uus teema   vasta Tarkvara »  Arvutimängude foorum »  Amnesia: The Dark Descent märgi kõik teemad loetuks
mine lehele 1, 2  järgmine
xpander
xpander
sõnum 20.02.2010 15:47:53 Amnesia: The Dark Descent vasta tsitaadiga
Developer(s):Frictional Games
Engine:HPL2
Platform(s):Microsoft Windows, Linux, Mac OS X
Release date(s):8. September 2010
Genre(s):Graphic adventure, Survival horror
Homepage: http://www.amnesiagame.com/
Uus mäng tulekul Penumbra seeria tegijatelt. Siiliks siis Õudukas-Seiklus. Ehk siis oma õudusunenäos või miskit. füüsika jms nagu ka Penumbra seeriast.
Preorderid hakkasid ka hiljuti, kui 2000 orderit enne 31 mai täis saadakse , siis lubatakes ka lisa contenti. thumbs_up.gif
ingliskeelne kirjeldus kodukalt:
Awake...
Amnesia: The Dark Descent, a first person survival horror. A game about immersion, discovery and living through a nightmare. An experience that will chill you to the core.
You stumble through the narrow corridors as the distant cry is heard.
It is getting closer.
Explore...
Amnesia: The Dark Descent puts you in the shoes of Daniel as he wakes up in a desolate castle, barely remembering anything about his past. Exploring the eerie pathways, you must also take part of Daniel's troubled memories. The horror does not only come from the outside, but from the inside as well. A disturbing odyssey into the dark corners of the human mind awaits.
A sound of dragging feet? Or is your mind playing tricks on you?
Experience...
By using a fully physically simulated world, cutting edge 3D graphics and a dynamic sound system, the game pulls no punches when trying to immerse you. Once the game starts, you will be in control from the beginning to the end. There are no cut-scenes or time-jumps, whatever happens will happen to you first hand.
Something emerges out of the darkness. It's approaching. Fast.
Survive...
Amnesia: The Dark Descent throws you headfirst into a dangerous world where danger can lurk behind every corner. Your only means of defense are hiding, running or using your wits.
Do you have what it takes to survive?
Gameplay video:
Linux Gaming Videos: Xpander69
viimati muutis xpander 25.08.2010 10:24:07, muudetud 1 kord
machoman
machoman
sõnum 21.02.2010 22:49:51 vasta tsitaadiga
Frictional Games'i Penumbra seeria on üks parimaid üldse, seega siit tuleb midagi väga head. Ise hoian end kursis developer'idega lugedes nende blogi http://frictionalgames.blogspot.com/
DeTHiCa.
DeTHiCa.
sõnum 21.02.2010 22:58:35 vasta tsitaadiga
penumbra seeria on jah sitaks hea.
Killer85
sõnum 22.02.2010 18:33:07 vasta tsitaadiga
Päris huvitav mäng paistab olevat. Märgin teema, et oleks meeles hankida.
Heineken
sõnum 23.02.2010 11:34:08 vasta tsitaadiga
Oi kurja , mõni mäng mis tõesti väärt ootamist icon_eek.gif thumbs_up.gif icon_smile.gif .
xpander
xpander
sõnum 06.08.2010 13:05:30 vasta tsitaadiga
väidetavalt järgmine kuu tuleb välja
Link
In preparation for this game's release, which is currently set to premiere on the 8th of September, Frictional Games has released a graphics compatibility test application. This test application, which is available for Windows, Mac OS X, and 32-bit Linux (x86_64 support is coming soon), simply runs a few visual tests of the HPL Engine 2 to produce some screenshots. Frictional Games wants its fans and hopeful customers to run this test application on their system to hopefully spot any engine problems or graphics driver bugs prior to the game's official release.
selle testi vidina saab tirida Siit
margus645
sõnum 06.08.2010 16:48:35 vasta tsitaadiga
Eelnevad Penumbra osad kõik läbi tehtud ning ootan huviga nüüd uut.
