FurattoShutsuryoku
10.11.2009 12:59:41
Kommentaarid: 38 loe/lisa |
36 |
mustiCas
11.11.2009 17:59:57
Üks parimaid
Kommentaarid: 26 loe/lisa |
24 |
Kassmees
Kommentaarid: 57 loe/lisa |
46 |
jkddp
02.12.2009 21:40:39
õudne probleem - rongijuht tegi ise nalja ja siis pildistas seda
_________________ Kui vaja joonistada/saagida/hööveldada midagi, võib alati küsida  |
Kommentaarid: 64 loe/lisa |
62 |
03.12.2009 13:54:24
Pole küll naljakas error, aga "imelik" igatahes. ID-kaardi tarkvara installeerimisel saadud veateade. Mis kuradi diski mul selle ID-kaardi tarkvara jaoks vaja peaks olema?
Kommentaarid: 729 loe/lisa |
550 |
RustyZ
10.12.2009 01:51:38
Google Wave ütles täna:
"This wave is experiencing some slight turbulence, and may explode. If you don't wanna explode, please re-open the wave. Some recent changes may not be saved."
Selle peale peab küll klaasid tõstma!
_________________ Wreckfest 2 server: 136.243.70.252:30102 | parool: isamaa (kui on enabled) |
Kommentaarid: 16 loe/lisa |
dzombe
10.12.2009 10:17:18
Vat selline viga siis:
Event Type: Warning
Event Source: Software Installation
Event Category: None
Event ID: 119
Date: 9.12.2009
Time: 14:48:01
User: N/A
Computer: XXX
Description:
Software Installation encountered an unexpected error while reading from the MSI file \\SERVER\Install\Adobe\Flash Player\v10\install_flash_player_10_active_x_1004234.msi. The error was not serious enough to justify halting the operation. The following error was encountered: The operation completed successfully.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 00 00 00 00 ....
_________________ -- |
Kommentaarid: 1 loe/lisa |
apelsin16
13.12.2009 23:11:16
ma tahtsin lihtsalt bootivat usb pulka teha milleks mulle esivedu vaja on
Kommentaarid: 63 loe/lisa |
57 |
Q.
Kommentaarid: 12 loe/lisa |
sama123
26.12.2009 01:56:31
Olen kuulnud lugu,kui väga,väga vana arvutiga mille ketas oli MB-tes laeti kogemata alla viirus....viirus tahtis installeeruda aga arvuti riistvara ei võimaldanud....ja viirus olla saatnud veateate...
Omal on olnud küll korra kui laadisin alla RAR-i avades ~100 trojani ja ~50 viirust!Arvuti kinni,tahtsin ekraanipilti teha aga midagi ei funganud,niikaua kui fotika leidsin oli sinine ekraan ja muidugi kõik kadunud.Oleks tahtnud arhiivi mälestuseks/hoiatuseks alles hoida.Mäletamist mööda oli kuskilt torrentis "key superpack".
Kommentaarid: 23 loe/lisa |
22 |
arnis
26.12.2009 08:29:02
apelsin16 kirjutas: |
ma tahtsin lihtsalt bootivat usb pulka teha milleks mulle esivedu vaja on  |
Tundub, et on kasutatud sõna-sõnalt tõlkimist, võibolla isegi google translate'i
Inglise keeles peaks see kõlama umbes nii, et mälupulgal olev partitsioon on
kasutusel ja seetõttu ei suuda see progra seda lukustada, et formattida vms.
Aga ikka, üsna fail. Parem juba inglise keeles kui see
_________________ Teen kodudes elektriasju korda. 40€/h. Anna murest märku.
Ooteajad väiketööd nädala jooksul, päev+ tööd kuu jooksul.
Ka korteriühistud ja ettevõtted. Auditi ettevalmistused. |
Kommentaarid: 120 loe/lisa |
117 |
K3891
28.12.2009 21:46:24
Head "EMule!" ka teile!
_________________ lapsesuu: "kui sa surnud oled, siis ei saa sa ise sellest aru, ainult teistel on raske. samamoodi on siis, kui sa loll oled" |
Kommentaarid: 60 loe/lisa |
49 |
mihhkel
28.12.2009 22:35:33
KimsSky kirjutas: |
Head "EMule!" ka teile!  |
Keegi on trolli nalja teinud ja "paremat" tõlget soovitanud... sama lause väikse algustähega tõlgitakse "good old end of the year"
_________________ ... |
Kommentaarid: 25 loe/lisa |
24 |
Mercury
28.12.2009 23:11:30
Dirt2 fail
Kommentaarid: 61 loe/lisa |
60 |
kaspar00
28.12.2009 23:18:16
mul läppar töötab õhust ja armastusest
Kommentaarid: 113 loe/lisa |
101 |
Valvejoodik
15 |
Atheya
08.01.2010 19:10:46
"Something happened"
Kommentaarid: 15 loe/lisa |
14 |
Howard
19.01.2010 17:40:15
Server error, aga muidu kõik OK!
Kommentaarid: 71 loe/lisa |
67 |
22.01.2010 20:49:42
Kas ma peaksin muretsema nüüd?
Kommentaarid: 92 loe/lisa |
synt3r
27.01.2010 17:55:21
Ei ole päris error aga ei oska kuhugi mujale seda panna. Tegin siis arvulile CCleaneriga puhastust ja peale puhastust vaatasin kui palju ebavajalikke faile kustutati siis selgu et see nr on väga suur Siis üleval vasakul nurgas
Kommentaarid: 22 loe/lisa |
21 |
badtouch
28.01.2010 00:41:17
synt3r kirjutas: |
Suur sul ketas on ka siis?
21 |
synt3r
28.01.2010 10:08:26
150 GB kettaruumi arvutis rohkem ei ole
21 |
siinus
Kommentaarid: 66 loe/lisa |
59 |
03.02.2010 20:57:59
Ehk siis Crash Reporter crashis ega saanud oma crashi kohta crash raportit saata
rewer
04.02.2010 11:30:00
Mida rohkem, seda uhkem- ei kehti alati
Kommentaarid: 1301 loe/lisa |
918 |
