xpander
20.02.2010 15:47:53
Amnesia: The Dark Descent |
Developer(s):Frictional Games
Engine:HPL2
Platform(s):Microsoft Windows, Linux, Mac OS X
Release date(s):8. September 2010
Genre(s):Graphic adventure, Survival horror
Homepage: http://www.amnesiagame.com/
Uus mäng tulekul Penumbra seeria tegijatelt. Siiliks siis Õudukas-Seiklus. Ehk siis oma õudusunenäos või miskit. füüsika jms nagu ka Penumbra seeriast.
Preorderid hakkasid ka hiljuti, kui 2000 orderit enne 31 mai täis saadakse , siis lubatakes ka lisa contenti.
ingliskeelne kirjeldus kodukalt:
Awake...
Amnesia: The Dark Descent, a first person survival horror. A game about immersion, discovery and living through a nightmare. An experience that will chill you to the core.
You stumble through the narrow corridors as the distant cry is heard.
It is getting closer.
Explore...
Amnesia: The Dark Descent puts you in the shoes of Daniel as he wakes up in a desolate castle, barely remembering anything about his past. Exploring the eerie pathways, you must also take part of Daniel's troubled memories. The horror does not only come from the outside, but from the inside as well. A disturbing odyssey into the dark corners of the human mind awaits.
A sound of dragging feet? Or is your mind playing tricks on you?
Experience...
By using a fully physically simulated world, cutting edge 3D graphics and a dynamic sound system, the game pulls no punches when trying to immerse you. Once the game starts, you will be in control from the beginning to the end. There are no cut-scenes or time-jumps, whatever happens will happen to you first hand.
Something emerges out of the darkness. It's approaching. Fast.
Survive...
Amnesia: The Dark Descent throws you headfirst into a dangerous world where danger can lurk behind every corner. Your only means of defense are hiding, running or using your wits.
Do you have what it takes to survive?
Gameplay video:
_________________ Linux Gaming Videos: Xpander69
viimati muutis xpander 25.08.2010 10:24:07, muudetud 1 kord |
| Kommentaarid: 18 loe/lisa |
16 |
machoman
21.02.2010 22:49:51
| Frictional Games'i Penumbra seeria on üks parimaid üldse, seega siit tuleb midagi väga head. Ise hoian end kursis developer'idega lugedes nende blogi http://frictionalgames.blogspot.com/
DeTHiCa.
21.02.2010 22:58:35
| penumbra seeria on jah sitaks hea.
140 |
Killer85
22.02.2010 18:33:07
| Päris huvitav mäng paistab olevat. Märgin teema, et oleks meeles hankida.
| Kommentaarid: 69 loe/lisa |
67 |
Heineken
23.02.2010 11:34:08
Oi kurja , mõni mäng mis tõesti väärt ootamist .
| Kommentaarid: 24 loe/lisa |
23 |
xpander
06.08.2010 13:05:30
väidetavalt järgmine kuu tuleb välja
Link
| In preparation for this game's release, which is currently set to premiere on the 8th of September, Frictional Games has released a graphics compatibility test application. This test application, which is available for Windows, Mac OS X, and 32-bit Linux (x86_64 support is coming soon), simply runs a few visual tests of the HPL Engine 2 to produce some screenshots. Frictional Games wants its fans and hopeful customers to run this test application on their system to hopefully spot any engine problems or graphics driver bugs prior to the game's official release. |
selle testi vidina saab tirida Siit
_________________ Linux Gaming Videos: Xpander69 |
16 |
margus645
06.08.2010 16:48:35
Eelnevad Penumbra osad kõik läbi tehtud ning ootan huviga nüüd uut.
tegemist küll uue mänguga kuid ülesehitus tundub videodes sama mis Penumbra seeriates
127 |
xpander
25.08.2010 10:22:34
vaatasin seda video uuesti mis neil kodukal (olles ise kõrvaklapidega pimedas toas), see ajab ikka judinad peale küll. muusika ja heli on selle mängus ikka väga tasemel. ja see kapist piilumise teema on ka lahe.. arvestades et seal peaks asju liigutada saama vastavalt kuidas sa hiirt liigutad.
16 |
Heineken
25.08.2010 23:17:25
| xpander kirjutas: |
vaatasin seda video uuesti mis neil kodukal (olles ise kõrvaklapidega pimedas toas), see ajab ikka judinad peale küll. muusika ja heli on selle mängus ikka väga tasemel. ja see kapist piilumise teema on ka lahe.. arvestades et seal peaks asju liigutada saama vastavalt kuidas sa hiirt liigutad.  |
Tegin sama just... küll ilma kõrvaklappideta.
23 |
machoman
3.0
02.09.2010 06:20:39
| Kas sama firma mis tegi Thief mängu seeria?
