One
22.02.2010 16:30:37
| 512bitti on nad juba ammu kasutanud, kui vajadus tekib siis võetakse asi uuesti kasutusele.
728 |
Killerwave
22.02.2010 16:35:03
| Pole ju mõtet hinda üles ajada kõige-kõige kasutamisega, mis aga ei tähenda et loodud tehnoloogia ära koaks või arengut selles vallas ei toimuks.
31 |
G80
22.02.2010 16:36:21
| denis28 kirjutas: |
see mitte vajaduse jutt minuarust natu mööda... kui hetkel pole asjale vajadust siis jätame kõik arendamise ja ehitamise pooleli w , ükskõik mis asjaga
inimesed ikka arendavad jne asju kuigi pole vajadust |
Siiski tuleb vaadata kas see on mõistlik, võiks ju teha 100m autod ka aga milleks?
210 |
denis28
22.02.2010 16:40:56
| no minu silmis pole vajadust ka üle 100kw autol... aga näed ikke tehakse nii 650kw versioone isegi
| Kommentaarid: 67 loe/lisa |
| Kommentaarid: 92 loe/lisa |
AJ
23.02.2010 13:08:01
ATI Radeon HD 5830 Specifications Surface
http://www.techpowerup.com/115908/ATI_Radeon_HD_5830_Specifications_Surface.html
AMD's new performance graphics card that targets an upper-mainstream price-point, the Radeon HD 5830, is slated for February 25. A set of company slides sourced by IT168.com shows the GPU's specifications are in tune with what we expected. The HD 5830 is based on AMD's Cypress 40 nm GPU. It has 1120 stream processors, a 256-bit wide GDDR5 memory interface, 16 ROPs, 56 TMUs, and clock speeds of 800 MHz (core) and 1000 MHz (memory). The memory bandwidth on the card is 128 GB/s, on par with that of the Radeon HD 5850. The core clock speed is slightly higher, too.
With a GPU of these specifications, AMD targets the market price-range of $200-$250, where there's room for a DirectX 11 generation graphics card to be positioned between the Radeon HD 5770 and Radeon HD 5850. The maximum board power of the card is slightly higher than that of the HD 5850, but we think that's because reference designs - if there are - might not use high-grade digital PWM circuitry. That typically shouldn't affect overclocking headroom a big deal.
The Radeon HD 5830 further has 1 GB of memory, and supports ATI Eyefinity technology. With the same display controllers as on the Radeon HD 5870, the card can support up to six physical displays. AMD's add-in board partners should be able to release non-reference design graphics cards right away, so you wouldn't have to wait any further for a PCS+, the VaporX, or the IceQ+. |
| Kommentaarid: 37 loe/lisa |
36 |
Killerwave
23.02.2010 13:12:53
| Kõlab huvitavalt, kuigi tahaks reaalseid teste näha ja hinda. Ehk midagi neile kel 5850 jaoks nutsu ei jagu, kuid loodetavasti on piisavalt kiire et paneb pigem seda ostma 5770 asemel.
31 |
23.02.2010 13:13:04
hmm, teste tahaks näha. ropide puudus peaks fullhd kanti resodel tappev olema ja väiksematel raiub 5770 juba korralikult... väiksema voolutarbe ja hinnaga.
_________________ - londiste
217 |
AJ
36 |
Killerwave
23.02.2010 13:22:29
| londiste kirjutas: |
| hmm, teste tahaks näha. ropide puudus peaks fullhd kanti resodel tappev olema ja väiksematel raiub 5770 juba korralikult... väiksema voolutarbe ja hinnaga. |
Isiklikult ise 5770 ei ostaks, vahe praeguse 8800GT-ga pole just kuigi suur, kuna iga aasta kaarti ei vaheta siis sooviks suuremat hüpet teha(parim oleks 5850 aga kui rahakotist tuul läbi puhub siis ehk leiab lohutust 5830 näol, aga eks see selgub teste nähes.
31 |
G80
210 |
Killerwave
23.02.2010 13:26:33
OCi all alistab küll WARHEADi 2560x resol ära max sätetel
31 |
Juan Pablo
23.02.2010 22:35:45
CRYSISE testis on 295gtx ikka selle kõrval "poisike"
29 |
AJ
23.02.2010 23:04:28
ASUS preparing HD5830 DirectCu
http://www.centrale3d.com/?Quelques-infos-sur-la-HD-5830-d
ASUS is one of many companies that will let loose their new Radeon HD 5830 graphics cards on February 25th. Unlike previous models of the Radeon HD 5800 series we can expect some custom built versions of Radeon HD 5830 from day one. ASUS has prepared a model using its new DirectCu cooler.