tegemist küll uue mänguga kuid ülesehitus tundub videodes sama mis Penumbra seeriates thumbs_up.gif thumbs_up.gif
Kommentaarid: 145 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 127
xpander
xpander
sõnum 25.08.2010 10:22:34 vasta tsitaadiga
vaatasin seda video uuesti mis neil kodukal (olles ise kõrvaklapidega pimedas toas), see ajab ikka judinad peale küll. muusika ja heli on selle mängus ikka väga tasemel. ja see kapist piilumise teema on ka lahe.. arvestades et seal peaks asju liigutada saama vastavalt kuidas sa hiirt liigutad. thumbs_up.gif
Heineken
sõnum 25.08.2010 23:17:25 vasta tsitaadiga
xpander kirjutas:
Tegin sama just... küll ilma kõrvaklappideta.
machoman
machoman
sõnum 30.08.2010 22:33:02 vasta tsitaadiga
http://frictionalgames.blogspot.com/2010/08/we-just-turned-into-gold.html
No nii... mäng on pmst valmis. Väljalaske kuupäev on 8. sept.
Veel üks video gameplay'st
Siin on väheke juttu muusikapoolest Amnesial.
3.0
sõnum 02.09.2010 06:20:39 vasta tsitaadiga
Kas sama firma mis tegi Thief mängu seeria?
MacAivar
sõnum 02.09.2010 08:19:57 vasta tsitaadiga
Eip, Thiefi kaks esimest osa tegi Looking Glass Studios, kolmanda osa tegi Ion Storm, kuhu paljud endised LGS töötajad üle läksid, peale seda kui Looking Glass Studio hingusele läks....
Kommentaarid: 72 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 69
Aah
Aah
sõnum 02.09.2010 09:48:42 vasta tsitaadiga
veso
veso
sõnum 02.09.2010 11:06:01 vasta tsitaadiga
Aah kirjutas:
Jep icon_biggrin.gif Ma saan aru, kui on niisama puzzle, et tõmbad kapid ja värgid ukse ette aga kurat, kui mingi suur elukas samal ajal sulle järgi jookseb, siis lasen küll püksid täis ja ei suuda midagi ette võtta. icon_biggrin.gif
Kommentaarid: 3 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 2
KrisVr
sõnum 04.09.2010 02:57:41 vasta tsitaadiga
Aah kirjutas:
Metro 2033-ga oli juba probleeme.
Kommentaarid: 30 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 27
xpander
xpander
sõnum 04.09.2010 03:23:10 vasta tsitaadiga
Demo on väljas:
http://www.amnesiagame.com/#demo
Nõuded Arvutile:
Heineken
sõnum 04.09.2010 12:03:12 vasta tsitaadiga
Kurat jõhkrat püssi masinat tahab ikka.
margus645
sõnum 04.09.2010 12:40:00 vasta tsitaadiga
Sai ära proovitud.isiklik arvamus on,et Penumbra seeriad olid huvitavamad ning õudsamad.
Graafika on mängus pisut paranenud ning füüsika kaasa arvatud.
Samas ma arvan,et full game on aga siiski ostmist väärt.
xpander
xpander
sõnum 05.09.2010 04:11:15 vasta tsitaadiga
mina rohkem vist mängida ei julge... demos sain küll kerge shoki icon_biggrin.gif
Klapid peas, toas tuli kustus ja see koht kus esimene monster tuli..pidin rabanduse saama...
3.0
sõnum 06.09.2010 16:11:54 vasta tsitaadiga
demo oli küll igav, natuke mängisin nägin mingit kolli ees käimas või zombi taolist jooksin järgi tahtsin pulli teha aga siis järsku silme all haistus lihtsalt ära. No see on tõesti väga õudne icon_lol.gif
xpander
xpander
sõnum 06.09.2010 17:22:41 vasta tsitaadiga
3.0 kirjutas:
kui niisama lampi ringi joosta siis võibolla küll jah..aga kui igat asja loed ja vaikselt ringi luurad siis teine tera. Muidugi ise istud pimedas toas klapid peas ja volume max annab ka päris kõvasti juurde thumbs_up.gif
3.0
sõnum 06.09.2010 17:24:01 vasta tsitaadiga
Kõrvad ei hakka valutama sellest, et nii kõvasti on?
