FurattoShutsuryoku
10.11.2009 12:59:41
| Kommentaarid: 38 loe/lisa |
36 |
mustiCas
11.11.2009 17:59:57
Üks parimaid
| Kommentaarid: 26 loe/lisa |
24 |
Kassmees
| Kommentaarid: 59 loe/lisa |
46 |
jkddp
02.12.2009 21:40:39
õudne probleem - rongijuht tegi ise nalja ja siis pildistas seda
_________________ Kui vaja joonistada/saagida/hööveldada midagi, võib alati küsida  |
| Kommentaarid: 64 loe/lisa |
62 |
03.12.2009 13:54:24
Pole küll naljakas error, aga "imelik" igatahes. ID-kaardi tarkvara installeerimisel saadud veateade. Mis kuradi diski mul selle ID-kaardi tarkvara jaoks vaja peaks olema?
| Kommentaarid: 762 loe/lisa |
571 |
RustyZ
10.12.2009 01:51:38
Google Wave ütles täna:
"This wave is experiencing some slight turbulence, and may explode. If you don't wanna explode, please re-open the wave. Some recent changes may not be saved."
Selle peale peab küll klaasid tõstma!
_________________ Wreckfest 2 server: 136.243.70.252:30102 | parool: isamaa (kui on enabled) |
| Kommentaarid: 16 loe/lisa |
dzombe
10.12.2009 10:17:18
Vat selline viga siis:
Event Type: Warning
Event Source: Software Installation
Event Category: None
Event ID: 119
Date: 9.12.2009
Time: 14:48:01
User: N/A
Computer: XXX
Description:
Software Installation encountered an unexpected error while reading from the MSI file \\SERVER\Install\Adobe\Flash Player\v10\install_flash_player_10_active_x_1004234.msi. The error was not serious enough to justify halting the operation. The following error was encountered: The operation completed successfully.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 00 00 00 00 ....
_________________ -- |
apelsin16
13.12.2009 23:11:16
ma tahtsin lihtsalt bootivat usb pulka teha milleks mulle esivedu vaja on
| Kommentaarid: 63 loe/lisa |
57 |
Q.
| Kommentaarid: 12 loe/lisa |
sama123
26.12.2009 01:56:31
Olen kuulnud lugu,kui väga,väga vana arvutiga mille ketas oli MB-tes laeti kogemata alla viirus....viirus tahtis installeeruda aga arvuti riistvara ei võimaldanud....ja viirus olla saatnud veateate...
Omal on olnud küll korra kui laadisin alla RAR-i avades ~100 trojani ja ~50 viirust!Arvuti kinni,tahtsin ekraanipilti teha aga midagi ei funganud,niikaua kui fotika leidsin oli sinine ekraan ja muidugi kõik kadunud.Oleks tahtnud arhiivi mälestuseks/hoiatuseks alles hoida.Mäletamist mööda oli kuskilt torrentis "key superpack".
| Kommentaarid: 23 loe/lisa |
22 |
arnis
26.12.2009 08:29:02
| apelsin16 kirjutas: |
ma tahtsin lihtsalt bootivat usb pulka teha milleks mulle esivedu vaja on  |
Tundub, et on kasutatud sõna-sõnalt tõlkimist, võibolla isegi google translate'i
Inglise keeles peaks see kõlama umbes nii, et mälupulgal olev partitsioon on
kasutusel ja seetõttu ei suuda see progra seda lukustada, et formattida vms.
Aga ikka, üsna fail. Parem juba inglise keeles kui see
_________________ Teen kodudes elektriasju korda. 50€/h. Anna murest märku.
Ooteajad hetkel suured (2026 ei võta vastu)
Ka korteriühistud ja ettevõtted. Auditi ettevalmistused. |
117 |
K3891
28.12.2009 21:46:24
Head "EMule!" ka teile!
_________________ lapsesuu: "kui sa surnud oled, siis ei saa sa ise sellest aru, ainult teistel on raske. samamoodi on siis, kui sa loll oled" |
| Kommentaarid: 60 loe/lisa |
49 |
mihhkel
28.12.2009 22:35:33
| KimsSky kirjutas: |
Head "EMule!" ka teile!  |
Keegi on trolli nalja teinud ja "paremat" tõlget soovitanud... sama lause väikse algustähega tõlgitakse "good old end of the year"
_________________ ... |
| Kommentaarid: 25 loe/lisa |
24 |
Mercury
28.12.2009 23:11:30
Dirt2 fail
| Kommentaarid: 61 loe/lisa |
60 |
kaspar00
28.12.2009 23:18:16
mul läppar töötab õhust ja armastusest
102 |
Valvejoodik
15 |
Atheya
08.01.2010 19:10:46
| "Something happened"
| Kommentaarid: 15 loe/lisa |
14 |
Howard
19.01.2010 17:40:15
Server error, aga muidu kõik OK!
