mine lehele eelmine  1, 2, 3 ... 521, 522, 523 ... 2343, 2344, 2345  järgmine
Jah
9%
 9%  [ 51 ]
Ei
42%
 42%  [ 225 ]
Mul juba olemas
38%
 38%  [ 201 ]
Kolin mujale
9%
 9%  [ 48 ]
hääli kokku : 525
eldorado
sõnum 24.12.2009 01:44:50 vasta tsitaadiga
ärihai kirjutas:
forint kirjutas:
ärihai kirjutas:
forint kirjutas:
ärihai kirjutas:
see eelnev oli ju siin puhas reklaam, mitte mahategemine.
NB: ma pole mode selles foorumi osas.
DVD´st divx tegemine on ka formaadi parandamine - vaevalt, sama teeb ka Elion.
teeb või ei tee.
tekib küsimus, miks siis Elionil on kõige kvaliteetsem pilt Eestis?
Oleneb mida kvaliteedi all silmas pead? (iga mobiili operaator mainib ka tavaliselt ,et ta on parim!!! )
sellest kirjutati ka mingil välismaa lehel.
ei usu, et see elioni enda vendade poolt oli kirjutatud.
HD videost... 21.12.2009 icon_smile.gif)
http://forums.cnet.com/5208-7596_102-0.html?threadID=249109&start=15
If you're talking about 1080/24p, as someone mentioned, that's actually possible today. And in fact, it'll look marginally better than 1080/60i made via 3:2 pulldown, since each frame can be slightly less compressed at the same bitrate.
For 1080/60p, though, you're going to have issues. Current US broadcast is limited to 19.4Mb/s... if you want 1080/60p, you're going to in short need twice the bandwidth, or accept half the quality, or change something. But in fact, 1080/60p isn't a legal ATSC format, so anything here is really post-ATSC, far as terrestrial broadcast goes.
For cable/satellite, it's possible essentially "whenever they feel like it", which also probably means not anytime soon. Satellite has already moved most HD content to H.264 rather than MPEG-2, and they're using modulation schemes that deliver 30-60Mb/s per analog channel, rather than 19.4MB/s. But satellite "real estate" is expensive, and even with the far greater coding efficiency of H.264, most HD content is likely downsampled, more likely 1440x1080 or 1280x1080 than the full 1920x1080, all at 60i. Don't expect any dramatic changes here.
Cable systems have more bandwidth, and FIOS TV more still, but they're also a competition where something just barely HD is often considered acceptable, and quantity wins over quality, after a point. As well, unless there's a big 1080/60p infrastructure, there's little point in paying for the ability to deliver it. If TV is primarily 1080/60i, and film primarily 1080/24p, where are you going to find enough 1080/60p content to push the demand onto any service provider?
siit: Italia 1(704x576 px TS: 7.54 Mbps), Canale 5(704x576 px TS: 7.53 Mbps), Retequattro(704x576 px TS: 7.53 Mbps)
ei näe HD icon_smile.gif 1080i/p ah? ei ? vale? icon_biggrin.gif ADSLi abiga FULLHD ei tule kunagi üle, arvestades seda, et vähemal 1mbps peaks ju sinu arvutini jõudma, või oled nõus 500kr ainult TV eest maksma? mu meelest siis VIASAT soodsam tuleb =)))
Steff. kirjutas:
eldorado, Sa unustad väikese asja. Eratarbjana võid sa palju SATi pealt tasuta saada aga teenusepakkujana ei saa sa kuskilt midagi tasuta. Vähemalt välismaalt! Seda ei tasu unustada. Teoorias ei saa ka ühistu pakkuda niisama teenuseid kui tal nende kanalite edastamis õiguseid pole icon_rolleyes.gif
KÜ = kõik elanikud, jagatud varaga. Ehk kõikedele kulub lift, kõikidele kuluvad sisse uksed jne jne.
Kas eraisikule on keelatud vastu võtta ja vaadata avatud kanaleid?