Other than that the card has the same clock frequencies as the AMD reference, but the cooler with its direct-touch copper heatpipes should do a better job at keeping the temperatures down.
Exactly what makes the card better than the rest, the coolers aside, is not that obvious though, but hopefully this means that the launch of Radeon HD 5830 will bring some greater variety than the otherwise fairly bland launches. |
Veel HD 5830-ide pilte
36 |
xxlmaster
23.02.2010 23:33:25
Aprilli alguses siis ka HD5970 omanik
| Kommentaarid: 83 loe/lisa |
77 |
WäntWõll
make.believe
23.02.2010 23:35:48
xxlmaster, Mis nüüd siis meiega saab.
Aga välja teed ikka onju,ma olen alati uskunud, et uute asjade "sisse pesemis" pidu on vähemalt 2x sotetavast vidina vääärtusest.
300 |
23.02.2010 23:36:58
| xxlmaster kirjutas: |
Aprilli alguses siis ka HD5970 omanik  |
ma kahjuks ei ole
xxlmaster
23.02.2010 23:50:09
| wanawoll kirjutas: |
Aga välja teed ikka onju,ma olen alati uskunud, et uute asjade "sisse pesemis" pidu on vähemalt 2x sotetavast vidina vääärtusest.  |
Kui oma tagumiku viljandi lohistad siis vabalt
77 |
WäntWõll
make.believe
23.02.2010 23:54:54
Cool ma mõtlesin et pean Norrasse laekuma
300 |
xxlmaster
23.02.2010 23:56:28
Cool ma mõtlesin et pean Norrasse laekuma  |
Ei ma pean ikka "Suureks Reedeks" koju lohisema.
77 |
aktuaalnek
AJ
24.02.2010 15:32:39
Kahju, et nad ei võrrelnud HD4890-iga mille asemel peaks HD5830 tulema.
36 |
24.02.2010 15:36:30
sama power usage ja päris karm performance drop 5850 võrreldes.
ma ei saa kaardi pointist hästi aru. liialt palju defektseid kive, millest vaja lahti saada?
nagu öeldud, tahaks võrdlust näha, aga pigem 5770
217 |
omgwtf
24.02.2010 15:55:19
2x6pin eri feili asetusega jälle Kaart niigi pikk ise ja nüüd veel pistikud ka otstes
137 |
One
24.02.2010 16:18:22
| see review on küll pars bs, ootaks siiski mingi normaalse ülevaate ära enne kui järeldusi teeks.
728 |
G80
24.02.2010 16:19:14
| omgwtf kirjutas: |
2x6pin eri feili asetusega jälle Kaart niigi pikk ise ja nüüd veel pistikud ka otstes  |
5850 ju sama.
210 |
omgwtf
24.02.2010 16:20:28
Ohh jah,ongi sama Seda ei pannudki tähele,kuna 5870 pistikud on viisakas kohas
137 |
One
24.02.2010 16:23:10
| ma ei tea, mul pole mingi eurosuure sisuga korpus aga HD5850 mahub kasti küll lõdvalt ära
728 |
omgwtf
24.02.2010 16:26:54
No mul mahub ka ära kenasti,kuid kui panen sahtli kettaid täis,siis läheks kõvemaks pistikute painutamiseks Seega pistikud võiks ikka olla normaalsel kohal Õnneks 5870 ta seda ka on Muu sodi nagunii ei koti.
137 |
One
24.02.2010 16:27:42
| selleest on HD5850 lühem kui HD5870 seega kui viimane mahub siis mahub ka esimene lõdvalt.
728 |
HDTanel
Overclocker
24.02.2010 16:42:19
Norm, Starcraft II test
_________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel |
496 |
G80
24.02.2010 17:02:10
| omgwtf kirjutas: |
No mul mahub ka ära kenasti,kuid kui panen sahtli kettaid täis,siis läheks kõvemaks pistikute painutamiseks Seega pistikud võiks ikka olla normaalsel kohal Õnneks 5870 ta seda ka on Muu sodi nagunii ei koti. |
Eks ta ole jah vähe imelik, 5870 vähemalt korralikult.