MacAivar
02.09.2010 08:19:57
| Eip, Thiefi kaks esimest osa tegi Looking Glass Studios, kolmanda osa tegi Ion Storm, kuhu paljud endised LGS töötajad üle läksid, peale seda kui Looking Glass Studio hingusele läks....
| Kommentaarid: 72 loe/lisa |
69 |
Aah
02.09.2010 09:48:42
Ei , mina seda küll ei mängi. Mul ei pea närv vastu
| Kommentaarid: 21 loe/lisa |
21 |
veso
02.09.2010 11:06:01
| Aah kirjutas: |
Ei , mina seda küll ei mängi. Mul ei pea närv vastu  |
Jep Ma saan aru, kui on niisama puzzle, et tõmbad kapid ja värgid ukse ette aga kurat, kui mingi suur elukas samal ajal sulle järgi jookseb, siis lasen küll püksid täis ja ei suuda midagi ette võtta.
KrisVr
04.09.2010 02:57:41
| Aah kirjutas: |
Sama siin!
Metro 2033-ga oli juba probleeme.
| Kommentaarid: 30 loe/lisa |
xpander
16 |
Heineken
04.09.2010 12:03:12
| Kurat jõhkrat püssi masinat tahab ikka.
23 |
margus645
04.09.2010 12:40:00
Sai ära proovitud.isiklik arvamus on,et Penumbra seeriad olid huvitavamad ning õudsamad.
Graafika on mängus pisut paranenud ning füüsika kaasa arvatud.
Samas ma arvan,et full game on aga siiski ostmist väärt.
127 |
xpander
05.09.2010 04:11:15
mina rohkem vist mängida ei julge... demos sain küll kerge shoki
Klapid peas, toas tuli kustus ja see koht kus esimene monster tuli..pidin rabanduse saama...
16 |
3.0
06.09.2010 16:11:54
demo oli küll igav, natuke mängisin nägin mingit kolli ees käimas või zombi taolist jooksin järgi tahtsin pulli teha aga siis järsku silme all haistus lihtsalt ära. No see on tõesti väga õudne
xpander
06.09.2010 17:22:41
| 3.0 kirjutas: |
demo oli küll igav, natuke mängisin nägin mingit kolli ees käimas või zombi taolist jooksin järgi tahtsin pulli teha aga siis järsku silme all haistus lihtsalt ära. No see on tõesti väga õudne  |
kui niisama lampi ringi joosta siis võibolla küll jah..aga kui igat asja loed ja vaikselt ringi luurad siis teine tera. Muidugi ise istud pimedas toas klapid peas ja volume max annab ka päris kõvasti juurde
16 |
3.0
06.09.2010 17:24:01
Kõrvad ei hakka valutama sellest, et nii kõvasti on?
Kas seal mängus on üldse võimalus surma saada?
xpander
06.09.2010 17:40:59
| 3.0 kirjutas: |
Kas seal mängus on üldse võimalus surma saada? |
siis võib veits volume maha võtta, mul integreeritud helikaart ja ei ole heli just väga valju.
surma on küll võimalik saada, ma sain selle kolli käest keda näha polnud aga vee pritsimise järgi nägin et jooksis minu poole, sain paar laksu ja olingi kutu
16 |
Andykas
| Kommentaarid: 25 loe/lisa |
22 |
3.0
08.09.2010 23:45:58
Ok, ma magama, soovige mulle õnne ja häid unenägusi
Andykas
09.09.2010 19:54:51
22 |
zpsy
10.09.2010 00:11:21
| Andykas kirjutas: |
ilus naeratus
| Kommentaarid: 825 loe/lisa |
587 |
3.0
14.09.2010 13:03:16
| kellelgi juba full ka on?
Evil14
| Kommentaarid: 227 loe/lisa |
198 |
xpander
17.09.2010 11:18:54
Ma ei julge osta seda. Ei suuda demo'gi mängida eriti...
Võibolla peaks ilma klappideta ja lambi valgel ikka mängima..siis poles nii hirmus.
ma vist liiga nõrk selliste mängude jaoks
Aga Developerit peaks ikka supportima... sest väärt mäng paistab olevat
16 |
Evil14
17.09.2010 12:40:35
Soovitan, Developerit tuleb kindlasti supportida, väärt mäng. 9/10 annaks julgelt hindeks.
198 |
manraynor
17.09.2010 13:06:36
Pirasin selle endale et proovida. Kell 2 öösel , täitsa pime ja üksi olla ja kuidas minul tuli siis see Scare factor ikka sisse , kuigi ma alles alguses ( Sain just läbi levelist kus ei tohi vee sees kõndida ).
Kuu alguses kui palga päev siis ma KINDLASTI ostan ära et supportida dev.