Kas seal mängus on üldse võimalus surma saada?
xpander
xpander
sõnum 06.09.2010 17:40:59 vasta tsitaadiga
3.0 kirjutas:
siis võib veits volume maha võtta, mul integreeritud helikaart ja ei ole heli just väga valju.
surma on küll võimalik saada, ma sain selle kolli käest keda näha polnud aga vee pritsimise järgi nägin et jooksis minu poole, sain paar laksu ja olingi kutu icon_biggrin.gif
Andykas
Andykas
sõnum 08.09.2010 21:58:16 vasta tsitaadiga
Hmm lõpp oli selline, et to be continued...
Ja huvitav mis see seal "The end" all tähendab, mingi devi "easteregg"?
http://www.xfire.com/profile/andykas/screenshots/?view#103885621
Kommentaarid: 25 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 22
3.0
sõnum 08.09.2010 23:45:58 vasta tsitaadiga
Andykas
Andykas
sõnum 09.09.2010 19:54:51 vasta tsitaadiga
zpsy
zpsy
sõnum 10.09.2010 00:11:21 vasta tsitaadiga
Andykas kirjutas:
Kommentaarid: 825 loe/lisa Kasutajad arvavad:  :: 4 :: 1 :: 587
3.0
sõnum 14.09.2010 13:03:16 vasta tsitaadiga
kellelgi juba full ka on?
Evil14
Evil14
sõnum 17.09.2010 11:03:08 vasta tsitaadiga
Ma igatahes ei suuda väga kaua mängida. icon_lol.gif Hirm poeb naha vahele, ausalt. icon_redface.gif
Kommentaarid: 227 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 198
xpander
xpander
sõnum 17.09.2010 11:18:54 vasta tsitaadiga
Ma ei julge osta seda. Ei suuda demo'gi mängida eriti...
Võibolla peaks ilma klappideta ja lambi valgel ikka mängima..siis poles nii hirmus.
Aga Developerit peaks ikka supportima... sest väärt mäng paistab olevat
Evil14
Evil14
sõnum 17.09.2010 12:40:35 vasta tsitaadiga
Soovitan, Developerit tuleb kindlasti supportida, väärt mäng. 9/10 annaks julgelt hindeks. thumbs_up.gif
manraynor
sõnum 17.09.2010 13:06:36 vasta tsitaadiga
Pirasin selle endale et proovida. Kell 2 öösel , täitsa pime ja üksi olla ja kuidas minul tuli siis see Scare factor ikka sisse , kuigi ma alles alguses ( Sain just läbi levelist kus ei tohi vee sees kõndida ).
Kuu alguses kui palga päev siis ma KINDLASTI ostan ära et supportida dev.
Kommentaarid: 15 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 13
486
sõnum 23.09.2010 20:03:25 vasta tsitaadiga
Väga häirb see pidev ähimine ja puhimine ja pilti ka kogu aeg väänatakse nagu mingi veider bug oleks mängul. Sellega on ikka kõvasti ülepingutatud. Penumbras oli seda mõõdukalt ei hakanud nii häirima nagu siin. Mõttetu hirmu peale surumine kohtads, kus ei ole ega toimugi midagi. Ehk poole peal läheb normaalsemaks asi.
zero
Andykas
Andykas
sõnum 23.09.2010 22:30:05 vasta tsitaadiga
Amnesias oleks võinud olla selline soundtrack:
486
sõnum 25.09.2010 21:24:52 vasta tsitaadiga
Vau milline jama võrreldes Penumbraga. Mitte midagi uut. Algusest lõpuni samad kivi tekstuurid, mis mind kohe alguses häirisid. Jubedust ka nagu polnud, sest see sama oli juba Black Plagues. Selles asjas nad ei viitsinud küll midagi uut välja mõelda. Jama ja lühike. thumbs_down.gif
zero
sigakoer
sõnum 04.10.2010 12:43:44 vasta tsitaadiga
http://www.escapistmagazine.com/videos/view/zero-punctuation/2092-Amnesia-The-Dark-Descent
sealt ma ka esimest korda sest mängust kuulsin. Penumbra mänge pole enne mänginud, nii et poleks justkui enne uskunudki, et first-person mäng võiks üldse õudne olla. Tuleb aga välja, et saab nii et vähe pole. Hirmu ja hullumise eriefektid + väga hea helitaust + fakt et ühtegi relva tegelasel kohatavate õuduste vastu ei ole = karm. Raudmats kõige õudsam mäng, mida eales näinud olen. Nendele viiele miinimumpalga eest mängu teha orjanud rootslasele tasub raha välja käia.