High-endil peaks ikka külje peal olema ilusasti.
4870X2-l olid ka vähe imelikult.
Aga noh korra paned külge, palju ei häiri.
210 |
One
24.02.2010 17:40:21
mis seal voolutarbes imestada? gpu klokk ju 100mhz suurem, loogiline ju et ka voolutarve tiba kõrgem.
enivei see suht poogen kuna mõlemad nagunii täielikud säästukaardid.
728 |
K3ndu
122 |
G80
210 |
Taavi©
25.02.2010 10:23:50
6 :: |
328 |
aap14
25.02.2010 10:39:29
ARES on asjale väga tabav nimi. 4GB videomälu on kah lihtsalt ülikõva.
Olemegi jõudnud aega, kus videomälu on high-end kaartidel sama palju kui keskklassil RAM-i
_________________ Slow is smooth and smooth is fast |
| Kommentaarid: 41 loe/lisa |
38 |
SurfData
25.02.2010 11:07:33
krdi ilusa disainiga, küsimus jääb ainult et mitu slotti ta võtab ja kui palju maksma hakkab
ma vist ootan endale järgmise põlvkonna ära, hüppan hd 4870 pealt järgmine aasta hd 6870 peale vms, hetkel väga piduriks asi veel ei jää
| Kommentaarid: 84 loe/lisa |
74 |
loser
25.02.2010 11:13:45
| tomorrow kirjutas: |
Tegelikult see 4GB on muidugi e-peen
Reaalselt ei tohiks üheski mängus ka kõige karmimate sätete ja resoga tõusta VRAM kasutus üle ~1,5GB
Teiselt küljest vb tuleks odavam osta see kui FireGL ja fläshida ümber FireGL-ks ja vastavad driverid peale saab odavamalt 4GB mäluga workstation kaardi  |
Kui 1,5 GB VRAM võib isegi asja ette minna, siis polegi varu teab mis suur, arvestades et antud kaardil "kõigest" 2GB VRAM per GPU.
| Kommentaarid: 17 loe/lisa |
16 |
trip
25.02.2010 11:40:18
GTA4 1680*1050 kõik graafika sätteid max peal =1,4gb videoram kasutusel.
eyefinity kasutades, nt 3x1920*1080 LCD ehk 5760*1080 resoga mängides peab siis kaardil rohkem kui 4gb olema?
(heh, gta4 ei toeta eyefinity )
303 |
217 |
One
25.02.2010 12:13:12
need ülevaated ei ole reaalsed, asi peaks hd4890-st ikka omajagu kiirem olema mitte aeglasem
nagu ülevaated väidavad. neil on seal kas mingi suur draiverijama või muu kala aga see pole loogiline, et kaart aeglasem kui hd4890
728 |
Optimist
25.02.2010 12:36:32
| Winterwind kirjutas: |
nagu ülevaated väidavad. neil on seal kas mingi suur draiverijama või muu kala aga see pole loogiline, et kaart aeglasem kui hd4890 |
Saab jah kolmes kõigis kolmes review's odavama HD4890 käest ära. 50MHz väiksem GPU klokk tähendab et max teoreetiline fillrate on 12,8 Gpixels/s vs HD4890 13,6 ilmselt siin ongi kala maetud. Kellamisel tõenäoliselt HD5830 potentsiaal siiski suurem. Hind on hetkel samuti sellise jõudluse kohta liiga suur.
| Kommentaarid: 10 loe/lisa |
denis28
25.02.2010 14:19:10
ja sellel on vajadust ? krt huvitav palju kaalub
heretic666
25.02.2010 14:57:09
(heh, gta4 ei toeta eyefinity icon_smile.gif )
See on s*tasti optimeeritud konsoolimäng.
| Kommentaarid: 73 loe/lisa |
217 |
Viilutaja
25.02.2010 15:02:30
5830 on küll pettumus. Ei usu, et seal marginaalselt mindagi muutub, isegi kui on draiverite taga praegu. Guru3d.com ülevaates näiteks draiverite kohta küll midagi ei mainitud. Hind võiks olla sinna 2600 kr peale siis võibolla oleks vedu.
_________________ Parim kodukino projektor müügis: https://foorum.hinnavaatlus.ee/viewtopic.php?p=11790090#11790090 |
| Kommentaarid: 226 loe/lisa |
196 |