Ära unusta, KÜ on MITTEtulundusühing. See aga tähendab, et IPTV projekt kulub iga inimesele majas, omal 1/54 näiteks thumbs_up.gif
Kui jagad oma korteris kahe TV vahel CATV, see ju peaks siis ebaseaduslik olla =)
Muidu jah, sain mis mõtlete praegu, aga probleemid siin küll ei ole, ega ehitajal ega KÜ-l =)
jeesus188 kirjutas:
näiteks mind mingid italiano ja saksa HD ei huvita absoluutselt, isegi kui nad tasuta oleks või maksaks peale mulle bananadance2.gif icon_lol.gif
Eesti kanalid, eurosport, discovery ja paar kanalit veel, rohkem pole vajagi
icon_smile.gif) täiesti nõus, aga see HD - HD ei ole =) võrreldes satellite kvaliteediga.. need ma leidsin selleks, et saab näha mis kvaliteediga need tulevad, ja mis kiirusega. Keegi üleval oli kirjutanud, et temal v.hea HD ja ainult 7mega alla tuleb =) - jep, pildis 704x576(720p tundub see ei ole) peaks paar korda suurem res olla ei? icon_smile.gif
Lõppsõna, ethernet võrgus, on võimalik edastada ükskõik mis kiirusega content, piirangud ei ole 100-1000mbps - vabalt. )) adsl=max 24mbps.
Jepp, kui fiiber tuleb siis on väga head võimalused ees =)
Aga fiiber praegu tallinnas peaaegu igas majas STV võrgus.
Vorst on teises, et võimalik kasutada 35kr/kuus(internet+TV) vs. 500kr/kuus , ja tulevikus lepida kokku "hulgi" IPTV ostust kaablioperaatorist(elion,stv,starman vahet pole) võõõõi taaassuuuuutaaaaaa vaadata enda IPTV serveri läbi, enda majas, enda valitud kanaleid icon_smile.gif
Ei räägi, et teenus on halb või ebakvaliteetne, jutt on kuidas saab enda raha käes hoidma. Ärge unustage, elion nüüd müüdud rootslastele, ja kasu usun peaks investorile liikuda ? ei ? lihtsalt toetab meid icon_lol.gif aga siit - vähem raha riigis, halvam meie majanduse seisukord..
viimati muutis eldorado 24.12.2009 02:06:54, muudetud 7 korda
Kommentaarid: 148 loe/lisa Kasutajad arvavad:  :: 9 :: 4 :: 106
sõnum 24.12.2009 01:49:23 vasta tsitaadiga
Steff.
Steff.
sõnum 24.12.2009 01:57:52 vasta tsitaadiga
eldorado, Üks asi veel. ADSL2+ on kaduv nähtus. Kui ma õigesti mäletan siis elion katsetab hetkel teisi kiiremaid lahendusi. + EU ja Riigi toetus kiiretesse võrkutesse. Kui sul Fiiber maja tuleb tee mida iganes.
Kui sind ei ole siin...Siis sind ei ole olemaski!
Kommentaarid: 44 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 41
sõnum 24.12.2009 10:48:13 vasta tsitaadiga
Ma ei oska eldorado, juttu kuidagi kommenteerida sest tegemist on ilmselgelt konkurendiga kes tahab ise midagi maha müüa. Jah, tema võib kortermajale müüa 100000kr eest võrgu ja hiljem kasseerida 35kr kuus interneti eest mis ilmselt on piirangutega. Ilmselt pakub ta lisaks mingeid tasuta taevast tulevaid kanaleid (ikkagi mingi raha eest) ja laseb sisevõrku ning MÜÜB seadmeid klientidele.
Elioni vaatest tehakse sellistesse majadesse tasuta majavõrk, antakse klientidele tasuta seadmed, paigaldatakse tasuta (hetkekampaania), antakse 3kuud tasuta testperiood kus klient võib ilma kohustusteta toote lõpetada, internet on praktiliselt piiramatu ja paketivalikud on ka olemas.
hdtv, iptv ja adsl2+
http://broadcastengineering.com/hdtv/IPTV-Alcatel-Broadcom-France-Telecom-20050622/
minuteada sama firma seadmeid Elion kasutabki.
viimati muutis indrpo 24.12.2009 10:50:23, muudetud 2 korda
Kommentaarid: 261 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 227
a1
a1
sõnum 24.12.2009 10:49:02 vasta tsitaadiga
Kui Levira on võimeline ühte MUXi mitu HD kanalit panema, siis pole ka ADSL2+ peal HD näitamine eriline probleem. VDSL uued lahendused lubavad enamat. Enamus HD asju on täna 720p, vähemus 1080i. Teab keegi eetris 1080p?
Kommentaarid: 39 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 38
eldorado
sõnum 24.12.2009 15:53:02 vasta tsitaadiga
indrekp kirjutas:
jälle pöörad kõik peast jalgale.
Elioni lahendus KORTERI kohta maksab ca 500 kr kuus. Midagi tasuta need ei jaga, seadmed 2 aasta siduv lepinguga tulevad KASUTUSSE mitte kingitusse.
