uus teema   vasta Hinnavaatlus »  Microsoft »  Windows 7 (arutelu ja probleemid) märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 198, 199, 200 ... 372, 373, 374  järgmine
sõnum 20.02.2010 20:41:12 vasta tsitaadiga
1dumbpcuser kirjutas:
Report: Most Windows 7 PCs Max Out RAM, Choke
Computerworld
Most Windows 7 PCs max out their memory, resulting in performance bottlenecks, a researcher said today.
Citing data from Devil Mountain Software's community-based Exo.performance.network (XPnet), Craig Barth, the company's chief technology officer, said that new metrics reveal an unsettling trend. On average, 86% of Windows 7 machines in the XPnet pool are regularly consuming 90%-95% of their available RAM, resulting in slow-downs as the systems were forced to increasingly turn to disk-based virtual memory to handle tasks.
Nende andmed on BS.Nad arvestavad: Superfetchi poolt cachetud RAM=suvalise programmi kasutatud RAM
So it was little surprise that, upon checking my reported stats on XPnet, I found that I too was in the "alarming" position of having virtually no free memory. A quick glance at Task Manager revealed the truth. Though my "free" memory is indeed negligible, this is because so much is used by cache. The important number is not "free," but "available." The "available" memory includes both memory that is free, and memory that can be trivially made available, and this figure is far more representative of the true amount of memory available to applications. The vast majority of cached memory can be freed up near-instantly, since it is used up merely by cached data from disk.
http://arstechnica.com/microsoft/news/2010/02/behind-the-windows-7-memory-usage-scaremongering.ars
liiv
liiv
sõnum 20.02.2010 21:25:57 vasta tsitaadiga
selline mure, oma mp3 failide detailset infot näen Vistaga ideaalselt.
WIN7 all, seal kus on kiri"Contributing Artist", peaks olema sama detailne info näha olema aga tühjus. Olen näppinud "more optionsite" all list, details jne. aga ikkagi infot ei kuvata. Kuidas see detailne info saada?
sõnum 20.02.2010 21:41:25 vasta tsitaadiga
liiv kirjutas:
Huvitav mul on küll kenasti iga faili juures kirjas.Seega ilmselt miski sinu enda bug.Kas see oli kohe pärast Win7 installi või tekkis alles nüüd?
Tegelikult asi mis mind väga häirib Win7 detailivaate puhul (pean silmas kui liigutad kursori faili peale ja näitab infot), on see et kui kaustas on nt 1 fail siis tee või tina aga infot ei näita icon_mad.gif .Samas kui 2 või rohkem siis näitab icon_rolleyes.gif
Laurman
Laurman
sõnum 20.02.2010 22:03:49 vasta tsitaadiga
Proovi, folderil paremklikk -> properties -> customize -> Optimize folder for: Music
tqz
tqz
sõnum 22.02.2010 15:26:52 vasta tsitaadiga
Probleem: tehes millestki screenshotti (nt brauseriaknast), siis hiljem Painti paste'des tuleb sinna ainult suur must kast. Vahet pole kas vajutada lihtsalt PrintScreen või Alt+Printscreen, see mis hiljem Painti ilmub on ikka kõik must. Sama probleem on ka Snipping Tooli kasutades. Kord aitas restart - peale restarti sai ühe screenshoti teha, teist korda proovides oli jälle kõik must. Alati ei aita ka restart.
Oskab keegi öelda, milles võib viga olla? Tegu on 64-bitise Windows 7 Professionaliga. Pole minu arvuti (ma pole üldse selle arvuti juureski), seega ei oska detailsemalt eriti midagi öelda. Googeldamisega midagi asjalikku ei leidnud.
sõnum 22.02.2010 15:44:52 vasta tsitaadiga
tqz kirjutas:
Vb vaja graafikadriveritest midagi sättida.Mingi Overlay vms asi.Ei tea pole endal esinenud kunagi aga nt meediapleierites vahel esinev probleem.