nolifer
sõnum 09.10.2010 03:40:10 vasta tsitaadiga
üle pike aja üks hea mäng, mõnus atmosfäär etc, 9/10, keep up good work thumbs_up.gif
sigakoer
sõnum 02.11.2010 16:01:18 vasta tsitaadiga
Kui ise oled korra läbi teinud, siis on lõbus vaadata kuidas teised mängivad ja reageerivad. icon_lol.gif
Üks soomlane on kuskil poole peale jõudnud juba.. ärge vaadake kui ise enne läbi teinud pole: http://www.youtube.com/watch?v=jHqlHoDGkqs
h2rra
sõnum 02.11.2010 16:32:29 vasta tsitaadiga
Ülikõva pela, pick it up.
Araablane
sõnum 10.12.2010 21:59:38 vasta tsitaadiga
See mäng on ikka paras mindfuck aga ei suuda lõpetada mängimist, story edasiandmine tõmbab kogu aeg ennast täis laskma thumbs_up.gif
Andykas
Andykas
sõnum 10.12.2010 22:39:55 vasta tsitaadiga
Steamis praegu 50% odavamalt saadaval ka
Araablane
sõnum 10.12.2010 23:50:31 vasta tsitaadiga
Joppa kolla, ma kinni ühes kohas
[/spoiler]
Flavius
sõnum 28.01.2011 16:26:56 vasta tsitaadiga
Kommentaarid: 126 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 118
realgamer
realgamer
sõnum 29.01.2011 13:01:03 vasta tsitaadiga
Mäng crashib kohe alguses,ei saa tööle. Proovisin demo ka huvipärast ja seegi ei lähe tööle,lööb pildi mustaks ja hangub.
Velociraptor
Velociraptor
sõnum 01.02.2011 00:25:20 vasta tsitaadiga
Ei ole ta midagi nii hirmus.. inimesed nutavad erinevates foorumites, et ei julge enam edasi mängida. Mis on maailmast saanud, kus inimesed ei julge mängu mängida icon_lol.gif
Muidu suht okei mäng.... teistsugune.
🕊 Kuruppo ぽ 🕊
https://www.last.fm/user/Ingvaarr
Kommentaarid: 32 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 30
estplayer
sõnum 19.02.2011 18:44:29 vasta tsitaadiga
Väga hea mäng ikka.. Peaaegu lõpus juba. Kogu aeg on pinge laes thumbs_up.gif Ja mina mõtlesin et Dead Space on õudne icon_biggrin.gif
Kommentaarid: 30 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 26
Evil14
Evil14
sõnum 21.02.2011 03:32:59 vasta tsitaadiga
Dead Space on ka õudne, kuid Amnesias oled sa täiesti sees ja tunned hirmu justkui omal nahal. icon_biggrin.gif Õnneks suutsin lõpuni mängida. Kindlasti soovitan neid mõlemaid mängida pimedas ruumis, üksinda, kas siis kõrvaklappide või 5.1 helisüsteemiga. thumbs_up.gif
Flavius
sõnum 30.10.2011 12:07:24 vasta tsitaadiga
http://store.steampowered.com/app/57300/
Cb4
Cb4
sõnum 30.10.2011 12:27:07 vasta tsitaadiga
Nendele kollidele midagi teha ka saab? Või ongi ainult eest ära põgenemine?
Ei teagi, kas kannatab üldse proovida...pärast olen mingi frukt ja tudisen kuskil nurgas icon_smile.gif
Ma ei ole agressiivne juht, olen lihtsalt võistlushimuline.
Kommentaarid: 113 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 95
Flavius
sõnum 30.10.2011 14:05:52 vasta tsitaadiga
Kollidele ei saa midagi teha, ainult ära joosta nii kaugele kui jõuab ja ära peita. thumbs_up.gif
uus teema   vasta Tarkvara »  Arvutimängude foorum »  Amnesia: The Dark Descent mine lehele 1, 2  järgmine