Kanalide eest ja interneti eest mul üldse mingisuguseid rahalisi küsimused pole, ja ma ei küsi selle eest lisa raha, sest kirjutasin et ALLA 100 000 kr saab dtv ca 30 kanaleid sisse lasta-lahendus on summa sees- hetkel ei mäleta, mul äriplaan mujal, aga oli ca 86000 või 89k.
VALIME: Kas TASUTA ELION 500kr kuus VÕI enda oma 35kr kuus ? Või ma suhtlen inimestega kes ei jaga maatematika üldse, või kõik on ime rikkad ja milljonid on arvel igal teisel =)
kaspar00
kaspar00
sõnum 24.12.2009 19:22:35 vasta tsitaadiga
eldorado, su jutt mõjuks oluliselt positiivsemana, kui sa teeksid korraliku teema, kus lased inimestel oma tegemiste üle kommenteerida ja kui asi on hea tuleb kindlasti kasulik vastukaja. Elioni konkreetse teenuse teemasse see ju ei puutu otseselt, et seda siin arutada icon_smile.gif
Kommentaarid: 114 loe/lisa Kasutajad arvavad:  :: 0 :: 3 :: 102
eldorado
sõnum 24.12.2009 20:05:40 vasta tsitaadiga
kaspar00 kirjutas:
täitsa nõus =) hetkel ei julge pdf failina presentatsiooni siia panna, natukene hiljem. Tahtsin hinna suhtes natukene vestluda, et minu arust hinnad on natukene kõrged thumbs_up.gif
Jerry
4K külmavana
Jerry
sõnum 24.12.2009 20:32:05 vasta tsitaadiga
indrekp kirjutas:
tuletab meelde kunagi Starman'i poolset pakkumist.Helistati mulle pidevalt ja pakuti kaabel-TV'd.Ja ikka iga nädal helistati paar korda icon_biggrin.gif .
lõpuks ma ei pidanud vastu ja ütlesin,et okei ma tahan jahh.Kui asi jõudis lepingu sõlmimisel aadressini siis kostis telefoni torust ainult mök-mök.Ma tahtsin ~100eek/kuus kaabel-tv'd aga nemad ei viitsinud 30km kaablit vedada.No mis sa teed sellistega icon_lol.gif .Nii,et pröögata võib see,kes suudaks ka maal elavatele inimestele sama teenust pakkuda,mis linnades.Kui nad seda ei suuda siis tõmmaku endile vesi peale icon_biggrin.gif thumbs_up.gif
Kes meie maale tulnud on ja kellel siin ei meeldi –
me rajad lahkelt lahti on, las minna, kui ei meeldi /Hando Runnel
Ellu jääb see, kes oskab oma kätega midagi valmis teha
Kommentaarid: 133 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 107
eldorado
sõnum 24.12.2009 22:56:43 vasta tsitaadiga
Jerry kirjutas:
indrekp kirjutas:
ega konkurendid siin ei olegi, kuna on võimalik igas majas Eestis seda teha, sõltumata kas on Elioni kaabel või teised või ei ole...
Merry Cristmas kõigile =))
Püüan konkretne projekt välja ehitada, ja esimesega teen pildimaterial ehk, siis saab siia avalikusse panna icon_razz1.gif
Digitv on küll hea asi, enda meelest töötab IpTv parim elionil kui teisel =) aga alati saab hinnad soodsamaks kruuvida icon_razz1.gif
amalfy
sõnum 25.12.2009 13:16:23 vasta tsitaadiga
Ma ei saa vabsee aru mis toimub. Tegin ruuterile reseti ja nüüd on mingi "Internet Gateway" tulnud Network Connectionsi alla. Ruuteriks on TG585 v7. Enne seda kui reseti tegin ei olnud vabsee sellist asja seal. Kuidas ma selle korda saaks?
PS! Häid jõule!
darkside
darkside
sõnum 25.12.2009 15:33:58 vasta tsitaadiga
amalfy kirjutas:
PS! Häid jõule!
internet ja digitv töötavad? abi oled palunud 6069966 ?
Kommentaarid: 71 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 70
Steff.
Steff.
sõnum 25.12.2009 16:20:24 vasta tsitaadiga
darkside kirjutas:
amalfy kirjutas:
PS! Häid jõule!
Minul on see seal terve elu olnud. Ja ükskõik mis ruuteriga. Ikka kõik töötab nii kuis peab.
darkside
darkside
sõnum 25.12.2009 19:03:44 vasta tsitaadiga
Steff. kirjutas:
darkside kirjutas:
amalfy kirjutas:
PS! Häid jõule!
no milles probleem siis? häirib see ikoon? kas see mitte ei näita et ruuter on UpnP võimeline icon_rolleyes.gif
*Lask!ja*
sõnum 25.12.2009 19:23:17 vasta tsitaadiga
Selliste andmetega ei hakka läpparis kaabliga nett tööle. Proovisin nii esimeses kui ka neljandas pesas netti jooksutada, aga ei hakanud tööle. Lauaarvutiga töötab mõlemas pesas. Kas peaksin ka teist ja kolmandat pesa proovima? Või oskaksite midagi targemat soovitada?