Kas see või siis on clipboard funktsioon katki.Kas teksti kopeerimine jms toimib?
Safe Mode-s sama kala?
Q.
Q.
sõnum 22.02.2010 21:19:57 vasta tsitaadiga
mteachx kirjutas:
Tegemit laptopiga.
Sain ta nüüd kätte ka, vaatasin ka, et see laadimis ikoon, tollel on laadija taga, laeb aga X on punaselt siiski peal.
Võttes laadija tagant ära, aku peab ilusti, kuid X on ikka peal, justkui kohe otsa lõppemas.
Aku tagant võttes ja aku peale pannes jääb see X alles, kuid patarei taha peitu, niiet servi ainult näha.
Ilmselt on juhuse kokkulangemisega ja kuskil riistvaraline viga siiski sees.
Mõtlema nüüd ainult, mis edasi, garantiise võib-olla laskma saata..
See punane X ja probleemid akuga peaksidki olema Win7 jamad. Mikropehme poisid on sellest teadlikud ning parandavad viga.
Look Right
Anna vin
Look Right
sõnum 22.02.2010 21:34:08 vasta tsitaadiga
Mul ka teinekord näitab seda punast X, kui laadija uuesti taha ühendan. Varsti kaob ära. Kuid aku vastupidavus on võrreldes XPga samaks jäänud. Miski 4h pigistab välja.
Look Right
Anna vin
Look Right
sõnum 23.02.2010 11:03:54 vasta tsitaadiga
Ehk et said TÜ käest omale icon_biggrin.gif. Lihtsalt installi ära, mitte ära upgrade. Andmed hoitakse alles, kuid proged pead uuesti installima.
kristjan07
sõnum 23.02.2010 19:18:04 vasta tsitaadiga
On ka teisi kohti kes on Microsofti sõbrad icon_wink.gif Sa räägid clean installist või mis?
sa pole hea seni, kuni sa teisi paremaks ei tee
Look Right
Anna vin
Look Right
sõnum 23.02.2010 19:26:44 vasta tsitaadiga
clean install jah...
RaPTiLE
RaPTiLE
sõnum 24.02.2010 16:13:30 vasta tsitaadiga
Sai tehtud clean install, et kõik maha ja siis 7 peale.
Aga starupil pakub OS'e valida.
Earlier version of windows või windows 7
Kust ja mida ma kustutama pean et automaatselt 7 käima läheks.
Kõvaketas on tehtud kaheks. Ühel on Windows 7 ja teisel on niisama failid.
sõnum 24.02.2010 17:06:49 vasta tsitaadiga
RaPTiLE kirjutas:
Kasuta http://neosmart.net/downloads/software/EasyBCD/EasyBCD%201.7.2.exe ja kustuta vana kirje maha thumbs_up.gif
Hardi
Hardi
sõnum 24.02.2010 18:29:16 vasta tsitaadiga
või siis sealtkohast näppida
siimi
siimi
sõnum 24.02.2010 20:47:45 vasta tsitaadiga
lasin peale uued ati 10.2 driverid ja nüüd experience index video poole pealt on väiksem kui varem, milles võib asi olla?..kaart muidu 5850
Slazenger
Slazenger
sõnum 25.02.2010 00:49:27 vasta tsitaadiga
oeh küll ajab see win 7 sita keema .. lasin täna originaal ultimate peale ja kõigepealt paneb chrome olemasolu arvuti hanguma, siis media player classic jnejne. enne beta buildiga ei olnud kordagi sellist jama, no tõesti on see minu jaoks arusaamatu kuidas niimoodi saab thumbs_down.gif
keegi oskab mulle seletada, kuidas leida põhjust miks arvuti nii hangub ? ma media player classicuga enam mingit seost ei leia .. vaatasin just uuemat 720p losti ja poole video pealt lihtsalt hangub video (koos heliga) ja ainult restart aitab. oleks tänulik abi eest thumbs_up.gif
NATAS999
sõnum 25.02.2010 01:11:23 vasta tsitaadiga
äkki läks installiga midagi sassi?
lasid ikka puhta ketta peale windowsi? ei mõtle mitte formatitud partitsiooni, vaid tervet ketast ikka.