Horror fannidele on see väärt mäng
| Kommentaarid: 15 loe/lisa |
486
23.09.2010 20:03:25
Väga häirb see pidev ähimine ja puhimine ja pilti ka kogu aeg väänatakse nagu mingi veider bug oleks mängul. Sellega on ikka kõvasti ülepingutatud. Penumbras oli seda mõõdukalt ei hakanud nii häirima nagu siin. Mõttetu hirmu peale surumine kohtads, kus ei ole ega toimugi midagi. Ehk poole peal läheb normaalsemaks asi.
_________________ zero |
| Kommentaarid: 46 loe/lisa |
39 |
Andykas
23.09.2010 22:30:05
Amnesias oleks võinud olla selline soundtrack:
22 |
486
25.09.2010 21:24:52
Vau milline jama võrreldes Penumbraga. Mitte midagi uut. Algusest lõpuni samad kivi tekstuurid, mis mind kohe alguses häirisid. Jubedust ka nagu polnud, sest see sama oli juba Black Plagues. Selles asjas nad ei viitsinud küll midagi uut välja mõelda. Jama ja lühike.
39 |
sigakoer
04.10.2010 12:43:44
Zero Punctuationi arvustus
http://www.escapistmagazine.com/videos/view/zero-punctuation/2092-Amnesia-The-Dark-Descent
sealt ma ka esimest korda sest mängust kuulsin. Penumbra mänge pole enne mänginud, nii et poleks justkui enne uskunudki, et first-person mäng võiks üldse õudne olla. Tuleb aga välja, et saab nii et vähe pole. Hirmu ja hullumise eriefektid + väga hea helitaust + fakt et ühtegi relva tegelasel kohatavate õuduste vastu ei ole = karm. Raudmats kõige õudsam mäng, mida eales näinud olen. Nendele viiele miinimumpalga eest mängu teha orjanud rootslasele tasub raha välja käia.
| Kommentaarid: 40 loe/lisa |
39 |
nolifer
09.10.2010 03:40:10
üle pike aja üks hea mäng, mõnus atmosfäär etc, 9/10, keep up good work
| Kommentaarid: 8 loe/lisa |
sigakoer
02.11.2010 16:01:18
Kui ise oled korra läbi teinud, siis on lõbus vaadata kuidas teised mängivad ja reageerivad.
Üks soomlane on kuskil poole peale jõudnud juba.. ärge vaadake kui ise enne läbi teinud pole: http://www.youtube.com/watch?v=jHqlHoDGkqs
39 |
h2rra
02.11.2010 16:32:29
| Ülikõva pela, pick it up.
| Kommentaarid: 4 loe/lisa |
Araablane
10.12.2010 21:59:38
See mäng on ikka paras mindfuck aga ei suuda lõpetada mängimist, story edasiandmine tõmbab kogu aeg ennast täis laskma
28 |
Andykas
10.12.2010 22:39:55
| Steamis praegu 50% odavamalt saadaval ka
22 |
Araablane
28 |
Flavius
28.01.2011 16:26:56
Päris mõnus mäng pimedatel õhtutel.
118 |
realgamer
29.01.2011 13:01:03
Mäng crashib kohe alguses,ei saa tööle. Proovisin demo ka huvipärast ja seegi ei lähe tööle,lööb pildi mustaks ja hangub.
Paljudel on täpselt sama jama
_________________ .............................................................................................................................................................. |
| Kommentaarid: 7 loe/lisa |
Velociraptor
01.02.2011 00:25:20
Ei ole ta midagi nii hirmus.. inimesed nutavad erinevates foorumites, et ei julge enam edasi mängida. Mis on maailmast saanud, kus inimesed ei julge mängu mängida
Muidu suht okei mäng.... teistsugune.
_________________ 🕊 Kuruppo ぽ 🕊
https://www.last.fm/user/Ingvaarr |
| Kommentaarid: 32 loe/lisa |
30 |
estplayer
19.02.2011 18:44:29
Väga hea mäng ikka.. Peaaegu lõpus juba. Kogu aeg on pinge laes Ja mina mõtlesin et Dead Space on õudne
26 |
Evil14
21.02.2011 03:32:59
Dead Space on ka õudne, kuid Amnesias oled sa täiesti sees ja tunned hirmu justkui omal nahal. Õnneks suutsin lõpuni mängida. Kindlasti soovitan neid mõlemaid mängida pimedas ruumis, üksinda, kas siis kõrvaklappide või 5.1 helisüsteemiga.
198 |
Flavius
118 |
Cb4
30.10.2011 12:27:07
Nendele kollidele midagi teha ka saab? Või ongi ainult eest ära põgenemine?
Ei teagi, kas kannatab üldse proovida...pärast olen mingi frukt ja tudisen kuskil nurgas
_________________ Ma ei ole agressiivne juht, olen lihtsalt võistlushimuline.
Did i ever tell you the definition of "Insanity"? |
| Kommentaarid: 113 loe/lisa |
95 |
Flavius
30.10.2011 14:05:52
Kollidele ei saa midagi teha, ainult ära joosta nii kaugele kui jõuab ja ära peita.
118 |
