uus teema   vasta Tarkvara »  Programmeerimine »  Shoutboxiga jama. märgi kõik teemad loetuks
JUSTer
JUSTer
sõnum 31.12.2009 13:37:40 Shoutboxiga jama. vasta tsitaadiga
Tere. Nimelt ma harjutan vähe kätte ühe brauseripõhise mänguga, et tulevikus midagi suurt ka ise oskaks teha.
Aga tekivad nagu ikka probleemid. Praegu on näiteks probleemiks see, et houtboxis edastab read valesti ja kas teie leiaksite selle vea ülesse?
function clanbabble() {
    global $userrow;
    if (isset($_POST["babble"])) {
        $safecontent = makesafe($_POST["babble"]);
        if ($safecontent == "" || $safecontent == " ") { //blank post. do nothing.
        } else { $insert = doquery("INSERT INTO {{table}} SET id='',posttime=NOW(),clan='".$userrow["clan"]."',author='".$userrow["charname"]."',babble='$safecontent'", "clanbabble"); }
        header("Location: index.php?do=clanbabble");
        die();
    $babblebox = array("content"=>"");
    $bg = 1;
    $babblequery = doquery("SELECT * FROM {{table}} ORDER BY id DESC LIMIT 20", "clanbabble");
    while ($babblerow = mysql_fetch_array($babblequery)) {
        if ($bg == 1) { $new = "<div style=\"width:98%; background-color:#eeeeee;\">[<b>".$babblerow["author"]."</b>] ".$babblerow["babble"]."</div>\n"; $bg = 2; }
        else { $new = "<div style=\"width:98%; background-color:#ffffff;\">[<b>".$babblerow["author"]."</b>] ".stripslashes($babblerow["babble"])."</div>\n"; $bg = 1; }
        $babblebox["content"] .= $new . $babblebox["content"];
    $babblebox["content"] .= "<center><form action=\"index.php?do=clanbabble\" method=\"post\"><input type=\"text\" name=\"babble\" size=\"40\" maxlength=\"220\" /><br /><input type=\"submit\" name=\"submit\" value=\"Sisesta\" /></form></center>";
    // Make page tags for XHTML validation.
    $xml = "<?xml version=\"1.0\" encoding=\"ISO-8859-1\"?>\n"
    . "<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\" \"DTD/xhtml1-transitional.dtd\">\n"
    . "<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"et\" lang=\"et\">\n";
    $page = $xml . gettemplate("babblebox");
    echo parsetemplate($page, $babblebox);
    die();
Manus
iceincube
iceincube
sõnum 01.01.2010 19:48:15 vasta tsitaadiga
Mismoodi valesti? vales järjekorras?
Mis peaks teisti olema ehk siis kuidas poleks valesti?
Hetkel on probleemipüstitus ikka väga mõõda.
JUSTer
JUSTer
sõnum 01.01.2010 20:07:19 vasta tsitaadiga
Pilt ei ütle siis ära?
Värvid peaks kordamööda olema, hall, valge, hall, valge. Aga ei ole ju icon_smile.gif
Nt igakord kui ma kirjutasin kirjutasin erinevat asja ja seal näitab seda asja mitu korda.
andrusny
andrusny
sõnum 01.01.2010 20:29:36 vasta tsitaadiga
Sa ei oska masiive kasutada. Värvid saad nii korda, muud ei oska öelda hetkel.
$babblebox["content"] .= $new . $babblebox["content"]; // selle asemel vaid nii vaja.
  $babblebox[] = $new ;
iceincube
iceincube
sõnum 01.01.2010 20:42:05 vasta tsitaadiga
Mina nedi värve tähele ei pannud.
Pealegi on suht heledad nad et märgata et see äkki viga on ...
JUSTer
JUSTer
sõnum 01.01.2010 21:23:19 vasta tsitaadiga
Kui ma tegin nii nagu andrusny ütles siis jäi mul sinna ainult "Sisesta" nupp järgi, shoutbox kadus üldse ära.
Hakkab kellelgi veel mõistus peale mis viga võib olla?
andrusny
andrusny
sõnum 01.01.2010 21:51:21 vasta tsitaadiga
No sa pead ise asjast aru saama. Minu näites paneb ta need $new andmed ehk siis need div väljad selle masiivi pesadesse järjest. Sul on see süsteem veider, sa liidad masiivile nagu stringi otsa. Võimalik, et see on mingi süsteem, kuid minu teada sedasi ei liideta masiivi. Ehk on sul viga selles, et ka edaspidises koodis on sul sarnaselt toimitud.
Kas kood on sinu enda tehtud või kusagilt tõmmatud?
kui sa näiitaks parsetemplate() funktsiooni,. siis oleks selgem, miks ta sul ei näita või mida ta sellest masiivist $babblebox üldse ootab.
JUSTer
JUSTer
sõnum 01.01.2010 23:31:37 vasta tsitaadiga
Ah tegelikult paneme teema lukku siis... Teen algusest ja uuesti.. Loodan, et siis rohkem vigu ei teki.