"Kuidas on see hea?"
-Auto kirurgia kliinik
Slazenger
Slazenger
sõnum 25.02.2010 02:23:18 vasta tsitaadiga
NATAS999, lasin enne installi terve ketta puhtaks jah, olen lugenud nüüd netis igasuguseid asju ja tundub et seda anomaaliat esineb ikka väga palju.. icon_rolleyes.gif
edit: tegin uuesti puhta installi, kohe alguses peale wifi kaardi driverite installi kiilus kinni kogu süsteem icon_eek.gif
-KRANTS-
vitamiinidiiler
-KRANTS-
sõnum 25.02.2010 09:19:13 vasta tsitaadiga
naljakas lugu on see, et eile lasin ühele FS Amilole win 7 peale. Korduvalt. Ükski kord ei andnud võimalust ketast formaatida ja clean installi teha. Nüüd siis kaks windows.old kausta, mida kustutama asusin... Oskab keegi öelda, miks formatit teha ei lasknud? Tuli see ketta koht installi käigus küll ette, aga seal polnud muud valikut kui refresh ja next. Ketas ise 60GB kui sellest nüüd miskit sõltub icon_rolleyes.gif
Partitsioone polnud plaaniski nii väiksele kettale teha, aga ka seda valikut ei olnud.
Ühendust saab siin: https://www.facebook.com/groups/1953700414852281/
sõnum 25.02.2010 09:28:58 vasta tsitaadiga
random pilt internetist:
- londiste
-KRANTS-
vitamiinidiiler
-KRANTS-
sõnum 25.02.2010 09:43:06 vasta tsitaadiga
sellise pildiga oleks ok olnud. Aga mul oli seal ainult üks ketas, refresh, load driver ja NEXT. muud ei miskit.
KrisVr
sõnum 25.02.2010 09:54:35 vasta tsitaadiga
KIVIKUJU kirjutas:
Panid algul ikka Custom install mitte upgrade?
-KRANTS-
vitamiinidiiler
-KRANTS-
sõnum 25.02.2010 10:39:42 vasta tsitaadiga
panin.
Nüüd mure ka selles, et peale Win7 installi Fujitsu Siemens Amilo läpparile, ei hakka wifi tööle icon_eek.gif Sellel läpakal käib wifi adapteri lülitus manuaalselt nupust, kuid ei mingit reaktsiooni. Kõik Win7 updated tehtud ja wireless adapter on "up to date", aga ikka ei miskit. OSkab keegi kommenteerida? Ja kui see toimima hakkab siis, kas seda annab ka nii seadistada, et see automaatselt tööle läheks arvutit sisse lülitades? icon_rolleyes.gif
Renka
Renka
sõnum 25.02.2010 10:41:47 vasta tsitaadiga
Nonii - nüüd oleks tarka abi vaja.
Olemasolev süstem on XP 32bit ja tahaks nüüd W7 64bit peale üle minna. Aga kuidas?
Upgrade ju niipidi ei toiminud minuarust?
Kas tõesti peab tegema puhta installi ja ka kõik aastatega kogunenud kola manuaalselt uuesti installima ja üle tooma? See variant väga ei lähe - siis jään pigem edasi XP'd kasutama.
Või on mingi mugav lahendus?
1dumbpcuser
sõnum 25.02.2010 10:48:05 vasta tsitaadiga
KIVIKUJU kirjutas:
panin.