67 |
| Kommentaarid: 92 loe/lisa |
synt3r
27.01.2010 17:55:21
Ei ole päris error aga ei oska kuhugi mujale seda panna. Tegin siis arvulile CCleaneriga puhastust ja peale puhastust vaatasin kui palju ebavajalikke faile kustutati siis selgu et see nr on väga suur Siis üleval vasakul nurgas
| Kommentaarid: 22 loe/lisa |
21 |
badtouch
28.01.2010 00:41:17
| synt3r kirjutas: |
Suur sul ketas on ka siis?
21 |
synt3r
28.01.2010 10:08:26
150 GB kettaruumi arvutis rohkem ei ole
21 |
siinus
| Kommentaarid: 70 loe/lisa |
63 |
rewer
04.02.2010 11:30:00
Mida rohkem, seda uhkem- ei kehti alati
| Kommentaarid: 1312 loe/lisa |
922 |
pringi
04.02.2010 19:48:19
rewer, kuidas sul üldse win tööl läks selle panni peal
97 |
pringi
04.02.2010 21:47:38
tomorrow, 2GB rammi ainult ju... Seda on 16 korda vähem, kui nimetatud mäng nõudis, windoosast rääkimata...
97 |
Cb4
04.02.2010 22:16:47
Sarkasm?
Pigem on rami 62,5x rohkem kui mäng nõuab.
_________________ Ma ei ole agressiivne juht, olen lihtsalt võistlushimuline.
Did i ever tell you the definition of "Insanity"? |
| Kommentaarid: 113 loe/lisa |
95 |
badtouch
05.02.2010 00:45:35
| Cb4 kirjutas: |
Sarkasm?
Pigem on rami 62,5x rohkem kui mäng nõuab. |
Pigem 64x.
21 |
windsurfer
17.02.2010 22:42:31
Mul sai üks kõvaketas täna endale uue nime.
vt ide channel 3'me
| Kommentaarid: 42 loe/lisa |
39 |
RedFusion
07.03.2010 04:04:27
Pole küll otseselt error, aga:
Recycle Bin-is oli mingi asi, mida tahtsin kustutada, aga too ei kuvanud seda faili millegipärast. Siis "empty..." klõpsides tuli selline kiri, kuigi sellenimelist faili minu meelest küll prügikastis ei olnud
| Kommentaarid: 8 loe/lisa |
jkddp
08.03.2010 21:15:18
| RedFusion kirjutas: |
Recycle Bin-is oli mingi asi, mida tahtsin kustutada, aga too ei kuvanud seda faili millegipärast. Siis "empty..." klõpsides tuli selline kiri, kuigi sellenimelist faili minu meelest küll prügikastis ei olnud  |
kui mul miski viiruse moodi asi oli siiis pidevalt oli mul ka selline error. Vaata om arvuti üle!
62 |
Eric80
08.03.2010 21:23:57
| Kommentaarid: 31 loe/lisa |
30 |
siinus
09.03.2010 20:59:35
täna nägin sellist asja
edit:
vahepeal selline:
_________________ suck less | no slop grenade
63 |
lokuta
09.03.2010 23:10:02
| windsurfer kirjutas: |
vt ide channel 3'me
kõvaketas kirjutab, mis häält teeb magama
80 |
villu70
20.03.2010 13:03:48
wtf..... windows 7 on masinas
122 |
siinus
20.03.2010 13:31:49
SPTD puudu?
restardi tegid DT installides ikka?
63 |
villu70
20.03.2010 13:38:22
| paar kuud tagasi installitud
122 |
siinus
20.03.2010 13:38:56
siis proovi reinstalli. vajadusel sptd'le
63 |
villu70
20.03.2010 13:40:18
| tegingi reininstalli aga lihtsalt error on jabur
122 |
siinus
20.03.2010 13:42:08
mis seal jaburat, kui sptd on kaduma läind? jabur pigem see, Kuidas see kadus.
63 |
The_Boss
20.03.2010 15:14:39
Mul oli ka daemoniga nii, et andis errori, et peab vähemalt Win XP SP2 peal olema, mul oli peale pandud Win XP Pro SP3
284 |
Valvejoodik
20.03.2010 19:46:32
Pole küll error, aga: >>>Statistika nohikutele<<<
15 |
mihhkel
20.03.2010 21:11:21
| eesti919 kirjutas: |
Paremklõpsa seal tegumihalduri sisemises osas, siis saad sisse lülitada ka teleporditud kitsede arvu näitamise
24 |
Valvejoodik
20.03.2010 21:16:52
| mihhkel kirjutas: |
Paremklõpsa seal tegumihalduri sisemises osas, siis saad sisse lülitada ka teleporditud kitsede arvu näitamise  |
Hmm, mul küll ei paku...
15 |
mihhkel
21.03.2010 02:23:41
24 |
QLIMAX
29.03.2010 19:38:28
Tegin ekaanitõmmise ja paintis salvestades
| Kommentaarid: 32 loe/lisa |
Anna tooli
05.04.2010 10:25:23
nüüd siis tean, kes youtube'is töötavad
300 |
