |
arvutiH YT
Heineken
12.04.2010 18:27:47
| Rääkige nüüd HD 5850 omanikud , kui suur 24/7 OC oleks veel talutav ? ( Hetkel endal kaarti ei ole , aga plaanis mingi hetk osta )
| Kommentaarid: 24 loe/lisa |
23 |
SogegaTyyp
12.04.2010 18:55:03
| Ma arvan, et ilma voldi lisamiseta ca 825/1150 ja ca 1.2V juures 925/1200 kandis. Kui arvestada, et 5870 core saab natuke alla 1.2V, siis 1.20 on sellele GPU-le veel talutav. Oleneb muidugi kaardist ka, mõni isend on nagu ikka, parem ja mõni kehvem.
| Kommentaarid: 54 loe/lisa |
51 |
AJ
36 |
aap14
12.04.2010 20:12:47
Sõltub meeletult isendist jah. Endal leidsin, et optimaalne on 946/4774 @ 1.226V. Eriti ei soovita üle 1.2V minna, kuna voolutarve ja seega ka kuumus suureneb siis kõvasti (vajab rohkem mürarikast jahutust). Kätte saad kaardi, siis anna siin teada, mis stabiilse OC saad (mängudes).
Muidu BIOS välja vahetatud Asuse vastu, et saaks Asus smartdoctorit kasutada. MSI afterburneriga oli probleem mälude kellamisega ja CCC-ga probleem voltide muutmisega.
Metro 2033 @ full hd @ very high ilma tesselatoni, DoF ja AA-ta on päris siidine (v.a. mõned valgusrikkad stseenid).
_________________ Slow is smooth and smooth is fast |
| Kommentaarid: 41 loe/lisa |
38 |
Ramones
12.04.2010 20:38:47
Endal hetkel ASUSe moditud FW-ga 915/1200 @ 1,15V. Muidu 850 oli ilma GPU volti tõstmata stabiilne veel. Ühtegi lisaprogrammi hetkel OC jaoks ei kasuta.
viimati muutis Ramones 12.04.2010 20:41:15, muudetud 1 kord |
| Kommentaarid: 76 loe/lisa |
75 |
Heineken
12.04.2010 20:42:36
Müra mind ei häiri pea üldse (kast laua all ja juba praegu lärmab , kuna kasti ventikad kõik max kiirusele kruvitud , aga kui toolil või diivanil istuda pole midagi kuulda) . Kui orig jahutusest puudu tuleb läheb S1 + 2x Scythe Ultra Kaze @3000 RPM peale , kuigi revüüde järgi ei tohiks nagu puudu tulla kui vent miski 70% peale keerata .
Loodetavasti satub hää isend . OC eesmärk oleks vähemalt HD 5870 perf välja pigistada .
23 |
G80
210 |
AJ
36 |
arvutiH YT
13.04.2010 19:44:30
| Millal seda Sapphire 4GB 5970-t müüma hakatakse ning kas on loota, et mõni Eestisse ka müügile tuleb?
HDTanel
Overclocker
13.04.2010 19:53:29
arvutiH YT, 12000.- hind eestis? Ei kipu väga ostma
_________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel |
496 |
One
13.04.2010 21:07:44
12k oleks ju väga odav.. pakun et hind tuleb pigem sinna 15k kanti
sest tegu igas mõttes kõige-kõigema kaardiga
728 |
denis28
13.04.2010 21:16:26
| Asus "Ares" Dual-5870 oleks äkki kiirem
| Kommentaarid: 67 loe/lisa |
aap14
13.04.2010 23:59:13
Mis te ikka seda odavat kraami ostate
38 |
AJ
36 |
Seller
14.04.2010 21:22:59
Päris igas mõttes kõige-kõige see Sapphire Radeon HD 5970 TOXIC 4GB Video Card
nüüd ka ei ole. 4gb kaarte teisigi (quadro FX 5800 4gb)...ainult teise suunitlusega.