Nüüd mure ka selles, et peale Win7 installi Fujitsu Siemens AMILO läpparile, ei hakka wifi tööle icon_eek.gif Sellel läpakal käib wifi adapteri lülitus manuaalselt nupust, kuid ei mingit reaktsiooni. Kõik Win7 updated tehtud ja wireless adapter on "up to date", aga ikka ei miskit. OSkab keegi kommenteerida? Ja kui see toimima hakkab siis, kas seda annab ka nii seadistada, et see automaatselt tööle läheks arvutit sisse lülitades? icon_rolleyes.gif
Kas sel nupul ka mingi draiver või utiliit on? Installi siis ka see (nt oma Ordi läpparil on Wireless Select Switch nimeline asi vaja installida enne kui saab wihvit või sinihammast kasutada)
M: MSI B660M MORTAR
M: Dell RTX 2060
O: AM5 ITX emaplaat
-KRANTS-
vitamiinidiiler
-KRANTS-
sõnum 25.02.2010 10:51:13 vasta tsitaadiga
1dumbpcuser, Kust ma tean, kas sellel mingit utiliiti vaja on? Driverid kõik ju uuendatud. Tegemist Amilo L1310G mudeliga. On võimalik, et saab ka netist utiliiti, kui selline asi vajalik on?
1dumbpcuser
sõnum 25.02.2010 11:07:18 vasta tsitaadiga
Kas installisid siis tutikale läpparile W7 peale, enne xp-d vms peal polnud?
Vaata Device Managerist, kas wifi kaardi tunneb ära ja siis võid FuSi kodulehelt ka otsida.
EDIT: google otsing: link
M: MSI B660M MORTAR
M: Dell RTX 2060
O: AM5 ITX emaplaat
viimati muutis 1dumbpcuser 25.02.2010 11:08:27, muudetud 1 kord
Renka
Renka
sõnum 25.02.2010 11:08:07 vasta tsitaadiga
No ma võin teha ka clean installi juhul ku ikergelt saaks ka kõikvõimaliku softi ja dokud üle tuua.
Dokudega lihtne aga erineva softiga läheb jamaks. Isegi nende uuesti installimine ei ole võibolla kõige suurem probleem. Hullem on see, et asjad on aastatega meelepäraseks seadistatud ja uuesti kõike küll tegema hakata ei viitsi.
-KRANTS-
vitamiinidiiler
-KRANTS-
sõnum 25.02.2010 11:27:58 vasta tsitaadiga
enne oli XP peal. Device managerist leiab kaardi.
lauripoiss
sõnum 25.02.2010 12:00:17 vasta tsitaadiga
Sellise lingi leidsin täna ... http://www.digitark.ee/?p=2448#more-2448
olafsand
olafsand
sõnum 25.02.2010 12:05:32 vasta tsitaadiga
KIVIKUJU, lülitile tuleb ka vast ikkagi driver otsida. Nagu eespool mainitud, siis Ordi läpakatel on lülitile eraldi driver.
sõnum 25.02.2010 12:32:18 vasta tsitaadiga
Krt kas seda windows updatet ei anna nii seadistada et installib ära vms aga iseseisvalt restardile ei läheks. Krt öösel oli vapralt resale läinud ja seetõttu 4,5 tundi video encodemist jälle metsas.
sõnum 25.02.2010 12:33:20 vasta tsitaadiga
salatoimik kirjutas:
Renka
Renka
sõnum 25.02.2010 12:40:22 vasta tsitaadiga
tomorrow kirjutas:
icon_rolleyes.gif See ei ole ju lahendus
sõnum 25.02.2010 13:01:17 vasta tsitaadiga
Renka kirjutas:
tomorrow kirjutas:
Miks mitte?.Järgi testitud ja toimib.WU Start/Stop võib ka lihtsa .cmd failina töölauale salvestada kui vaja näiteks hommikul uuesti käima tõmmata thumbs_up.gif
sõnum 25.02.2010 13:26:07 vasta tsitaadiga
Renka, enamus programme peaks oma sätted salvestama kenasti application data ja local settings\application data kaustadesse. Sealt üle kopeerides Win7'sse AppData\Roaming ja AppData\Local kaustadesse (vastavalt) peaksid saama enamus programme samade sätetega tööle.
sõnum 25.02.2010 13:48:21 vasta tsitaadiga
group policy.
