uus teema   vasta Tarkvara »  Arvutimängude foorum »  S.T.A.L.K.E.R.: Call of Pripyat märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 12, 13, 14 ... 22, 23, 24  järgmine
KuriVaiM1
KuriVaiM1
sõnum 24.01.2010 10:37:52 vasta tsitaadiga
* CoP Patch 1.602 Rus
Changes:
- Fixed a bug where the game runs in windowed mode instead of fullscreen.
- Changed parameter tessellation which leads to increased productivity for vysokopoligonalnyh models.
- Fixed bug with removing the dump config when not correctly shows the change in parameters.
- Optimized playback partiklov in the interaction with water. - Fixed bug with mouse button binds.
- Reduced time switching between windows and Windows games.
- Optimized synchronization mechanism of characters on the network (the number of traffic has decreased approximately 3-fold).
- Fixed a bug with the emergence of a dynamic light bulbs with a client with low graphics settings.
- Fixed bug with Kreshem dedicated server when you try to login from the server console.
- Fixed bug with Kreshem in obtaining, or screenshot config dump at losses in the network.
- Removed the possibility for auto-shooting Bulldogs or grenade launchers.
- Fixed a crash after a long game (in single player).
- Added functionality of a dedicated server in which the statistics of players have saved some time after the shut-off (console command sv_client_reconnect_time).
- Remote Administration menu displays the correct value of max ping limit.
- Removed the automatic switching to the best weapon in the inventory after the lifting of the artifact in multiplayer.
- Fixed a bug with the appearance of rifle grenades in underbarrel grenade.
- Fixed bug with transfer profile.
- Improved the quality of dynamic shadows.
- Fixed numerous flights in the multiplayer.
- Improved system to combat cheaters.
- Change the speed of the character height of his jump and control during flight.
- Changed the characteristics of certain types of weapons.
- Fixed a crash with the message "No available phrase to say, dialog [zat_b30_owl_stalker_trader_start_dialog]".
- Fixed a crash with the message "No available phrase to say, dialog [about_quests_dialog_stalkers]".
- Fixed hang before you talk with Kowalski after leaving the laboratory x8.
- Improved support for integrated graphics Intel GMA G43/45 and above.
icon_arrow.gif "Mõtle kriitiliselt"
Kommentaarid: 68 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 63
python
sõnum 28.01.2010 13:17:46 vasta tsitaadiga
Kui tunnelist välja tulla Pripyati crashib loadimisel mäng iga kord. Kas selle vastu mingit rohtu ka leidub?
Valvejoodik
Valvejoodik
sõnum 28.01.2010 13:19:57 vasta tsitaadiga
Patchid peal?
python
sõnum 28.01.2010 13:24:39 vasta tsitaadiga
English translation 1.0 ja Carry max 75kg. Kuskilt jäi silma, et sellel vene keelsel ongi selline bug?
Valvejoodik
Valvejoodik
sõnum 28.01.2010 13:29:48 vasta tsitaadiga
ma mõtlen, et kas 1.602 vene patch on peal?
See, millele Kurivaim1 vihjas.
python
sõnum 28.01.2010 21:12:15 vasta tsitaadiga
Ei, see jäi märkamata..Tänud!
eesti919 kirjutas:
kuidas selle install, see ei tundu nagu funkavat?
Satakas
Satakas
sõnum 28.01.2010 21:26:55 vasta tsitaadiga
python kirjutas:
KA selles mängus aitab taoliste asjade vastu see kui avada mõni vanem save ja teha enne kräššivasse kohta minekut eelmisest midagi erinevat.
KuriVaiM1
KuriVaiM1
sõnum 28.01.2010 21:34:54 vasta tsitaadiga
http://www.strategyinformer.com/pc/stalkercallofpripyat/patch/34670.html - 1.602 vene patch, lase tõlge peale paika uuesti üle
python
sõnum 28.01.2010 22:01:35 vasta tsitaadiga
Jah, eelmistes osades aitas. Seda proovinud igatepidi, kuid ei aita....
Ma selle patchi leidsin üles aga see exe fail ei hakka tööle või mis moodi sellega täpsemalt talitama peaks?
KuriVaiM1
KuriVaiM1
sõnum 29.01.2010 22:30:04 vasta tsitaadiga
python kirjutas:
pakki lahti - setup-cop-rp-any-02
multizync
multizync
sõnum 30.01.2010 12:59:47 vasta tsitaadiga
Kas call of pripyatis saab ka relvi ja armourit upgradedda nagu clear sky's oli, et pead neid usb drivesi otsima ja siis nendele tüüpidele need viima..?
Kommentaarid: 20 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 18
KuriVaiM1
KuriVaiM1
sõnum 31.01.2010 13:07:36 vasta tsitaadiga
multizync kirjutas:
ikka saab
Lõpplikud väljalaskeajad paigas neile kodanikele kes ikka veel ilma:
* UK, France, Nordic, Italy - 05/02/2010 icon_exclaim.gif
Australia, Taiwan, Japan, South Africa - February 2010
USA - 02/02/2010
Benelux, Spain - March 2010
vasques
vasques
sõnum 02.02.2010 11:53:01 vasta tsitaadiga
troglodyte kirjutas:
Crow, traderid ostavad ainult peaaegu täesti korras oleva relvi (vist max. -1 pulk) . Teised stalkerid ostavad ka veidi halvemas olukorras relvi (vist -2 pulka).