// carlking, nii teises kui ka kolmandas pesas on sama IP.
viimati muutis *Lask!ja* 25.12.2009 19:45:30, muudetud 2 korda
Kommentaarid: 9 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 7
sõnum 25.12.2009 19:35:40 vasta tsitaadiga
Väga huvitav ip conf
minuarust 10.xxx algusega IP'd jagati vaid digiboksidele
Müüa korter
sõnum 25.12.2009 21:09:55 vasta tsitaadiga
*Lask!ja* kirjutas:
Mida iganes sa ära oled võssa keeranud ei tea. Aga DTV ipga ei peagi netti saama.
*Lask!ja*
sõnum 25.12.2009 23:23:41 vasta tsitaadiga
Reinstallisin modemi ja networki draiverid, kuid ikkagi ei anna mingit tulemust:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&product=1842155&dlc=en
Proovisin ka panna samu andmeid nagu lauaarvutil (teise IP muidugi), aga siis ütleb selle peale MSNi Troubleshooter, et DNSi ja Key Portsidega on miskit mäda.
TCP/IP configisse panin sellised seaded:
IP: 10.18.12.40
Subnet: 255.255.254.0
Gateway: 192.168.1.254
DNS: 192.168.1.254
Ipconfigis näitab ka seda sama IP-d, kuid miskit on ikkagi mäda.
// Edit: Lahenduse sain Elioni foorumist:
Josh kirjutas:
kõik peale IP on õige, pane IP:10.18.12.40 asemele näiteks 192.168.1.70 ja vaata kas saad interneti.
viimati muutis *Lask!ja* 26.12.2009 12:28:21, muudetud 1 kord
darkside
darkside
sõnum 26.12.2009 11:37:38 vasta tsitaadiga
*Lask!ja* kirjutas:
IP: 10.18.12.40
DNS: 192.168.1.254
ega sa arvuti võrgukaardi mac aadressi pole muutnud, et digitv'd arvutist vaadata? ehk jäi tagasi muutmata?
sõnum 26.12.2009 13:45:39 vasta tsitaadiga
*Lask!ja* kirjutas:
Ja miks sa usud seda MSNi Troubleshooterit? Sellel on öelda isegi siis midagi kui kõik korras on.
Ja nagu näha eksis see taaskord. DNS on õige.
sõnum 26.12.2009 15:06:31 vasta tsitaadiga
salatoimik kirjutas:
*Lask!ja* kirjutas:
Eksid, DNS on vale kui see on kättesaamatu. Antud juhul polnud võimalik antud ip'ga antud DNS ip'le ligi pääseda seega oli DNS vale.
amalfy
sõnum 26.12.2009 18:52:36 vasta tsitaadiga
darkside kirjutas:
Steff. kirjutas:
darkside kirjutas:
amalfy kirjutas:
PS! Häid jõule!
Ma ei tea mida ta näitab seal. Igaljuhul enne seda polnud. Nii kui see sinna tekkis ei saa ma enam cmd'st ruuteri IP'd ja asju võtta "ipconfig /all" käsuga. Tahaks vana-aasta õhtul DTV vaadata arvutist, aga kui ei saa neid IP asju tõmmata sealt siis jääb vist üritus ära...
sõnum 26.12.2009 19:09:03 vasta tsitaadiga
täpselt. amalfy, mine ruuterisse ning keela uPnP ära.
http://192.168.1.254/cgi/b/games/ov/?be=0&l0=3&l1=4
sõnum 26.12.2009 21:36:26 vasta tsitaadiga
mikk36 kirjutas:
*Lask!ja* kirjutas:
Ja siis hakkad pead vaevama mis krt selle DNSiga on ja jätad IP silmevahele...
Redikate
Redikate
sõnum 26.12.2009 23:47:50 vasta tsitaadiga
Kas Elioni DigiTV'ga on endiselt võimalik vimkat teha ja läbi VLC telekat vaadata, ruuter kergelt ümber confides?
uus teema   vasta Hinnavaatlus »  Andmeside ja kõnelevi »  Telia TV mine lehele eelmine  1, 2, 3 ... 521, 522, 523 ... 2343, 2344, 2345  järgmine