computer configuration > administrative templates > windows components > windows update > no auto-restart with logged on users for scheduled automatic updates installations
- londiste
Kaarta
sõnum 25.02.2010 14:12:13 vasta tsitaadiga
see aitab kah : http://code.google.com/p/shutdownguard/
-KRANTS-
vitamiinidiiler
-KRANTS-
sõnum 25.02.2010 18:44:53 vasta tsitaadiga
olafsand kirjutas:
tundub nii. leidsin isegi mingi draiverite plaadi üles, mis arutiga kaasas, aga nüüd kisab mingit "ActiveX registration errorit" icon_evil.gif Kuidasma sellest lahti saan? Mitu tundi juba jauranud sellega icon_confused.gif
sõnum 25.02.2010 18:50:42 vasta tsitaadiga
londiste kirjutas:
group policy.
Pead silmas Local Group Policy (gpedit.msc)?
Siis kahjuks see asi mul puudub (win 7 home premiumil sellist asja pole-nagu netis urgitsedes silma jäi)
Aga see järgmise posti asi kõlbab kh (vähemalt loodan). Peaasi et iseseisvalt ei läheks.
mteachx
mteachx
sõnum 25.02.2010 23:23:24 vasta tsitaadiga
Win update panna käsitsi installimise peale, ei kurda ühtegi muret resaga nii..
Harjunud ja kasutanud aastaid seda meetodi nii XP'l, kui nüüd W7'l..
Või saan teemast valesti natuke aru..?!
SisNok OÜ
- Sinu isiklik nutipartner
Hollow
Hollow
sõnum 26.02.2010 12:27:24 vasta tsitaadiga
ei, ainult ühte
heretic666
heretic666
sõnum 26.02.2010 16:32:11 vasta tsitaadiga
Kust kuradi kohast ma saan selle lollaka popupi kinni keerata, et iga kord kui mingit setupi vms runnin, ei küsiks üle "Are you sure to run this blahblahblah"?
sõnum 26.02.2010 17:14:27 vasta tsitaadiga
heretic666 kirjutas:
Start -> Change User Account Control settings
heretic666
heretic666
sõnum 26.02.2010 17:27:27 vasta tsitaadiga
Ammu proovitud, UAC kinnikeeramine mööda toda slide riba ei aita.
Nihukene ta on sis:
Kui see linnukene sealt checkboxist eemaldada, siis see kehtib ainult selle ühe ja sama antud olukorra faili kohta, mitte nüüd iga järgneva .exe puhul.
sõnum 26.02.2010 17:47:27 vasta tsitaadiga
Nihukene ta on sis:
heretic666
heretic666
sõnum 26.02.2010 17:57:57 vasta tsitaadiga
Täitsa kasutajasõbralikus kohas saab muuta seda thumbs_up.gif Tänud lahenduse eest.
Dude .
sõnum 26.02.2010 22:23:50 vasta tsitaadiga
Plaanin minna RC't täisversioonile. Nagu ma aru saan, siis ei saa üle lasta nii, et kõik töötab edasi (mõlema puhul x64). Aga mis teema selle windows.old asjaga on? Kas oleks mõttekas teha täis format või jätta asjad sinna folderisse alla (ehk kas sellel võib olla halbu tagajärgi?)?
TALUSILDID
NATAS999
sõnum 26.02.2010 23:06:27 vasta tsitaadiga
windows.old peaks olema ainult backup vanast OS'st. uue wini jaoks seal imho midagi kasulikku küll ei ole.
Look Right
Anna vin
Look Right
sõnum 26.02.2010 23:07:34 vasta tsitaadiga
Windows.old folderist saad oma oma mussi, dokumendid jne kätte, kui varasemalt pole kuhugi varunud. Kopid sealt uutesse kaustadesse ning siis ülejäänu võid ära kustutada.
uus teema   vasta Hinnavaatlus »  Microsoft »  Windows 7 (arutelu ja probleemid) mine lehele eelmine  1, 2, 3 ... 198, 199, 200 ... 372, 373, 374  järgmine