Relvi parandada ei ole mõtet enne müüki (isegi kui -1 pulga juures) - kui sa just kahjumisse ei jää on kasum ikkagi marginaalne.
100 Kg relvi(kriigis)=parandasin 20k eest sain 33k lõpuks, peale seda kui vaatad mida parandada siis tead ka kuidas raha teha
pm probleem ka, mängu sain tööle(naljakas see et kräkkima ei pidanud ?), panin inglise keele faili külge, nüüd pripyati ei saa, crashib, aga pätsi 1.6.0.1 peale ei võta, hindukeelne hoiatus(aru sellest ei saa) ja kogu kino. reinstall ? eelmist mängu versiooni vaja ?
EDIT: Reinstall ei aidanud, hmm mis keelne see asi peaks olema, win7 russian küll mitte icon_lol.gif icon_lol.gif icon_lol.gif . Keele saaks teada siis oleks võimalus veateade ka teada saada icon_biggrin.gif
EDIT2: Päts ei lähe peale sest ta ei suuda mängu leida icon_razz.gif aga lahendust ikka ei tea icon_sad.gif
Käisin jahil
KuriVaiM1
KuriVaiM1
sõnum 02.02.2010 19:00:42 vasta tsitaadiga
vasques, ju siis sul mingi "X" mittestandartne installer/DVD mis ei jätta installist jälge maha
Käisin jahil
DeTHiCa.
DeTHiCa.
sõnum 06.02.2010 05:14:20 vasta tsitaadiga
kohekohekohevarsti saab inglisekeelset osta poest.
Kommentaarid: 144 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 136
KuriVaiM1
KuriVaiM1
sõnum 06.02.2010 11:35:35 vasta tsitaadiga
ametlik EU reliis oli eile, turustamisega kippub probleeme olema igal mandril
rewer
rewer
sõnum 06.02.2010 11:49:22 vasta tsitaadiga
Miinimum nõuded on päris lahjad, kas keegi on proovinud mõne nõrga videkaardiga mängu(näiteks 6600GT)?
Kommentaarid: 1303 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 919
KuriVaiM1
KuriVaiM1
sõnum 06.02.2010 11:53:38 vasta tsitaadiga
rewer, miinimum: nVidia GeForce 5700/ATI Radeon 9600/128MB DirectX 9c compatible video card, vabalt
denis28
denis28
sõnum 06.02.2010 12:11:56 vasta tsitaadiga
mis vahet on sellel võrreldes eelmiste versioonidega ? lihtsalt mingi järg pmst w?
Kommentaarid: 67 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 64
KuriVaiM1
KuriVaiM1
sõnum 06.02.2010 12:25:28 vasta tsitaadiga
denis28, suvaline ülevaade streami foorumist
Tony Almeida's S.T.A.L.K.E.R.: Call of Pripyat Review
Pros:
* Gameplay is refined to perfection, taking the best from each previous game.
* Every quest is unique, engaging and full of depth and plot.
* Pretty much bug-free.
* The ending isn't a silly cliffhanger.
* The Zone is really unique and feels vast.
* Supports a LOT of hardware. Perhaps the most ever for a game.
* Atmospheric as always. Much more like Shadow of Chernobyl than Clear Sky
Cones:
* Factions are pretty much useless. You'll barely acknowledge their existence. It's mostly 'friend or enemy'
* Some terrible texture mapping can be really distracting.
* Lacks any real sizable camps
* Inability to max out textures on 32-bit OS's
* Some sounds are still very poor quality
* A.I. no longer uses cover in the same way as Clear Sky (with animations etc)
denis28
denis28
sõnum 06.02.2010 12:38:52 vasta tsitaadiga
vasques
vasques
sõnum 06.02.2010 13:53:00 vasta tsitaadiga
nö idaeuroopa betatesterid on asja kallal mitu kuud olnud. lääne meestel 1.6.0.2 on basic, ma arvan icon_razz.gif. kusjuures mida rohkem mudid seadeid ja asju seda rohkem nalja saab
villu70
villu70
sõnum 06.02.2010 16:24:27 vasta tsitaadiga
Kust seda eestis osta saab?
Kommentaarid: 142 loe/lisa Kasutajad arvavad:  :: 3 :: 0 :: 122
Valvejoodik
Valvejoodik
sõnum 06.02.2010 17:45:10 vasta tsitaadiga
villu70 kirjutas:
Inglise või vene?
vasques
vasques
sõnum 06.02.2010 19:33:44 vasta tsitaadiga
Vene versioon
http://www.gamepood.ee/est/?page=catalog&cat=3&sub=8&let=S&item=7003&UID=2009083123121088.196.190.97
Inglisekeelse hinnaks ma arvan umbes 3-4 korda rohkem...
Chuck Norris on juba 2 aastat surnud. Vikatimees kogub siiamaani julgust, et seda talle öelda.
uus teema   vasta Tarkvara »  Arvutimängude foorum »  S.T.A.L.K.E.R.: Call of Pripyat mine lehele eelmine  1, 2, 3 ... 12, 13, 14 ... 22, 23, 24  järgmine
